General Supercharger Thread
  1. Apr 2, 2024 at 9:13 PM
    blenton
    blenton New Member
    Have you been able to verify whether or not the wideband/PSB1 data is accurate? What I mean is, have you compared it to the stock O2 sensor data? I use my head unit and iDatalink to monitor basic engine data like trans temp, load, etc available through the OBDII port; when setting up my PSB-1, I had some weirdness on the reading for a bit and went through the same setup process a few times. I was able to read the PSB-1 and head unit data concurrently and verify when the PSB-1 was reading correctly.
    You could use HP Tuners or any OBDII monitor, really, to see what your factory O2’s are reading, then compare it to the PSB-1. That would at least tell you which end of the tale to chase - the tune or the PSB1.
    I may have missed it, but where in the exhaust is the wideband mounted? And Innovate sent you a new sensor, yes? So there *shouldn’t* be an issue with the wideband itself - like using the wrong sensor or a bad/dirty/faulty sensor, correct?
    The other thing I thought of would be a leak in the exhaust, possibly around the sensor hung. I don’t think it would behave as your gauge is behaving, but it’s worth giving it a look see?
    snivilous[OP] likes this.
  2. Apr 3, 2024 at 7:38 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I don't have that kind of access/control. This is barely OBD1 (has a 20 pin connector under the hood and because it is after 1996, an OBD2 port in the car but the programmer is very basic.
    I have been getting O2 codes, have new sensors coming Friday, Rock Auto sent the wrong ones yesterday.
    The wideband is after the 2 banks (inline 6) in front of the cat, there was very limited access/available locations, it is literally in front of the front OEM O2.
  3. Apr 3, 2024 at 12:48 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    For something a little different lol
    My son always nags me to make things for his trucks and for the last 2 weeks hes been asking for a camper shell made. So ill surprise him with this
  4. Apr 3, 2024 at 3:09 PM
    NatesNightMare
    Pinetop Az
    So I just got a mech gauge and its showing the correct numbers at idle and even in boost my numbers are the same as before hitting about 8-9psi wot.
    reywcms and Mdl like this.
  5. Apr 3, 2024 at 3:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
  6. Apr 3, 2024 at 3:33 PM
    e30cabrio
    I think your post ended up in my quote :
    How close to the exhaust ports? Too close/far can throw them off.
    What do you mean?
    The head is several feet away
  7. Apr 3, 2024 at 3:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok. Re-read your post as to the location. Thought it may be to close to the exhaust ports on the head...
    e30cabrio[QUOTED] likes this.
  8. Apr 3, 2024 at 6:40 PM
    e30cabrio
    It is kind of like this but at a different angle. (this is oem)
  9. Apr 4, 2024 at 7:46 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    This might not be known (I didn't know about it until a few months ago). For those with the PSB-1, or presumably any Innovate gauge, if it throws a "Boost Cut" text on the screen and you find it annoying you can turn it off by adjusting the settings that activate the boost cut. The boost cut as I recall is what triggers the relay output and on a turbo would activate the blow off valve. Regardless, here is how you access the menu through the gauge, and then I just increased the boost level beyond what the truck would ever see and then it won't throw the boost cut message anymore.
    Wynnded, AZTundra, Mdl and 2 others like this.
  10. Apr 4, 2024 at 9:08 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    You could also use that output to trigger a warning light or buzzer and set it to go if if you went lean under boost. I was going to do that, but turns out I'm lazy
  11. Apr 4, 2024 at 10:55 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Believe me! If there is a way for it to trigger the ecu to cut rpm, throttle or add fuel that is faster than you seeing or hearing a letting off the skinny pedal. Had my AEM failsafe set for visual and by the time the eyes see brain says let off it'll go boom.
    But maybe if your not hell bent on going all out you have a chance.
    Just my 2 cents, or engines, worth. :D
    NatesNightMare and e30cabrio like this.
  12. Apr 4, 2024 at 11:04 AM
    e30cabrio
    My 1st thought, I need a BOV or something for the BMW as the tune calls for a max of 8lbs on a 100mm pulley & I have an 85mm pulley, this would be great to connect that to.
    Mdl[QUOTED] likes this.
  13. Apr 4, 2024 at 11:10 AM
    snivilous
    SW UT
    Tie it into the ignition so the truck turns off :rofl:
    Wynnded, e30cabrio and Mdl[QUOTED] like this.
  14. Apr 4, 2024 at 11:41 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Any non-FFV ppl in CA need to jump on this
    ZPhilip, Mdl, e30cabrio and 2 others like this.
  15. Apr 4, 2024 at 11:43 AM
    NatesNightMare
    Pinetop Az
    Almost like a governor of sorts
  16. Apr 4, 2024 at 11:46 AM
    NatesNightMare
    Pinetop Az
    Sad someone doesnt know what truck their driving to order the correct parts lol they make a 2650 for FFV
    Saltyhero13 likes this.
  17. Apr 4, 2024 at 11:49 AM
    e30cabrio
    Does this also apply to get what you really want? I have a garage full of parts/have taken large losses on parts I got, then decided I NEEDED an uppergrade (Upgrade to an upgrade)
  18. Apr 4, 2024 at 11:53 AM
    NatesNightMare
    Pinetop Az
    More engine wise as different engine have specific oarts or needs to work correctly. Sure some parts may be swapable but for somethung like flex fuel itll most likely have to be specific to run right.
  19. Apr 4, 2024 at 12:12 PM
    e30cabrio
    I round pegged my non flex fuel set up into my square hole Flex Sequoia.
    lol
    Mdl likes this.
  20. Apr 4, 2024 at 12:37 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Won't help with your procharger, but it could trigger a solenoid to interrupt the bypass valve. Won't kill all boost when spinning fast, but maybe enough to drop into the safe zone.
  21. Apr 4, 2024 at 1:02 PM
    e30cabrio
    Thanks, it's a Rotrex C38. Is that the same thing?
  22. Apr 4, 2024 at 2:33 PM
    VWTim
    Corvallis, OR
    Not quite the same, but similar design. You could certainly wire it to a BOV or dump solenoid for extra protection like you mentioned. On a Tundra SC it could interface with the boost bypass valve.
    e30cabrio[QUOTED] and Mdl like this.
  23. Apr 4, 2024 at 4:54 PM
    helidave
    flagstaff
    2015 DC 4x4
    You could have that output do all kinds of useful things if you're clever enough to wire it up. Or make it honk the horn every time you hit max boost, just for the lolz
    e30cabrio, koditten and Mdl[QUOTED] like this.
  24. Apr 4, 2024 at 5:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wiser and smarter 9 years later...I hope! Better tuning and more knowledgeable people to lend advice.
    e30cabrio and Wynnded like this.
  25. Apr 4, 2024 at 5:20 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Understood I assumed you were using HP
    Hmmm. My kit was a non flex fuel kit works fine:notsure:
  26. Apr 4, 2024 at 5:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ARES35 I was thinking the same with the maggy and ffv. Is it a CA EPA thing? Maybe the Tundra owner didn't want to mess with tuning?
  27. Apr 4, 2024 at 5:43 PM
    ARES35
    Mile high
    Maybe a CA thing not sure. All I know is the non FFV comes with the pump. Everything else is exactly the same. When initially using their RTD device Maggie just sends over a FFV tune if FFV or non if not.
  28. Apr 4, 2024 at 6:00 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    I got the FFV specific kit. Only difference I saw and have been told was no fuel pump in the FFV kit.
    As far as the tune though, I was informed they don't have a FFV specific tune :notsure:. There's one FFV truck that I know of that Magnuson referred to mcbautotech/yotawerx for a flex tune
    ARES35[QUOTED] likes this.
  29. Apr 4, 2024 at 6:54 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    If anyone has the factory FFV fuel pump laying on the bench, can you confirm the part number? Is it F90000239?
  30. Apr 4, 2024 at 7:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes it is! Had it in the FFV canister I ordered.
    reywcms, kbahus[QUOTED] and ARES35 like this.
