General Supercharger Thread
  1. Mar 18, 2024 at 6:56 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Not yet, but there's a good thread going on tuning a GM TB to eventually take advantage of this. Haven't been able to overcome the driveability with that large of a TB...yet.
    Mdl likes this.
  2. Mar 18, 2024 at 7:03 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
  3. Mar 18, 2024 at 7:05 PM
    Grippy_Blu
    Grippy_Blu Plava_Laguna_Tundra
    DFW
    Blue 08 DC Tundra 4×4 Ltd
    Magnuson tvs2650 Mishimoto radiator JS 400amp alternator Grip Pro LC200 AWD transfer case
    Are you speaking of the "initial development and prototyping 102mm...." thread? I've been looking it over. I saw someone asked a similar question but I never saw a solid response. I figure with the D2A it should be operational just need a good tune? :notsure:
  4. Mar 18, 2024 at 7:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  5. Mar 18, 2024 at 7:07 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Nope I have to f with the gears and shims or nope I don’t have to
  6. Mar 18, 2024 at 7:09 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Won't be as simple as a swap, if you get lucky you might not need to adjust shims, but will need to remove brakes to pull the axles, and swap the ring over to the powertrax.
    koditten and Wynnded like this.
  7. Mar 18, 2024 at 7:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You'll need to have it set up correctly, or bad things happen that will cost you money.
  8. Mar 18, 2024 at 7:10 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I was thinking of getting that unit, but controlling the larger TB with a tune is new territory on these trucks and challenging.
    Mdl and VWTim like this.
  9. Mar 18, 2024 at 7:11 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Fine with doing all but shims lol just don’t want to mess with it. So you’re saying it’s possible…
  10. Mar 18, 2024 at 7:14 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    You shouldn’t need to mess with pinion depth, which is a PITA. The backlash will need to measured and possibly adjusted, though it does have a chance of being in spec. The carrier bearing shims are a crap ton easier to adjust/swap, if required.
    Mdl and Wynnded like this.
  11. Mar 18, 2024 at 7:14 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You could get lucky with the spacing, but I would get an install kit with shims, proper tools, etc. just in case you don't get lucky.
  12. Mar 18, 2024 at 7:24 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Ok I’ll order with a kit so I have shims on hand if needed. We will see. I guess worst the truck is parked for a bit.
    Mdl likes this.
  13. Mar 18, 2024 at 7:27 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Side note. This any one of you guys?
    Fastlane47 and Ctaylor76 like this.
  14. Mar 18, 2024 at 7:30 PM
    Grippy_Blu
    DFW
    Fuel related: I haven't heard anyone talk about this, but if more fuel is needed why not swap an aeromotive 525 into a Delphi pump module? It looks like it should fit.
    I bought a Delphi when I was doing my S/C thinking it was the "best" option come to find out the pump was different.
    I ended up buying a stock replacement module just so it would be new instead of my dirty ass 200k+ mile module. Then I started thinking what I could do with it and saw the 525.
    Should be an easy swap, but I honestly know nothing.
  15. Mar 18, 2024 at 7:57 PM
    Grippy_Blu
    DFW
    Just FYI
    But obviously if you can't properly control it then that can be a bit of a problem. I've seen Viktor's set up on YouTube and this seems like it could save some space up front. Then just throw on something like this and be good to go
  16. Mar 18, 2024 at 8:04 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Oh yeah, I know it physically mounts up, tuning for more than a track truck is another story...but others are working on it, so there is hope!
    Mdl likes this.
  17. Mar 18, 2024 at 8:09 PM
    Grippy_Blu
    DFW
    I mean if you live outside certain counties in TX and don't need emissions testing couldn't you just get a plug and play motec/haltec and do whatever? I'm talking out my ass because I have no idea about tuning etc just trying to learn realistic possibilities. Not even sure if a stand alone even controls the TB lol
  18. Mar 18, 2024 at 9:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I installed my auburn in a few hours. Benching that carrier at 2am was fun! Got lucky and backlash was withing spec on first go.
    Wynnded and carn_dogg[QUOTED] like this.
  19. Mar 18, 2024 at 9:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The biggest hurdle is setting up your torque load/airload/shift speed/and adjusting the TB vs throttle position. I'm running the GM 95mm TB. When I set the throttle position reduced by 50 percent I had a few hard starts. Not sure if it was ecu or? Reduced it down to 40 percent and is running alright. Still fine tuning torque/shifting. I had issues with a crappy 103mm. Viktor didn't fine tune his and was ok with the high shift rpm at the drag strip. Going motec/ stand alone might have better tunability.
  20. Mar 18, 2024 at 9:47 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I originally installed the aermotive 340. It fit but had to hack the canisterforbit to sit right. I was able to fit a walbro 450 model 267 in a ffv canister in a non ffv tundra. You'll also need to upgrade your fuel lines to take advantage of the extra fuel. At least -8AN supply teeing off to -6AN for each bank.
    I'm just running both -6AN supply and return.
  21. Mar 18, 2024 at 9:54 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I’m selling the 103 mm Harrop inlet snout. If you are interested, message me. I can’t see anyone needing a 110mm on a Tundra unless you are going for 1000+ hp, but if you end up going that route, it would be cool to see!
    armyoffoo and Mdl like this.
  22. Mar 18, 2024 at 9:55 PM
    ViktorG
    Viktor
    Calgary, Canada
    A moose is probably more powerful than a horse, so I’ll go with 800 wmp any day :)
  23. Mar 18, 2024 at 10:20 PM
    Grippy_Blu
    DFW
    I mean 1000+hp does have a nice ring to it haha. I know I'm not the only one with that dream in mind. Time will tell and this forum will be my go-to for many things.
    On the bright side I did get the go ahead from the boss for ANYTHING I want to do to the truck so there is a 6.8L fully built xat motor in my future.
    nchlsbr, Silver17, Wynnded and 2 others like this.
  24. Mar 19, 2024 at 4:43 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    had a challenge this morning. stoplight @ FM225/BW8
    hopped up F250 powerstrokes are spunky.
    not spunky enough tho.
    I wonder what these folks think when a bone stock looking '20 Tundra moves ahead?
  25. Mar 19, 2024 at 4:43 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Ref the convo about which pump comes with mag 2650.
    SCOL reached out to mag. SCOL thinks it might be the same pump as the 1900 kit. Do we know what that it? mag said they don’t know what pump they include. SCOL is sure it’s denso but hasn’t given any flow rates. Will report back once I have some answers.
    NatesNightMare likes this.
  26. Mar 19, 2024 at 5:40 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I love spanking "racecarZ" in my ginormous, lifted, big tired Tree.
    lol
  27. Mar 19, 2024 at 6:30 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Had a similar situation last week. Powerstroke attempted to do the roll coal thing on me and he proceeded to get freight trained. I also look completely stock, down to the oem trd cat back :thumbsup:
    Edit: I guess the headers show if you look hard enough :monocle:
  28. Mar 19, 2024 at 6:38 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Be interesting to see the specs from the manufacturer. We only know @ViktorG testing which was around 196lph for the denso TRD supplies one for the 1900.
  29. Mar 19, 2024 at 7:03 AM
    carn_dogg
    Pat
    Eastern Shore MD
    I’d be shocked if my fuel pump can only flow 196lph given I’m running rich enough at max dc with 650’s on the 76 pulley producing 12psi. I was really thinking more like 340lph. It would make much more sense with how the truck has responded with afr’s upgrading from 535 to 650
    If the flow rate is 196lph, that can only provide enough flow for the green 535’s at 70% dc at 3bar… and 650’s at 57% dc. All of that would mean my truck wouldn’t get any richer by upgrading injectors.
    Does that make sense? 1900 users are only able to get 70% in dc from the pump provided in the mag kit?
    HulkSmurf14 and snivilous[OP] like this.
  30. Mar 19, 2024 at 7:29 AM
    ViktorG
    Viktor
    Calgary, Canada
    This is a debate that can be easily solved by disconnecting the feed line to the rail, sticking it into a bucket, supplying the pump with 12 volts and using a stopwatch to measure the volume over time.
    The 196 lph was measured at the outlet of the FPR, so it is a lower value than what the pump would supply to the rails since the FPR is a restriction. I just had no other way of keeping the pressure at 43 psi at that time. From personal experience the original TRD blower supplied pump maxed out before the injectors did on a couple of friends’ trucks I dyno tuned. These is a good chance the pump supplied with the Maggy kit now is a different model that flows more, but until someone tests it, it will just be an endless internet debate. If someone ships me their Maggy pump that they are not using, I can flow test it.
