General Supercharger Thread
  1. Mar 14, 2024 at 5:04 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Figured I'd check the seal around the sensor, blast MAF with some electronics cleaner. It seems to have kicked on looking at the log with some throttle coming off a ramp in Cheyenne WY. Cleared it and was fine to Denver figured maybe a fluke.
    HulkSmurf14 likes this.
  2. Mar 14, 2024 at 5:08 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I threw a MAF code after attempting to do some pulls. Replaced my oiled cone with a dry cone and replaced the MAF. No issues since then.
    ARES35[QUOTED] likes this.
  3. Mar 14, 2024 at 9:29 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I only get the occasional MAF error when I'm in throttle at higher elevations... goes away pretty quick tho...
    ARES35 likes this.
  4. Mar 14, 2024 at 10:16 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep mines on all the time now. Hence moving to the 5” pipe lol
  5. Mar 15, 2024 at 1:17 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I'm sure it has been posted here, but where do y'all mount AFR gauge? I'd like it to be as hidden/integrated as possible.
  6. Mar 15, 2024 at 3:22 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    People like the craven mount on steering column. Mine are on my a-pillar. Others have a gauge mounted in the nannies button spot. This is mine
  7. Mar 15, 2024 at 8:28 AM
    AZTundra
    Paul
    Phoenix, AZ
  8. Mar 15, 2024 at 8:31 AM
    HulkSmurf14
    2014 Tundra Limited
    Looks sharp!
    Get that bung welded in now!
    AZTundra likes this.
  9. Mar 15, 2024 at 8:33 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    cravenspeed flexpod mount
    Fastlane47, ARES35 and HulkSmurf14 like this.
  10. Mar 15, 2024 at 8:41 AM
    ARES35
    Mile high
    Alright sounds like a common issue then! I'll just reset that bitch unless it turns consistent.
    Mdl likes this.
  11. Mar 15, 2024 at 8:43 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Rear brakes to handle all the this powwa.
    Fastlane47, Mdl, HulkSmurf14 and 6 others like this.
  12. Mar 15, 2024 at 8:48 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Damn that looks good. Your brake upgrade has me slightly mad that I put 17’s on years ago. Can’t fit any of the bbk’s on the market.
  13. Mar 15, 2024 at 8:50 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The Alcon kit fits in a 17. Only kit that is also complete front and rear. We run 17s
    Fastlane47, Mdl and carn_dogg[QUOTED] like this.
  14. Mar 15, 2024 at 8:56 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Interesting. Last I checked their site they said 18” required.
    you’re bad news for my wallet. Every time you chime in about something I think about buying something.
    bflooks and reywcms[QUOTED] like this.
  15. Mar 15, 2024 at 9:06 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I've heard this before lol
    Mdl likes this.
  16. Mar 15, 2024 at 9:12 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    What truck? Cause mines an 18 and leafs are on top
  17. Mar 15, 2024 at 9:33 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This is a full long travel truck so I relocated my leafs below the axle. 2017 tundra
  18. Mar 15, 2024 at 1:11 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    What's the difference between a long travel truck and a full long travel truck?
  19. Mar 15, 2024 at 1:11 PM
    helidave
    flagstaff
    2015 DC 4x4
    Gold heat wrap, mostly
    Ponderosa_Pine, VWTim, Mdl and 14 others like this.
  20. Mar 15, 2024 at 1:29 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nothing just saying this is fully setup long travel front and rear.
    Mdl, HulkSmurf14 and BigAl[QUOTED] like this.
  21. Mar 15, 2024 at 6:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    She's coming along nicely and will open it up and see where she's at.
    ARES35, ZPhilip, Silver17 and 5 others like this.
  22. Mar 15, 2024 at 7:17 PM
    koditten
    Kirk
    Midland of the Mitten
    Would it be too much to ask if you broke down what your logging is indicating?
    Fwiw I'm glad to see you are running at 4600 RPMs . I just cringe at winding any engine above 5k. I'm old school, so I always worry, even though I know these motors run fine at those speeds.
  23. Mar 15, 2024 at 7:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's a bad picture of my hptuner scanner. I was posting that I haven't gone a full WOT(wide open throttle) where I'll hit 6200rpm. I'm at 70%(86% is max opening) throttle and at 10.8 psi with an afr of 10.27. I still have 1600 rpm to go and I am cautious of hitting too high of boost as I want my system to stay under 13 and my target is in the 12's but I'll be happy at 11ish psi.
    Here it is at 6159rpm doing a short burnout for my brother and wanted to see the progress.
  24. Mar 15, 2024 at 7:57 PM
    blenton
    blenton New Member
    I hit 3.8 psi today. So neener neener neener.. :anonymous:
  25. Mar 15, 2024 at 8:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I am sure if I were in the mountains it would be right around there.
    blenton[QUOTED] and koditten like this.
  26. Mar 18, 2024 at 5:31 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I went to the adventure outdoor thing in starke Florida. I met a guy who said that magnuson was too conservative and with a different tune I’d get 1000hp easily. I have been giving some thought as to what I would like to do from here.
    I wonder if those of you who are using superchargers by other manufacturers are going higher rwhp and if so how high are you going?
  27. Mar 18, 2024 at 5:33 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Here are my gauges
    ARES35 likes this.
  28. Mar 18, 2024 at 5:37 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    my $.02
    all Eaton 2650's will act the same in any similar situation. Harrop = Magnuson = Whipple = Kenne Bell
    <Magnuson is not special>
    spin them faster & you get more power.
    add a bunch of stuff to your motor and you can get all kinds of HP.
    however....keep the stock engine under 600whp if you drive it a lot - or like driving it at all.
    "Too conservative" is nice. it means you will have a daily driver.
  29. Mar 18, 2024 at 5:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes - the whipple & Kenne Bell differ slightly in function than the TVS2650...but not much.
    Bayou Spartan likes this.
  30. Mar 18, 2024 at 5:39 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sure, more powerful is possible. ONCE.
