General Supercharger Thread
  1. Jul 8, 2021 at 6:52 PM
    #91
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    I haven’t installed any AFR gauges so I can’t answer your question. But I was wondering the same!
    Saltyhero13 likes this.
  2. Jul 8, 2021 at 6:56 PM
    #92
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Your truck has a narrowband sensor that will allow you to see down to 11.8-11.9 or so. If it pins at 11.8-11.9 you're probably good to go. but you'll be able to see everything between there and 17.9
    You can look at this using an OBDLink MX+ with OBD Fusion etc.
  3. Jul 9, 2021 at 6:51 AM
    #93
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I normally don't either, but noticed it on the track, my speed limiter kicks in and cuts off at 150km/h, so I'm stuck at low 15s passes (15.2@89mph), but the 60ft is great thou, I'm consistently at around 2sec flat, we think it's the transmission output sensor that limits the top speed.
  4. Jul 9, 2021 at 7:52 AM
    #94
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I wonder if @ViktorG would know anything about this? I know he’s upped the rev limiter via HP tunes.
  5. Jul 9, 2021 at 8:03 AM
    #95
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I have the OBD fusion app and purchased the Toyota PIDs. Which one is the correct item to choose to view this narrow band information?
  6. Jul 9, 2021 at 8:45 AM
    #96
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    There should be a AFR average or something as I recall
  7. Jul 9, 2021 at 8:54 AM
    #97
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    A/F Actual which is located under PID -> Calculated PIDs
    It is not a Toyota, Lexus, Scion specific PID. The one under there gives you a value that you need to do math with which is not ideal.
    Platinum714[QUOTED] likes this.
  8. Jul 9, 2021 at 9:03 AM
    #98
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    Thanks so much, now I found it!
  9. Jul 9, 2021 at 10:29 AM
    #99
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    The speed limiter gets its input from the wheel speed sensors, not the transmission output sensor.
    When you go to the track, you can just unplug all 4 wheel speed sensors or pull one of the 30A/50A ABS1/ABS2 fuses (if they are removable on a 2019, not too sure on that).
  10. Jul 9, 2021 at 3:31 PM
    #100
    Downytide
    GTA
    Hi Viktor, so what makes the speed limiter kicks in at 150kmh after gear swap? Before I had hit 160kmh no issue.
  11. Jul 9, 2021 at 3:54 PM
    #101
    ViktorG
    Viktor
    Calgary, Canada
    Not sure, maybe they changed something on the newer trucks, but my 2008 and 2010 could go as fast as you want if you unplugged the WSS.
    Easy enough for you to try and see.
  12. Jul 10, 2021 at 5:34 AM
    #102
    Downytide
    GTA
    Hi Viktor, will give that a try and let you know, taking this thing to the track is fun in a strange way.
    ViktorG likes this.
  13. Jul 11, 2021 at 4:33 PM
    #103
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    @Platinum714 Nice to meet you Brotha! :bowdown::bowdown::muscleflexing: Wow! Thanks for the ride. That whale pulls hard LOL. We could’ve gone 100mph if you didn’t let go of the gas LOL. Now, the waiting game for me :-( Hope to see you in 3weeks!
  14. Jul 11, 2021 at 5:39 PM
    #104
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I worked on getting the external transmission install today. The Setrab version will work with the Harrop supercharger. It’s a bit tight with the intercooler radiator so I had to take off the front number to fit the bottom bracket screws in. I will try to finish up with install g the thermostat tomorrow but did all the hard stuff today!
    @Classy63 thumbs up for such a nice product. everything fit simply so far and had no issues.
  15. Jul 12, 2021 at 3:38 AM
    #105
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    thanks Platinum714
    Mine goes for the Harrop install tomorrow....I will now be doing the transmission cooler very soon.
    AZTundra, boringdriver, sd172 and 2 others like this.
  16. Jul 12, 2021 at 6:01 AM
    #106
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I was thinking of paying for the shop to install the cooler but I don’t think it would be worth it since a lot of stuff needs to be taken apart. So just wanted to give you guys a heads up on that aspect.
  17. Jul 12, 2021 at 8:43 AM
    #107
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Following your build, good luck with aligning all of the pieces. I already have the Setrab kit installed and thinking about the supercharger options for my 2021 Sequoia.
  18. Jul 21, 2021 at 3:33 AM
    #108
    nobodyintexas
    nobodyintexas What?
    South of Houston
    The Harrop Stage 1 is in. factory tune - this is a 2020 1794
    6.2lbs boost 120hp gain 101ft/lb tq gain
    A/F ratio went to 11.9 @ heavy throttle - very safe
    they put in cooler plugs as an extra safety measure.
    the tuner said the dyno numbers showed numerous places to add power, and that the Toyota tune was very safe for the application. (comforting)
    very pleased with the power delivery. it's a very normal Tundra at cruise. hitting the the pedal is glorious.
    I've only been 1/2 into the pedal. This truck gets to a hustle quick.
    on cruise control, it behaves. however, it does not drop down a gear when I go up over passes. it just lugs up. nice.
    passing...the TRD exhaust emits the voice of Satan.
  19. Jul 21, 2021 at 6:57 AM
    #109
    AZTundra
    Paul
    Phoenix, AZ
    Add the pedal commander and it only gets better...
    nobodyintexas[QUOTED] likes this.
  20. Jul 21, 2021 at 7:47 AM
    #110
    Saltyhero13
    Saltyhero13 Throbbing Member
    Great write up. Thanks for sharing your experience with this product.
    Platinum714 likes this.
  21. Jul 21, 2021 at 8:40 AM
    #111
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I agree I tried with and without pedal commander and I still felt the delay in the throttle without it activated. Still going to keep it for now.
    AZTundra[QUOTED] likes this.
  22. Jul 21, 2021 at 9:07 AM
    #112
    AZTundra
    Paul
    Phoenix, AZ
    Especially if you're running larger tires. I forget the setting I'm using maybe sport +1 but it makes so much of a difference when you drive.
  23. Jul 21, 2021 at 10:12 AM
    #113
    Saltyhero13
    I know MPGs is not why people get PC but I was able to get really good MPG results with Harrop + PC in ECO -4 for City driving, I was able to get around 15+ MPGs for a good portion of my city driving. Since then I've removed my PC so I haven't tested Highway MPGs.
  24. Jul 21, 2021 at 1:34 PM
    #114
    AZTundra
    Paul
    Phoenix, AZ
    I'll have to give eco a try for a tank and see what happens. I used to average about 15-16mpg before the magnuson and larger tires. Now I consistently average about 12.5.
  25. Jul 21, 2021 at 3:45 PM
    #115
    Saltyhero13
    After poo pooing ECO mode as trash I was surprised I jumped from 11 to 15 on that setting. ECO -4 takes some getting use to but in city traffic its doable. As soon as I hit the highway the mode gets switched to something more palatable.
  26. Jul 23, 2021 at 6:02 AM
    #116
    nobodyintexas
    nobodyintexas What?
    South of Houston
    update.
    I left the map!
    I threw a P0174/P0171 code...lean whatever.
    this happens if you give it big throttle and immediately let off the gas.
    I'm guessing the blower does not have time to get into bypass and is still throwing air at zero throttle, hence the lean out. I use a scanguage all the time....simple reset.
    I'm not concerned as there is no load on the motor when the lean out happens. I do know my A/F ratio is safely ~11.9 under load.
    other than that..it is behaving well. I'm getting the same mileage, if I drive normally.
    It turns in to the Valdeeez when I get juvenile. miles of smiles.
  27. Jul 23, 2021 at 7:21 AM
    #117
    sd172
    sd172 New Member
    South Dakota
    @nobodyintexas
    Do you have the stock injectors and the fuel pump (and is it a flex fuel)?
    Running a blower on E85 would be really sweet and economically viable in my case. Plenty of corn around here.
  28. Jul 23, 2021 at 7:36 AM
    #118
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it's the Stage 1 pkg from Harrop
    stock injectors
    upgraded fuel pump from Harrop
    non-flex fuel
    it runs awesome in all situations....it just throws a code if you hit the gas then immediately let off...understandably.
    the lesson here....never let up on the gas!
  29. Jul 24, 2021 at 5:06 AM
    #119
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I finally figured out the A/F ratio on my scanguage II. I'll post the XGuage stuff Monday
    1/2 throttle see's 12.8
    full throttle sees 12.1. I haven't stayed in full throttle long, still learning.
    otherwise it cruises around at 14.5-14.7
    vq35721, sd172, AZTundra and 3 others like this.
  30. Jul 24, 2021 at 10:19 AM
    #120
    Downytide
    GTA
    Well, gonna order it after the suspension is done, can't wait to join the club
