General Supercharger Thread
  1. Nov 11, 2023 at 3:44 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Can I just get confirmation that this is the correct hookup for the pcv catch can?
    green pcv valve under blower to top port on catch can
    Middle blower port that had small vac line from it to pcv valve… over to side port on catch can.
    tia
    Mdl, ARES35, reywcms and 1 other person like this.
  2. Nov 11, 2023 at 5:34 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Correct, PCV connects to top, side is the return back.
  3. Nov 11, 2023 at 7:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Correct
    carn_dogg[QUOTED] likes this.
  4. Nov 11, 2023 at 7:22 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Saw someone earlier in this thread put some adhesive heat shield material on the bottom of the blower. Is that worth doing? I know the cool kids wrap everything in gold, but this stuff was silver.
    Mdl and reywcms like this.
  5. Nov 11, 2023 at 7:26 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    There's a lot of debate on how much they help, but yeah, it's a thing
    https://fiinterchillers.com/product/thermal-blanket/
    Edit: I plan on doing it next time I have the blower off, every little bit of thermal protection helps in my opinion
    Mdl, helidave[QUOTED] and reywcms like this.
  6. Nov 11, 2023 at 8:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Agreed
    Mdl and helidave like this.
  7. Nov 11, 2023 at 8:14 AM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Alright finally got wideband bung welded on and ready for psb-1. Now just have to tie in the 02 sensor, find a vacuum line on this 2650 and get map sensor hooked, and wire up gauge.
  8. Nov 11, 2023 at 9:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Bank 1 rear.
    ARES35[QUOTED], carn_dogg and reywcms like this.
  9. Nov 11, 2023 at 10:02 AM
    helidave
    flagstaff
    2015 DC 4x4
    Only 85 pages to go til im caught up on this thread...
    Can the maggie base tune deal with the SABM or would I need to wait to do that until I can tune it for real?
    ARES35 and Mdl like this.
  10. Nov 11, 2023 at 10:09 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    It'll be totally fine. The MAF with help with any minor corrections needed.
  11. Nov 11, 2023 at 11:53 AM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Moving from Stock Maggie setup, OTT Tuned to
    2.3 Pulley, 650cc dw, 300c dw pump
    wondering if it is necessary to move to the colder plugs?
    ARES35, Mdl and HulkSmurf14 like this.
  12. Nov 11, 2023 at 12:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Where are you located? Plugs aren't a bad idea I dont think, but not necessarily needed. I'm doing the same setup but with a 2.2" super Sniv pulley... I'm excited!!
  13. Nov 11, 2023 at 12:36 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You could go a bit colder with ikh24's normal gap .032 to .028. It's been said if you are running higher psi you can gap smaller to prevent spark blowout. I gapped to .021 but it's overkill. Will gap up and see if I get better rpm response.
    Edit: **We aren't running 20psi plus so gapping down may affect drivability. I haven't seen it but will gap up next chanaccordingly.
    Re-read some stuff I had. Ikh22 gapped at .032 good for 8psi. 10 psi and up gap to .028 or run ikh24 at .032 to .028. Look at condition of plugs plugs and change accordinly.
  14. Nov 11, 2023 at 2:38 PM
    AZTundra
    Paul
    Phoenix, AZ
    Finally getting around to install my psb-1 which has been collecting dust for months. Are you wiring up a relay for power or tapping into 12v switched from a specific location?
    Mdl likes this.
  15. Nov 11, 2023 at 3:09 PM
    ARES35
    Mile high
    Damn Magnuson just has the plug in so need to find a nipple.:facepalm:
  16. Nov 11, 2023 at 3:14 PM
    ARES35
    Mile high
    I tapped off a switched 12v that feeds my remote start. Had a hell of a time finding a switched 12v that would reach the psb-1, damn conductors they give are short. Ground for the black and white, I'm not auto dimming was easy, bolt under dash within reach.
    Mdl and AZTundra[QUOTED] like this.
  17. Nov 11, 2023 at 3:19 PM
    carn_dogg
    Pat
    Eastern Shore MD
    There is a nice spot under the dash near your left knee that supplies 12v with ignition. It’s a blank spot right now. It’s like the 6th from the bottom when you’re upside down looking up at the fuse panel. You’ll see what I mean once you set eyes on it.
    FYI- this is the brass npt that you need for the 2650 boost tap: https://www.amazon.com/dp/B07VHH9J3S
    Mdl, ARES35[QUOTED] and AZTundra like this.
  18. Nov 11, 2023 at 3:23 PM
    ARES35
    Mile high
    Installing this was kinda a bitch lol. First off not impressed by the mount. Had to fab it to fit the psb-1 interference with dial ring, screws to mount to column to damn small. Ran the map sensor and have it ready cause no nipple supplied with the Maggie smh. 02 sensor ran to exhaust, biggest bitch was removing my cat plate to screw sensor on bung. Wired up and tie wrapped real nice just need that nipple:cool:
  19. Nov 11, 2023 at 3:31 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice setup. That sucks not knowing about the nipple. Thought the company would install and cap it for you...
    ARES35 likes this.
  20. Nov 11, 2023 at 3:32 PM
    carn_dogg
    Pat
    Eastern Shore MD
    You would think. SCOL told me it would be included so there is a disconnect somewhere.
    Mdl[QUOTED] and ARES35 like this.
  21. Nov 11, 2023 at 3:35 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks, I'll take a look there to tap 12v power.
    Mdl and ARES35[QUOTED] like this.
  22. Nov 11, 2023 at 3:36 PM
    ARES35
    Mile high
    That's what I thought at first, I was bitching lol. I was most disappointed with the mount! Damn thing was so loose wobbled around, gauge ring was all smashed against the pod, rear mount to pod holes not even close to lining up, me cursing in the driveway haha
    Mdl[QUOTED] and AZTundra like this.
  23. Nov 11, 2023 at 4:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Most do have to mod that pod mount setup. I put mine in the dash under the cluster. I can view it but not as easy as the steering wheel mount.
    Edit: *I probably posted this pic before. But a decent setup for gen 2's afr and sniv's lower console pod mod for afr,boost or fuel psi.
  24. Nov 11, 2023 at 6:00 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I run tapped power off the left 12V outlet, and I run the dimmer off or of the switches that light up (tow haul or trac off for example). Not sure if the 2.5 gen is different than the 2.0 in regards to 12V outlet powering (the right outlet stays on after ignition turns off for example). Though keep in mind the gauges I've mounted are in the center console where the brake controller would otherwise be.
  25. Nov 11, 2023 at 7:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Another great idea. I got a little too busy with yard work and didn't get a chance to start today. I like the idea of tapping the switch for the dimmer functionality.
    nobodyintexas, Mdl, ARES35 and 2 others like this.
  26. Nov 12, 2023 at 4:36 PM
    ARES35
    Mile high
    Rigged up but now I got boost lol
  27. Nov 12, 2023 at 4:49 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Nice! What psi are you getting?
  28. Nov 12, 2023 at 4:50 PM
    ARES35
    Mile high
    I got to mulching leaves right after still have to see.
    Mdl likes this.
  29. Nov 12, 2023 at 4:52 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Lol yard work this time of the year takes over any free time you have.
  30. Nov 12, 2023 at 4:57 PM
    ARES35
    Mile high
    Yes sir. I do it the easy way though. Suck up with the mower way better then raking lol
