General Supercharger Thread
  1. Dec 10, 2021 at 1:43 PM
    #1081
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    My inner plan of getting 250k out of this engine is constantly battling with the thought of a supercharger. Dammit.
  2. Dec 10, 2021 at 4:08 PM
    #1082
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Not gonna say this is typical, but it’s pretty insane.
  3. Dec 11, 2021 at 5:08 AM
    #1083
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    If you take care of it you'll get 1,000,000 w/ no boost. There are S/C engines that are in the 200,000. If something breaks just fix it and keep making music.
  4. Dec 11, 2021 at 10:38 AM
    #1084
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What’s everyone’s consensus on spark plugs and oil weight for supercharging a truck with 60k miles?
    I was going to switch to 5w30 since the engine will be making more heat(hp) but was unsure of new OEM plugs or going colder?
    Also I’ll get the shop to weld on an O2 bung for the inevitable Stage 2 tuning.
  5. Dec 11, 2021 at 10:52 AM
    #1085
    Silver17
    Eastern PA
    I used new OEM standard iridium plugs when I installed stage 1 at the recommendation of Prospeed. For stage 2 Im using colder IKH24 plugs at the recommendation of DAP. As far as oil, living in an area that gets cold in the winter I plan to keep the 0w20. I still believe the most wear happens at cold startup, so the quicker that oil gets where it needs to go the better. In year round southern heat or something, I’d maybe consider other options. Im no oil expert though, so I’m curious what others think.
    snivilous[OP] likes this.
  6. Dec 11, 2021 at 11:25 AM
    #1086
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I run IKH22 as per Magnuson's recommendation. You're only making more horsepower when you're at higher throttle and in boost, the engine shouldn't be running hotter the majority of the time. The only time I notice my engine going over 203F is if I'm in boost for an extended period, and even then the hottest it'll climb to is 212ish. I don't think that's enough to warrant thicker oil, but I also don't think you'll hurt anything with thicker oil. I recommend running a O2 sensor regardless of what "stage" you're going to, you're modifying the engine and the air and fuel dynamics and that's one of the easiest and quickest ways to destroy the engine is the air fuel ratio being off, I think it's mandatory to have an external O2 sensor that you can monitor as easily as you can watch your normal gauges... but that's just me, I also installed my O2 sensor before I installed the blower just so I had a baseline before installing the blower :D
    Wynnded and nobodyintexas like this.
  7. Dec 11, 2021 at 11:27 AM
    #1087
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I live near Houston, so I use 5w30 with ZDDP additive, for spark, Prospeed recommended IKH22 plugs gapped at .022 on 85mm pulley and they've worked well for me over the past year
    Check with your tuner before placement on the additional O2 bung, for my longtube headers Prospeed recommended a bung on an individual runner instead of at the collector or after...just a heads up
  8. Dec 11, 2021 at 11:40 AM
    #1088
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i just sent a sample on my Kirkland 0-20 oil. I'll let y'all know how it held up. it has the dyno pulls on it.
    I run the cooler plugs- because I was told to by Alex Pietz. Don't know if they make a diff.
    I'm in hot ass Houston.
    Saltyhero13 likes this.
  9. Dec 11, 2021 at 7:15 PM
    #1089
    snivilous
    SW UT
    Idk how accurate this app is but you guys got me excited to try it. This was down the hill, 3800ft and 40F outside and a bit of an incline. Truck also had a weird fueling hiccup it felt like, so if 4.4s 0-60 is correct I'm amazed!
    Excuse my Magnuson boosted self posting things :D but the truck just rolled 264k and I'm pretty stoked if that number is remotely true!
  10. Dec 11, 2021 at 8:27 PM
    #1090
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    @snivilous - when you say you felt like it had a weird fueling hiccup, how much fuel was in the tank? In my experience, anything less than 1/2 tank you can experience surging at WOT on longer pulls. According to Viktor, it's due to fuel sloshing back in the tank on acceleration and the fuel pump basket being sucked dry by the pump.
  11. Dec 11, 2021 at 8:31 PM
    #1091
    snivilous
    SW UT
    I suspect it was that, I had a 1/2 tank and haven't had it happen before with that much fuel but I also don't often do a WOT pull for that long (especially at lower elevation where it pulls a lot harder than the house). Though when I've had it happen (usually a 1/4 tank or less) it was the same feeling.
  12. Dec 11, 2021 at 10:03 PM
    #1092
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Someone over at Harrop is really strong because I went to install my 80mm pulley today and I stripped one of those 5mm hex bolts trying to loosen it. So I'm trying to think of how I want to deal with that. But I did install the 650 injectors, and uploaded one of the tunes I got in my tune pack from VF tuner. Truck runs WAY better than just the stock stage 1. Also a pleasant surprise is my MPG's. with 34's and 5.29 gears, before the Harrop my average was 11.7mpg. With the stage 1 it dropped to 11.3 average. Now with the tune and 650cc's still 85mm pulley my average has been 17.8mpg. That's my normal driving habits around DFW.
  13. Dec 12, 2021 at 2:02 AM
    #1093
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Holy cow.
    I seem to remember a thread asking for over 200k mile supercharged tundras with nobody fussing up to having one.
  14. Dec 12, 2021 at 2:54 AM
    #1094
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Wow! way to go!
    @snivilous would you reckon you have about 675hp @ crank?
    snivilous[QUOTED][OP] likes this.
  15. Dec 12, 2021 at 2:57 AM
    #1095
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It had me avging 27mpg...real calc was 17. I have to use my scanguage now to monitor fuel.
  16. Dec 12, 2021 at 2:59 AM
    #1096
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This.
    I remember my installer said to keep fuel in it.
    now I know why he said it.
  17. Dec 12, 2021 at 5:45 AM
    #1097
    Silver17
    Eastern PA
    For those of you going to stage 2. Are you changing the Fuel pressure regulator back out to the stock one? I’ve seen people suggest to leave the modified higher pressure regulator installed and tune it with that on stage 2…but I’ve also seen someone else with stage 2 say they went back to the stock regulator as per Harrop. Any thoughts on this? I was planning to leave the modified regulator in.
  18. Dec 12, 2021 at 5:49 AM
    #1098
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’m not sure what I have
    I know I have the fuel pump that came with the harrop
    not sure if a regulator was changed
    how can I tell?
  19. Dec 12, 2021 at 6:07 AM
    #1099
    Silver17
    Eastern PA
    Here is what the installer used to have to do in the previously sent kits. They would send a jig that you would use to compress the regulator a little bit thus changing spring tension. Newer kits probably like yours and mine they sent the regulator already modified and you just change it. The regulator is mounted on the fuel rail next to the blower base, I forget if it’s the driver is passenger side rail. If it looks compressed you know it’s the modified one. If you still have the original one in your box of removed parts you can compare it, but if D3 never asked for it back when going stage 2 I’m guessing they didn’t swap it back out. I tried to tag Chris@Harrop but it wouldn’t work.
  20. Dec 12, 2021 at 6:10 AM
    #1100
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’m still balled up over all these low 0-60 times you folks are posting
    I need to go whip this mule
  21. Dec 12, 2021 at 7:54 AM
    #1101
    snivilous
    SW UT
    I think at sea level it's maybe in the 600 range. I also have 5.29s so have 25% more torque to the wheels.
  22. Dec 12, 2021 at 10:25 AM
    #1102
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Coming along nicely boys and girls! All that’s left is the fuel pump…
    AZTundra, 1UP, Platinum714 and 8 others like this.
  23. Dec 12, 2021 at 10:35 AM
    #1103
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You may've already mentioned and I obviously missed it, but who are you having doing your tuning?
  24. Dec 12, 2021 at 10:43 AM
    #1104
    boostedtrdpro
    Jeremy
    I plan on driving it a little while untuned stage 1 (not for terribly long) in hopes to actually feel the difference of progression. I’d like to see HP come out with something in the near future. If not, DAP did my previous 2017 and I may have him do this one as well. I haven’t landed on anything firm quite yet, just kinda taking it one step at a time. When the SC was ordered, it was still before anyone cracked the 2019 ECU so it’s been a journey just to get it fitted so far.
  25. Dec 12, 2021 at 10:51 AM
    #1105
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah, thanks. I'm kind of trying to keep my ear to the wind for anyone in CO who's competent with VFTuner. I think that most places seem to stick with HP as they deal with other manufacturers and are more in there comfort zone with them.
  26. Dec 12, 2021 at 7:41 PM
    #1106
    boostedtrdpro
    Jeremy
    Fuel pump installed and tank put back.
    Tomorrow morning get the fluids in and fill er’ up with 91 and give it a shake down.
  27. Dec 12, 2021 at 7:58 PM
    #1107
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Chug a couple monsters and pull an all nighter. Priorities!
  28. Dec 13, 2021 at 2:34 PM
    #1108
    boostedtrdpro
    Jeremy
    Holy. Shit! I really wanna elaborate, but I’m truly speechless at the moment.
  29. Dec 13, 2021 at 2:36 PM
    #1109
    ZPhilip
    Philip
    West Chester, PA
    More info please!
  30. Dec 13, 2021 at 3:09 PM
    #1110
    Silver17
    Eastern PA
    Don’t forget to try tow/haul! Lol
