General Supercharger Thread
  1. Oct 17, 2023 at 8:09 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    and...
    I now want to get the boost gauge working before I put on the 77.5mm.
    so I ordered a new AEM X gauge. comes in Tomorrow
    I'm wanting to see, after the swap, if the following reading are the same:
    idle @ -17-ish
    60mph cruise @ -10-ish
    Beltway 8 ship channel bridge crossing 60mph on cruise control @ +2lbs
    on ramp to Hardy Toll Road @ +6lbs
    for science.
  2. Oct 17, 2023 at 8:11 AM
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Silver17, Mdl, reywcms and 1 other person like this.
  3. Oct 17, 2023 at 9:49 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    RCA sent me Innovate's response:
    Hi Stefan,
    thank you for bearing with me. Innovate has gotten back to me regarding this issue and has stated me with the following.
    "This is a very common code to receive with these gauges that use o2 sensors due to the fumes within the exhaust clogging the sensor up. 99% of the time this issue can be fixed by pulling the o2 sensor out and using a cleaner on it. To test before throwing the sensor back in to the car you can use butane gas such as lighter fluid and spray it onto the sensor itself and you should receive a reading in the high 90's on the gauge. At that point it is safe to throw the sensor back into the car and you are good to go". If you have anymore questions on this process you can contact Innovate's technical support line. I have included their contact info below. Please let me know if you have any further questions or concerns.
  4. Oct 17, 2023 at 9:57 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Brake cleaner works too for testing. You can use other wide band sensors that cross reference the Bosch but I would stick with Bosch or Denso.
    e30cabrio, snivilous[OP] and Wynnded like this.
  5. Oct 17, 2023 at 10:00 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Note to self: if it takes a 12 ton press to get it on a 5 ton puller is not going to work. Wasted my weekend but the hack job got it off. Old to new! Got it ported for the RCF. Now on to intake...
  6. Oct 17, 2023 at 10:07 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks awesome! Still need to hear that exhaust!
    e30cabrio likes this.
  7. Oct 17, 2023 at 10:22 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I always used a 3 jaw 6-ton puller to get them off, and it's always scary when it finally pops loose
    ssmokedz and Mdl[QUOTED] like this.
  8. Oct 17, 2023 at 10:44 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Highest so far. Think im going to just weld up the mid pipe to LTs to stop the leaks
  9. Oct 17, 2023 at 12:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  10. Oct 17, 2023 at 12:15 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    e30cabrio and Mdl[QUOTED] like this.
  11. Oct 17, 2023 at 3:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Finally got snout back on and did Matt Smith mod on fuel rails, removed bevel. Know hes not on here but major Thanks to 4firemandan for his write up on some good mods. On to the intake.
    HulkSmurf14, VWTim, Silver17 and 6 others like this.
  12. Oct 17, 2023 at 4:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Where’s that write up I’m curious on what this mod is
    Mdl[QUOTED] likes this.
  13. Oct 17, 2023 at 4:35 PM
    e30cabrio
    I have the solution to the Innovate.
    Step 1 search a replacement sensor.
    2 Buy sensor.
    HulkSmurf14, Saltyhero13, Mdl and 3 others like this.
  14. Oct 17, 2023 at 6:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  15. Oct 17, 2023 at 8:17 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Now I gotta start a thread somewhere for this fella. 2005 GX470 4.7L. Based on the 4Runner platform. Gonna try and keep it long term. But it's definitely getting supercharged!
  16. Oct 18, 2023 at 2:21 AM
    e30cabrio
  17. Oct 18, 2023 at 7:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Got the 4.5inch intake mocked up in the SC TRD airbox. The dremel got away from me in the lower left area, about 7 ocolck. Anyone ever use zip ties in a glue gun to fuse ABS plastic? May just use JB Weld and some rivets to hold flange in place. Looking for the most solid connection.
    Would it look ghetto wrapping in black header wrap. All is see is @reywcms gold or silver heat wrap online. Thanks.
    M3Tundra-JK, 1UP, Saltyhero13 and 6 others like this.
  18. Oct 18, 2023 at 7:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Don't use header wrap... just paint it or use the foil!!
    JB weld is great!!
    Mdl likes this.
  19. Oct 18, 2023 at 8:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks! All I could find was jb weld for abs and aluminum. I have the silver wrap but it's not too hot here in summer 90's for a week or 2. Hopefully fill in a few voids.
    HulkSmurf14[QUOTED] likes this.
  20. Oct 18, 2023 at 8:56 PM
    PolishedTRD
    PolishedTRD I do my own stunts
    CO
    Supercharged 2011 DC, 2025 RAM 2500 6.7 Big Horn
    In my efforts to chase a P0430, I stumbled upon some information that might be relevant to this anomaly: in an attempt to determine whether emissions equipment has been defeated or substantially altered, the ECU will quickly and subtly modulate the AFR in an effort to test the resulting catalyzed exhaust, generally during an extended duration of a consistent AFR (such as being on cruise). If the downstream sensor doesn't detect the subtle change, ECU will return a P0420/P0430.
  21. Oct 19, 2023 at 3:15 AM
    e30cabrio
    I have used plastic pens through a cheap glue gun for things like this. Worked shockingly well.
    HulkSmurf14 likes this.
  22. Oct 19, 2023 at 4:27 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I would consider using a weather seal. The engine moves under torque so a hard seal will likely crack.
  23. Oct 19, 2023 at 4:29 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Then he should be upgrading to the solid motor mounts....:rofl::spending:
  24. Oct 19, 2023 at 4:30 AM
    Saltyhero13
    He might already have them.
    Wynnded[QUOTED] likes this.
  25. Oct 19, 2023 at 4:34 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed...engine movement cracked the lid tabs on my stock lower air box. hence, the new TRD one I just put in....that has the same DAMN tabs!!!
    and I zip tie the Harrop cable to the MAF tube to keep it stationary - so as to prevent any further drama.
    Mdl and Saltyhero13[QUOTED] like this.
  26. Oct 19, 2023 at 4:39 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I need to get all this grown up adult crap off my calendar...I have important shit to do!
    Vizsla, 19PlatinumCrew, Mdl and 5 others like this.
  27. Oct 19, 2023 at 6:15 AM
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    I don't recall ever seeing an option in techstream to reset a maint light. I tried anyways on my 2019 and could not find any option to reset one. I looked up the diagram for a 2013 Sequoia and there is a 7.5 amp fuse labeled "MET" in the fuse box under the hood on the driver side, and a 5 amp labeled "MET-B" also in the drivers side fuse box that would completely remove power from the combination meter. You might be able to try to remove those 2 fuses first before going through the hassle of removing the whole cluster. Hope this helps a bit.
  28. Oct 19, 2023 at 8:04 AM
    e30cabrio
    Thanks, I pulled the battery yesterday, no joy. :(
    ssmokedz[QUOTED] likes this.
  29. Oct 19, 2023 at 8:08 AM
    ssmokedz
    Shelton CT
    Damn. And the button for the odometer/trip A/B isn't functional?
  30. Oct 19, 2023 at 8:21 AM
    e30cabrio
    18+ wants it through menus accessed in the cluster via the right switches. I have cobbled the 18 cluster into my 13 & this is part of the deal apparently. The right buttons become dead when low fuel & apparently oil interval occurs.
    Low fuel was fixed by filling up. I'll try the fuses. Thanks!
    Mdl likes this.
