General Supercharger Thread
  1. Oct 10, 2023 at 8:15 AM
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Sorry i am a little behind. You got a new truck i assume. Those permanent dtc's cannot be cleared either with a scan tool or by disconnecting the battery. They need a specific drive cycle performed that the ecm can then use to determine if that dtc is fixed. You really are more concerned with current or pending dtc's. Give me a few minutes and ill look into those dtc's you had though.
  2. Oct 10, 2023 at 8:18 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It is the crashed truck continuing to be an ass.
    M3Tundra-JK and ssmokedz like this.
  3. Oct 10, 2023 at 8:44 AM
    ssmokedz
    Shelton CT
    Ah i see. That sucks. It doesn't look like you are looking at a pedal position problem at the accelerator pedal. And i really don't think an accident would cause an issue with that anyways. I don't think in my 18 years at Toyota that i have seen a pedal go bad. Maybe one or two isolated cases but i don't recall one at least. Those dtc's pertain only to the throttle body and wiring to the ecm. There might have been some harness damage from the accident kicking your ass. Sorry for the long post but this is directly from TIS for those codes:
    The TP sensor is mounted on the throttle body, and detects the opening angle of the throttle valve. This sensor is a non-contact type. It uses Hall-effect elements in order to yield accurate signals even in extreme driving conditions, such as at high speeds as well as very low speeds.
    The TP sensor has 2 sensor circuits, each of which transmits a signal, VTA1 and VTA2. VTA1 is used to detect the throttle valve angle and VTA2 is used to detect malfunctions in VTA1. The sensor signal voltages vary between 0 V and 5 V in proportion to the throttle valve opening angle, and are transmitted to the VTA terminals of the ECM.
    As the valve closes, the sensor output voltage decreases and as the valve opens, the sensor output voltage increases. The ECM calculates the throttle valve opening angle according to these signals and controls the throttle actuator in response to driver inputs. These signals are also used in calculations such as air-fuel ratio correction, power increase correction and fuel-cut control.
    DTC Code
    DTC Detection Condition
    Trouble Area
    P0120
    Output voltage of VTA1 quickly fluctuates beyond lower and upper malfunction thresholds for 2 seconds or more
    (1 trip detection logic)
    • Throttle position sensor (built into throttle body)
    • ECM
    P0121
    The difference between the VTA1 and VTA2 voltages is below 0.8 V or higher than 1.6 V for 2 seconds or less
    • Throttle position sensor circuit
    • ECM
    P0122
    Output voltage of VTA1 0.2 V or less for 2 seconds or more
    • Short in VTA1 circuit
    • Open in VC circuit
    • ECM
    P0123
    Output voltage of VTA1 4.535 V or more for 2 seconds or more
    • Open in VTA1 circuit
    • Open in E2 circuit
    • Short between VC and VTA1 circuits
    • ECM
    P0220
    Output voltage of VTA2 quickly fluctuates beyond lower and upper malfunction thresholds for 2 seconds or more
    • ECM
    P0222
    Output voltage of VTA2 1.75 V or less for 2 seconds or more
    • Short in VTA2 circuit
    • ECM
    P0223
    Output voltage of VTA2 4.8 V or more, and VTA1 between 0.2 V and 2.02 V for 2 seconds or more
    • Open in VTA2 circuit
    • Short between VC and VTA2 circuits
    • ECM
    P2135
    Either condition (a) or (b) met (1 trip detection logic):
    (a) Difference between output voltages of VTA1 and VTA2 0.02 V or less for 0.5 seconds or more
    (b) Output voltage of VTA1 0.2 V or less, and VTA2 1.75 V or less, for 0.4 seconds or more
    • Short between VTA1 and VTA2 circuits
    • ECM
    HINT:
    • When any of these DTCs are set, check the throttle valve opening angle by entering the following menus: Powertrain / Engine and ECT / Data List / ETCS / Throttle Position No. 1 and Throttle Position No. 2.
    • Throttle Position No. 1 is the VTA1 signal, and Throttle Position No. 2 is the VTA2 signal.
      Reference (Normal Condition):
      Display Item
      Accelerator Pedal Fully Released
      Accelerator Pedal Fully Depressed
      0.5 to 1.1 V
      3.2 to 4.8 V
      2.1 to 3.1 V
      4.6 to 5.0 V
    MONITOR DESCRIPTION
    P0120, P0122, P0123, P0220, P0222, P0223, P2135
    The ECM uses the throttle position sensor to monitor the throttle valve opening angle. There are several checks that the ECM performs to confirm the proper operation of the throttle position sensor.
    • A specific voltage difference is expected between the sensor terminals, VTA1 and VTA2, for each throttle valve opening angle. If the difference between VTA1 and VTA2 is incorrect, the ECM interprets this as a malfunction in the sensor, and stores a DTC.
    • VTA1 and VTA2 each have a specific voltage range. If VTA1 or VTA2 is outside the normal operating range, the ECM interprets this as a malfunction in the sensor, and stores a DTC.
    • VTA1 and VTA2 should never be close to the same voltage level. If VTA1 is within 0.02 V of VTA2, the ECM determines that there is a short circuit in the sensor, and stores a DTC.
    If the malfunction is not repaired successfully, a DTC is stored 10 seconds after the engine is next started.
    P0121
    This sensor transmits 2 signals: VTA1 and VTA2. VTA1 is used to detect the throttle opening angle and VTA2 is used to detect malfunctions in VTA1. The ECM performs several checks to confirm the proper operation of the throttle position sensor and VTA1.
    For each throttle opening angle, a specific voltage difference is expected between the outputs of VTA1 and VTA2. If the output voltage difference between the two signals deviates from the normal operating range, the ECM interprets this as a malfunction of the TP sensor. The ECM illuminates the MIL and stores the DTC.
    If the malfunction is not repaired successfully, the DTC is stored 2 seconds after the engine is next started.
    MONITOR STRATEGY
    Related DTCs
    P0120: Throttle position sensor 1 range check (Fluctuating)
    P0121: Throttle position sensor rationality
    P0122: Throttle position sensor 1 range check (Low voltage)
    P0123: Throttle position sensor 1 range check (High voltage)
    P0220: Throttle position sensor 2 range check (Fluctuating)
    P0222: Throttle position sensor 2 range check (Low voltage)
    P0223: Throttle position sensor 2 range check (High voltage)
    P2135: Throttle position sensor range check (Correlation)
    Required Sensors/Components (Main)
    Required Sensors/Components (Related)
    Frequency of Operation
    Continuous
    Duration
    2 seconds: P0120, P0122, P0123, P0220, P0222 and P0223
    Within 2 seconds: P0121
    0.5 seconds: P2135 Case 1
    0.4 seconds: P2135 Case 2
    MIL Operation
    Immediate
    Sequence of Operation
    None
    TYPICAL ENABLING CONDITIONS
    Monitor runs whenever following DTCs not present
    None
    Either of following conditions A or B met
    A. Ignition switch
    ON
    B. Electronic throttle actuator power
    ON
    P0121
    P0120, P0122, P0123, P0220, P0222, P0223, P2135 (Throttle position sensor)
    Either of following conditions met
    A. Ignition switch
    ON
    ON
    TYPICAL MALFUNCTION THRESHOLDS
    P0120:
    VTA1 voltage
    0.2 V or less, or 4.535 V or higher
    P0121:
    Either of following conditions is met:
    Difference of learned TP sensor opener position voltage between VTA2 and VTA1
    Higher than 1.6 V
    Below 0.8 V
    P0122:
    VTA1 voltage
    0.2 V or less
    P0123:
    VTA1 voltage
    4.535 V or higher
    P0220:
    When either condition below is met:
    Condition A or B
    A. VTA2 voltage
    1.75 V or less
    B. VTA2 voltage when VTA1 0.2 V or more, and 2.02 V or less
    4.8 V or higher
    P0222:
    VTA2 voltage
    1.75 V or less
    P0223:
    4.8 V or higher
    P2135 Case 1:
    Difference between VTA1 and VTA2 voltages
    0.02 V or less
    P2135 Case 2:
    VTA1 voltage
    0.2 V or less
    VTA2 voltage
    1.75 V or less
    COMPONENT OPERATING RANGE
    VTA1 voltage
    0.2 to 4.535 V
    VTA2 voltage
    1.75 to 4.8 V
    CONFIRMATION DRIVING PATTERN
    1. Connect the Techstream to the DLC3.
    2. Turn the ignition switch to ON and turn the Techstream on.
    3. Clear DTCs (even if no DTCs are stored, perform the clear DTC operation).
    4. Turn the ignition switch off and wait for at least 30 seconds.
    5. Turn the ignition switch to ON and turn the Techstream on [A].
    6. Start the engine.
    7. With the vehicle stationary, fully depress and release the accelerator pedal .
      [*]Idle the engine for 2 seconds or more [C].
      [*]Enter the following menus: Powertrain / Engine and ECT / Trouble Codes [D].
      [*]Read the Pending DTCs.
      HINT:
      • If a pending DTC is output, the system is malfunctioning.
      • If a pending DTC is not output, perform the following procedure.
      [*]Enter the following menus: Powertrain / Engine and ECT / Utility / All Readiness.
      [*]Input the DTC: P0120, P0121, P0122, P0123, P0220, P0222, P0223 or P2135.
      [*]Check the DTC judgment result.
      Tester Display
      Description
      NORMAL
      • DTC judgment completed
      • System normal
      ABNORMAL
      • System abnormal
      INCOMPLETE
      • DTC judgment not completed
      • Perform driving pattern after confirming DTC enabling conditions
      N/A
      • Unable to perform DTC judgment
      • Number of DTCs which do not fulfill DTC preconditions has reached ECU's memory limit
      HINT:
      • If the judgment result shows ABNORMAL, the system has a malfunction.
      • If the judgment result shows INCOMPLETE or N/A, perform steps and [D] again.
      [*]If no pending DTC is output, perform a universal trip and check for permanent DTCs (See page [​IMG] ).
      HINT:
      • If a permanent DTC is output, the system is malfunctioning.
      • If no permanent DTC is output, the system is normal.
    FAIL-SAFE
    When any of these DTCs, as well as other DTCs relating to ETCS (Electronic Throttle Control System) malfunctions are set, the ECM enters fail-safe mode. During fail-safe mode, the ECM cuts the current to the throttle actuator, and the throttle valve is returned to a 7° throttle angle by the return spring. The ECM then adjusts the engine output by controlling the fuel injection (intermittent fuel-cut) and ignition timing, in accordance with the accelerator pedal opening angle, to allow the vehicle to continue at a minimal speed. If the accelerator pedal is depressed firmly and gently, the vehicle can be driven slowly.
    Fail-safe mode continues until a pass condition is detected, and the ignition switch is then turned off.
    WIRING DIAGRAM
    CAUTION / NOTICE / HINT
    HINT:
    • These DTCs relate to the Throttle Position (TP) sensor.
    • Read freeze frame data using the Techstream. Freeze frame data records the engine condition when malfunctions are detected. When troubleshooting, freeze frame data can help determine if the vehicle was moving or stationary, if the engine was warmed up or not, if the air-fuel ratio was lean or rich, and other data from the time the malfunction occurred.
    PROCEDURE
    1.
    READ VALUE USING TECHSTREAM (THROTTLE POSITION)
    (a) Connect the Techstream to the DLC3.
    (b) Turn the ignition switch to ON.
    (c) Turn the Techstream on.
    (d) Enter the following menus: Powertrain / Engine and ECT / Data List / ETCS / Throttle Position No. 1 and Throttle Position No. 2.
    (e) Read the values displayed on the Techstream.
    Result
    When Accelerator Pedal Released
    When Accelerator Pedal Depressed
    Trouble Area
    Proceed to
    0 to 0.2 V
    0 to 0.2 V
    0 to 0.2 V
    0 to 0.2 V
    VC circuit open
    A
    4.5 to 5.0 V
    4.5 to 5.0 V
    4.5 to 5.0 V
    4.5 to 5.0 V
    E2 circuit open
    0 to 0.2 V,
    or 4.5 to 5.0 V
    2.1 V to 3.1 V
    (Fail-safe)
    0 to 0.2 V,
    or 4.5 to 5.0 V
    2.1 V to 3.1 V
    (Fail-safe)
    VTA1 circuit open or ground short
    0.6 V to 1.4 V
    (Fail-safe)
    0 to 0.2 V,
    or 4.5 to 5.0 V
    0.6 V to 1.4 V
    (Fail-safe)
    0 to 0.2 V,
    or 4.5 to 5.0 V
    VTA2 circuit open or ground short
    0.5 to 1.1 V
    2.1 to 3.1 V
    3.2 to 4.8 V
    (Not fail-safe)
    4.6 to 5.0 V
    (Not fail-safe)
    Throttle position sensor circuit normal
    B
    HINT:
    • DTC P0121 is stored when the voltages output from VTA1 and VTA2 are not consistent with the characteristics of the sensors. Therefore, check the Freeze Frame Data when this DTC is output. Use the following formula to confirm relative fluctuations in voltage.
      Features of sensor output:
      VTA2 x 0.8 is approximately equal to VTA1 + 1.11 V
      VTA1: Throttle Position No. 1
      VTA2: Throttle position No. 2
    • If DTC P0121 is output, proceed to "CHECK HARNESS AND CONNECTOR (THROTTLE POSITION SENSOR - ECM)".
    B [​IMG]
    GO TO STEP 5
    A
    (a) Disconnect the D9 throttle body connector.
    (b) Disconnect the D74 ECM connector.
    (c) Measure the resistance according to the value(s) in the table below.
    Standard resistance:
    Tester Connection
    Condition
    Specified Condition
    D9-5 (VC) - D74-125 (VCTA)
    Always
    Below 1 Ω
    D9-6 (VTA) - D74-126 (VTA1)
    Always
    Below 1 Ω
    D9-4 (VTA2) - D74-101 (VTA2)
    Always
    Below 1 Ω
    D9-3 (E2) - D74-124 (ETA)
    Always
    Below 1 Ω
    D9-5 (VC) or D74-125 (VCTA) - Body ground
    Always
    10 kΩ or higher
    D9-6 (VTA) or D74-126 (VTA1) - Body ground
    Always
    10 kΩ or higher
    D9-4 (VTA2) or D74-101 (VTA2) - Body ground
    Always
    10 kΩ or higher
    NG [​IMG]
    REPAIR OR REPLACE HARNESS OR CONNECTOR
    OK
    INSPECT ECM (VC VOLTAGE)
    (c) Measure the voltage according to the value(s) in the table below.
    Standard voltage:
    Tester Connection
    Switch Condition
    Specified Condition
    D9-5 (VC) - D9-3 (E2)
    Ignition switch ON
    4.5 to 5.5 V
    NG [​IMG]
    REPLACE ECM
    OK
    REPLACE THROTTLE BODY ASSEMBLY
    (a) Replace the throttle body assembly (See page [​IMG] ).
    HINT:
    Perform "Inspection After Repair" after replacing the throttle body assembly (See page [​IMG] ).
    NEXT
    CHECK WHETHER DTC OUTPUT RECURS (THROTTLE POSITION SENSOR DTCS)
    (b) Turn the ignition switch to ON and turn the Techstream on.
    (c) Clear DTCs (See page [​IMG] ).
    (d) Start the engine.
    (e) Allow the engine to idle for 15 seconds or more.
    (f) Enter the following menus: Powertrain / Engine and ECT / Trouble Codes.
    (g) Read DTCs.
    Result
    Result
    Proceed to
    P0120, P0121, P0122, P0123, P0220, P0222, P0223 and/or P2135 are output
    A
    No DTC is output
    B
    A [​IMG]
    REPLACE ECM
    B [​IMG]
    END
  4. Oct 10, 2023 at 8:59 AM
    ssmokedz
    Shelton CT
    I would test for continuity between the throttle body connector and the ecm to verify all is good there.
    IMG_2628.jpg IMG_2627.jpg .
  5. Oct 10, 2023 at 10:09 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Good grief, soneone owes this guy a beer.
  6. Oct 10, 2023 at 11:10 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    oh wow, thanks for all the info! I'm about to head to the body shop to see what I can with it. I spoke with them earlier about getting it towed to the dealer to have it sorted. Sounds like "if it's not directly related to the incident" i have to cover the cost.
  7. Oct 10, 2023 at 11:12 AM
    ssmokedz
    Shelton CT
    My guess is that it is probably related. I would hope insurance will do the right thing if that's the case. Good luck!
  8. Oct 10, 2023 at 12:15 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Doing testing now. Only issue is that I can't access some areas of techstream, throws an error at me.
    Mdl and ssmokedz[QUOTED] like this.
  9. Oct 10, 2023 at 1:18 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Appreciate the help, all. No progress on my end. Off to the dealership from the body shop it goes. Maybe that dealer just shoots me a reasonable buy offer while it's there...
    e30cabrio, Mdl, Wynnded and 1 other person like this.
  10. Oct 10, 2023 at 5:21 PM
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Finally here. Going in tomorrow along with the new pulley.
    e30cabrio, reywcms, ssmokedz and 6 others like this.
  11. Oct 10, 2023 at 5:53 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Cool. Is that the X series or the regular one? I have the regular one and wonder if the X Series has the same plug and if it would just plug in. I’d like to see my boost in decimals instead of just whole numbers. Maybe when you have it unboxed you could send a pic of the plug.
    On a related note, I was looking into the Banks iDash and it’s pretty sweet. It can fit in a 52mm pod mount. If you buy a boost sensor, intake temp sensor, and 4 channel module you can view a lot of different info including manifold PSIA, PSIG, and air density (the best indicator of how much power you’re really making) as compared to just knowing boost and temperature. Here’s a good explanation and showcase of the idash. https://official.bankspower.com/density/
    Saltyhero13 and Mdl like this.
  12. Oct 10, 2023 at 7:16 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yeah been eyeballing the Banks iDash. It is well supported with a variety of sensors just wish they didn't use proprietary log data.
    Mdl, Silver17 and HulkSmurf14 like this.
  13. Oct 11, 2023 at 3:48 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    IAT nonsense.
    so it's a frigid 70 degrees, 100 humidity & raining.
    my IAT delta is that same as it ever was...27 degrees.
    I would have thought all that water hitting the inter-cooler would have made a difference.
    I even got behind a semi, to get in all the mega-spray.....nope, 27 degrees.
    what kind of heat exchange, thermo-dynamic witchery is this?
    it bolsters my ruminations that there ain't a whole lot you can do to lower IAT.
    it's all about heat soak.
    with that said...cool, thick, humid air is marvelous. I get a smidge more whine & exhaust notation.
    This Friday my goal is to do 50% of these:
    77.5mm pulley
    TRD air box install - stock girth
    trans drain & fill
    center diff drain & fill
    front diff drain & fill
    fix the fvckin' boost gauge molex connector thing. (I'm not sure I have accrued enough cuss words yet to do this one.)
    my son will be in town, so indentured servitude will be utilized.
    Mdl, e30cabrio, Wynnded and 1 other person like this.
  14. Oct 11, 2023 at 5:02 AM
    nags
    nags New Member
    It's the X.
  15. Oct 11, 2023 at 5:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    THAT'S the damn molex connector I'll be messin' with Friday.
    thanks for the picture.
    Mdl and nags[QUOTED] like this.
  16. Oct 11, 2023 at 7:17 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    This supercharger project has been eyeing opening experience for me. One thing I considered but due to the fact that I have the TRD exhaust ( which doesn’t bother me at all) I thought it was not necessary to change out the exhaust after putting in the supercharger.
    I know some people say start with the exhaust first but I didn’t. I have a 2019 tundra TRD Pro and wanted to know if you changed out your exhaust or kept the stock TRD Pro with your supercharger. If you changed out your stock trd exhaust what exhaust did you goto and why ?
    Also did you change out your headers as well
    Mdl likes this.
  17. Oct 11, 2023 at 7:18 AM
    nags
    nags New Member
    No need to change your exhaust.
  18. Oct 11, 2023 at 7:30 AM
    Saltyhero13
    No need but I've seen people x-pipe their TRD duals to recoup low end torque loss; I don't think it matters with a supercharger.
  19. Oct 11, 2023 at 7:40 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Prospeed's tune with an 80mm pulley on a Harrop told a different story for me.
    Wynnded likes this.
  20. Oct 11, 2023 at 7:41 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    And that story is?...
  21. Oct 11, 2023 at 7:51 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Probably to spend another $1000.00
    nags likes this.
  22. Oct 11, 2023 at 7:55 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    you can get to ~500whp with the TRD exhaust. no problem.
  23. Oct 11, 2023 at 8:03 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    You've seen my posts. Shot gunned cats
    Edit: You drive like a grandpa
    Mdl and nobodyintexas[QUOTED] like this.
  24. Oct 11, 2023 at 8:05 AM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think about what happened to you fairly regularly. There's some good sized hills around me and when I'm towing I'll be in boost at 10.5 AFR (maybe even richer) for minutes at a time, and I have stock 300k mile cats and exhaust and had the blower on now for 80k+ miles. I think what happened to you was a fluke, or my cats are just full Hulk handling the extra fuel like a champ.
    mustang67408, Mdl, e30cabrio and 3 others like this.
  25. Oct 11, 2023 at 8:06 AM
    Saltyhero13
    RE: Wet heat exchanger.
    I've only noticed a drop in temps after running through an automatic touchless car wash never through torrential rain. Here is a test of the theory:
    https://youtu.be/O0MY0diHo4U?si=5C0dzaZiuEdFmSOs
  26. Oct 11, 2023 at 8:06 AM
    VWTim
    Corvallis, OR
    Ahh, you seem to be the anomaly here tho. I don't have enough hard miles to chime in yet with experience. Did you ever check if they left component protection on in your tune? Just thinking of reasons it would spit cats so quickly.
    Mdl likes this.
  27. Oct 11, 2023 at 8:13 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Being a fluke would be just another cherry on top with my experience throughout this build. At least I was able to keep my trd cat back.
  28. Oct 11, 2023 at 8:17 AM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Component protection. You're the first to mention that in my year battle with a "ready to go" kit from PS with their tuner via remote.
    Mdl likes this.
  29. Oct 11, 2023 at 8:24 AM
    ToyFan
    ToyFan New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    Jay from Banks here. The iDash logs .csv files. You can play it back on the iDash, or open it in Microsoft Excel, any spreadsheet viewer regardless of platform, just about any professional data log analysis tool or Banks' free analysis tool datalogviewer.com.
  30. Oct 11, 2023 at 8:37 AM
    snivilous
    SW UT
    Component protection is additional fueling added based on a calculated (assumed) cat temperature. It's kind of an airflow/duration additional fueling the truck can do. The original TRD tune attempted to modify and use component protection to ramp up fueling during extended boost, albeit it's kind of a funky method. Most people either turn it off entirely or disable the fueling designed to "protect" the cats, actually I'm not aware of anyone that leaves it functioning as it's original intended purpose just since we are already running rich enough to begin with.
