General Supercharger Thread
  1. Jul 28, 2023 at 9:27 PM
    #9721
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I purchased this from Amazon.. should be here by the time I wake up. Planning to unscrew the gauge currently on the regulator and screw this in and place under windshield wiper like you're saying.
    https://www.amazon.com/dp/B00VV29NHM?ref=ppx_yo2ov_dt_b_product_details
  2. Jul 29, 2023 at 12:01 AM
    #9722
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    You could back probe after the the fuel control module by rear tank. Is it leaning out at a specific time. Mine seemed happened from 4-5 shift. Are you running a walbro or dw pump? Walbro's are hit and miss but I always seem to go back to them.
    Remember to back off if too lean...
    V10Ace[QUOTED] likes this.
  3. Jul 29, 2023 at 12:05 AM
    #9723
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Walbro 450. Honestly I cant follow the behavior of the wide band at this point.. its swinging all over under any partial throttle.
  4. Jul 29, 2023 at 1:03 AM
    #9724
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    After a little reading...heat soak in fuel rails and injectors can cause it to lean out. Also having the afr sensor too close to exhaust manifold will lean out from excessive exhaust heat. Goes along with Aem and Innovate minimum distance from manifold. Just a thought...are you running above 1/4 tank? I had issues of losing suction from modifying the fuel canister. Why I went with the 267 model of the 450 walbro in a ffv canister. Hope all goes well with fuel psi test.
    reywcms likes this.
  5. Jul 29, 2023 at 6:00 AM
    #9725
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Wideband readings will definitely bounce back and forth during driving etc but what matters is when you’re on it if it’s holding the target afr tuned.
    nobodyintexas likes this.
  6. Jul 29, 2023 at 6:30 AM
    #9726
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From everything that I've read, the closed loop AFRs will oscillate back and forth a bit. I think of it like the way we have to make steering corrections back and forth even when driving in a straight line. I think that if you graph the signal of the sensor, it's a sine wave. Voltage deflection is limited though and that's probably where fuel trims come in, to bring it within range of the sensor. Then you're just riding the wave!
    reywcms[QUOTED] and e30cabrio like this.
  7. Jul 29, 2023 at 6:54 AM
    #9727
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  8. Jul 29, 2023 at 7:36 AM
    #9728
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this
    mine jumps around 14.2-14.8. When I drive normal. Avg is 14.7ish
    when I get to PE, it goes straight to 10.5ish
    I love the sounds it makes in PE
    Mdl and e30cabrio like this.
  9. Jul 29, 2023 at 7:39 AM
    #9729
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I checked on my header order today, when I ordered them from extreme terrain they said they have them in stock and I should see them today. It turns out they don't stock them, they just say that on the site, they said they will ship 8/22. Hopefully they do, that will still be a few months faster than Prospeed.
  10. Jul 29, 2023 at 7:40 AM
    #9730
    e30cabrio
    I hate that shady ass shit. Sorry.
    Mdl, reywcms, Wynnded and 1 other person like this.
  11. Jul 29, 2023 at 8:30 AM
    #9731
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    What's the range of swinging? Is it instantly jumping around or ramps up and down?
  12. Jul 29, 2023 at 8:46 AM
    #9732
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Instantly and for no reason is swinging from mid 9's to 17's. It hangs out mostly, albeit erratically, beteeen 11-13 under partial throttle. Before headers and new placement, it would stay within 0.5 variance under partial throttle and continue to get richer with more throttle applied.
    Fuel pressure tester kit is here but doesnt have an 1/8 npt for the regulator naturally
    Mdl likes this.
  13. Jul 29, 2023 at 9:17 AM
    #9733
    snivilous
    SW UT
    Wow that's weird! Doesn't sound like a fueling issue. Could be a bad sensor? Maybe got compromised during the swap?
    If you move the bung I would consider adding multiple while you're in there and cap off the ones you don't use. Then you could try a variety of spots. Maybe add one further down, one off a primary, further down a primary, etc.
    V10Ace[QUOTED] and Mdl like this.
  14. Jul 29, 2023 at 10:31 AM
    #9734
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    It seems the readings are delayed. As if the sensor is simply in the wrong spot. Aem says 18" from exhaust port and the bung on these Kooks down past the collector is well beyond 24". Gauge swings toward rich (high 9's, low 10's) like before while WOT.. just delayed. Normal driving numbers are all skewed and dont make sense based on throttle input.
    Been to 4 different local hardware stores to try and adapt the 1/8" female npt on the regulator to the hose w/ gauge on the kit I purchased with no luck. About to tape my phone with flashlight on under my hood and drive around
  15. Jul 29, 2023 at 10:34 AM
    #9735
    e30cabrio
    I have this on my FPR:
    https://www.amazon.com/gp/product/B07QWJZ4Z1?ie=UTF8
    It allows this under the hood:
    https://www.amazon.com/gp/product/B001O06BGM?ie=UTF8
    And the sensor for the AutoMeter.
    Mdl and V10Ace[QUOTED] like this.
  16. Jul 29, 2023 at 10:39 AM
    #9736
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is the sensor before your primary o2? Should be after it and nor inline as it will skew readings. Was the engine ran without the sensor plugged in? That can damage it. As @snivilous stated try a new sensor and a better location. I've had good luck with Baxter auto parts having fittings.
    V10Ace likes this.
  17. Jul 29, 2023 at 10:43 AM
    #9737
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Ace has that fitting
    Mdl likes this.
  18. Jul 29, 2023 at 10:44 AM
    #9738
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Primary o2's were moved to within ~4" of the heads, on the top of runners, per Prospeeds recommendation to avoid fuel trimming with long tubes. Wideband is below it probably ~18" and not in line. I tried Baxters with no luck unfortunately!
    Mdl[QUOTED] likes this.
  19. Jul 29, 2023 at 10:45 AM
    #9739
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Im planning to go back out and try Ace. Looks like a male 1/8 npt to female m12 would work.. which 2 of the 4 stores i went to were out of lol
    reywcms[QUOTED] likes this.
  20. Jul 29, 2023 at 12:55 PM
    #9740
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Drove around with gauge hooked up. Fuel pressure is dropping while on the pedal. At idle it'll hold 60 base pressure and then drop to 50 a few seconds later and hold there.
  21. Jul 29, 2023 at 3:08 PM
    #9741
    snivilous
    SW UT
    I despise whoever designed the tundras fuel tank. The gas light comes on with 8 gallons left, but the truck will starve for fuel if I have less than a "quarter tank", which means full throttle is risky below essentially a half tank. Whoever set that up was a fucking moron. I can live with shitty fuel mileage, but the fact I have to fill up almost every time I leave the house to not worry about leaning out is insane.
    mustang67408, nags, e30cabrio and 7 others like this.
  22. Jul 29, 2023 at 4:19 PM
    #9742
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    Do these issues go away with an upgraded/ larger fuel tank?
  23. Jul 29, 2023 at 4:35 PM
    #9743
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So that’s confirmed linked and fuel cell lol
    snivilous[QUOTED][OP] likes this.
  24. Jul 29, 2023 at 4:38 PM
    #9744
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous. Is it a fuel issue loosing suction/air with the walbro 450lph model 274 pump? When I modded the fuel canister for the aeromotive 340 it would suck air when taking off with less than 1/4 tank. May have contributed to my blown engine. Didn't want to risk it again. Running the ffv canister with the 267 model with less than 1/8 tank didn't run into issues with the new tune.
    mustang67408 and reywcms like this.
  25. Jul 29, 2023 at 4:42 PM
    #9745
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Walbro 267 here no issues. When I first did the Maggy I threw in a 340 aeromotive and it was faulty from new. Super annoying
    Fastlane47 likes this.
  26. Jul 29, 2023 at 5:15 PM
    #9746
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Can't even do a fuel mat because non of the bottom surface of the tank is flat enough lol.
    Fastlane47, snivilous[OP] and Mdl like this.
  27. Jul 29, 2023 at 5:23 PM
    #9747
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    After the aeromotive fiasco I bought walbro fuel pucks and was going to have 2 in the back and one mid tank. Decided to just get a new canister and pump.
  28. Jul 29, 2023 at 6:14 PM
    #9748
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I used a fuel puck on my duramax lift pump inrake...it grabbed ALL the fuel from the tank and was easy to install. You're committed once you drill a hole in the bottom of your fuel tank though...
    mustang67408 and snivilous[OP] like this.
  29. Jul 29, 2023 at 6:57 PM
    #9749
    snivilous
    SW UT
    My setup is essentially totally stock with the fuel basket, so I haven't put much brain power into making it better. When I had the aeromotive 340 I dont remember ever having an issue but was making a lot less power then.
    mustang67408 likes this.
  30. Jul 29, 2023 at 6:58 PM
    #9750
    snivilous
    SW UT
    Was telling the wife that actually :D not much point to sell the Tundra, and it already gets horrible gas mileage like it would as a prerunner and then I can throw a 50+ gallon cell out back!
