General Supercharger Thread
  1. Jul 16, 2023 at 11:28 AM
    #9571
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Agreed 200% happy! I have the heimholtz, didn't install it.
  2. Jul 17, 2023 at 6:49 AM
    #9572
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I noticed a difference from running the DD muffler delete then adding carven tr mufflers back in. It picked up .2-.3 lbs of boost. Figured out the Evap issue so replacing a few parts then I’ll schedule the tune session
  3. Jul 17, 2023 at 7:04 AM
    #9573
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    For those of you running 35s and mid 600hp which is a stage 3 blower?. Are your dragy times better or worse than the 2023 F150 Raptor's 3.7 sec 0-60? (Raptor comes with 35s which is why I point that out).
    Wife's 392 Wrangler stock setup has 35s and runs a 0-60 in 4.5 sec.
    Just curious.
  4. Jul 17, 2023 at 7:04 AM
    #9574
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    what are the '23 Raptor dragy numbers?
  5. Jul 17, 2023 at 7:08 AM
    #9575
    1UP
    1UP Truck Gang
    I edited the post, sorry. 3.7 per the interwebs
  6. Jul 17, 2023 at 7:17 AM
    #9576
    nobodyintexas
    nobodyintexas What?
    South of Houston
    TFL got 7.5 seconds last year. yes, it was hot.
    The Raptor R is probably what you are inquiring about. it is a comparable S/C v-8...albeit >$108k
    Winks4x4Toy likes this.
  7. Jul 17, 2023 at 7:21 AM
    #9577
    1UP
    1UP Truck Gang
    Yeah Raptor R. 3.7 vs. 7.5 ? Good grief even with 600hp our truck is still slow. I was hoping I'd hold a candle to the Jeep at least.
  8. Jul 17, 2023 at 7:23 AM
    #9578
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    392 jeep was no problem to outrun from a roll.
  9. Jul 17, 2023 at 7:26 AM
    #9579
    nobodyintexas
    nobodyintexas What?
    South of Houston
    We REALLY need a 10sp trans.
    my Stock Wheels & susp gets 5.1-ish other folks are getting mid 4's on hotter setups.
    but, I don't race it....it is now perfection with on-ramps, towing, etc.
    WCTXN, Winks4x4Toy, kos221 and 2 others like this.
  10. Jul 17, 2023 at 7:27 AM
    #9580
    Saltyhero13
    Saltyhero13 Throbbing Member
    TFL is also at elevation in Colorado I think.
  11. Jul 17, 2023 at 7:28 AM
    #9581
    nobodyintexas
    nobodyintexas What?
    South of Houston
    and....I FINALLY got my AEM boost gauge to work consistently. I had to push the connection in the back HARD.
    the cause...when the steering wheel tilts up, when I turn the engine off, is jack-farting with the connection.
    life is still good.
    Silver17, HulkSmurf14, 1UP and 2 others like this.
  12. Jul 17, 2023 at 7:29 AM
    #9582
    Saltyhero13
    Best dragy we've seen with a Tundra on 35s is ~4.5ish we just can't post them here.
  13. Jul 17, 2023 at 7:29 AM
    #9583
    nobodyintexas
    nobodyintexas What?
    South of Houston
    that's Colorado's fault.
    Saltyhero13[QUOTED] likes this.
  14. Jul 17, 2023 at 7:35 AM
    #9584
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    Are you getting a check engine light?
  15. Jul 17, 2023 at 7:46 AM
    #9585
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Stages is a retarded term imo, unless some manufacturer specifies it. The only people that are remotely close to 3.7s have built engines, which is Viktor and @Winks4x4Toy (though not sure what Winks time is). @Silver17 and I might be the next closest with verified times on this forum, with my truck doing 4.5s (4.3s subtracting the 1ft roll out, so like what a drag strip time would give). And my truck is on 35s with 5.29s, and still is far flung from 3.7s.
  16. Jul 17, 2023 at 7:54 AM
    #9586
    e30cabrio
    What was the evap solution? I cannot get it to report ready (not that it matters.) But I hate things not being right.
    reywcms[QUOTED] likes this.
  17. Jul 17, 2023 at 7:58 AM
    #9587
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Mine is gross leak code, found a problem with my filler neck and maybe the canister. I'm going to replace the filler neck first and hoping I don't need a canister but we shall see.
  18. Jul 17, 2023 at 8:08 AM
    #9588
    e30cabrio
    Gotcha, I have no codes, just INC on the readiness.
  19. Jul 17, 2023 at 8:12 AM
    #9589
    1UP
    1UP Truck Gang
    Yeah these guys do https://nationalspeedinc.com/packages/toyota/toyota-truck/2007-2021-tundra/tundra-xk50-platform/ and I thought others did but I see your point.
    I was just curious how far away 610(ish) hp was from the Raptor R. Seems like I'd be on par with the Jeep, which is fine. Everytime I fire that thing up I think about how I need long tube headers in my truck.
    All the Cat codes and work arounds I see in here always bring me back to reality.
  20. Jul 17, 2023 at 9:00 AM
    #9590
    Saltyhero13
    The Nat Speed stages are just how they name their packages. Like Sniv said each vendor has different meaning to their stages.
    The only somewhat consistent thing I've seen is Stage 1 is usually a big pulley w/ or wo/ a tune. Stage 2 is usually a smaller pulley with other supporting upgrades. After that it all goes to shit.
    If you use Nat Speed best way to approach it is by looking at HP goals. Their most expensive kit for Harrop runs on E85 (Stage 4 but their website doesn't render properly). If you want more HP than what that offers you will need a built engine. At that point I would probably work with ProSpeed.
  21. Jul 17, 2023 at 9:03 AM
    #9591
    nobodyintexas
    nobodyintexas What?
    South of Houston
    and if you do a Stage 2 Harrop -but you don't change the stock intake....it's really only a stage 1.5.
    ask me how I know.
  22. Jul 17, 2023 at 9:39 AM
    #9592
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Yes, its been on for months.. cat codes
    reywcms likes this.
  23. Jul 17, 2023 at 9:40 AM
    #9593
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    It's down a significant amount compared to before. Won't even spin the tires from a stop now lol
    Mdl[QUOTED] likes this.
  24. Jul 17, 2023 at 9:44 AM
    #9594
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Are you sure all of the cat material is out of the exhaust? Could have some blockage? That will definitely make it run worse.
  25. Jul 17, 2023 at 9:46 AM
    #9595
    e30cabrio
    Driving 98% street like a maniac has seen my MPGs drop to 7. As a result I have been in 2WD & driving much less exuberantly to see what I can get if I chill out.
    In 4WD, I rarely broke the tires loose (Cooper AT3+ 295 70 18s) in 2WD I can barely give it any gas & they chirp.
  26. Jul 17, 2023 at 10:00 AM
    #9596
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I cut everything open and welded back myself.. it's cleared out. 3" all the way next week.. going to do a compression test also for peace of mind
    Silver17, Mdl and reywcms like this.
  27. Jul 17, 2023 at 10:02 AM
    #9597
    Bluecobra
    2014 Tundra
    Hmmm, when mine blew out the cats the only difference was it got louder and the cat code was activated. It still ran good, maybe better. It was a while back so I don't remember.
  28. Jul 17, 2023 at 11:37 AM
    #9598
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I had one off brand metal cat implode and blocked up. The welds for the cells came loose and was plugged in the back. Just seemed off driving with no codes. Luckily it was the front one so now I'm down to one each side.
    Dropped the tank and installed the ti450 with the FFV canister. It fit well. The orientation is different and had to make a new 6AN supply line to get another 3 inches. Good flow and psi. Now to install @snivilous hpt tune and do some data logging this afternoon.
  29. Jul 17, 2023 at 11:52 AM
    #9599
    e30cabrio
    I heres a side by side of the 450 & FFV pumps, they looked the same to me.
  30. Jul 17, 2023 at 12:06 PM
    #9600
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I didnt want to cut up the canister. I installed an aermotive 340 on the initial install of the SC in 2015. Drilled a few holes and at clamp area. At a little less than 1/4 it would lose suction. Just didnt want to deal after one engine and transmission replacement. Thanks to @Silver17 for the info. The 267 model fit, only draws 14 amps, and I found a 30 micron pre-filter that needed a little modification to fit, trim plastic foot area. The venturi system is larger than the non ffv canister. We'll see how it holds up.
    Silver17 likes this.
