General Supercharger Thread
  1. Jun 30, 2023 at 4:21 PM
    #9331
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Never thought to ask about it for the Tundra s/c, but on the Tacoma there's a brass restrictor jet you can remove from the bypass valve that when done you can actually feel the improvement in throttle response.
    I'm guessing that's not a thing on the tundra?
  2. Jun 30, 2023 at 4:33 PM
    #9332
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd have to go look.....
  3. Jun 30, 2023 at 6:01 PM
    #9333
    M3Tundra-JK
    Scott
    2005 GX470
    I'd check mine but it's all boxed up
  4. Jun 30, 2023 at 6:32 PM
    #9334
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Yup, it's there.
    M3Tundra-JK[QUOTED] likes this.
  5. Jun 30, 2023 at 6:46 PM
    #9335
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  6. Jun 30, 2023 at 6:48 PM
    #9336
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, mine has one. There are no markings on it. A 0.036in drill bit will fit through it with some play, but a 0.037in will not.
    Saltyhero13 likes this.
  7. Jun 30, 2023 at 6:49 PM
    #9337
    e30cabrio
    So do we leave it out?
  8. Jun 30, 2023 at 7:04 PM
    #9338
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ¯\_(ツ)_/¯Dunno, I haven't plans to use the truck in the next day or so....but I haven't reinstalled it yet either. :rofl:
    I'm not coming up with any hypotheses for it's function, why the hole might be the size it is.
  9. Jun 30, 2023 at 7:06 PM
    #9339
    e30cabrio
    Mine is out, the hose is on.
    I had no plan to go anywhere.
    Lol
  10. Jun 30, 2023 at 7:13 PM
    #9340
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You're more motivated than me, I left everything sitting on the blower. I didn't even close the hood all the way.
    (This is like a 'who is lazier' contest.) ;)
  11. Jun 30, 2023 at 7:17 PM
    #9341
    e30cabrio
    In my defense it is 110 in my garage.
    Also, my upstairs AC is not cooling so I'm sleeping on the couch downstairs oh & my wife is stuck in New Orleans because she got covid and can't fly.
    Wynnded likes this.
  12. Jun 30, 2023 at 7:18 PM
    #9342
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Looking at the pictures in the first post, it looks like there are two hoses on the Harrop bypass and it looks similar to the Maggie one; I can't see the bypass on the picture of the Whipple.
    e30cabrio likes this.
  13. Jun 30, 2023 at 7:23 PM
    #9343
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I guess I can't blame you.
    It's beautiful here and 58F. Motorcycle weather actually. :bikewheelie2:
  14. Jun 30, 2023 at 8:34 PM
    #9344
    M3Tundra-JK
    Scott
    2005 GX470
    Ya, leave it out!! It's one of the core mods over on the Tacomaworld supercharger thread
  15. Jun 30, 2023 at 8:38 PM
    #9345
    M3Tundra-JK
    Scott
    2005 GX470
    From page 1 of the Tacoma Magnuson Tips and Trucks page https://www.tacomaworld.com/threads/trd-magnuson-4-0-supercharger-tips-tricks-and-mods.518932/
    Restrictor jet mod:
    A now well known (and free) mod which involves removing hose from factory bypass valve in the rear of the supercharger to a port in the rear of supercharger itself. There is a small brass colored restrictor jet either stuck on the bypass valve vacuum port, or gets sucked into the hose. Remove it for better overall vacuum at idle and cruising, better bypass valve functionality (now moves as quick as the throttle body can) and better boost consistency. Added bonus is you gain back boost you should have with the pulley in place. Tested and run by yours truly, no problems.
    Post showing restrictor jet stuck in hose:
    https://www.tacomaworld.com/threads/trd-supercharger.4313/page-230#post-16411228
    Posts showing restrictor jet removed:
    https://www.tacomaworld.com/threads/trd-supercharger.4313/page-226#post-16409460
    https://www.tacomaworld.com/threads/trd-supercharger.4313/page-226#post-16410123
    The factory hose from bypass valve to supercharger leaks due to being oversized. It is advisable to either replace it with a smaller ID hose or to clamp it.
  16. Jun 30, 2023 at 8:50 PM
    #9346
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Curiosity will have gotten the best of me by tomorrow. I'll take mine for a drive without the jet and share what I feel.
    M3Tundra-JK likes this.
  17. Jun 30, 2023 at 8:51 PM
    #9347
    e30cabrio
    I just started it & revved, it jumps to 8.7lbs immediately.
  18. Jun 30, 2023 at 9:00 PM
    #9348
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmmm, I wonder if the jet is intended to cause the bypass to close more "progressively".
  19. Jun 30, 2023 at 9:04 PM
    #9349
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My hose pulled off the blower port rather easily, however I had to cut it from the bypass. I was first going to try it with the hose reversed and the freshly cut end stuck on the blower port. I'll probably dig out a clamp for it later though.
  20. Jun 30, 2023 at 9:18 PM
    #9350
    M3Tundra-JK
    Scott
    2005 GX470
    I removed it on the Tacoma before a long road trip, and noticed a big jump on the top end when passing those slow cars on back country "highways"
    It's a pia on the Tacoma cause it's at the rear underside of the s/c. Sounds like everyone should be doing it on the Tundra with how easy it is to get to
    HulkSmurf14 and Wynnded like this.
  21. Jun 30, 2023 at 9:38 PM
    #9351
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Now I'm wondering if there was one on the blower bypass for the 5VZ engine. Bet there was. But no one ever found a reason to remove the hose. Why would you ever think there was something in there?
  22. Jun 30, 2023 at 9:49 PM
    #9352
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Same bypass on the Whipple I’ll have to Look for this brass fitting
    M3Tundra-JK, e30cabrio and Wynnded like this.
  23. Jun 30, 2023 at 10:17 PM
    #9353
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I did this back in the day to my Tacoma...great for power, not so great for cruising. Caused surging during transitions between vacuum and boost, and it will increase your IAT. If you do it, do some logging to see what effect it has on your AFR and IATs.
  24. Jul 1, 2023 at 4:00 AM
    #9354
    Silver17
    Eastern PA
    I noticed no such fitting on the Harrop bypass.
  25. Jul 1, 2023 at 4:48 AM
    #9355
    Silver17
    Eastern PA
    You made me look at that Harrop pic on the first page. Mine only has one hose on the left port going to the blower. I don’t have a hose installed on the front facing port. I don’t think there is supposed to be a hose on there… what about you other guys with the Harrop?
    e30cabrio and Wynnded[QUOTED] like this.
  26. Jul 1, 2023 at 6:25 AM
    #9356
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I'm sure that I do, but do any of you know if I will need to get more credits from HP on my new ECM? Since they aren't programed by Toyota with the vin, I'm not sure how HP can verify what ECM you are flashing.
  27. Jul 1, 2023 at 6:42 AM
    #9357
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ahh, maybe it's there to provide a dampening effect then, that might explain the vac/boost transitional surging. I could see where it could alter the AFRs, but not the IATs, at least at the stock MAF location.
  28. Jul 1, 2023 at 7:04 AM
    #9358
    Silver17
    Eastern PA
    If you contact HPtuners and tell them you bricked the ECU they may not make you pay for more credits in order to flash your replacement ECU, you may just have to provide the new ECU ID number or something. If by chance you got a replacement ECU with the same ID/calibration number then maybe it will work without doing anything?
  29. Jul 1, 2023 at 7:15 AM
    #9359
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Only one hose it connected, the other barb is open to atmosphere.
  30. Jul 1, 2023 at 7:39 AM
    #9360
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Had a brain fart, was thinking about post-charge temps like with the Harrop.
