General Supercharger Thread
  1. May 30, 2023 at 11:34 AM
    #8641
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Do it, the more scientific answers we have the better, since 99% of modifying things is assumptions.
  2. May 30, 2023 at 11:40 AM
    #8642
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    To me it’s less about the power and more about reducing cylinder temps with cooler IATs for longevity’s sake.
    nobodyintexas, e30cabrio and reywcms like this.
  3. May 30, 2023 at 11:54 AM
    #8643
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    i did it by not following instructions closely enough during the install. Just left it that way. Of course, no idea if it made any difference
    e30cabrio and Silver17 like this.
  4. May 30, 2023 at 12:40 PM
    #8644
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Oh and I would recommend using a little compressed air to blow the metal coolant line out as some will get stuck in there and make a mess later. Some people cap them too but seems redundant to me, unless you’re doing a summer/winter switch over setup. The process is so fast though doesn’t seem worth the trouble (just do it manually twice a year).
  5. May 30, 2023 at 12:52 PM
    #8645
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    gonna get her dyno tuned tomorrow
  6. May 30, 2023 at 1:27 PM
    #8646
    Silver17
    Eastern PA
    Sounds awesome. Interested to hear if the stock size intake is a problem/restriction when dyno tuning. I’m sure it would be a little more power on at least the Maggie intake box.
  7. May 30, 2023 at 2:14 PM
    #8647
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ditto
    I’ll start the bidding
    480whp
    520tq
  8. May 30, 2023 at 4:21 PM
    #8648
    50Shades
    J
    West Coast
    very curious as well. if i can make more power il definitely get a bigger intake.
    sounds about right. il bet on that haha. if i can make at least 500 im happy
  9. May 30, 2023 at 7:30 PM
    #8649
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What are your accompanying mods with the Harrop?
  10. May 31, 2023 at 9:16 AM
    #8650
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pops rig update. Maggy box on and smaller blower pulley in. Waiting on tuning session appointment.
  11. May 31, 2023 at 9:37 AM
    #8651
    M3Tundra-JK
    Scott
    2005 GX470
    Whipple dimensions look weird. Fat snout, skinny body, fat base
    50Shades and reywcms like this.
  12. May 31, 2023 at 10:27 AM
    #8652
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, that Whipple looks lean.
    Black@Blue19 likes this.
  13. May 31, 2023 at 10:31 AM
    #8653
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Twinscrew less width needed.
  14. May 31, 2023 at 12:38 PM
    #8654
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    (Sorry random question). I thought I saw a post where someone put the (3.85”) maggie intake onto the Rcf throttle body without any modifications. I just got mine in the mail and the intake rubber will not go on the rcf throttle body easily (as expected its .3” wider). I was thinking to put it in boiling water and work it over the rcf, but was curious if other people had attempted this same situation and had any advice. I could also see someone just cut the very end and use an adapter but won’t look as finished.
  15. May 31, 2023 at 1:01 PM
    #8655
    50Shades
    J
    West Coast
    650cc injectors, upgraded fuel pump, csf radiator, and dual catch can
    ZPhilip[QUOTED] and HulkSmurf14 like this.
  16. May 31, 2023 at 2:13 PM
    #8656
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Snout is 102mm is why
  17. May 31, 2023 at 3:35 PM
    #8657
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @e30cabrio how did you like Xact as tuners? I may send pops over there since they have the dyne etc
  18. May 31, 2023 at 3:47 PM
    #8658
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Tim the owner is great, he knows his stuff. How else could I get 574tq/537hp?
    HulkSmurf14, M3Tundra-JK and reywcms like this.
  19. May 31, 2023 at 3:55 PM
    #8659
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sweet! Left them a message
    e30cabrio[QUOTED] likes this.
  20. May 31, 2023 at 4:54 PM
    #8660
    Silver17
    Eastern PA
    Well gents, it’s early yet but my initial impression after doing the TB coolant bypass is it does in fact do SOMETHING. My typical IAT before this mod once the truck was up to temp and cruising was about 37 degrees above ambient. After this mod and some initial testing with 15 minutes of driving and 5 minutes idling in between is that it has decreased that delta.
    It was 79-81 out today depending on when I looked at the OA temp on the truck. On the initial drive before it got super hot I was seeing a 15-19 degree delta at 96-100 degree IAT. I then parked it in the garage and let it idle and got the IAT up to 120ish to try and heat soak it a bit. I then took it back down the road again cruising at 60 (in and out of the throttle due to hills) and it was pretty much hanging out at 105 while slightly on the throttle and cruising at 60ish. That’s a 25ish degree delta. The temp would drop cooler when on the gas vs coasting as it pulled more cool outside air in and across the HX and sensor. Some pics are included.
    I’ll keep you all updated as I drive it more, but it appears right now it’s good for at least a 10 degree drop in IAT. I also pinned the transmission thermostat open to test that as well, and under my testing which included some aggressive acceleration the hottest I saw was 176ish at the pan at the end of the drive. I’ll be monitoring that as well.
  21. May 31, 2023 at 4:57 PM
    #8661
    e30cabrio
    I left My transmission thermostat pinned open when I retrofitted the oem cooler.
  22. May 31, 2023 at 5:25 PM
    #8662
    ZPhilip
    Philip
    West Chester, PA
    Thanks for the findings, doctor! Next mod on the list.
  23. May 31, 2023 at 5:29 PM
    #8663
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    what’s that coolant mod involve? Cap the TB ones and how do you run the coolant line?
  24. May 31, 2023 at 5:32 PM
    #8664
    ZPhilip
    Philip
    West Chester, PA
    Looks like 1 nipple, 2 caps and a zip tie. I might see another worm style hose clamp for good measure.
    Silver17 likes this.
  25. May 31, 2023 at 5:36 PM
    #8665
    Silver17
    Eastern PA
    Yup, bought a 5/16” barbed fitting which i would probably have upsized to the next size if I did it again. Just removed the 2 hoses to the TB and secure them together. It was not leaking with the 2 regular clamps but decided to put a worm gear in the center for extra insurance. I got the caps to make it clean and keep junk out of the TB.
    reywcms likes this.
  26. May 31, 2023 at 5:55 PM
    #8666
    50Shades
    J
    West Coast
    soo dropped of truck at the dyno, the gave my installer compliments how clean and how well mechanically the truck performs. another slight hiccup, didnt know D3 has their own software. my dyno tuner uses HP tuners. HP tuners cannot unlock D3 tuned ECU, well theres a way but lots of red tape involved..whatever. ordered D3 pro tuning software with their cable, so just waiting on that to arrive then finally we can get her tuned right.
  27. May 31, 2023 at 6:54 PM
    #8667
    Silver17
    Eastern PA
    If it’s as hard as getting the Harrop boot over the Maggie intake box, it’s gonna be a real bitch to be honest. I was able to handle the box lid roughly cause it’s just plastic. It’s gonna be hard to not damage the TB in the struggle. Your idea with boiling water might work.
  28. Jun 1, 2023 at 9:07 AM
    #8668
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    How was Prospeeds shipping time for everyone? (On day 8 just “order placed”). Anxiously awaiting the good stuff from them haha. Got a full stage (fill in the blank) coming in the mail.
  29. Jun 1, 2023 at 9:25 AM
    #8669
    M3Tundra-JK
    Scott
    2005 GX470
    it took i think a couple of weeks before fuel rails and lines got here, and they didn't respond to emails asking for shipping eta. i had to call them
    Ponderosa_Pine likes this.
  30. Jun 1, 2023 at 9:29 AM
    #8670
    snivilous
    SW UT
    I bought injectors and intake from them, and the intake they didn't have in stock but didn't say anything so on week two of waiting I called them, and they said they were waiting on the intake and I asked if I could get the injectors since that's really what mattered to me and they said sure if I pay more for shipping which I did. And then apparently out of coincidence the intake then came into stock like two days later and they shipped that. Ultimately took 3+ weeks to get my stuff.
