General Supercharger Thread
  1. May 26, 2023 at 7:24 PM
    #8611
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    finally got the truck back! jesus christ these big beast can move! sorta taking it easy for now, not sure if theres a break in period with the Harrop. but imma wait until i finish this full tank of gas first before sending it.
    slight hiccup, got codes for P0175 system too rich. popped after 30 miles of driving. cleared codes. drove 2 miles and hasnt come back yet. il do more driving tomorrow to see if it comes back.
    truck is tuned by D3
  2. May 26, 2023 at 7:54 PM
    #8612
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I was doing WOT logs with mine on the first day.. if there is a break-in period, oh well! A 5.3 Silverado wanted some at a light in Mexico today as I was on my way to get oil for my generator and the punishment was exciting considering I only get to drive my truck on the weekends. I'm running super rich (9's AFR) and have never seen that code... keep an eye on your cats each time you go WOT by looking at your exhaust tips lol
  3. May 27, 2023 at 7:37 AM
    #8613
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If that's the bank too rich code, then it seems to be triggered by the MAF being too far out of range. So it's not really based on how rich the truck is running, just how rich it's running compared to what it expects from the MAF. Not something to worry about too much, especially if it's a rich code, and if you cleared it and it hasn't come back then I wouldn't worry.
    Some tuners adjust the MAF values and others don't. Some trucks seem to have a smaller range than others and throw that code easier. Some of the tunes I've seen the MAF is off by 30% which should trigger it and it's fine, other tunes it's off by 25% and triggers it. I wouldn't worry about it unless it becomes a common repeating issue.
  4. May 27, 2023 at 6:25 PM
    #8614
    50Shades
    J
    West Coast
    oh i appreciate this response! i obviously still have a lot to learn haha so this gave me a bit of relief. it's pop the code again 2 more times driving about 20-25 miles each time it happened. but i will continue to monitor and keep you posted :) running rich is better than lean, the CEL is just annoying haha
  5. May 27, 2023 at 6:47 PM
    #8615
    50Shades
    J
    West Coast
    woops..threw a P0101 doing a half throttle pull. haha. wtf D3 never again
  6. May 27, 2023 at 7:14 PM
    #8616
    snivilous
    SW UT
    I wouldn't rule them out yet, it usually takes a few tune revisions to get it dialed in. I've tuned (or helped) a few guys on the forum and it's not uncommon to get a lean or rich code, and is usually an easy and quick fix. Hell, right around the time you posted earlier @Fastlane47 sent me an email that a tune I sent a few days ago was throwing a lean code! And his datalog only had the MAF out of wack below 2000rpm.
    To be fair though I don't know your circumstances and if it was tuned in person or remotely or how their datalogging works, but it's definitely a common issue and usually a quick and simple fix!
  7. May 27, 2023 at 7:53 PM
    #8617
    50Shades
    J
    West Coast
    sorry, waited 2 days for the revision and this was the result, i guess to be fair its memorial day weekend and everyone is excited for the long weekend and probably just missed something haha. all good thanks for letting me vent!
  8. May 27, 2023 at 8:35 PM
    #8618
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I needed a revision on my Dyno based tune to get it right.
    50Shades likes this.
  9. May 28, 2023 at 5:43 AM
    #8619
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  10. May 28, 2023 at 5:48 AM
    #8620
    e30cabrio
    ^Woot!
    On the way home from LA p101 2x
  11. May 28, 2023 at 9:25 AM
    #8621
    50Shades
    J
    West Coast
    quick question, trd intake is technically stock, will it fit with the harrop? ive looked everywhere and cant seem to find pictures with it
  12. May 28, 2023 at 12:36 PM
    #8622
    snivilous
    SW UT
    This was the last datalog you sent me on May 1st, and the MAF was quite a bit off so not surprised. The code usually seems to trigger around +-25, so you had a bit of room left but at 2.8V you were at 18% out of wack. Green indicates the long term fuel trim is leaned out (ie the truck is running richer and is compensating) so would make sense you had a rich code.
    Of course, take everything I say with a grain of salt, I am NOT a tuner and every tune and person does their stuff differently. Just showing the values you had for your long term fuel trims a month ago.
  13. May 28, 2023 at 1:16 PM
    #8623
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    When I've been messing with mine, which seems to be all the time:rolleyes:, I've noticed that if I try to adjust using the "exact" percentage, it tends to over compensate, even on the same test drive loop. I usually go with half the percentage. I've wondered if it's at least in part due to the larger injectors. Have you noticed anything similar?
  14. May 28, 2023 at 2:08 PM
    #8624
    e30cabrio
    It's weird, I had not gotten that in over 500 miles, Xact sent a new tune after that datalog, I'll do a new datalog & we'll see where it is now.
    Also, things are running pretty well.
    1 degree between ambient & IAT & high coolant temp is 203.
    Is that 404 range not found?
    snivilous[QUOTED][OP] likes this.
  15. May 28, 2023 at 3:22 PM
    #8625
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    So completely out of left field, but I had to share. I ordered a set of plugs and they came in today, I have 7 of what I ordered and one XU22HDR9, lol. PXL_20230528_222015802.jpg
  16. May 28, 2023 at 4:16 PM
    #8626
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Yes this is mine (3.60” ID) before I went with Maggie intake (3.86” ID) . Not to be confused with the TRD intake that comes with the supercharger kit.
  17. May 28, 2023 at 5:08 PM
    #8627
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Haha
    Fastlane47[QUOTED] likes this.
  18. May 28, 2023 at 5:55 PM
    #8628
    50Shades
    J
    West Coast
    youre awesome! based on this pic, im guessing you obly replace the top cover part and the aie accelerstor
  19. May 28, 2023 at 7:16 PM
    #8629
    ZPhilip
    Philip
    West Chester, PA
    I replaced the airbox upper and lower. The earlier year 2nd gen had the larger lower airbox that can be reused with the larger upper. And I did remove the air accelerator because I don’t think it can be used on the Maggie upper. I will be doing the SABM so I’ll have another 3” air inlet feeding it.
    The Harrop coupler does stretch to fit the larger MAF housing but is quite difficult to get on there.
    50Shades[QUOTED] and Fastlane47 like this.
  20. May 28, 2023 at 7:36 PM
    #8630
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I feel this is an understatement. :rofl: If I didn’t know it could be done based on others saying so I’d have given up and not seen it through.
  21. May 28, 2023 at 7:42 PM
    #8631
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Accelerator fits the maggy box and works well with the SABM.
    Fastlane47 likes this.
  22. May 28, 2023 at 8:58 PM
    #8632
    snivilous
    SW UT
    I haven't, I just change by the % and it seems to be on the money pretty consistently.
  23. May 29, 2023 at 6:20 AM
    #8633
    ZPhilip
    Philip
    West Chester, PA
    Good to know. I might try that
    reywcms[QUOTED] likes this.
  24. May 29, 2023 at 6:20 AM
    #8634
    ZPhilip
    Philip
    West Chester, PA
    Totally agree with that.
    Silver17[QUOTED] likes this.
  25. May 29, 2023 at 12:53 PM
    #8635
    Silver17
    Eastern PA
    The soot on the tailpipes after pulling the camper around for 300 miles has me praying for those cats! Ran great on the highway though in S5, TC locked at 65mph. Left the new Silverado behind me pulling a TT half the size for dead on the hills and didn’t even unlock the TC lol. It really holds speed and gear like a honey badger. Got 9mpg out and 7.5 coming back. Im a broken record I know, but I love this thing more every time I hook the trailer up.
  26. May 29, 2023 at 12:58 PM
    #8636
    e30cabrio
    I averaged 11 city & 14 highway on the 700 mile round trip to L.A. Friday to Sunday.
    After the pump repair fuel pressure was up from 44 at idle (tune set) to 50. I set it back to 44 when I got home yesterday.
    Silver17 likes this.
  27. May 30, 2023 at 10:58 AM
    #8637
    Silver17
    Eastern PA
    Thinking of trying that TB coolant bypass to see if it actually does anything. Since I pretty much have my intake temps figured out consistently post SC intercooler I should be able to get a definitive answer on if it actually does a damn thing or not. If it does, I’d probably plumb in a bypass to open for summer and close for winter like previously discussed. Doesn’t seem like anyone has ever actually measured temps before and after the TB to see if the bypass mod does anything. I’m a little skeptical due to the relatively small area of the TB and the speed and volume of the air passing through it.
  28. May 30, 2023 at 11:08 AM
    #8638
    e30cabrio
    It's super easy, I ran a single hose between the two points the TB was connecting to. I mean, it's never under 50 here in the depths of "winter" It's been "mild" so far not over 105 yet & still getting down to the 70s at night. (usually by now, never under 90 & as much as 120.
  29. May 30, 2023 at 11:12 AM
    #8639
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I was thinking of this but like you said Im skeptical for the same reasons.
  30. May 30, 2023 at 11:13 AM
    #8640
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I’ve done the bypass since 2017 on Tundras in below freezing without any issues. If you lived in the midwest or interior of Alaska I would switch it back in the winter, otherwise the engine heats up everything just fine. If you run your truck, hop out and touch the throttle body it’s likely 200f as-is.
    e30cabrio, Silver17 and reywcms like this.
