General Supercharger Thread
  1. Apr 26, 2023 at 6:21 AM
    #7951
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You could try this method from the HPTuner Forum:
  2. Apr 26, 2023 at 6:28 AM
    #7952
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Here are 2 examples, I'll send Xact that info, thanks.
    Wynnded likes this.
  3. Apr 26, 2023 at 6:35 AM
    #7953
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    @Wynnded post would explain it, when I looked at your log the fuel trims were off by over 30% in some cases and 20% almost across the board.
    Wynnded likes this.
  4. Apr 26, 2023 at 6:40 AM
    #7954
    e30cabrio
    Is it possible the addition of the adaptor to allow 2 gauges at the FPR could do this? Outside the replacement hose, that is the only change.
    Looking at that picture, I realized I also cut down the boost reference hose so It's not curling like that.
  5. Apr 26, 2023 at 6:58 AM
    #7955
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I like it mounted there more than the prospeed recommended firewall placement!
    e30cabrio[QUOTED] likes this.
  6. Apr 26, 2023 at 7:10 AM
    #7956
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    The additional gauge sensor and adapter wouldn't have caused any changes to the system, more likely that the tuner needs to adjust the fueling with the information that Wynnded pointed out, and pretty much confirmed with the fuel trims that snivilous was seeing in your logs.
    Before taking back to tuner, you might want to go over the connections and make sure nothing is leaking. Can you reach your hand up on top of the tank and feel if the feed hose is also not leaking while the engine is running? I know it's a tight fit, but I was able to get my arm up there and feel around on my connections.
    The regulator looks good mounted there, and has a clear shot at both rails and the return, but if I might make a suggestion...I would move the side port on the regulator to the other side, so you don't have the extra hose and loop. If you make any adjustments, double-check the base fuel pressure again to make sure it didn't move.
  7. Apr 26, 2023 at 7:17 AM
    #7957
    e30cabrio
    There are no leaks, I know because that is the first thing I checked & the truck lives in my garage & it stinks of gas if there is any leak at all.
    When I replaced the hose I intended to move the port back there & got sidetracked. I'll definitely do it, thanks.
    Thanks!
    armyoffoo likes this.
  8. Apr 26, 2023 at 7:37 AM
    #7958
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I don’t know what all is involved, but I’ve seen it mentioned that you can totally delete the FFV crap. I think it involves getting a non FFV ECU and then deleting all the hardware components, which I think has mostly been done already from the sounds of it.
    e30cabrio likes this.
  9. Apr 26, 2023 at 10:55 AM
    #7959
    e30cabrio
  10. Apr 26, 2023 at 2:27 PM
    #7960
    e30cabrio
  11. Apr 26, 2023 at 7:07 PM
    #7961
    snivilous
    SW UT
    I finally hooked up my gauge to HPT today (with assistance from @ZPhilip ) and used this one: https://www.amazon.com/gp/aw/d/B00IDSM6BW?ref=ppx_pop_mob_b_asin_title
    I now understand why some of your logs didn't have the gauge working, mine has some inconsistency too but it seems to be an issue with the datalogger since the gauge can always talk to the computer through the Innovate software, but the log doesn't always want to see it for some reason. I haven't messed with it much since getting it all working, though that was a head banger to get it talking to the logger.
    HulkSmurf14 likes this.
  12. Apr 26, 2023 at 7:13 PM
    #7962
    e30cabrio
    The old one I have on every boot up says it is not compatible with Win11. I found a fix, but I have to go in to Device Manager & uninstall (including drivers) & do a hardware scan.
    Considering I bought it in 2017 to talk to Sun servers in Putty, I don't care I have to get another, just hope it works. Guess it's lucky I got stuck at home, the reason I was going to L.A. went to N.Y. so I saved a wasted trip. :D
  13. Apr 27, 2023 at 7:50 AM
    #7963
    e30cabrio
    Resetting fuel density solved the AFR issue, thanks for the HPtune forum info, Xact will look into using it.
    Wynnded, armyoffoo and HulkSmurf14 like this.
  14. Apr 27, 2023 at 8:20 AM
    #7964
    e30cabrio
    What is the logic on the flex pump relay? Removed or grounded? (It's grounded right now)
  15. Apr 27, 2023 at 9:08 AM
    #7965
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    one of y'all need to whoop up a sensor that tells me when the bypass is open/closed.
    little green light on dash to monitor.
    I have no legitimate reason to need this...i want it.
  16. Apr 27, 2023 at 9:15 AM
    #7966
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's what your boost/vacuum gauge does. It's a progression, more boost more closed. Less boost less closed.
    snivilous[OP] and Silver17 like this.
  17. Apr 27, 2023 at 9:20 AM
    #7967
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I hear you...and that's what caused my quandary. Chris @ Harrop said it's not gradual...it is either open or closed.
    yes, vacuum is changing, but I would like to know when it closes/opens. how much vacuum activates it?
    like when I go over an overpass...does it activate?
  18. Apr 27, 2023 at 9:25 AM
    #7968
    Silver17
    Northeast
    If you’re smiling, the bypass is closed. It is indeed gradual/progressive. Put the truck in 2nd and accelerate up to 45mph, from there and you can see with the RPMs up you can modulate the boost pressure with how quickly you stab the throttle for example. It can range from vacuum to full boost.
    nobodyintexas, e30cabrio and Wynnded like this.
  19. Apr 27, 2023 at 9:47 AM
    #7969
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That seems like an odd thing to say. Had I heard him say that, I think that I'd be asking him to elaborate.
  20. Apr 27, 2023 at 9:53 AM
    #7970
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    He could have a simple circuit made so that when it's fully closed, it makes his bottom seat cushion vibrate.
  21. Apr 27, 2023 at 9:57 AM
    #7971
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it is odd...but since he used the word "basically" i perceived it to be a simple and concise answer.
    so I ask him...
    Chris,
    Concerning the bypass valve on the Tundra'sHarrop.
    does it move in a variable way - dependant on different levels of vacuum?
    or is it simply open or closed - depending on vacuum?
    he answers...
    Glad to hear the truck is running great, the valve is basically either open or closed based on the load situation. Let me know if that helps answer your question.
    Thanks
    Chris Mentrup | Operations Manager - USA
    HarropEngineering USA
    3578 S. Kettering Blvd Suite 600,
    Dayton, OH 45439
  22. Apr 27, 2023 at 9:58 AM
    #7972
    nobodyintexas
    nobodyintexas What?
    South of Houston
    now you're thinking.
  23. Apr 27, 2023 at 10:03 AM
    #7973
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Well, it doesn't have exactly a large range of motion. So I can accept that.
    You could use one of those old-timey handshake button buzzers.
    nobodyintexas[QUOTED] likes this.
  24. Apr 27, 2023 at 12:47 PM
    #7974
    snivilous
    SW UT
    I don't know if I believe that. But you could take a video of the bypass valve and see if it's on/off or gradually changes. At least on the Magnuson I don't see anything that would let it be only on/off; less vacuum = less closed.
    My assumption was the valve is essentially coupled to your throttle angle. Full throttle = full closed = full boost, idle = full open = no boost. And it's a curve or linear between those two. The valve is always moving since it's based on how much force the vacuum diaphragm is opposing the spring.
  25. Apr 27, 2023 at 12:48 PM
    #7975
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Epa likes this post.. she runs better now as I wait for the headers. Had a slow day at the shop. Primary cats blew back into the secondary cats. 20230427_104157.jpg 20230427_113343.jpg 20230427_113846.jpg
    Vizsla, Fastlane47, reywcms and 4 others like this.
  26. Apr 27, 2023 at 2:08 PM
    #7976
    e30cabrio
    Crunchy!
    Also, do I leave the secondary flex pump relay in grounded or remove it? (currently it's in & grounded)
  27. Apr 27, 2023 at 2:14 PM
    #7977
    Silver17
    Northeast
    It’s hard to believe exhaust gas flows through that crap with any ease.
    reywcms and V10Ace[QUOTED] like this.
  28. Apr 27, 2023 at 3:11 PM
    #7978
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Agreed. Your theory makes much more sense.
    I’m going to summon my old 12v car audio skills and come up with something
    I’m guessing a simple contact switch on the movey thing would suffice.
  29. Apr 27, 2023 at 4:59 PM
    #7979
    e30cabrio
    The new cable came, seen properly immediately by the system.
    It works, make sure the right port is set in Logworks.
    Wynnded likes this.
  30. Apr 27, 2023 at 6:59 PM
    #7980
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Your truck will accelerate when the bypass port is closed.
