General Supercharger Thread
  1. Apr 24, 2023 at 12:58 PM
    #7921
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Fastlane47[QUOTED] likes this.
  2. Apr 24, 2023 at 4:30 PM
    #7922
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Apr 24, 2023 at 5:18 PM
    #7923
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    Well, Prospeed told me ten weeks, ordered them anyway. It's hard to get a lot of stuff right now, long wait times.
    V10Ace[QUOTED] likes this.
  4. Apr 24, 2023 at 5:34 PM
    #7924
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Camping season is here and it probably wouldn't be a good idea to pull my TT with clogged cats. Think I'm gonna cut the cats open this week and gut them and reweld. I couldn't get the drivers side mid pipe out when I initially attempted to gut them lol
    Silver17 and Fastlane47[QUOTED] like this.
  5. Apr 24, 2023 at 5:46 PM
    #7925
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    NOBODY messes with camping season :D. That’s one of the draws of the reliable 2nd gen for me, minus the pesky clogged cats…
  6. Apr 24, 2023 at 5:49 PM
    #7926
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Especially in Oregon where the window is tight lol. I'll run open header to drink crispy boys in the woods :rofl:
    Wynnded, reywcms and Silver17[QUOTED] like this.
  7. Apr 24, 2023 at 5:49 PM
    #7927
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I have a set of JBA long tubes with custom mid-pipes, $600 plus shipping and their yours. Here is what they looked like when I boxed them up and put them in storage 2 years ago. These are ceramic coated, so not sure why they have the surface oxidation, in use for about 1.5 years in Houston, so no salt. I would recommend getting them blasted and recoated, and have the flanges flattened on a belt sander for better seal.
  8. Apr 24, 2023 at 8:16 PM
    #7928
    Saltyhero13
    Saltyhero13 Throbbing Member
  9. Apr 25, 2023 at 8:56 AM
    #7929
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Saltyhero13[QUOTED] and reywcms like this.
  10. Apr 25, 2023 at 9:33 AM
    #7930
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Damn, why am I being dumber than usual? Am I to use the side port off the TRD Maggy on the DS to tie into for the PSB-1? Or do I use the Innovate supplied Tee on the port under the snout? Also, my IC pump is already using the IGN tapped source, I probably shouldn't add another tap onto that circuit for the gauge, right? And for RPM reference, did you boys use that feature and tap into the negative lead of an injector harness? Wow, I thought I knew this crap until I start on it...:angrygirl:
    **edit: I will use "1" for the boost reference....
    Saltyhero13 likes this.
  11. Apr 25, 2023 at 9:34 AM
    #7931
    Saltyhero13
    Oh this is great news to hear for reasons.... I was not clear what rating the SW headers cats had. Thanks for confirming.
  12. Apr 25, 2023 at 9:43 AM
    #7932
    Silver17
    Eastern PA
    There is an IGN fuse inside the truck as well above the drivers side kick panel. I used an add a fuse on that one, but I just used it as the trigger circuit for a relay with direct power from the battery (with a fuse in line as well).
    HulkSmurf14[QUOTED] likes this.
  13. Apr 25, 2023 at 9:50 AM
    #7933
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Number one is for boost referencing/guage
  14. Apr 25, 2023 at 9:54 AM
    #7934
    e30cabrio
    I used #1 for boost, & a fused ign from the contortionist under dash fuse panel. I'd really like to kill the guy that designed that.
  15. Apr 25, 2023 at 10:03 AM
    #7935
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I completely understand, my hands and forearms look like I've been fighting badgers...why does every piece of metal without paint have to be razor sharp?
  16. Apr 25, 2023 at 10:03 AM
    #7936
    ssmokedz
    Shelton CT
    You can also get a tach signal from the Data link connector. On mine it is pin 9 and is a green wire. Shoot me your year and i can look it up. I used the shift light option on mine and i like it. Its much brighter than you would think.
    Wynnded, Saltyhero13 and armyoffoo like this.
  17. Apr 25, 2023 at 10:10 AM
    #7937
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The driver's side rear port is the only boost port available, if you're already using it (like for the fuel pressure regulator) then tee into it, if not then just run the line straight to it. The ports under the intake at the front are all vacuum ports (front vacuum, rear boost) and are used for things like catch cans and the PCVs.
    I did not use RPM reference. I forget where I tapped power from, but since it's powering a relay it doesn't really matter if you tee into the IC pump or not. For the dimming feature I tee'd into the cigarette lighter as I recall...
  18. Apr 25, 2023 at 10:26 AM
    #7938
    HulkSmurf14
    2014 Tundra Limited
    Thank you all...It's a 2014 Limited...only 200k miles less than @snivilous 's...
    snivilous[OP] likes this.
  19. Apr 25, 2023 at 10:48 AM
    #7939
    ssmokedz
    Shelton CT
    Tach signal is still pin 9 but will be a brown wire for you.
  20. Apr 25, 2023 at 10:50 AM
    #7940
    ssmokedz
    Shelton CT
    Heres a picture of dlc connector layout for reference.
  21. Apr 25, 2023 at 11:07 AM
    #7941
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmm, more stuff for my list. That might be cool.
  22. Apr 25, 2023 at 11:22 AM
    #7942
    HulkSmurf14
    2014 Tundra Limited
    Thank you @ssmokedz ! That's an easy option...I'm tapped into the brown wire now! :hattip:
    Okay, last bit of Hodar-inspired needing of help: The Relay diagram, for those using it, shows 87 going to the red wire on the PSB gauge...however, the pins 86 & 85 are pig-tailed together in the x2 pin connector...
    I plan on using the red wire from the gauge itself to tie into the IGN under the dash...doing this would make the 87 pin on the relay obsolete, right? I assumed the 85 pin would need to go to the battery ground but that's not the case on my pre-wired relay...sheesh, thank you for your grace on this...what should I do with the 87 pin on the relay if I'm intending to use the red wire (off the back of gauge) as my trigger wire?
    Was my relay mis-wired if my 85 & 86 pins are the 2-pin connector that ties into the gauge itself seen above? I'm Ron Burgundy?
  23. Apr 25, 2023 at 4:33 PM
    #7943
    HulkSmurf14
    2014 Tundra Limited
    Welp, I got it installed...not the relay persey, as I still need confirm the wiring on that bugger...getting the three harness wires thru the firewall is such a b&#:h! Haha nothing Dawn dish soap couldn't solve. I don't have the bung installed or wideband yet but everything is routed and ready...here she is...I think I hit nearly 7psi somehow...most of the time it's like 3.8-4.2psi...
    https://m.youtube.com/shorts/O2HdUR031yw
  24. Apr 25, 2023 at 5:37 PM
    #7944
    Silver17
    Eastern PA
    According to the interwebs, the critical/melting point of most cats is around 1600 degrees. I got a Scangauge3 installed today and was monitoring the temps. Bank 1 (drivers side) seems to run hotter than bank 2 by a couple hundred degrees most of the time. I noticed under pretty brief WOT pulls it would shoot over 1400 degrees pretty quick. It otherwise hangs out in the 1100-1200 range when the truck is up to temp. No doubt on a 1/4 mile it would hit the 1600 mark in a hurry.
    Not sure how accurate the temps are that read read via OBD2, is the O2 sensor actually able to transmit temp? Either way, I set an alarm on the SG to beep if the cat temp on the drivers side exceeds 1550 degrees. Will be interesting to monitor that metric towing the TT this summer.
    reywcms, HulkSmurf14, Wynnded and 2 others like this.
  25. Apr 25, 2023 at 5:55 PM
    #7945
    snivilous
    SW UT
    My understanding is no, the cat temp is a predicted value. You can actually change those values in the COTS table in HPT. As I recall rpm and airmass create a predicted cat value, and that triggers certain enrichment events if you have it turned on. There is not however an actual temperature being measured.
  26. Apr 25, 2023 at 6:03 PM
    #7946
    Silver17
    Eastern PA
    If it is predicted, it’s more sophisticated logic than I’d have guessed. I only say that because even after a WOT pull for 10 seconds or so the cat temp continues to climb a little even after I’ve let off the gas. It then takes at least a good 60 seconds or so of being easy on the throttle for the temp to drop back down to normal operating temps. It would
    be interesting for it to try and calculate the cat temp in real time base on anything other than the air and fuel going into the engine at each given second and providing an immediate calculation. Does that make sense?
    Edit: Not saying I don’t believe that it’s calculated, just saying it’s interesting they have even programmed in logic for figuring on the cat “cooldown” after a high load pull.
  27. Apr 25, 2023 at 6:21 PM
    #7947
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm not sure about the 2-pin connection, but the relay only needs to have the red power wire connected to it.
    Battery power to Pin 30
    Ignition tap to Pin 86
    Innovate Gauge Red Power wire to Pin 87
    Ground to Pin 85
    Also need to ground the Gauge, I would recommend you use same ground as the relay.
  28. Apr 26, 2023 at 5:58 AM
    #7948
    Silver17
    Eastern PA
    I saw this listed for sale, and I’ve never seen that style before. Does anyone know what the deal is with this? I’m wondering what size MAF tube it has, but I’ve never seen that style filter before or what looks like an extended height lid.
  29. Apr 26, 2023 at 6:00 AM
    #7949
    HulkSmurf14
    2014 Tundra Limited
    That's the TRD Cold Air Intake they sell...I believe it still sports the 4" tube and MAF...
    Silver17 likes this.
  30. Apr 26, 2023 at 6:14 AM
    #7950
    e30cabrio
    Xact won't send a remote tune. I'm going back Monday. What should I do before I go? Also, it occurred to me to check the alcohol % & it's oddly 55-70% changing by throttle position in my last read, which seems odd. I reset the fuel density learning & I'll see if that makes any changes. Any idea why it keeps thinking there is alcohol?
