General Supercharger Thread
  1. Nov 9, 2021 at 3:38 AM
    #751
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I wonder if you could have a tune developed that would pass CARB? then flash back to fun?
    Platinum714[QUOTED] likes this.
  2. Nov 9, 2021 at 3:43 AM
    #752
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Could one develop a CARB tune that remaps the gas pedal/throttle to make it 40% at top...mega weak throttle. This would work, no? Then the motor would act like a 381/401 motor.
    just ruminating....
    Platinum714 likes this.
  3. Nov 9, 2021 at 4:21 AM
    #753
    nobodyintexas
    nobodyintexas What?
    South of Houston
    The nature of Stage 2.
    I appreciate the Tundra acting like a pussy cat as I cruise down the hwy @ 60mph - getting ~17mpg. (used to be 18 - we'll see when I run a tank)
    and
    lumbering around town without any indication of massive TQ.
    and
    have the ability to summon a LOT of power by simply pressing the gas.
    it is quite intoxicating.
    Yes, I could push the limits of the motor, but I generally behave. The truck abides.
    This comforts me - as I know if I break something, it's because I did not behave.
    behaving is tough when even light throttle nudges you back in the seat.
    Stage 1 was very nice - probably all I really needed. it checked all the boxes.
    I imagine Stage 1 tuned would be Primo.
    Stage 2 goes to the second page.
    Cruise control -
    Stage 1 going up hills, the trans rarely downshifted. boost bypass closed and lumbered up the hill.
    Stage 2 going up hills, the trans rarely downshifts. Boost bypass closes and it accelerates faster than stage 1, then back off & adjusts speed. nice.
  4. Nov 9, 2021 at 6:29 AM
    #754
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    Supercharged with aftermarket wheels and tires
    I can’t wait to join the club! My intake is getting built as we speak. Hopefully will ship out this week. Looking good NobodyinTexas!!! I was guessing mine was at about 440-450 after stage one tune. Mine transmission was acting crazy on the one- two shift while on the stock calibration also! I thought it could be where I leveled it but even after doing a ZPC it was still happening. Had it tuned and no problems since. I believe 600 crank hp is max from what I’ve been told. Hopefully I won’t blow it up! I only get a heavy foot every once in a while.
    Silver17 and nobodyintexas like this.
  5. Nov 9, 2021 at 6:37 AM
    #755
    nobodyintexas
    nobodyintexas What?
    South of Houston
    damn it.
    please post pictures of said intake when you get it all installed. I was hoping I was done!
    glad to hear your stage 1 tune cured similar issues. Validates issues for others to see.
    I enjoy the stewardship this forum brings to the folks that do this kind of stuff.
    Saltyhero13 and Platinum714 like this.
  6. Nov 9, 2021 at 7:02 AM
    #756
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    Will do. Aluminum shortage has held mine up. Yeah I like the idea that we can share our experiences and knowledge with others! I’m not to good to take advice or get good information from other people! Hell I’m almost 50 years old and learn something new everyday!
    Saltyhero13 likes this.
  7. Nov 9, 2021 at 7:16 AM
    #757
    nobodyintexas
    nobodyintexas What?
    South of Houston
    what number are you shooting for on Stage 2?
    with a larger intake you could probably hit 520/560 at the wheels with ease.
  8. Nov 9, 2021 at 8:08 AM
    #758
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @nobodyintexas Did you change out your spark plugs from the factory ones? I’ve read that at the higher power levels we should be running colder IKH24 plugs I just installed new standard iridium plugs when I went stage 1, I should have just waited cause I’ll have to change them again for stage 2.
  9. Nov 9, 2021 at 8:10 AM
    #759
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes. cooler plugs.
    I did this for Stage 1...kept them for Stage 2.
    Silver17[QUOTED] likes this.
  10. Nov 9, 2021 at 9:02 AM
    #760
    Saltyhero13
    Saltyhero13 Throbbing Member
    Yes. I'm not familiar with Cali law on this. From what I understand the Harrop is CARB certified but the issue lies with modified ECUs now. It appears a recent law requires the ECU needs to be CARB approved as well.
    https://www.roadandtrack.com/car-cu...californias-new-ecu-law-means-for-tuned-cars/
  11. Nov 9, 2021 at 9:07 AM
    #761
    nobodyintexas
    nobodyintexas What?
    South of Houston
  12. Nov 9, 2021 at 9:08 AM
    #762
    Saltyhero13
    yep....:evil:
  13. Nov 9, 2021 at 9:19 AM
    #763
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I am refraining from stating that states/Gov should not be able to control the modifications to a vehicle.
  14. Nov 9, 2021 at 9:25 AM
    #764
    boringdriver
    boringdriver New Member
    2015 LX 570
    Dropped my whip off to Prospeed this morning, very eager!
  15. Nov 9, 2021 at 9:26 AM
    #765
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Stage 2?
    larger inlet?
  16. Nov 9, 2021 at 9:28 AM
    #766
    boringdriver
    2015 LX 570
    Prospeed billet fuel rails, 750cc injectors, adjustable FPR, ARH long tube headers, 80mm pulley and finally a tune (ECM and TCM via HP Tuners)
  17. Nov 9, 2021 at 9:32 AM
    #767
    nobodyintexas
    nobodyintexas What?
    South of Houston
    My goodness.
    Color me intrigued.
    Let's guess numbers - I say 507/532 accounting for larger drive loss of your 4wd system
    you'll need a rollcage!
  18. Nov 9, 2021 at 10:03 AM
    #768
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was told there was fire breathing NSX here. Where did it go?
    Never mind I found it in a terrible news article. Guess my car will never pass smog again.
  19. Nov 9, 2021 at 12:19 PM
    #769
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  20. Nov 9, 2021 at 12:40 PM
    #770
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    COMMIFONIA LAW… Simple… YOU CAN’T DO SHIT :D
    nobodyintexas likes this.
  21. Nov 9, 2021 at 1:50 PM
    #771
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    To be honest my goal is not to get the most hp I can. I just feel after spending 8k on a blower I want it to run the best efficient way it can. I don’t like it being held back or things turned down to make it work. Something over 500 to the wheels is good for me! Now later on if something happens to my engine I going forged block and I’m turning it up! Does anyone know the max wheel hp?
    nobodyintexas, Saltyhero13 and 1UP like this.
  22. Nov 9, 2021 at 3:37 PM
    #772
    Silver17
    Eastern PA
    Man this thread is a bad influence. Finally pushed me over the edge and I ordered my remote DAP tune using HP tuners and the MVPI2. Also ordered the 650cc injectors and the IKH24 plugs. Now to decide if I really need the 80mm pulley! So many things to buy for the truck yet, including a limited slip diff to put all this power to the ground. It’s a real rabbit hole.
  23. Nov 9, 2021 at 3:51 PM
    #773
    nobodyintexas
    nobodyintexas What?
    South of Houston
    tuned Stage 1 will last a few months. Stage 2 will be easy.
  24. Nov 9, 2021 at 3:55 PM
    #774
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Working your way through your list of mods…. It’s only money… can’t take it with you…:anonymous:
  25. Nov 9, 2021 at 4:06 PM
    #775
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    I too am getting tempted by all these Stage 2 upgrades from you guys. I am still loving Stage 1 untuned.....but for how long?!?!?!
  26. Nov 9, 2021 at 4:07 PM
    #776
    nobodyintexas
    nobodyintexas What?
    South of Houston
    just stepped out to garage & noticed my intercooler pump running.
    hmmm....
    I unplugged/plugged battery and it reset.
    will monitor.
  27. Nov 9, 2021 at 4:07 PM
    #777
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I asked my installer about Stage 2 and he said as long as you change the Pulley and injectors back to original and then reflash to original ECU, that should be enough to pass SMOG.
  28. Nov 9, 2021 at 4:08 PM
    #778
    nobodyintexas
    nobodyintexas What?
    South of Houston
    tune stage 1
    easy upgrade
    or will that un-CARB you?
  29. Nov 9, 2021 at 4:09 PM
    #779
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    Yeah technically it will un-CARB me.
  30. Nov 9, 2021 at 4:10 PM
    #780
    nobodyintexas
    nobodyintexas What?
    South of Houston
    does the intercooler have a boil over / cooling timer?
