General Supercharger Thread
  1. Apr 1, 2023 at 2:21 PM
    #7111
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I'm laughing way too hard at this
    Saltyhero13, Silver17 and e30cabrio like this.
  2. Apr 1, 2023 at 2:21 PM
    #7112
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Hahahaha
    Saltyhero13 and e30cabrio like this.
  3. Apr 1, 2023 at 2:22 PM
    #7113
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Me too, it is very funny.
    Saltyhero13 likes this.
  4. Apr 1, 2023 at 2:23 PM
    #7114
    Silver17
    Eastern PA
    I was sure there was a consensus to talk like this on the forum today, and I just wasn’t privy to it.
  5. Apr 1, 2023 at 3:38 PM
    #7115
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Lmao! Thought I had a stroke cause I know I didn't write it that way!
  6. Apr 1, 2023 at 3:46 PM
    #7116
    M3Tundra-JK
    Scott
    2005 GX470
    It's so much funnier knowing it's a bot changing people's posts
    Silver17, e30cabrio and Saltyhero13 like this.
  7. Apr 1, 2023 at 4:07 PM
    #7117
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Some of the posts are easier to understand now...
    e30cabrio and Silver17 like this.
  8. Apr 1, 2023 at 4:28 PM
    #7118
    e30cabrio
    So I got the hose, installed it and am totally flumoxed, it goes from 58 to 40 @ throttle (I am afraid to go wot as the afrs are up to 16). Why would that happen?
    https://streamable.com/5kc6cs
  9. Apr 1, 2023 at 4:39 PM
    #7119
    e30cabrio
  10. Apr 1, 2023 at 4:51 PM
    #7120
    armyoffoo
    armyoffoo Member
    Cypress, TX
    e30cabrio[QUOTED] likes this.
  11. Apr 1, 2023 at 5:11 PM
    #7121
    armyoffoo
    armyoffoo Member
    Cypress, TX
  12. Apr 1, 2023 at 5:21 PM
    #7122
    e30cabrio
    HulkSmurf14 and Saltyhero13 like this.
  13. Apr 1, 2023 at 5:23 PM
    #7123
    Saltyhero13
    Saltyhero13 Throbbing Member
    OMFG this Old English talk is hilarious.
    HulkSmurf14 likes this.
  14. Apr 1, 2023 at 5:24 PM
    #7124
    e30cabrio
    omg it's back.
    love it!
  15. Apr 1, 2023 at 5:25 PM
    #7125
    Saltyhero13
    Totally not what I said. Hahaha.
  16. Apr 1, 2023 at 5:25 PM
    #7126
    armyoffoo
    armyoffoo Member
    Cypress, TX
    There is a universal kit...would be best to run a dedicated wire as the stock wiring is a bit thin.
    https://kennebell.net/product/boost-a-pump-universal/
  17. Apr 1, 2023 at 5:33 PM
    #7127
    Silver17
    Eastern PA
    Your pressure goes from 58 to 40 and you have it boost referenced? I’m afraid to post anything technical in fear of this new language making me sound like a stupid ass lol. But anyway, no way your 450lph pump would be insufficient if it’s working right. I’m running AFRs in the 10s with 650s and a 340lph pump with similar airflow. I would assume you either have a faulty pump or a pump related issue.
    snivilous[OP] likes this.
  18. Apr 1, 2023 at 5:35 PM
    #7128
    Saltyhero13
    It did. Turned it into a pirate poem.
    e30cabrio and Silver17[QUOTED] like this.
  19. Apr 1, 2023 at 5:43 PM
    #7129
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What wideband are you running? And did it need a calibration?
  20. Apr 1, 2023 at 5:47 PM
    #7130
    e30cabrio
    I have the Innovate PSB-1 & I callibrated it the way the manual said, out in the open, disconnected, err on the display, plug it in, get a reading, turn it off, install in the pipe.
    ZPhilip likes this.
  21. Apr 1, 2023 at 5:52 PM
    #7131
    ZPhilip
    Philip
    West Chester, PA
    If we keep quoting others posts, we can understand what is being said in modern words.
    Ok sounds like you did the calibration correctly.
  22. Apr 1, 2023 at 6:25 PM
    #7132
    armyoffoo
    armyoffoo Member
    Cypress, TX
    e30cabrio likes this.
  23. Apr 1, 2023 at 6:31 PM
    #7133
    e30cabrio
  24. Apr 1, 2023 at 6:53 PM
    #7134
    armyoffoo
    armyoffoo Member
    Cypress, TX
    They would probably charge you to install it, not offer up advise or support on someone else's product.
    It should be fairly straight forward according to the diagram below:
    For dedicated wiring, use 10gauge for both power and ground. Connect power to BAP, connect ground to tested-good ground or back to battery negative.
    Install Two terminals in the fuel basket top hat for pump power and ground: http://www.radiumauto.com/Electrical-Bulkhead-Stud-Kit-6-Pack-P1049.aspx
    Connect pump harness on the inside connected to the terminals and pump: http://www.radiumauto.com/Fuel-Pump-Connector-Harnesses-P812.aspx (Walbro uses model 17-0049-00)
    Install pressure switch connected to your boost source: http://www.radiumauto.com/Adjustable-Pressure-Switch-P921.aspx
  25. Apr 1, 2023 at 7:12 PM
    #7135
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Question for those with aftermarket fuel pressure regulators...after you shut off the engine, does your pressure immediately drop to 0, or stay pressurized?
  26. Apr 1, 2023 at 7:15 PM
    #7136
    e30cabrio
    On the one I have currently yes. I'll report tomorrow after I get the Aeromotive in.
  27. Apr 1, 2023 at 7:18 PM
    #7137
    ZPhilip
    Philip
    West Chester, PA
    Side note. Why don’t your responses go all olde English- Piratey?
  28. Apr 1, 2023 at 7:19 PM
    #7138
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm not sure...some did, but the last several haven't been.
  29. Apr 1, 2023 at 7:49 PM
    #7139
    e30cabrio
    Apparently Ohio is on the way from Texas to Phoneix???
  30. Apr 1, 2023 at 8:03 PM
    #7140
    armyoffoo
    armyoffoo Member
    Cypress, TX
    @e30cabrio, you might want to hold off ordering the BAP, it lists the Walbro450 as not recommended for the BAP, due to stock wiring size from what I can tell. The tech document below implies that the pump is more than capable of supplying up to 800HP if wiring is sufficient. You can likely just upgrade the wiring along with the new FPR and be good to go, that's what I did...but I haven't monitored the pressure/RPM to verify that resolved the issue, I just assumed that along with staged 2nd fuel pump took care of my delivery issue.
    https://kennebell.net/wp-content/uploads/2022/03/Fuel-Pump-Tech-1.pdf
