General Supercharger Thread
  1. Mar 31, 2023 at 2:23 PM
    #7081
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  2. Mar 31, 2023 at 4:36 PM
    #7082
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Quick update over here for visibility lol. Found blown STOP fuse under steering wheel area. Got truck backed into driveway! Forgot to clamp the transmissions hoses after removing Setrab trans cooler lol
  3. Mar 31, 2023 at 6:08 PM
    #7083
    Saltyhero13
    Saltyhero13 Throbbing Member
    Summary at around 15:30ish. Holdener tests discharge pipe length and exhaust pipe length on a turbo application. I was surprised peak power didn't change with the increased exhaust length even though the power shifts right. Discharge length made no difference. Almost makes the case for remote mounted turbos:
    https://youtu.be/UaKaxcNIyBA
    HulkSmurf14 and M3Tundra-JK like this.
  4. Mar 31, 2023 at 7:43 PM
    #7084
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
  5. Mar 31, 2023 at 8:01 PM
    #7085
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @Silver17
    @V10Ace
    Were either of you able to determine what aspect of your tunes resolved your extended crank times?
  6. Mar 31, 2023 at 8:11 PM
    #7086
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Mine's intermittent. Just gonna roll with it
  7. Mar 31, 2023 at 8:19 PM
    #7087
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Kind of ruins the remote start feature when I don't know if it's running or not. But I guess that Spring is right around the corner, right?
    HulkSmurf14 likes this.
  8. Mar 31, 2023 at 8:20 PM
    #7088
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Remote start works every time for me.. extended cranking or not :thumbsup:
    Wynnded[QUOTED] likes this.
  9. Mar 31, 2023 at 8:24 PM
    #7089
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I try to avoid commenting on this thread at times so people don't get annoyed by always seeing me saying something. And yes, been working on the other supercharged vehicle.
  10. Mar 31, 2023 at 10:52 PM
    #7090
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Add me to the unresolved extended cranking on warm starts, cold and hot starts are ok. I’ve been scouring the HPT forums but finding little info.
  11. Apr 1, 2023 at 5:02 AM
    #7091
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Mine is 95% fixed I’d say after making the adjustments I outlined somewhere in this thread for Zphilip. If you search airflow adder ECT IAT it may pull up the post. Those exact changes didn’t fix his though so no promises but at least you know you would be working on the right tables to start tweaking.
    e30cabrio and Wynnded[QUOTED] like this.
  12. Apr 1, 2023 at 5:14 AM
    #7092
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Remote mount
    Way back…I looked at squires turbo systems (STS). For my 96 4R. They had a decent pkg, till they went belly up
    Saltyhero13[QUOTED] likes this.
  13. Apr 1, 2023 at 6:08 AM
    #7093
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'll have a gander; coincidentally, I was staring at what I think were those tables, but I wasn't able to make sense of them enough to start messing with them.
  14. Apr 1, 2023 at 6:37 AM
    #7094
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Bravo supercharger troubleshooting poem-writer!!
  15. Apr 1, 2023 at 7:13 AM
    #7095
    Saltyhero13
    You had a boosted 4Runner? Now that is cool! Do tell!
    I am familiar with STS kits, Holley bought them if I am not mistaken and their remote mounted turbo offerings are still available. The turbo warning I posted about excessive chamber heat while towing and piston melting is from the back of their kit documentation.
    What is interesting to me about the Holdener video is he basically disproves the claim turbo enthusiast repeat that you will loose exhaust pressure and heat by remote mounting. In Holdener's demo he didn't even wrap the exhaust and it was an extremely excessive length. Both cases, short and extra long exhaust, made the same peak power. Now I've seen videos where the length of pipe leading to the turbo inlet makes a difference but the discharge side made no difference as demoed in this video.
    For me the video demonstrates on a standard turbo you don't need to have it in the engine bay and it will be just as effective as long as you don't have long exhaust between engine and turbo; for an e-boost device you can have the device mounted anywhere since your discharge pipe length doesn't matter.
    e30cabrio and Silver17 like this.
  16. Apr 1, 2023 at 12:03 PM
    #7096
    e30cabrio
    I'm still lean (over 15) the higher pressure I give, the lower the afr number gets (14-15 at 58) which is as high as this FPR will go.
    I ordered an Aeromotive, from Amazon that said it would deliver today but is not coming until tomorrow.
    The fittings are coming today though :p
    AZTundra and V10Ace like this.
  17. Apr 1, 2023 at 12:06 PM
    #7097
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    That should fix your issue. I hit ~72 psi at WOT
  18. Apr 1, 2023 at 12:09 PM
    #7098
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I never put one on. Got close didn’t have the $ then
  19. Apr 1, 2023 at 12:17 PM
    #7099
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Hate to be a party pooper, but the FPR pictured needs -8 ORB fittings. The regulator is perfect for what you need though.
    The Aeromotive regulators, Part #13138 (AN-06), 13139 (AN-08) & 13140 (AN-10), utilize two o-ring sealed ORB06/08/10 inlet/outlet ports, respectively, and an o-ring sealed ORB-06 style bypass or return port.
    e30cabrio[QUOTED] likes this.
  20. Apr 1, 2023 at 12:27 PM
    #7100
    Silver17
    Eastern PA
    Are you sure the injectors are the size you thought and are properly functioning? Did you reset your alcohol content before starting the tuning? Would you really see the fuel pressure drop on the gauge just revving the truck in park as opposed to revving it out with load on it? Just throwing out ideas. Seems odd to me and would love to see you get it wrapped up.
    snivilous[OP] likes this.
  21. Apr 1, 2023 at 12:28 PM
    #7101
    e30cabrio
    I ordered AN10 & 6 because that's what I thought it said I need.
    What should I order?
    thanks
  22. Apr 1, 2023 at 12:30 PM
    #7102
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you can, try to setup a dual feed, dual return now that you have the regulator, like ViktorG suggests. You'll need a Y-fitting for the feed side, and both rails would have a line each back to the FPR, with a line from the FPR back to the return hard line. Similar to this:
    Saltyhero13 and e30cabrio like this.
  23. Apr 1, 2023 at 12:31 PM
    #7103
    e30cabrio
    Saltyhero13 and V10Ace like this.
  24. Apr 1, 2023 at 12:32 PM
    #7104
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Your -6 return fitting is correct, but your feed and plugs need to be -8AN ORB to whatever, instead of -10AN ORB.
  25. Apr 1, 2023 at 12:35 PM
    #7105
    e30cabrio
  26. Apr 1, 2023 at 12:38 PM
    #7106
    e30cabrio
    Here is the BS that is Amazon (that just cost them 100 bux) When browsing it says order within (x time) get it tomorrow.
    Proceed to check out...
    AZTundra likes this.
  27. Apr 1, 2023 at 12:50 PM
    #7107
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Depends on the barb you have coming off the adapter, but you probably need a -8an orb to 3/8" male barb, or 5/16" male barb. Look for -8AN ORB fittings on summit, you can usually get them next day or close to it if they have a store near you. I'm in Cypress (Houston), and get next day delivery from their Arlington location. Or you can get the part number from Summit and search Amazon.
  28. Apr 1, 2023 at 12:58 PM
    #7108
    armyoffoo
    armyoffoo Member
    Cypress, TX
    LOL, April Fools filter? I was wondering why everyone was talking like pirates...
    e30cabrio and M3Tundra-JK like this.
  29. Apr 1, 2023 at 2:15 PM
    #7109
    e30cabrio
    I have no idea what happened to post 7110, this was my response, I have edited it 3x & the prose stays, guess it needs to be there.
    lol
    I have a hose coming to run the fuel pressure gauge to see it when driving. I believe the injectors were running in the 70% area but am not sure.
    I'm ready to be able to enjoy it, stinks not gassing it to see what I have.
    Thanks
  30. Apr 1, 2023 at 2:17 PM
    #7110
    e30cabrio
    omg
    Since It's not really my post I want to like it.
    lol
    Saltyhero13 and Silver17 like this.
