General Supercharger Thread
  1. Mar 31, 2023 at 6:31 AM
    #7051
    Saltyhero13
    Saltyhero13 Throbbing Member
    Any of y'all tracking e-boost products?
    One of the early release Euro vendors just released their initial kits (~$3K with current exchange rates):
    https://torqamp.com/shop/
    armyoffoo and nobodyintexas like this.
  2. Mar 31, 2023 at 6:35 AM
    #7052
    Saltyhero13
  3. Mar 31, 2023 at 6:54 AM
    #7053
    Saltyhero13
    HulkSmurf14 likes this.
  4. Mar 31, 2023 at 7:11 AM
    #7054
    Saltyhero13
  5. Mar 31, 2023 at 7:13 AM
    #7055
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Saltyhero13[QUOTED] likes this.
  6. Mar 31, 2023 at 7:15 AM
    #7056
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    How about 2 hair dryers??
    Saltyhero13 likes this.
  7. Mar 31, 2023 at 7:17 AM
    #7057
    Saltyhero13
    lol Project farm did something like this. I think he used a leaf blower on his RV.
    e30cabrio[QUOTED] likes this.
  8. Mar 31, 2023 at 7:17 AM
    #7058
    e30cabrio
    Moar better!
  9. Mar 31, 2023 at 7:18 AM
    #7059
    Saltyhero13
    Yes. It is like a pulley upgrade without the parasitic loss.
  10. Mar 31, 2023 at 7:20 AM
    #7060
    Saltyhero13
  11. Mar 31, 2023 at 7:22 AM
    #7061
    armyoffoo
    armyoffoo Member
    Cypress, TX
    No lag, instant boost, can stage it like nitrous and ramp it up with voltage, seems like a no-brainer for a performance upgrade. Other than the battery box, wiring and needing an intercooler for it...but can use a water to air IC under the hood, no need for the air to air complexity.
  12. Mar 31, 2023 at 7:24 AM
    #7062
    armyoffoo
    armyoffoo Member
    Cypress, TX
  13. Mar 31, 2023 at 8:31 AM
    #7063
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    got the original gas tank lines reconnected. Went to start the truck but the brake pedal appears to be fully depressed and will not go back to normal position. The truck will not even crank and has a Brake Malfunction error
    Any suggestions??
  14. Mar 31, 2023 at 8:45 AM
    #7064
    e30cabrio
    See if there are kinks in the ebrake mechanism?
  15. Mar 31, 2023 at 8:49 AM
    #7065
    Saltyhero13
    I think so too. Unlike a standard turbo these wont be a restriction on the exhaust side.
    Holdener tested intake pipe length vs exhaust manifold length for turbo applications (remote mounted). The longer the exhaust runner the more turbo lag was experienced (shifted the curve to the right) but interesting enough the length of the intake had none to minimal impact on lag. You could feasibly mount these anywhere on the truck.
    Silver17 likes this.
  16. Mar 31, 2023 at 8:51 AM
    #7066
    M3Tundra-JK
    Scott
    2005 GX470
    Ebrake seemed to work fine when putting it on and off. I also have a Brake Override Malfunction Visit Dealer warning on dash
  17. Mar 31, 2023 at 8:55 AM
    #7067
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    This is seriously awesome, I’d love to see this implemented on a tundra. Pretty ingenious. I wonder if they could be set up as compound turbos in series and used to boost up to 12psi instead of 6….
  18. Mar 31, 2023 at 9:05 AM
    #7068
    armyoffoo
    armyoffoo Member
    Cypress, TX
    They have a bypass valve for exactly that, spooling up a larger turbo and then bypassing once boost overcomes the electric system, pretty slick stuff.
    Saltyhero13 and Silver17[QUOTED] like this.
  19. Mar 31, 2023 at 9:07 AM
    #7069
    Saltyhero13
    You could. The second turbo wouldn't care what the pressure is coming in you would just need to deal with the heat of compression.
    The compounding is calculated differently so it isn't additive. I think in this case you would get almost ~14.5 PSI
    Edit: I think you have to multiply the values in BARs
  20. Mar 31, 2023 at 9:13 AM
    #7070
    Silver17
    Eastern PA
    He said the max flow at top speed is 140g/s which comes out to 504 kg/hour. I wasn’t sure how that compared a SC like ours for example, but looking at the 2650 chart I think even at just 12kish RPM where I’m running mine that’s around 2,200 kg/hour. They’re definitely not big air movers but are pretty sweet to get instantaneous boost with no parasitic loss. I’m guessing the boost psi is totally dependent on the application. A 2.0 4 cylinder or something it may make 6psi but on a big V8 I’m guessing it’s less.
  21. Mar 31, 2023 at 9:13 AM
    #7071
    armyoffoo
    armyoffoo Member
    Cypress, TX
    This wouldn't be too difficult to mount up https://www.frozenboost.com/air_water-ic/small-liquid_air-intercooler-p-210.html
    Or you could just plumb the electric's output to the bigger turbo's input, that's how it's done on many stock compound turbo setups, then of course the bigger turbo's charge has to get cooled.
  22. Mar 31, 2023 at 9:17 AM
    #7072
    Silver17
    Eastern PA
    True. 14.7psia x 1.4PR = 20.58psia out of turbo 1 into turbo 2. 20.58 x 1.4PR =28.81 - 14.7 = 14.1 PSIG output of turbo 2…. I think.
  23. Mar 31, 2023 at 9:55 AM
    #7073
    e30cabrio
    What if I try getting FPR vacuum from the boost port on the SC instead of the intake?
  24. Mar 31, 2023 at 9:56 AM
    #7074
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That's where you should be getting it, I forgot that step...plug the barb on the intake and connect to the SC.
  25. Mar 31, 2023 at 10:02 AM
    #7075
    Saltyhero13
    I think so. Would need to adjust for heat which I didn't calculate.
    If twin charging, probably best to size a pulley that puts the blower through the middle of the best efficiency island and have the e-boost do the rest of the work.
  26. Mar 31, 2023 at 10:12 AM
    #7076
    e30cabrio
    I was where oem got it at the intake.
    I just capped the intake and put the T on the boost port.
    Thanks
  27. Mar 31, 2023 at 12:47 PM
    #7077
    e30cabrio
    snivilous[OP] and HulkSmurf14 like this.
  28. Mar 31, 2023 at 1:01 PM
    #7078
    Saltyhero13
    He is probably busy boosting something...or designing something that can help boost something that isn't boosted.
  29. Mar 31, 2023 at 1:04 PM
    #7079
    e30cabrio
    Not complaining, just noticed.
  30. Mar 31, 2023 at 1:52 PM
    #7080
    e30cabrio
    I'm still lean, fuel pressure isn't dropping though. Any ideas?
    For reference, here is where the pressure is set (Xact said do 50)
    Stays 99% there on revs.
    https://streamable.com/89qal8
    Any ideas on getting it to not be lean?
