General Supercharger Thread
  1. Mar 27, 2023 at 6:59 PM
    #6991
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    M3Tundra-JK and e30cabrio like this.
  2. Mar 27, 2023 at 7:10 PM
    #6992
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Mar 27, 2023 at 7:19 PM
    #6993
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    All you should need is that second adapter in place of the stock FPR, with fuel injection hose connecting to the aftermarket FPR, and connect the output of the FPR to the stock return hardline.
  4. Mar 28, 2023 at 6:09 AM
    #6994
    e30cabrio
  5. Mar 28, 2023 at 6:13 AM
    #6995
    armyoffoo
    armyoffoo Member
    Cypress, TX
    e30cabrio[QUOTED] likes this.
  6. Mar 28, 2023 at 6:57 AM
    #6996
    Saltyhero13
    Saltyhero13 Throbbing Member
    I've really only seen blower spacers used for heat management. The few on the market for other engines would be too thin for sensors/spray ports. I did see quite a few Carb and TB spacers that were ported for sprayers and sensors but these are much thicker with enough material to support these devices. Probably limited to how thick the spacers can be.
    snivilous[QUOTED][OP] likes this.
  7. Mar 28, 2023 at 8:15 AM
    #6997
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  8. Mar 28, 2023 at 4:26 PM
    #6998
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Mostly back together, in a slap dash fashion. Haven't tightened most of the hose clamps, vacuum or coolant. About to reflash it back to stock tune. Adjuster comes out tomorrow morning to look at it. Then gonna work on the gas tank. And since I have to do that in the street, I'm gonna go buy some of those little neon children at play figures with flags to put out
  9. Mar 28, 2023 at 4:29 PM
    #6999
    1UP
    1UP Truck Gang
    @Tundraloyal these are the right guys to ask about SC drivetrain mileage.
  10. Mar 28, 2023 at 5:03 PM
    #7000
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just borrow some actual children, aren't they on Spring Break anyway? Maybe charge their parents for babysitting. Win-win.
  11. Mar 28, 2023 at 5:43 PM
    #7001
    e30cabrio
    Forgot to post the CARB sticker, cause I'm OEM.
    lol
  12. Mar 28, 2023 at 5:51 PM
    #7002
    M3Tundra-JK
    Scott
    2005 GX470
    How did you get the carb sticker? Any special process?
  13. Mar 28, 2023 at 6:14 PM
    #7003
    e30cabrio
    M3Tundra-JK, HulkSmurf14 and Blang805 like this.
  14. Mar 28, 2023 at 7:24 PM
    #7004
    e30cabrio
    When the FPR install parts come after I install the FPR, what pressure should I set it at?
  15. Mar 28, 2023 at 7:37 PM
    #7005
    AZTundra
    Paul
    Phoenix, AZ
    Here is the data sheet from my injectors (same as yours), I would think 43.5 psi since they are rated as 750cc? Don't take my word for it as I truly do not know, but maybe this will help someone else be able to answer. I'm curious as well.
  16. Mar 28, 2023 at 7:40 PM
    #7006
    AZTundra
    Paul
    Phoenix, AZ
    Who's Harrop is this from post#1. I see they have a FPR installed, maybe they can chime in.
    e30cabrio likes this.
  17. Mar 28, 2023 at 7:44 PM
    #7007
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Set to what the supercharger instructions say, or what the Tuner wants. The Harrop says to set to 60PSI, I didn't see any suggestions in the Magnuson instructions so probably 43.5PSI (stock).
  18. Mar 28, 2023 at 9:11 PM
    #7008
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    43.5psi (3 bar). If you go to a different value the tune needs to be updated for the flow rate at the different pressure.
    e30cabrio[QUOTED] and AZTundra like this.
  19. Mar 28, 2023 at 9:12 PM
    #7009
    snivilous
    SW UT
    I think it's @V10Ace
  20. Mar 28, 2023 at 9:16 PM
    #7010
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Not I. But as @armyoffoo mentioned.. 60 psi is base pressure for mine as well.
    e30cabrio and AZTundra like this.
  21. Mar 29, 2023 at 2:47 AM
    #7011
    Silver17
    Eastern PA
    The photo on the front is @HonorNotInner i believe. As for @e30cabrio, being that it’s an FFV your stock FPR is a 60psi from the factory as opposed to the non FFV 43.5.
    Also I thought you bought used 650s? Yours just may be flowing more like 750s due to the higher pressure FPR.
    My 650s with the FPR boost referenced are most likely flowing over 700 at full boost at 51.5psi. 650s at 60psi flow roughly 763.
  22. Mar 29, 2023 at 4:38 AM
    #7012
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    It hurts to see it back to stock :(
  23. Mar 29, 2023 at 8:33 AM
    #7013
    M3Tundra-JK
    Scott
    2005 GX470
    Adjuster said he doesn't think that it's totalled. Went over everything they'd replace. Said will have to wait till it's at the shop and the bed is removed to check for any frame damage. However the driveshaft, and leaf springs do appear to be slightly crooked. It could just be the SUA flip kit slid a little bit on the axle
  24. Mar 29, 2023 at 8:38 AM
    #7014
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That might just be the shackles bent, as that's the weakest part of the rear suspension, it would give before the front leaf mounts. It doesn't look that bad actually, how do your front leaf mounts look? Any leaking at the rear of the transfer case/transmission?
  25. Mar 29, 2023 at 8:47 AM
    #7015
    e30cabrio
    I was concerned that was going to happen.
  26. Mar 29, 2023 at 8:47 AM
    #7016
    M3Tundra-JK
    Scott
    2005 GX470
    No leaks. Really hard to tell with the front mount. It may or may not be cocked a little. I'll just have to find a really good repair shop and have a talk with them.
    He said 2-3 weeks repair time and I lol'd. No way they can order parts that quickly. And then at the end he said most shops are a month out wait just to accept the vehicle
    armyoffoo[QUOTED] likes this.
  27. Mar 29, 2023 at 8:48 AM
    #7017
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The leafs don’t go straight they do have some angle to them as they move to the rear
    Wynnded and M3Tundra-JK[QUOTED] like this.
  28. Mar 29, 2023 at 10:44 AM
    #7018
    M3Tundra-JK
    Scott
    2005 GX470
    I'm wondering if I can get a quote w/supplemental parts from the body shop, and then take on the work myself...I've had insurance cut me a check like that in the past when I got rear-ended. I ordered and replaced the bumper and tailgate after taking to shop for quote. I've gathered some shop recommendations, but most places are 1-2 months out from even accepting the work
    e30cabrio and reywcms like this.
  29. Mar 29, 2023 at 11:55 AM
    #7019
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Definitely not 2-3 weeks.
    Back on May 21, 2022 I got t-boned and I didn't get my truck back til late October. Parts were on backorder through mid September.
    M3Tundra-JK[QUOTED] likes this.
  30. Mar 29, 2023 at 11:59 AM
    #7020
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You should be able to get a check for parts and est labor from the Insurance company, they will ask you to provide proof of repairs once completed so they can be sure you repaired the vehicle.
