General Supercharger Thread
  1. Mar 14, 2023 at 6:26 AM
    #6601
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Edited my comment a bit to correct typos
  2. Mar 14, 2023 at 10:37 AM
    #6602
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It has started!
  3. Mar 14, 2023 at 11:00 AM
    #6603
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Good luck! It's not so bad and when your done you will be smiling for days!
    e30cabrio[QUOTED] likes this.
  4. Mar 14, 2023 at 12:22 PM
    #6604
    e30cabrio
    HulkSmurf14 and AZTundra like this.
  5. Mar 14, 2023 at 12:30 PM
    #6605
    AZTundra
    Paul
    Phoenix, AZ
  6. Mar 14, 2023 at 12:33 PM
    #6606
    e30cabrio
    I have it, thanks!
    snivilous[OP] and AZTundra like this.
  7. Mar 14, 2023 at 12:59 PM
    #6607
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
  8. Mar 14, 2023 at 1:27 PM
    #6608
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Innnnteresting. I seem to be skating by on the standard kit belt with my URD 3.456" +2psi pulley. Maybe that's the limit? Just something else to monitor.
  9. Mar 14, 2023 at 3:33 PM
    #6609
    e30cabrio
  10. Mar 14, 2023 at 3:34 PM
    #6610
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    WHAT DREAMS ARE MADE OF!!! In the robot world of trucks! Yeeeehaw! Nice work!!
    e30cabrio, AZTundra and M3Tundra-JK like this.
  11. Mar 14, 2023 at 3:39 PM
    #6611
    snivilous
    SW UT
    Well I run the same belt as people with a 2.3" pulley with my 2.0" pulley, so I think there's plenty of room for error. People just tend to run the smaller belt when going down in pulley size.
  12. Mar 14, 2023 at 4:23 PM
    #6612
    e30cabrio
  13. Mar 14, 2023 at 4:43 PM
    #6613
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The belt? It's a forearm scratcher.
  14. Mar 14, 2023 at 4:48 PM
    #6614
    e30cabrio
    Ya, will not concede. Taking a break.
    Black@Blue19 and Wynnded[QUOTED] like this.
  15. Mar 14, 2023 at 4:55 PM
    #6615
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    This read is the reason I did the RCF and the PS intake. I have to say I was disappointed with my Dyno numbers, seeing this truck make 630 on a hub Dyno.
  16. Mar 14, 2023 at 5:06 PM
    #6616
    e30cabrio
    Could not get the Gates on, gave up, went with the Dayco. It was not easy but went on.
    Wynnded and Black@Blue19 like this.
  17. Mar 14, 2023 at 5:24 PM
    #6617
    Fastlane47
    Maryland
    2018 Platinum
    Victor G has a great video out about the stock fuel rails and how well the flow up to about 800hp with out needing to replace them. Using a bigger fuel pump and injectors seem to solve any issues.
    https://youtu.be/4u8HijUKgvI
    https://youtu.be/7lohURVY_3s
  18. Mar 14, 2023 at 5:34 PM
    #6618
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I don’t remember, do you have all the same mods ARH headers and all?
    Fastlane47[QUOTED] likes this.
  19. Mar 14, 2023 at 5:40 PM
    #6619
    Fastlane47
    Maryland
    2018 Platinum
    I don't have headers, my last build lost power after installing JBA system, so on this build I didn't do them.
  20. Mar 14, 2023 at 5:48 PM
    #6620
    Silver17
    Eastern PA
    From what I gather, 1-7/8” ARH is the way to go to make power with headers. Don’t think other brands make as big of gains.
    reywcms and Fastlane47[QUOTED] like this.
  21. Mar 14, 2023 at 5:51 PM
    #6621
    Fastlane47
    Maryland
    2018 Platinum
    I went with JBA and mid pipes with converters made by dirty deeds. The converters melted in a week of driving, I had to cut them out and weld in my stock ones. Lost a ton of low end power. I have used ARH headers on some of my car builds, and they always work well.
  22. Mar 14, 2023 at 7:32 PM
    #6622
    e30cabrio
    It's done, quick drive all seems well. I'm beat!
    What's the best intake, I had to cobble this together, the passenger side hood support had to come out.
    What does the PVC connect to? What about the valve that went to the back of the original intake? I plugged the electrical connector but not the vacuum hoses.
  23. Mar 14, 2023 at 7:37 PM
    #6623
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The magnuson box is what you need. The small line needs to be hooked to the intake that goes to the fuel rail. The large pcv I capped at the intake end and connected it to the pcv system lines
    e30cabrio[QUOTED] and AZTundra like this.
  24. Mar 14, 2023 at 7:41 PM
    #6624
    AZTundra
    Paul
    Phoenix, AZ
    Nice work! Hard to tell from the first picture angle, but looks like your coolant reservoir might be rotated 180 degrees pushing it to the drivers side instead of tucked next to the maggie.
  25. Mar 14, 2023 at 7:46 PM
    #6625
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep I did that at first then I thought not a bad place away from the heat of the blower but moved mine back lol.
    I’d also recommend a catch can. I’ll be redoing mine from the prospeed to a radium. If anyone wants the prospeed unit let me know.
  26. Mar 14, 2023 at 7:48 PM
    #6626
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Looks like the lander with all that gold wrap!
  27. Mar 14, 2023 at 7:49 PM
    #6627
    e30cabrio
    Thanks, I'll turn it around tomorrow. How much is the catch can?
    HulkSmurf14 likes this.
  28. Mar 14, 2023 at 7:53 PM
    #6628
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Prospeed new is $300 I believe and the radium single unit is $250 or something like that. No need for the dual radium can setup.
  29. Mar 14, 2023 at 8:00 PM
    #6629
    e30cabrio
    I meant when you sell yours.
    lol
    I'll take it .
    AZTundra and reywcms[QUOTED] like this.
  30. Mar 14, 2023 at 8:05 PM
    #6630
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Deal!
