General Supercharger Thread
  1. Feb 26, 2023 at 5:14 PM
    #6001
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Oh wow, I never noticed that before. I thought it had a higher range. Pay no attention to the man behind the keyboard...
  2. Feb 26, 2023 at 5:17 PM
    #6002
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Thanks for the info, missing parts and poor customer service turns me off. I cant even find anything on YouTube about the Whipple with the Tundra. I am probably going to go with the Magnuson as I need the truck to be a reliable daily driver for the next 10 years.
  3. Feb 26, 2023 at 5:20 PM
    #6003
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    After I get out of this soothing, calming bath, I'm gonna check this out. If you tighten the vacuum port down too much it can interfere with the internal pressure spring. Not sure if that would be my case, since mine was more sudden. Learning towards the internal seal not seating
    https://youtu.be/BwPlr3l2lGk
  4. Feb 26, 2023 at 5:24 PM
    #6004
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Not many running the whipple. The whipple is very reliable on many platforms across the board and makes awesome power. Outside of the missing hardware and service it’s great unit.
    HulkSmurf14 likes this.
  5. Feb 26, 2023 at 5:42 PM
    #6005
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    This is the one I’ve have had for the last couple minutes. No issues with it
  6. Feb 26, 2023 at 5:43 PM
    #6006
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Whatever you do, make sure you get a good tune and not the boxed shit that ships with the superchargers. That's the key to longevity imo. There's lots of people running the stock tune without issue, but for not much money you can have a much happier engine.
  7. Feb 26, 2023 at 5:44 PM
    #6007
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    This 100%
  8. Feb 26, 2023 at 5:48 PM
    #6008
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    And likely an extra 30+ hp to boot!
  9. Feb 26, 2023 at 7:32 PM
    #6009
    M3Tundra-JK
    Scott
    2005 GX470
    I took the Aeromotive fpr completely apart and put back together. Nothing obviously wrong to my eyes. But still super low fuel pressure on the gauge. Hopefully the new fpr comes in early in the day tomorrow
    snivilous[OP] and AZTundra like this.
  10. Feb 26, 2023 at 8:26 PM
    #6010
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    What fuel pump did you do again?
  11. Feb 26, 2023 at 9:09 PM
    #6011
    M3Tundra-JK
    Scott
    2005 GX470
    The 450lph that ProSpeed sells, but I got it from Figs locally
    reywcms[QUOTED] likes this.
  12. Feb 27, 2023 at 4:50 AM
    #6012
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  13. Feb 27, 2023 at 5:38 AM
    #6013
    nobodyintexas
    nobodyintexas What?
    South of Houston
    now that I have a boost gauge...it is quite interesting when boost is actually happening.
    with me it's very rarely. on-ramps are ~4.5 psi
    otherwise, a firm push from a light is around 2psi.
    I saw 8psi on a log pull on the hwy...10.8AFR.
    I'm about to get in a wreck watching the gauges.
    But all other times I'm negative boost. cruising to work at 58mph....negative boost.
    am I supposed to be seeing -14psi? or is the gauge wonky?
    M3Tundra-JK and reywcms like this.
  14. Feb 27, 2023 at 5:38 AM
    #6014
    bmw345
    bmw345 New Member
    CT
    Is this tune something that I could get from member here? I am comparing it to a power commander in a motorcycle where you simply upload a new map which would be sent via email. Or does the truck have to be there at the the dyno facility where they can physically tune it in person?
  15. Feb 27, 2023 at 5:52 AM
    #6015
    Silver17
    Eastern PA
    When not in boost the gauge is reading the usual vacuum from the engine as would be found on an NA intake manifold (displayed in inches of mercury not psi). It’s working properly. It’s a good way of judging how loaded the engine is in a particular gear as well. If you’re in 6th for example and start climbing a decent hill without it downshifting you’ll see it creep up from inches of mercury vacuum to 0psi, push the pedal further and it will go positive and start reading higher PSIG. It’s at that point you see the SC doing work as the bypass starts closing and giving you way more gear holding power in those situations that an NA truck would definitely be downshifting in.
  16. Feb 27, 2023 at 6:02 AM
    #6016
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    There are members that can help with tunes, you need the device of the software being used, an OBD2 dongle. I have an HP Tune MPVI2+
  17. Feb 27, 2023 at 6:05 AM
    #6017
    bmw345
    bmw345 New Member
    CT
    Thanks, so is the generic tune that comes with the supercharger safe to use for everyday long term use? Looking at the Magnuson or Whipple for my 2018. Thanks
  18. Feb 27, 2023 at 6:12 AM
    #6018
    e30cabrio
    I am not aware of the base tune causing harm, I do know tuners have said it was insufficient when looking at the motor's stats.
    Speaking of HP Tunes, anyone have any insight into the MPVI3? Seems they have been worse than OV Tune on promised release dates. (promised late December, mid January, early February & now TBD....
  19. Feb 27, 2023 at 6:43 AM
    #6019
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This? I'm missing where it says that it's TBD.
    https://www.hptuners.com/mpvi3/
  20. Feb 27, 2023 at 7:02 AM
    #6020
    e30cabrio
  21. Feb 27, 2023 at 7:03 AM
    #6021
    Silver17
    Eastern PA
    I’d say do it right from the beginning and don’t half ass it, you’re already spending a ton of money. The provided tune may be OK, but others have seen knock and less than ideal AFRs with the provided tunes. This would be my game plan if I were you for each of the kits based on what they lack as they come.
    Magnuson: buy the kit, larger injectors than are supplied, a larger fuel pump than is supplied and a custom tune.
    Harrop: buy the kit, larger injectors (none are supplied), a larger intake box, and a custom tune. The fuel pump supplied in the kit is sufficient. The stock airbox is borderline on the stock pulley but will be too small with a smaller pulley.
    Whipple: buy the kit, the supplied injectors and pump are sufficient, buy a larger intake box, and a custom tune. The stock airbox is borderline on the stock pulley but will be too small with a smaller pulley.
    kos221, Saltyhero13, reywcms and 2 others like this.
  22. Feb 27, 2023 at 7:05 AM
    #6022
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Unfortunately you can't just clear permanent codes. The lean condition will have to be repaired first and those codes will be deleted from the ecu after a specific drive cycle is performed.
  23. Feb 27, 2023 at 7:11 AM
    #6023
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It sure seems to be available this morning. I put one in my cart and all, are they just baiting me?
  24. Feb 27, 2023 at 7:14 AM
    #6024
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    They show in stock at Amazon even with next day delivery...
    Wynnded[QUOTED] likes this.
  25. Feb 27, 2023 at 7:28 AM
    #6025
    M3Tundra-JK
    Scott
    2005 GX470
    I've seen that trick before. Waiting 13 months on my M3 hood that said Available in 2-3 days. After you completely place the order, get an email saying it's on backorder. AFE did the same to me also.
    e30cabrio and Wynnded like this.
  26. Feb 27, 2023 at 7:40 AM
    #6026
    e30cabrio
    I have not seen a buy link on their site & I want to trade in my 2+ (which they have been promising)
  27. Feb 27, 2023 at 7:43 AM
    #6027
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Scroll down on the product page, its at the bottom. I was able to purchase one and the Pro link this morning, will see when it gets here.
    e30cabrio[QUOTED] and Wynnded like this.
  28. Feb 27, 2023 at 7:55 AM
    #6028
    e30cabrio
    Cool, the problem is I don't use it enough to warrant buying another so need the upgrade & I also have 4 credits in the 2+ I need to be transferred. So add that to their horrendous customer service, I'm sticking where I am.
  29. Feb 27, 2023 at 8:02 AM
    #6029
    M3Tundra-JK
    Scott
    2005 GX470
    I thought I read that with the MPVI3, the Prolink wasn't necessary anymore? I haven't read on it in a few months though, maybe misread
  30. Feb 27, 2023 at 8:03 AM
    #6030
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It comes standard with the Pro Feature set, you still need the cable to add analog or CAN inputs.
    M3Tundra-JK[QUOTED] likes this.
