General Supercharger Thread
  1. Feb 26, 2023 at 11:46 AM
    #5971
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  2. Feb 26, 2023 at 11:48 AM
    #5972
    M3Tundra-JK
    Scott
    2005 GX470
    Gotta be something with the fuel pump, guessing
  3. Feb 26, 2023 at 11:49 AM
    #5973
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    15psi when the engine is idling? Something must have come loose, if you don't see any leaks it's probably a connection in the tank.
  4. Feb 26, 2023 at 12:00 PM
    #5974
    M3Tundra-JK
    Scott
    2005 GX470
    What I'm thinking too...damn dropping the tank sucks, especially cause I just filled it up!!! Stupid 38 gallon tank
  5. Feb 26, 2023 at 12:01 PM
    #5975
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Fuck with the FPR. The aeromotive FPR on my buggy did something similar. I had it set and then when it actually drove it seemed to settle in and the FPR almost jammed up, I had to open the pressure back up and then it came back to normal. Almost like a seal in there expanded and decreased the pressure.
    reywcms and M3Tundra-JK[QUOTED] like this.
  6. Feb 26, 2023 at 12:17 PM
    #5976
    M3Tundra-JK
    Scott
    2005 GX470
    When you say open the pressure back up, you mean removing the vacuum line? I ran back through the instructions, taking the vacuum hose off and adjusted the top screw, but the pressure didn't seem to change at all.
    While looking things over I did notice that the fuse in the ignition port was lose. And the errors on the dash were VERY similar to when I was originally doing the wiring in that area. It may have wiggled while driving and caused a chain of events, idk I hope. Maybe that put me into limp mode. Also the nut on the top of the positive battery cable wasn't fully tightened. I've cleared the temp codes with ODB Fusion. But the permanent lean codes were still there. The dash errors for trailer brake and whatnot went away, positive that was related to the IGN lose fuse. Disconnected battery for a while and recheck in a bit
  7. Feb 26, 2023 at 12:21 PM
    #5977
    snivilous
    SW UT
    Yea I meant the adjustment top screw. If that doesn't change your pressure then it would seem like it'd have to be a fuel pump issue, but I'm not familiar with the AEM FPR.
    M3Tundra-JK[QUOTED] likes this.
  8. Feb 26, 2023 at 1:06 PM
    #5978
    M3Tundra-JK
    Scott
    2005 GX470
    Hmm...how long do I need to leave the battery unplugged to clear the ECU? I left both cables off about 15 minutes, still there. Then left just negative off for about 15 minutes, still there. Then messed with my Autel MaxiDAS, but it only supports vehicles up to 2015. It was able to read and clear one code related to anti lock brakes, but didn't see the lean codes. Odb Fusion still has two permanent lean codes. The truck hesitates to crank at first, takes 2-3 seconds I assume to prime the fuel line. Then seems to idle and rev as normal, but the fuel pressure gauge still only reading 15 or less. Linked a vid to it. You can see the dial move barely when I slow rev to 3k rpm
    https://youtu.be/CjF7CGjwdJA
  9. Feb 26, 2023 at 1:17 PM
    #5979
    snivilous
    SW UT
    Oh it is an aeromotive FPR! And you screwed the top screw in and out? Can you make it have less fuel pressure so you know it's actually doing something or that the gauge actually works?
  10. Feb 26, 2023 at 1:28 PM
    #5980
    M3Tundra-JK
    Scott
    2005 GX470
    I took the screw all the way out beforehand and tapped the fpr with a mallet. I'm also leaning towards the gauge not working but want to really double check everything before I go on another drive, and would really like for the permanent lean codes to go away first. But I crawled under the truck with flashlight and camera, all external connections to gas tank seem to be fine.
    HulkSmurf14 likes this.
  11. Feb 26, 2023 at 1:33 PM
    #5981
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The lean codes are a direct effect of low pressure, replacement gauges can be found at local autoparts stores if you want to rule it out.
  12. Feb 26, 2023 at 1:34 PM
    #5982
    snivilous
    SW UT
    Did you put the screw all the way in?
  13. Feb 26, 2023 at 1:38 PM
    #5983
    M3Tundra-JK
    Scott
    2005 GX470
    Not all the way in, no, like 75% probably. I'll do that next.
    I got the M3 battery on the charger since it was dead early. It's a nice day, so guess I'll take it for a spin to the store
  14. Feb 26, 2023 at 1:38 PM
    #5984
    Saltyhero13
    Saltyhero13 Throbbing Member
    I hope that's not what she said! :)
  15. Feb 26, 2023 at 1:46 PM
    #5985
    Saltyhero13
    Fairly sure it is 15mins.
  16. Feb 26, 2023 at 1:52 PM
    #5986
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry, hope it's easily resolved.
    The joy of modding!
  17. Feb 26, 2023 at 2:00 PM
    #5987
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I hope it's resolved quickly too! HAS to be the FPR...
    I just order led my glowshift cradle and PSB-1 gauge!
    M3Tundra-JK and e30cabrio like this.
  18. Feb 26, 2023 at 2:15 PM
    #5988
    M3Tundra-JK
    Scott
    2005 GX470
    O'Reillys didn't have any. And the one I got from AutoZone was $46. Didn't notice till I got home it only reads to 15 psi lol.
    Wynnded and HulkSmurf14 like this.
  19. Feb 26, 2023 at 2:17 PM
    #5989
    M3Tundra-JK
    Scott
    2005 GX470
    I took out the current gauge and reinstalled it. Screwed the fpr down all the way so it's flush with the nut. Probably go on a test drive for a few miles and see if that resets any lean code
  20. Feb 26, 2023 at 2:18 PM
    #5990
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Those aren't clearable. I'll bet that once you get the fuel pressure sorted out and a few run cycles on it, they will go away. That's what happened with a "permanent" faulty sensor code I had yesterday. After correcting the sensor issue it went away, I never at any time disconnected the battery.
  21. Feb 26, 2023 at 2:20 PM
    #5991
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If you have a clamp on amp probe you could make sure the pump is drawing proper amps just to verify the pump itself is running. Not sure where the best place to get the clamp around a wire would be.
  22. Feb 26, 2023 at 3:06 PM
    #5992
    M3Tundra-JK
    Scott
    2005 GX470
    Went for a drive but all the codes came back. Truck seems to hesitate off the line at 1k rpm, but then seems to kick in and go
  23. Feb 26, 2023 at 3:07 PM
    #5993
    M3Tundra-JK
    Scott
    2005 GX470
    I'll call ProSpeed tomorrow and see what they say about the FPR
    And of course the fuel injection pressure tester I bought came with the female adapter, and I need the male end
  24. Feb 26, 2023 at 3:34 PM
    #5994
    M3Tundra-JK
    Scott
    2005 GX470
    snivilous[OP] likes this.
  25. Feb 26, 2023 at 3:39 PM
    #5995
    Silver17
    Eastern PA
    No worries, The fuel pump does not prime in the ON position on the tundras. It only runs when it is actually engaging the starter and after it has started.
  26. Feb 26, 2023 at 4:04 PM
    #5996
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I went with SCOL, so far so good. Mine started making noise at 7k miles.
    AZTundra[QUOTED] likes this.
  27. Feb 26, 2023 at 4:55 PM
    #5997
    M3Tundra-JK
    Scott
    2005 GX470
    Fingers crossed its a bad FPR. These two reviews kinda sounds like whats going on with me
  28. Feb 26, 2023 at 5:00 PM
    #5998
    M3Tundra-JK
    Scott
    2005 GX470
  29. Feb 26, 2023 at 5:03 PM
    #5999
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That might get maxed out if you're upgrading pulleys...base pressure set be 60psi, that only leaves room for 10psi of boost before it's unable to keep up with increased air pressure.
  30. Feb 26, 2023 at 5:10 PM
    #6000
    M3Tundra-JK
    Scott
    2005 GX470
