General Supercharger Thread
  1. Oct 29, 2021 at 4:03 PM
    #571
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    It should be easy as pie.
    I swapped my Maggie w/all associated parts, and fuel tank,off a doner truck,over to my current tundra...then put all the stock parts Off my current tundra back on the doner truck had both running and back together in my driveway over a weekend.
    : With the knowledge of others that was shared on this forum! Thank you!
  2. Oct 29, 2021 at 4:07 PM
    #572
    Saltyhero13
    Saltyhero13 Throbbing Member
    boostedtrdpro, sd172 and Dr Doobie like this.
  3. Oct 30, 2021 at 4:48 AM
    #573
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Lean code update:
    I think i found it!
    can one of you fine gents take a picture of the vacuum connection on the bottom of the front of the blower, just behind the top pulley.
    just on top of the coolant crossover.
    one of you fellas called this out many posts ago!
    Really, really....D3 helped me locate the leak when i went by there yesterday
    and yes....we are doing the stage 2. Damn the torpedoes!
  4. Oct 30, 2021 at 6:06 AM
    #574
    TFTundra
    TFTundra New Member
    Magnuson now has 2020/2021 tundra kits available.
    Dr Doobie likes this.
  5. Oct 30, 2021 at 6:15 AM
    #575
    nobodyintexas
    nobodyintexas What?
    South of Houston
    just did the chik-fil-a test..chicken mini's!.....idling in line. no code & it's 48 here.
    I'll send pictures of the culprit Monday...I used an old pipe band to fix it.
  6. Oct 30, 2021 at 6:23 AM
    #576
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    This one? Glad to hear you found something. And I take it your visit to D3 was convincing!
  7. Oct 30, 2021 at 6:26 AM
    #577
    nobodyintexas
    nobodyintexas What?
    South of Houston
    THAT!
    my hose is a smidge bigger....it was leaking when it got cold.
    you could wiggle the hose & see the air gap.
    i used a pipe band to MAKE it fit.
  8. Oct 30, 2021 at 7:55 AM
    #578
    Saltyhero13
    Thats a relief that you found it! I could see why it was hard to find.
    nobodyintexas[QUOTED] likes this.
  9. Oct 30, 2021 at 7:56 AM
    #579
    Saltyhero13
    Yes. Magnuson dropped HP Tuner in favor of OVs Tuner to make this happen.
  10. Oct 30, 2021 at 8:01 AM
    #580
    Saltyhero13
  11. Oct 30, 2021 at 8:11 AM
    #581
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I watch that channel every morning at work!...all this info is not helping the "Didero effect" of buying a S/C.
    Saltyhero13[QUOTED] likes this.
  12. Oct 30, 2021 at 11:48 PM
    #582
    LunarTick
    LunarTick New Member
    I just ordered up a Magnuson kit for my 21’ Pro. It’s hard to get away from the fact that Magnuson was the OEM provider for Toyota for years. Not to mention their kit makes plenty of power for me. I don’t plan for anything more. When are you expecting your kit?
    Dr Doobie and nobodyintexas like this.
  13. Oct 31, 2021 at 7:39 AM
    #583
    nobodyintexas
    nobodyintexas What?
    South of Houston
    as a guesstimate....is the Magnuson turning ~8psi? for a 160hp gain.
    I gained 120hp off of 6psi
  14. Oct 31, 2021 at 9:34 AM
    #584
    LunarTick
    Magnuson claims 162 hp gain. They put out like 6.5-7 psi from what I’m seeing and being told.
  15. Nov 1, 2021 at 3:45 AM
    #585
    nobodyintexas
    nobodyintexas What?
    South of Houston
    before the fix
    after the fix
    I have not seen a difference in performance.
    What would such a leak affect?
  16. Nov 1, 2021 at 3:54 AM
    #586
    nobodyintexas
    nobodyintexas What?
    South of Houston
    We are living in the golden era of horsepower.
    From >500hp Tundras to 707hp TRX's...to 1000hp Tesla's....to flat plane v-8 american supercars.
    enjoy it fellas. I am.
  17. Nov 1, 2021 at 4:11 AM
    #587
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    With the URD pulley mine gets 6+ psi at 3000ft elevation and I've seen 10+ at sea level
  18. Nov 1, 2021 at 6:22 AM
    #588
    Silver17
    Northeast
    Was it really hot out when you had yours on the dyno? If so I’d be curious if you had another go in some cooler weather if you would both make a little more boost and make even more power. Mine hits 7psi usually. I know Harrops website claims 160hp gain in stage 1 as well. Also, how soon are you planning to do the stage 2 upgrade? I’m excited to see your results. I’m on the cusp of ordering the pulley and injectors and a remote tune pack. I may do it any minute, hour, or day now depending on how impulsive I am.
    :spending:
    Dr Doobie and AZTundra like this.
  19. Nov 1, 2021 at 6:25 AM
    #589
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes...it was 93 in the garage + 1 billion % humidity
    Stage 2 - waiting on the parts from Harrop. 1 week? I had to get the grippy pulley, the regular 80mm was backordered.
  20. Nov 1, 2021 at 6:32 AM
    #590
    Silver17
    Northeast
    What did Harrop get for the parts? I checked with SDHQ and Superchargersonline. Seems like the injectors are gonna run 600 and the pulley is 140 for a Harrop or 165 for the griptec. I’ll probably just get the injectors through DAP with the tune pack. I’d budget for a different intake as well on stage 2, it seems like there’s a good chance we will exceed the MAF voltage scale with the factory 3.5” intake tube. Harrop said some customers find that limit on the 80mm, and I’ve seen a few cases now where they had to upgrade the intake to get it tuned right.
  21. Nov 1, 2021 at 6:32 AM
    #591
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Our tuning talk was good.
    I'm getting the safest, old man tune to 500whp. Nothing wild. safe AFR's.
    firming up the 1-2 shift a tad.
    and my Trans cooler comes in soon.
    Dr Doobie, cowboyjack and sd172 like this.
  22. Nov 1, 2021 at 6:36 AM
    #592
    nobodyintexas
    nobodyintexas What?
    South of Houston
    $750-ish for parts. The MAF might need a larger intake coming from airbox - he explained air math, but I zoned out...we will cross that bridge soon.
    Dr Doobie and Silver17[QUOTED] like this.
  23. Nov 1, 2021 at 6:42 AM
    #593
    nobodyintexas
    nobodyintexas What?
    South of Houston
    to add...it was so hot when I dropped off the truck in June, that I gave 4 cases of Gatorade & a case of Monster's to the shop guys.
    Dr Doobie, sd172, Platinum714 and 2 others like this.
  24. Nov 1, 2021 at 2:09 PM
    #594
    Silver17
    Northeast
    DAP says I can expect 40-50hp gain from going with bigger injectors and a tune with the 85mm. Switching to the 80mm he said is good for an extra 20-30hp on top of that. Not sure if it’s worth the extra 450-$500 for a pulley and a larger intake for that much power. Not to mention the added stress although likely minimal from the higher boost
  25. Nov 2, 2021 at 3:08 AM
    #595
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This jives with what my installer said...there was a lot more power left in it....just couldn't get to the ECU at the time.
  26. Nov 2, 2021 at 4:02 AM
    #596
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Magnuson measures at the crank. Drivetrain Loss has not been factored in. They advertise 162 gain over the stock 381 number to have 543 hp. No way anyone's stock Tundra dynos 381 at the hub or wheels.
    The Harrop is measured at the hub. This puts the stock Tundra at 318 hp which looks more reasonable with a 17% drivetrain Loss, factor that into Harrops advertised number and crank HP with their supercharger is 580 HP. I would expect there to be a little more gain on same psi with the Harrop since it is larger.
    • Stage 1 (50 State Emissions Approved) @ 6.5 psi – 478hp / 463 ft-lbs (+160hp / +88 ft-lbs over stock)
    Dr Doobie and Saltyhero13 like this.
  27. Nov 2, 2021 at 4:15 AM
    #597
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This is my understanding as well. AND I do not want to start a mag vs harrop issue.
    it's just that the Harrop is larger & by all other indications thermally cooler (visually too, but whatever). therefore, it's ability to make power are clearly obvious. The Mag turns faster & produces more heat for the same PSI.
    Both solutions are fantastic.
    on a Mustang dyno....I did 287whp stock....405whp w/stage 1. so 120-ish gain.
    mag = 543hp-17% = 450whp
    I can see the Mag putting an additional 50hp out @ 7psi with a tune. (and it not being AFRICA hot & humid during the dyno run!!!)
    Mine goes in shop today for stage 2. I deserve Stage 2.
    trans cooler arrives today. I am conserving cuss words, so as to not run out during install.
    Dr Doobie, cowboyjack, sd172 and 4 others like this.
  28. Nov 2, 2021 at 4:28 AM
    #598
    omgboost
    East Coast
    Super excited to see what the stage 2 does. I was on the fence of getting the Harrop because of your issue with the lean codes but now that you may have gotten it fixed, the urge to buy is coming back!
    I understand what you are saying about not wanting it to be a Magnuson vs Harrop issue. I just wanted to point it out that both advertised numbers are measured differently and cannot be compared directly. I wouldn't want them to think the Magnuson makes 550 HP while Harrop only makes 480.
  29. Nov 2, 2021 at 4:34 AM
    #599
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Agreed - both blowers accomplish what they set out to do. and the Mag is using marketing math.
    The lean codes are a non-issue now. it's purring like a kitten.
    It was a simple install error - using the wrong pipe clamp.
    Dr Doobie, Vr0ck, sd172 and 3 others like this.
  30. Nov 2, 2021 at 6:26 AM
    #600
    Silver17
    Northeast
    Are you expecting it to get on the Dyno today?
