General Supercharger Thread
  1. Feb 20, 2023 at 8:31 AM
    #5731
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Well hell...with the Maggy on, the Stillen intake tube is to long. And the custom tubing would require a rework of my adapter or some absurd offset couplers...
    I gotta figure this out quick like. Anyone got a Maggy intake for sale cheap?
    Saltyhero13 likes this.
  2. Feb 20, 2023 at 8:33 AM
    #5732
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Would a silicone coupler reducer cover the gap? These are up to 6" long!
    https://hpsperformanceproducts.com/...forced-transition-hose?variant=40803544924350
  3. Feb 20, 2023 at 8:37 AM
    #5733
    M3Tundra-JK
    Scott
    2005 GX470
    It's hard to see from that picture, but the intake tube is offset to the rear of the TB. I'd need two offset couplers, one 4.5" to 4.5", and a 4.5"-3.5". The offset reducing couple is proving hard to find
  4. Feb 20, 2023 at 8:39 AM
    #5734
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Wow, that's miles off...not sure what your options are, other than modifying that box to change the entry angle.
  5. Feb 20, 2023 at 8:46 AM
    #5735
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The intake tube that comes with the Harrop is flexible, wonder if that might would work for you? Temp MAF rube replacement until you find a better solution? Top right in this pic
    Ponderosa_Pine and M3Tundra-JK like this.
  6. Feb 20, 2023 at 8:47 AM
    #5736
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    That sucks & I'm going to have a similar issue. :(
  7. Feb 20, 2023 at 8:49 AM
    #5737
    M3Tundra-JK
    Scott
    2005 GX470
    Maybe. I'm going to think on this till this afternoon. Other option is to order the TRD Intake Tube, if I can verify the Supercharger part number separate from the non s/c TRD intake tube.
    https://parts.sparkstoyota.com/p/TR...0300140AC.html?clickSource=relatedPerformance
    https://parts.toyota.com/p/Toyota__...-Air-Intake-System/69528501/PTR0300140AB.html
  8. Feb 20, 2023 at 8:53 AM
    #5738
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You may be able to buy at least the lid off of this guy. He was switching to a non SC lid. https://www.tundras.com/threads/wanted-stock-air-box-lid.120026/
    M3Tundra-JK[QUOTED] likes this.
  9. Feb 20, 2023 at 8:54 AM
    #5739
    Silver17
    Eastern PA
    The bottom half of the airbox is the same as any 07-13 tundra which can probably be found cheap and easy. I have the magnuson tube and clamps I could send you.
    M3Tundra-JK likes this.
  10. Feb 20, 2023 at 8:57 AM
    #5740
    Saltyhero13
    Saltyhero13 Throbbing Member
    I would rework your printed part to accommodate parts as they are available. The other option is to use a duct coupler to route your intake through it and seal it off in similar manner like I did.
    When I looked at offset coupler reducers they only dropped in 1/2inch increments and the elbows make them hard to trim down to cover shorter lengths.
    A flexible coupler pipe like @armyoffoo is suggesting could work to but the largest size I could find was 4 inches. Spectre #9775
    https://smile.amazon.com/gp/product/B00553PQCY?ie=UTF8
    PM me your addy and I can ship it out to you at no cost.
    NOTE it is not recommend for boost applications.
  11. Feb 20, 2023 at 9:00 AM
    #5741
    M3Tundra-JK
    Scott
    2005 GX470
    Will pm you. I'm thinking I could get away with using the magnuson tube and some couplers. I may have to get the stock lower box back out of storage since it looks like it's outlet is more in a straight line with the TB than the still is.
    I gotta go do some work work, though. Monday's UGH
  12. Feb 20, 2023 at 9:00 AM
    #5742
    e30cabrio
  13. Feb 20, 2023 at 9:01 AM
    #5743
    e30cabrio
    Damn job getting in the way of life!
    :D
  14. Feb 20, 2023 at 9:05 AM
    #5744
    Saltyhero13
    Not a whole lot of flex to this one. I have a longer one off of the Supercharger parts store that is more pliable but longer and it is rated for boost applications.
  15. Feb 20, 2023 at 9:05 AM
    #5745
    Silver17
    Eastern PA
    Sounds good. Just be aware the magnuson lid won’t work with the factory 2014+ lower air box. 14+ is a good bit smaller.
  16. Feb 20, 2023 at 9:05 AM
    #5746
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Same problem here. I should be out doing more data logs but nooo, gotta work
  17. Feb 20, 2023 at 9:19 AM
    #5747
    Silver17
    Eastern PA
    I wonder if the boosted rating is in regards to positive pressure, like if used for turbo outlet charge piping. I’d guess it would probably be ok on a SC application where it would be more of a slight vacuum.
  18. Feb 20, 2023 at 9:47 AM
    #5748
    Saltyhero13
    Not sure but a good point. The Amazon listing states "Not recommended for turbo-charged and super-charged engines". The product box gives no such warnings and only states its for an intake. What I've found is some couplers list their PSI ratings but most don't.
    This particular product is pretty stiff so not a lot of flex to it. I have a flex coupler from the SCer parts store you linked that is rated for SCs but it is longer and more flexible. Personally I don't like the ribbed surface, I think it will generate turbulence but I'm not an ME/Aero guy so what the frack do I know. In a pinch to get the project running I think it will be fine while he figures our a permanent solution.
    Looking at the small physical envelop and the tight angles I would work from the TB side into the box to figure out a solution. You can redesign your 3D printed part but you can't change the TB angle or dimensions.
    e30cabrio and M3Tundra-JK like this.
  19. Feb 20, 2023 at 10:34 AM
    #5749
    e30cabrio
    Anyone know about Magnuson serials & build dates? The SC has a 2017 date but the bag the pump & injectors were in have a '21 date.
  20. Feb 20, 2023 at 10:53 AM
    #5750
    armyoffoo
    armyoffoo Member
    Cypress, TX
    This is getting ridiculous... here is a Parts/Price list for converting my existing fuel delivery setup (2x6AN pump feeds to Y-block 8AN to engine bay Y-block back to 2x6AN feeds for fuel rails and 2x6AN return to FPR and 6AN return to tank) to a 8AN solution from pumps to FPR.
    Prices are totals where Qty greater than 1, not including tax and shipping, void where prohibited, available while supplies last, may cause uncontrollable flatulance...
    From XAT:
    XAT Racing 3UR Fuel Rails Fuel Rail Color: Anodized Black
    Qty 1
    $925.00
    From Five-O Motorsports
    Denso; 2008-2019, 5.7L, 4.6L, V8, Sequoia, Tundra
    Part Number: 23250-00150, (12349) (12350) Tundra Sequoia 5.7
    Options
    EACH 750cc
    Qty 8
    $800.00
    From Racetronix:
    Bulkhead, -8AN to 10mm Barb, BLK
    Qty 2
    $11.68
    Fuel Tube, 120 x 10mm, Black
    Qty 2
    $3.19
    Fuel Tube, 125 x 8mm, Black
    Qty 2
    $3.19
    From Summit Racing:
    AEI-15674 - Fuel Block, Y-Type, Aluminum, Black Anodized, Male -8 AN Inlet, Male -8 AN Outlets
    Qty 2
    $159.90
    Vibrant Performance 28008
    Qty 9
    $142.11
    Vibrant Performance 28808
    Qty 3
    $88.77
    Vibrant Performance 28408
    Qty 2
    $49.18
    Vibrant Performance 28908
    Qty 1
    $24.59
    Vibrant Performance 28976
    Qty 1
    $14.59
    Vibrant Performance 28978
    Qty 1
    $15.59
    Aeromotive 15610 - Aeromotive AN O-Ring Adapter Fittings
    Qty 2
    $49.90
    EAR-AT100194ERL
    -6 Fuel Pressure GA Adapter
    Qty 1
    $17.04
    VPE-18968
    Hose, PTFE, Black Nylon Braided, -8 AN, 10 ft. Length
    Qty 1
    $75.99
    snivilous[OP] and M3Tundra-JK like this.
  21. Feb 20, 2023 at 10:55 AM
    #5751
    e30cabrio
    Wow, that's pricy.
  22. Feb 20, 2023 at 11:32 AM
    #5752
    Silver17
    Eastern PA
    Some of these fuel mods seems a bit unnecessary unless you’re running a +5 psi pulley and sending it down the drag strip every weekend, or making frequent pulls from 0-120. But that’s just my dumb opinion, and humble income speaking.
    snivilous[OP] and reywcms like this.
  23. Feb 20, 2023 at 11:39 AM
    #5753
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It is definitely overkill for now.
  24. Feb 20, 2023 at 11:49 AM
    #5754
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Hoping to get some time to upgrade the internals this summer, now that I have all the parts ready to go.
  25. Feb 20, 2023 at 11:50 AM
    #5755
    Saltyhero13
    Nice! What compression ratio?
  26. Feb 20, 2023 at 11:52 AM
    #5756
    armyoffoo
    armyoffoo Member
    Cypress, TX
    9:1
  27. Feb 20, 2023 at 11:52 AM
    #5757
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    update...
    Well…It needs a re-tune. Alex said the present tune is 90% of what he expects.
    If I drive like an old man (I do), then this tune is OK. However - I want it ideal.
    650 injectors are @74% at WOT. this is good
    MAF is smooth. this is good.
    Bad:
    AFR’s don’t drop below 11.4
    AFR bumps to 13 @ 4200rpm. Not good.
    The cat protections thing is messing with the AFR.
    So…he is fixing all that.
    should be done later today....Can't get over to Tomball till Wed.
    Life is still good.
  28. Feb 20, 2023 at 11:56 AM
    #5758
    Silver17
    Eastern PA
    Interesting, mine one the 650s runs up to 86% duty cycle on the same pulley. I’m guessing the difference is yours is tuned to run 11.4, mine is tuned richer than that causing the duty cycle to be higher? I’d say while it’s getting tuned upgrade the intake, but I guess it’s just some minor adjustments if you do so down the line.
  29. Feb 20, 2023 at 12:01 PM
    #5759
    Silver17
    Eastern PA
    @nobodyintexas are you also still using the paper filter in the intake, along with the carbon filter in the lid? That could also account for some reduced airflow and therefore less fueling demands, me thinks.:monocle:
    Did he say what psi it was hitting?
  30. Feb 20, 2023 at 12:02 PM
    #5760
    nobodyintexas
    nobodyintexas What?
    South of Houston
    He said will put it in the 10's @ WOT....I bet I get to your 86% number.
    I've been without the truck for 2 weeks...the AEM boost gauge was faulty from the factory & had to wait on a new one.
    I just want the truck back.
    and I agree ...If I add a larger intake down the road. it should be easy for Alex to tune that in - now that it will be HPT.
    You really miss a s/c Tundra when you have to drive an old GMC with 368k miles on it. (one of our truckers let me borrow it)
