General Supercharger Thread
  1. Feb 19, 2023 at 1:11 PM
    #5701
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Ok tip for anyone with the Magnuson. After trying a few different things to get the bolts started in the recessed areas, enough to torque em down with something that'll fit, realized a long flathead would work just fine.
    I did have to remove the PS fuel rails, impossible to get to them otherwise
  2. Feb 19, 2023 at 1:54 PM
    #5702
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  3. Feb 19, 2023 at 2:02 PM
    #5703
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that's to hold the long water pipes that go down to the oil cooler next to the oil filter if your truck is so equipped. Not all have that. If yours does, you probably had to loosen the A/C compressor to remove the originals. If you didn't need to do that, I don't think that you'll need to worry about it.
    M3Tundra-JK likes this.
  4. Feb 19, 2023 at 2:25 PM
    #5704
    e30cabrio
    I took that from the instructions I downloaded, don't know if I have that. I'll look but in case I need it what's the thread pitch?
  5. Feb 19, 2023 at 2:33 PM
    #5705
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'd look at your truck to see if you have the coolant pipes first. If you do, you'll have to remove them and the bolt that's currently there, then you could use that bolt at the hardware store to compare to their thread gauge. That's the best I got.
    e30cabrio[QUOTED] likes this.
  6. Feb 19, 2023 at 3:19 PM
    #5706
    M3Tundra-JK
    Scott
    2005 GX470
    What size belts are people using with the smaller Griptec pulley on the Maggy? I got the 113" gates belt, but impossible to get it on.
  7. Feb 19, 2023 at 3:25 PM
    #5707
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    112.4" listed on the first page of the thread. It's a bitch, you need to pry it over with a screwdriver. Make sure the tensioner is fully cranked too. It's not easy, especially with a new belt.
  8. Feb 19, 2023 at 3:28 PM
    #5708
    M3Tundra-JK
    Scott
    2005 GX470
    Ah, screwdriver, not finger lol. Which pulley is best to try and slip the belt over?
    Also, forgot the front page had info now! I was trying to use the search function
    HulkSmurf14 likes this.
  9. Feb 19, 2023 at 3:29 PM
    #5709
    snivilous
    SW UT
    The supercharger pulley is what I always did.
    And actually since you have the Griptec, you might be better off pulling the pulley and put the belt on and then it might just slide back onto the shaft. That's how my pulley is designed and works brilliantly. I'd think the Griptec would function the same even if the hub isn't chamfered.
    M3Tundra-JK[QUOTED] likes this.
  10. Feb 19, 2023 at 3:30 PM
    #5710
    Kung
    KG, VA
    Heh.
  11. Feb 19, 2023 at 3:36 PM
    #5711
    e30cabrio
    Here's what I can see. Looks like there are coolant lines.
    Also, the vacuum fitting came tiny item, medium box.
  12. Feb 19, 2023 at 3:42 PM
    #5712
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes they are. I don't know if it says in your set of instructions, but mine said that you'll need to loosen the A/C compressor through the wheel well to slide if forward to replace those lines. You won't need to disconnect anything else A/C related, just have to make some room between it and the block.
  13. Feb 19, 2023 at 3:50 PM
    #5713
    e30cabrio
    Yup, move the compressor is there. Guess I'll bet the 10 bucks and get those studs.
    Thanks
    Wynnded likes this.
  14. Feb 19, 2023 at 3:59 PM
    #5714
    M3Tundra-JK
    Scott
    2005 GX470
    That was exactly it, thanks! Had to take the pulley off the hub and then it slipped right on. Only Griptec doesn't have any keyways like yours does, and now I gotta blindly line up the screw holes
  15. Feb 19, 2023 at 4:31 PM
    #5715
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Or the idler usually is the one to slip it on last.
  16. Feb 19, 2023 at 4:41 PM
    #5716
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    I'm using this one, seems like they all slip some.Screenshot_20230219-193949.jpg
  17. Feb 19, 2023 at 6:06 PM
    #5717
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I love this "the making if an awesome truck" series! Nice work @M3Tundra-JK!!
  18. Feb 19, 2023 at 6:25 PM
    #5718
    M3Tundra-JK
    Scott
    2005 GX470
    Thanks! Can't wait to take it to some car meets
    So I'm doing the throttle body and wondering if the Harrop gang with the bad throttle body extensions could do this instead? Maggy instructions have you separate the wire loom so that it can reach the new TB connector position
    Silver17 and HulkSmurf14[QUOTED] like this.
  19. Feb 19, 2023 at 6:26 PM
    #5719
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    That's what I did to remedy mine.
  20. Feb 19, 2023 at 7:16 PM
    #5720
    snivilous
    SW UT
    I don't even remember doing that. I thought you flipped the throttle body 180 degrees and that was it :D
  21. Feb 19, 2023 at 7:19 PM
    #5721
    e30cabrio
    Is that ok? Seems like there’d be a gravity issue.
  22. Feb 19, 2023 at 7:22 PM
    #5722
    snivilous
    SW UT
    What do you think can't handle gravity being oriented the opposite direction?
    Anyways it's what the instructions said, not like I came up with that on my own :D
    reywcms and e30cabrio[QUOTED] like this.
  23. Feb 19, 2023 at 7:26 PM
    #5723
    snivilous
    SW UT
    Oh jk, I guess I did peel the wires out to go to the throttle body. I thought just flipping it prevented that but I guess not.
    M3Tundra-JK and e30cabrio like this.
  24. Feb 19, 2023 at 7:27 PM
    #5724
    Saltyhero13
    Saltyhero13 Throbbing Member
    Mine is oriented that way with the connector towards the rear. Running the RCF TB if that matters.
    snivilous[OP] and e30cabrio like this.
  25. Feb 19, 2023 at 7:29 PM
    #5725
    e30cabrio
    No idea, seems like there’d be a top and bottom. I have had TBs off other motors, not these what do I know? If you say it’s good I’m a believer!
  26. Feb 19, 2023 at 7:30 PM
    #5726
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I have the RCF throttle body and it would only go on one way, I removed the SAIS pumps so I had enough slack to reach comfortably.
    Saltyhero13 likes this.
  27. Feb 19, 2023 at 7:35 PM
    #5727
    snivilous
    SW UT
    Unless it's carbureted I don't know why any throttle body would care about the orientation. The actuator motor and airflow certainly don't care, and any springs or throttle cables don't care. One of the last steps in the instructions is to flip the throttle body so the plug is oriented towards the rear of the engine for the new TB coolant hoses.
  28. Feb 19, 2023 at 7:44 PM
    #5728
    M3Tundra-JK
    Scott
    2005 GX470
    There's a set of instructions from Toyota for 2007-13, and a slightly different set for 2014+
    Ok nevermind I see your update that you also did it lol
    e30cabrio likes this.
  29. Feb 20, 2023 at 4:20 AM
    #5729
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Thanks for sharing, I wasn’t aware of this difference between the magnuson and Harrop in regards to the TB wiring. Seems like Harrop tried to make it easier with a harness but only introduced a failure point. May have to do this to be proactive instead of having an issue roadside.
    V10Ace and M3Tundra-JK[QUOTED] like this.
  30. Feb 20, 2023 at 7:06 AM
    #5730
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I just reused the oem tb harness with zip ties to avoid any potential issue. Theres minimal tension on the wiring after a little reroute.
