General Supercharger Thread
  1. Feb 15, 2023 at 3:26 PM
    #5581
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Can you link me that vid? I must've missed it. Looks like that pump is upgraded over the TRD one, but want to see if it's the same as the ZZP
    https://zzperformance.com/products/zzp-high-output-intercooler-pump-stage-1
    also
    https://shopfigs.com/v5/L1030
  2. Feb 15, 2023 at 3:29 PM
    #5582
    M3Tundra-JK
    Scott
    2005 GX470
    Also I'm just noticing this, since I haven't gotten to the part of installing the Figs res tank, but it looks like I may be missing an Intercooler Resevoir Bracket that connects the res tank to the supercharger. I'll have to go back through my parts list to confirm
    reywcms likes this.
  3. Feb 15, 2023 at 3:30 PM
    #5583
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  4. Feb 15, 2023 at 3:40 PM
    #5584
    M3Tundra-JK
    Scott
    2005 GX470
    He doesn't mention what the lpm is, but i did notice he had to solder the new wires into that connector. The ZZP you can direct connect, even is it is a little loose. I think @reywcms pop is running it? I'll be running it soon, but can confirm the loose connection. Fixed with a little bit of electrical tape
    reywcms likes this.
  5. Feb 15, 2023 at 3:42 PM
    #5585
    e30cabrio
    He scientifically showed it was x% (don't remember) better via the speed it emptied the bucket.
    lol
    I don't mind soldering & need a relay & to make my own harness as that is missing.
    M3Tundra-JK likes this.
  6. Feb 15, 2023 at 3:49 PM
    #5586
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    10%...
  7. Feb 15, 2023 at 3:49 PM
    #5587
    M3Tundra-JK
    Scott
    2005 GX470
    Need a smarter brain than mine to figure out how to convert and compare bucket numbers to what it says on the zzp site lol but i'm guessing they're the same, just one is red!
    HulkSmurf14 likes this.
  8. Feb 15, 2023 at 4:13 PM
    #5588
    e30cabrio
  9. Feb 15, 2023 at 6:30 PM
    #5589
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d wager 10% increased flow won’t make a lick of difference in sensible heat removal. BTUs= 500xGPMxDelta T. More GPM just means less time the fluid is in the coil rejecting heat which means a lower delta T. You can have a higher GPM and a lower delta, or a lower GPM and a higher delta but either way the heat exchanger will remove X amount of heat at a given airflow across it. Too large of a pump just adds kinetic energy to the water and makes it warmer, as well as a higher amp draw. Nothing wrong with the ZZP pump, just geeking.
    Unrelated, I replaced my K&N with an AFE filter and the pesky whistle is at least half as quiet. The K&N is very thin and like a wet noodle compared to the much thicker and more rigid AFE.
    reywcms, M3Tundra-JK and HulkSmurf14 like this.
  10. Feb 15, 2023 at 6:35 PM
    #5590
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is pretty much my setup too. I installed the bypass and block off plates shortly after I purchased the truck used in 2014 as a preventative measure. Paul (Hewitt) did upgrade me a couple of times as he made a couple revisions.
    Buut, when I installed the S/C in October of 2019, I couldn't seem to get at good tune. I first used VFT and had Mat remote it. It just never ran right. I eventually slid over to HPT and had Viktor remote it. It was much, much better, but over a few hundred miles, the fuel trims got all wonky and it would run poorly again setting rich and/or lean codes and sending fuel trims all over the place. Viktor had a go at adjusting it a few more times, and he had me check for vacuum leaks as well a replacing the MAF sensor. It continued and I just decided to drive it to see how crazy it would get.
    After a while of "driving it till it breaks", I'd noticed that the temperature gauge would drop briefly and then return to normal when the vehicle was at full operating temp. I got under the hood gingerly wiggling wires and such, focusing mostly on the wiring for the bypass. I wasn't able to "make" the gauge respond, so I replaced the coolant temp sensor in the water bypass pipe (cheap and quick). Almost immediately after firing up the truck, the gauge dropped and came back up again.
    Next I removed the wiring harness of the bypass. Truck ran perfect for a few days before setting a SAIS P2445 (I think, I deleted the screenshot from my code reader). I went into HPT and unchecked the boxes for that code and have been running it without a single hiccup since. That doesn't mean a lot of miles, as I haven't been driving it much, I walk to work. I've run continuity checks on the harness a hundred ways to Sunday and don't find an intermittent wire, but there's that proprietary little black box... I intend to reach out to Paul to see if I can send the harness back to him to see if he is able to test it, as I think that something in it may have failed or gone out of spec and is sending skewed readings from the MAF to the ECU causing it to adjust fuel trims based on faulty readings giving Viktor and myself endless headaches.
    When I have had the chance to drive, I try to log as well and have my LTFTs down to a pretty steady -2% so far.
  11. Feb 15, 2023 at 6:38 PM
    #5591
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
  12. Feb 15, 2023 at 6:48 PM
    #5592
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    What crank/whp would a 2.3” pulley plus injector/pump/rcf throttle body do roughly? Guessing 9psi vs 6ish would be in the 650-700 crank range, just not sure. Then likely are in forged internals territory anyways?
  13. Feb 15, 2023 at 7:04 PM
    #5593
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes he was and can confirm the connector is slightly loose but nothing to make it come out. Zip tie or tape is sufficient back up. It’s coming out so I’ll probably throw it in mine until the blower upgrade.
    M3Tundra-JK[QUOTED] likes this.
  14. Feb 15, 2023 at 7:10 PM
    #5594
    Silver17
    Eastern PA
    That’s a hard question to answer since there is so many variables. I can say I have the Harrop and was told by DAP that a custom tune adds 40-50hp and the Harrop equivalent pulley to the 2.30 (80mm) adds another 20-30. So basically a tune and pulley should give another 60-80hp. RCF TB might add 10-20 more if your intake is set up right? Add in some longtubes and you’ll get even more out of it. Id guess you would be in the neighborhood of 500whp and maybe 620ish crank which is still supposedly safe. The consensus seems to be 600whp is where it starts getting iffy.
  15. Feb 15, 2023 at 8:13 PM
    #5595
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Stock supercharger claims 550hp @ 21.7psia, at 9psi that's 23.7psia which would be ~600hp at the crank, which matches up with @Silver17 post
  16. Feb 16, 2023 at 6:38 AM
    #5596
    M3Tundra-JK
    Scott
    2005 GX470
    I just placed an order and looks like they came matched. The Flow sheet had them all at 750, one was at 749.
  17. Feb 16, 2023 at 9:29 AM
    #5597
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    So what’s the go to Spark Plugs? IKH24?
  18. Feb 16, 2023 at 9:41 AM
    #5598
    Saltyhero13
    Saltyhero13 Throbbing Member
    MRP custom length 8" intake vs ProSpeed. There is a very slight difference in ID as the PS is not perfectly circular on the TB end; on average it is less than 1/32 difference. Reused the Vibrant no weld vacuum fitting.
    Pricing for the tube w/o screen was $173 and w/screen $207 at the time. Does not include S&H.
    The Vibrant part is the 16mm $10.99 SKU#2896. I used a step drill bit to make a 5/8" hole.
    reywcms, e30cabrio, Silver17 and 4 others like this.
  19. Feb 16, 2023 at 10:29 AM
    #5599
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Ikh22's unless you're above 8 psi imo
  20. Feb 16, 2023 at 10:53 AM
    #5600
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'd have had these on since putting the Harrop on. 80mm pulley
    M3Tundra-JK and V10Ace like this.
  21. Feb 16, 2023 at 10:53 AM
    #5601
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Thanks ! Stage 2 Harrop.
  22. Feb 16, 2023 at 10:54 AM
    #5602
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Thank you! Are these pre-gapped for our rig/set up?
    reywcms likes this.
  23. Feb 16, 2023 at 10:55 AM
    #5603
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I think so.
    vq35721[QUOTED] likes this.
  24. Feb 16, 2023 at 11:09 AM
    #5604
    Silver17
    Eastern PA
    vq35721 likes this.
  25. Feb 16, 2023 at 11:15 AM
    #5605
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Are you on the .031 gap they come with or tighter?
  26. Feb 16, 2023 at 11:22 AM
    #5606
    Silver17
    Eastern PA
    I left mine alone as they came.
    vq35721 and V10Ace[QUOTED] like this.
  27. Feb 16, 2023 at 1:35 PM
    #5607
    e30cabrio
    Viktor is retired I asked Magnuson for the base tune & told them that I'm a flex Sequoia, they sent a canned we don't have an application for that vehicle, I screen shot the Tundra version from their site & said they are the same, I'd appreciate the file & crickets.
    Anyone have a flex base file I can "borrow"?
  28. Feb 16, 2023 at 3:05 PM
    #5608
    Silver17
    Eastern PA
    I’d just take it for a custom tune at Xact dyno in Tempe, AZ since you’re not far. I hear a lot that the tuner there named Tim does great work tuning these engines.
  29. Feb 16, 2023 at 3:10 PM
    #5609
    e30cabrio
    I worked with Tim in the mid 2k's on my stroked high compression Z, he was great to work with. The machine shop did a shitty job on the build and the motor blew a custom JE piston. I know it was not Tim's fault (the shop blamed the tune) I did not know he worked on these, I'll give him a call.
    snivilous[OP] and Silver17 like this.
  30. Feb 16, 2023 at 3:13 PM
    #5610
    Saltyhero13
    ...and done. Test drive tomorrow.
    Before:
    After:
    Jcmf52, HulkSmurf14, Rodbolt and 8 others like this.
