General Supercharger Thread
  1. Feb 1, 2023 at 12:08 PM
    #5431
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Well.. found the 3k cutout problem.
    Fuel delivery is working as intended and doing the modifications to the basket did drop afr's significantly in a non ffv basket.
    Starting off with the 75mm pulley was the cutout issue. We swapped to the 80mm and all problems went away. Could it be the stock exhaust? Could it be the plugs? Dunno
  2. Feb 1, 2023 at 12:15 PM
    #5432
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    interesting hmmm. Can you swap and regap plugs and throw the other pulley in?
    Silver17, HonorNotInner and trddriver like this.
  3. Feb 1, 2023 at 12:17 PM
    #5433
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Honestly I'm gonna roll with the 80mm for now as I need my truck back and I'm gonna need lube for the labor bill after all this back and forth bs. I'm at sea level and should still see ~10psi.. I'm happy with that.
  4. Feb 1, 2023 at 1:33 PM
    #5434
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    With the 80 I left the plugs at .029. Didn’t have to gap lower till I switched to the 75mm so you should be good.
    trddriver and V10Ace[QUOTED] like this.
  5. Feb 1, 2023 at 1:35 PM
    #5435
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    So are you still running the stock heat range plugs at the stock gap? If so it does kind of make sense to think the plugs/gap are indeed the culprit. Either way, it should run great on the 80. DAP had told me if I was going to use the truck for heavy towing that the 80 was a good place to stop for reliability.
  6. Feb 1, 2023 at 1:38 PM
    #5436
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Yeah still using oem plugs that havent been pulled.. truck has 15k miles. Ikh24's will be here Friday but will hold off on installing them if I can. Good info regarding the 80mm and pulling as I do pull a TT often
  7. Feb 1, 2023 at 3:10 PM
    #5437
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Well at least it's running and the hard part is done. I'd be interested at what boost it was having issue before. Sure it could be the plugs, but I thought blowing out the spark usually happened at really high boost, and around 10psi I'd think even the stock plugs are fine. But at least now you don't need a shop to do testing like that since plug and pulley change takes three wrenches.
    Make sure it's running well and how you want and then incrementally start stepping the power and mods up when you want.
  8. Feb 1, 2023 at 3:16 PM
    #5438
    snivilous
    SW UT
    Also I am back from 1200 miles of driving and the first trip in awhile to sea level with the supercharger. I didn't touch the tune, and my fuel trims appeared to stay within 5% or so. 2.3 pulley made shy of 9psi at sea level, nearly the same the 2.0 makes at 5500ft. Part of me feels like the 2.0 would've been fine since I've done 11psi before, so what's 13psi at sea level :D
    But that ended up being good testing, my boost predictions for a stock truck have been correct within a psi across two pulleys and from sea level to 10000ft, and now we've confirmed that if you tune for max boost then step to a larger pulley the same tune should be fine.
  9. Feb 1, 2023 at 3:18 PM
    #5439
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    It's at ~10 psi now on stock plugs and running way better with no cutout on an initial tune from PS. With the 75mm it was at ~12psi. Now that we got the cutout issue solved, PS is going to continue sending revisions. Looking at posts on Boosted Tundras FB page, at my elevation and 12 psi through the Harrop I'd be over 600whp on pump gas. I feel better with the 80mm on stock bottom end.
  10. Feb 1, 2023 at 3:18 PM
    #5440
    snivilous
    SW UT
    I suspect the difference between say Fastlane and my truck and why he makes more boost with the same pulley is all down to intake and exhaust. If the only variable you change is pulley size, and you have one data point of your pulley/boost/elevation then you can accurately predict the boost for other pulleys and elevations.
  11. Feb 1, 2023 at 3:23 PM
    #5441
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Shop said the Harrop is quite the whiner with the fender cutout and PS intake. Something else for the wife to bitch about :rofl:
  12. Feb 1, 2023 at 3:27 PM
    #5442
    Silver17
    Eastern PA
    I thought women liked to be whined and dined… or did I read that wrong?
  13. Feb 1, 2023 at 6:55 PM
    #5443
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Just an FYI for anyone in the NW that Shrek from DAP will be in town to do in person tunes for n/a and s/c trucks second weekend of Sept. He's gonna spend some time in Idaho, WA, and OR. He's always a hard guy to get a hold of
    trddriver likes this.
  14. Feb 1, 2023 at 7:13 PM
    #5444
    Silver17
    Eastern PA
    I’m on the verge of tossing in the DAP towel despite liking my current tune. Just came up on a month of no return communication. Was thinking I’ll give him to the end of this week…
    V10Ace and reywcms like this.
  15. Feb 2, 2023 at 3:31 AM
    #5445
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  16. Feb 2, 2023 at 3:47 AM
    #5446
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I like when he says intake air affects power output!! :). Everything about a vehicle should affect the power output!:)
    The truck has to breath to put out power,, no breathy no power!:)
    V10Ace likes this.
  17. Feb 2, 2023 at 4:01 AM
    #5447
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Dynos are fun, but Dragy tells you if the bull is shitting in the buckwheat.
  18. Feb 2, 2023 at 5:55 AM
    #5448
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Video proof of this whiner please!
  19. Feb 2, 2023 at 6:09 AM
    #5449
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Agreed..although surface conditions come into play with them dragy runs. I'm assuming you guys are in 4wd?
    I'd say it's still not as loud as a Mag, especially a pullied one, but the Harrop has been known to be quiet. I'll get video asap
  20. Feb 2, 2023 at 6:12 AM
    #5450
    ssmokedz
    Shelton CT
    Ya I've driven both and the Harrop is definitely a little bit quieter.
    V10Ace[QUOTED] likes this.
  21. Feb 2, 2023 at 6:26 AM
    #5451
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes...4hi
    it's painfully quiet.
  22. Feb 2, 2023 at 6:45 AM
    #5452
    ssmokedz
    Shelton CT
    What are you seeing for 60 foots? I've been pretty consistent at 2.0. I'd love to get it a little lower but i guess I'm asking a lot for a full size truck on 35's. I have only done runs on the stock maggy tune but will try the new tune from OTT soon.
    reywcms likes this.
  23. Feb 2, 2023 at 6:55 AM
    #5453
    nobodyintexas
    nobodyintexas What?
    South of Houston
    no idea on the 60ft's I guess I don't have the Dragy set to measure that.
  24. Feb 2, 2023 at 7:00 AM
    #5454
    ssmokedz
    Shelton CT
    I think it has to be on 1/8th or 1/4 mile runs to get a 60' time. I've done a lot of 1/8 mile pulls because i don't feel like getting arrested for doing a full 1/4 lol. Are you primarily just getting 0-60 times?
    M3Tundra-JK likes this.
  25. Feb 2, 2023 at 7:02 AM
    #5455
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yeah...just 0-60
  26. Feb 2, 2023 at 7:03 AM
    #5456
    ssmokedz
    Shelton CT
    what kind of times are you seeing?
  27. Feb 2, 2023 at 7:06 AM
    #5457
    nobodyintexas
    nobodyintexas What?
    South of Houston
    5.4-5.5
    5.2-ish with rollout.
    stock intake. 80mm 650cc's
    Saltyhero13 and Silver17 like this.
  28. Feb 2, 2023 at 7:08 AM
    #5458
    ssmokedz
    Shelton CT
    That's about what i'm seeing. Pretty consistent 5.4's but i have run a 5.2 before on a nice cold day. I'll see if i have a dragy video i can post.
    Silver17 and nobodyintexas like this.
  29. Feb 2, 2023 at 7:09 AM
    #5459
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I am, as others will tell assure you, not great at 0-60's.
    I'm sure one of y'all could squeeze 5.1 out of it. 4.9-ish with rollout.
  30. Feb 2, 2023 at 7:11 AM
    #5460
    Silver17
    Eastern PA
    It still records 1/8 and 1/4 mile times even if you weren’t in it for the whole stretch which should give you accurate 60ft times. Just go to your 1/8 mile runs and look at the 60ft. Mine are mostly 1.9x with a best of 1.91 I believe. @ssmokedz I’ll add you to a group chat we have going to discuss these things and post dragy runs. I wouldn’t post it here as the admins aren’t fond of it unless you can prove it was at the track. Also if anyone wants to be a part of said chat, and isn’t yet just let me know. We have a few dragy runs posted there.
    snivilous[OP] likes this.
