General Supercharger Thread
  1. Jan 30, 2023 at 9:16 AM
    #5371
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    all right, all right, all right...
    bringing the bitch in to get AFR & Boost gauges installed & re-dyno'd.
    getting a schedule today.
    HPTuners will be used if they see any issues to fix.
    yes, graphs will be provided.
    Black@Blue19 and M3Tundra-JK like this.
  2. Jan 30, 2023 at 9:27 AM
    #5372
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Any install guides out there for these two? I need to do mine. And I'm a lost without instructions kinda guy.
  3. Jan 30, 2023 at 9:29 AM
    #5373
    nobodyintexas
    nobodyintexas What?
    South of Houston
    we are simpatico
    hence, why I'm having it done.
    I know me.
  4. Jan 30, 2023 at 9:57 AM
    #5374
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Trying to recall how I did mine. I believe I ran a hot wire on a 10amp fuse from the battery + terminal to through the normally open contacts of a small relay and hooked the load side of the relay to the power wire for the gauges. This provides the power to energize the gauges and the wideband O2 sensor heater. I then used a fuse tap on the ignition fuse inside the fuse panel below the steering wheel that was hooked to the coil contacts of the relay. When the ignition is turned ON, this energizes the relay and powers the gauges.
    Other than the wiring, it’s just welding in the O2 sensor bung and installing the sensor, and then teeing in the boost gauge transducer at the boost port of the blower.
    Edit: I drew a terrible picture how I recall wiring it. Is even a bad picture worth a thousand words? If there’s more than one gauge they just get wired in parallel.
  5. Jan 30, 2023 at 4:23 PM
    #5375
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Oh.. Well, guess I got lucky then.. For once in my life.
    Wynnded[QUOTED] likes this.
  6. Jan 30, 2023 at 7:01 PM
    #5376
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I stuck with VFT for quite a while hoping that it would get sorted so that it'd work on my truck. The aforementioned workaround functioned, but there were fueling glitches that just couldn't seem to get resolved, so I hit up Viktor. Now I have proper fueling and I'm eyeing what @snivilous is doing with his transmission tuning. I haven't actually made any changes to what Viktor has done though. I've just been crushed at work and don't normally drive much during the winter, but I'll get around to it.
    snivilous[OP] and HulkSmurf14 like this.
  7. Jan 30, 2023 at 7:14 PM
    #5377
    cjscinta
    cjscinta New Member
    Nashville TN
    Thank you for the info.
  8. Jan 30, 2023 at 8:48 PM
    #5378
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'd hardly call anything I've done transmission tuning. I just have the torque converter setup to engage instantly in 4-6 and use Viktors line pressure and torque reduction tweaks. Nothing fancy really. Like I said, it does what I want and I don't see a need for direct shift or gear lock, since it tends to feel that way already between the gears and blower.
    Wynnded[QUOTED] and trddriver like this.
  9. Jan 30, 2023 at 9:23 PM
    #5379
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    I'd love gl and ds but only in s. But I say that bc right now at my elevation (still na) I think I'd prefer to be able to lug a lower rpm up a hill instead of finely tuning my throttle input to JUST shy of the truck downshifting.... I imagine more torque from the SC may actually remedy that a bit and perhaps less throttle angle would produce more power negating the need for downshift, but that's all speculation at this point.
  10. Jan 30, 2023 at 9:36 PM
    #5380
    snivilous
    SW UT
    Yea that's how mine drives, it needs to be a pretty nasty hill for it to downshift to 5th, it adds in a few psi of boost and makes enough power before it hits the shift point usually.
  11. Jan 30, 2023 at 9:39 PM
    #5381
    snivilous
    SW UT
    Hopefully that fucking pulley you bought shows up soon, because running the 2.3 pulley right now feels so fucking slow :rofl:
  12. Jan 30, 2023 at 9:40 PM
    #5382
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    At least your shits moving :rofl:
    snivilous[QUOTED][OP] likes this.
  13. Jan 30, 2023 at 9:41 PM
    #5383
    trddriver
    '14 1794
    open to discussion
    I'd love that.. I'm more pissed bc I'm already in 5th and the downshift to 4th is what I'm avoiding... I'm working on the boss. Then I'll bug about the tips when I install and tune. Hell, even if I deal with my rotten tranny tuning but with a blower I'll be happy!
  14. Jan 30, 2023 at 9:43 PM
    #5384
    snivilous
    SW UT
    I know how you feel. The stock transmission setup was one of a handful of things I hated about the truck almost to the point of selling it. The supercharger actually made cruise control work right and 6th be viable and not constantly searching. Granted I think tuning can fix that, but from day 1 of the supercharger the transmission behaviour was 100% better.
  15. Jan 30, 2023 at 9:47 PM
    #5385
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Dap tune fixed the hunting and hanging bs with my 08 and 21 while na. I'd highly recommend a tune to anyone just because of that. Better throttle response and noticeably more power.
  16. Jan 31, 2023 at 3:47 AM
    #5386
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    I did just hear back from Mat at VF that the GL/DS patch will for sure come to 2007-17 Tundra, although he gave no indication on the timeline for it. I'll keep you guys updated though.
    Wynnded likes this.
  17. Jan 31, 2023 at 4:22 AM
    #5387
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm still on Viktor's tune, only making adjustments to lower LTFTs based on your post some time back. In that same post, I noticed that your transmission table had different values than mine though. I don't know what the reason is for that, but it got me to thinking that I could tweak mine a little to see how that changes things to give me a better understanding and possibly make it more suitable to my driving style. I have this one hill that I hit frequently where it lugs just a bit too much for my comfort.
  18. Jan 31, 2023 at 8:28 AM
    #5388
    nobodyintexas
    nobodyintexas What?
    South of Houston
  19. Jan 31, 2023 at 2:47 PM
    #5389
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Referenced back through thread and saw Harrop guys were having issues with 3k rpm cutout. Now we're experiencing that.. it'll cutout and get right back into it. Seems too quick to be a fuel issue.
    We tried removing the maf and tb harness extension as noted in this thread and neither fixed it.
    Edit: It doesn't cutout while ~1/2 throttle. Only WOT
    mustang67408 likes this.
  20. Jan 31, 2023 at 4:19 PM
    #5390
    Silver17
    Eastern PA
    Have you caught it on data logs? I could never make it do it repeatedly. It was a once in a blue moon thing, and I haven’t experienced it in a while.
  21. Jan 31, 2023 at 4:22 PM
    #5391
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Installing external pressure gauge now and then will data log and send to PS. It's doing it every time for us.. feels like the traction control kicking in but its fully disabled with "trac off" on the dash.
    Wanted to touch base on the Ti 450 pump. Website says this pump wants a 25a circuit while I believe Tundra's have a 15a circuit. We used PS's splice kit and followed their directions and they haven't mentioned anything about it.
  22. Jan 31, 2023 at 5:17 PM
    #5392
    M3Tundra-JK
    Scott
    2005 GX470
  23. Jan 31, 2023 at 5:22 PM
    #5393
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    M3Tundra-JK[QUOTED] likes this.
  24. Jan 31, 2023 at 5:26 PM
    #5394
    Silver17
    Eastern PA
    The higher the fuel pressure the higher the amp draw will be. 14.1 amps is only at 40psi. The base pressure for tundras is 43.5, if boost referenced it may exceed 50. Prospeed wants the regulator at 60psi I believe? It’s easily drawing over 15 amps.
    M3Tundra-JK likes this.
  25. Jan 31, 2023 at 5:30 PM
    #5395
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    HulkSmurf14, Silver17 and M3Tundra-JK like this.
  26. Jan 31, 2023 at 5:30 PM
    #5396
    M3Tundra-JK
    Scott
    2005 GX470
    Second question, and may be dumb, but if nothing else is drawing from that line, can you just drop in a larger fuse?
    armyoffoo likes this.
  27. Jan 31, 2023 at 5:31 PM
    #5397
    armyoffoo
    armyoffoo Member
    Cypress, TX
    No, I wouldn't trust the stock wiring to handle 15 amps continuous, let alone any higher.
  28. Jan 31, 2023 at 5:31 PM
    #5398
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I guess this is the info I was looking for. Tomorrow morning we're going to drive it around and watch the gauge. PS hasn't said anything about running a dedicated circuit for this setup.
    trddriver and M3Tundra-JK like this.
  29. Jan 31, 2023 at 5:32 PM
    #5399
    M3Tundra-JK
    Scott
    2005 GX470
    Welp...guess I'll find out in the next week or two if I have a similar issue
  30. Jan 31, 2023 at 5:33 PM
    #5400
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Truck revs fine, truck goes through the rpm range fine at ~half throttle. Under WOT conditions it's hitting a brick wall/breaking up at exactly 3k rpm.
