General Supercharger Thread
  1. Jan 29, 2023 at 4:14 PM
    #5341
    Saltyhero13
    Saltyhero13 Throbbing Member
    I think Viktor has a 6" with a TB from a Chevy or something. Looks crazy.
    HulkSmurf14[QUOTED] likes this.
  2. Jan 29, 2023 at 5:36 PM
    #5342
    nags
    nags New Member
    2008 SC RCSB w/ all the goodies.
    Matt Smith is a legend. Pretty much if he says it, it can be taken as gold. He is the reason my truck is up and running perfectly.
    mZiggy, Silver17 and Black@Blue19 like this.
  3. Jan 29, 2023 at 5:37 PM
    #5343
    nags
    nags New Member
    Transmission tuning was done by Chris @ Prospeed as part of my remote tuning package.
    trddriver likes this.
  4. Jan 29, 2023 at 5:40 PM
    #5344
    nags
    nags New Member
    What do you mean by 'Gear Lock'? ProSpeed set my Tow/Haul button to lock my transmission in whatever gear I put it in manually... So if that's what you mean.. We did it on mine. It was required for tuning.
  5. Jan 29, 2023 at 5:44 PM
    #5345
    Saltyhero13
  6. Jan 29, 2023 at 5:55 PM
    #5346
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I saw they have a custom billet upper oil pan with a lower oil pan that looks like it's quite a bit bigger. So hard to get parts from over there back here though, never heard back from PerfectLamda that makes the plug and play adapter for the bigger GM throttle body that Viktor is rocking.
    nags and Saltyhero13[QUOTED] like this.
  7. Jan 29, 2023 at 6:03 PM
    #5347
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Saltyhero13 likes this.
  8. Jan 29, 2023 at 6:05 PM
    #5348
    Saltyhero13
  9. Jan 29, 2023 at 6:06 PM
    #5349
    Saltyhero13
    I think that one has a Harrop, Harrop or HP interviewed them. Dig the widebody kit; looks like a bulldog.
    Silver17[QUOTED] likes this.
  10. Jan 29, 2023 at 6:14 PM
    #5350
    Silver17
    Eastern PA
    Yup you’re right. Here was that video which includes some more details on it. Reminds me of @Fastlane47 truck but this one is 4x4 I think. https://m.youtube.com/watch?v=tRwj6256Kbw
  11. Jan 29, 2023 at 6:47 PM
    #5351
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Gear lock is activated when you press T/H with the VFT tune...it ensures you srat un the gear you select and will not shift for you while in (S)equential mode...amazing features for towing...I hope HPt finds this stuff out!!
  12. Jan 29, 2023 at 6:53 PM
    #5352
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    With VFT it's supposed to be when the shifter was put in S-Mode and a top gear was selected, like 2nd, if you punched it, it wouldn't downshift. The same for any other higher gear, 3rd, 4th, 5th, and 6th. It worked for some TCUs, others (like mine) needed a workaround where it would only function as intended if it was in S-Mode and T/H were both activated. Viktor attempted to replicate it with HPT, but the problem was that if you came to a stop, or slowed enough for the trans to downshift, it wouldn't upshift, even if you were to have had S-Mode set to 6th gear. If you came to a complete stop, it would not upshift from 1st gear even if you had a higher gear selected. Viktor told me that HPT didn't have access to all the tables needed for it to function as requested, or like it would in VFT.
    I asked around about seeing if there was a way to flash just the TCU or just the ECU so I could have Viktor's fueling tweaks and VFT's GL and DS features, but apparently it can't be done on the Tundras. I understand that it can on the Tacomas (flashing of just the TCU).
    HulkSmurf14 likes this.
  13. Jan 29, 2023 at 6:58 PM
    #5353
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    So just a 75mm and 650s and it’s running 12s? I can dig that.
  14. Jan 29, 2023 at 7:10 PM
    #5354
    cjscinta
    cjscinta New Member
    Nashville TN
    Question: I have a 2017 5.7 Flex fuel Magnusen supercharged Tundra Stage 1. Does anyone know what the part number is or what the best high output fuel pump I need? The stock pump is not providing enough output pressure and I want to upgrade it. Thanks.
  15. Jan 29, 2023 at 7:15 PM
    #5355
    Silver17
    Eastern PA
    I think it has ARH headers as well, but it seems that’s about it.
    If you’re not looking to go crazy with future mods and plan to keep it under 600whp the Deatschwerks 300c 340LPH is going to be the easiest fuss free drop in replacement IMO. You can also go with a bigger Walbro/Ti 450 as a few guys here have with a little more modification to the fuel basket situation which I’m sure someone else would be happy to explain.
    trddriver and ZPhilip[QUOTED] like this.
  16. Jan 29, 2023 at 7:51 PM
    #5356
    Saltyhero13
    That's what I am saying!
  17. Jan 29, 2023 at 7:59 PM
    #5357
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    I met him out in Chandler/Phoenix. Dude is super knowledgeable, it was great talking with him.
    nags[QUOTED] likes this.
  18. Jan 30, 2023 at 4:44 AM
    #5358
    nags
    nags New Member
    Hmm. Something must have changed cause that's exactly what they had me doing. They'd have me shift into 3rd and roll at like 20mph and then floor it and it would not shift at all. It stayed in 3rd until I manually shifted.
  19. Jan 30, 2023 at 5:27 AM
    #5359
    Silver17
    Eastern PA
    On my prior 2010 I had an OV/VF tune and the gear lock was all jacked up IMO. I would be towing and want to use tow/haul for the other benefits of it, and it would lock in whatever gear I had picked previously in S mode even in D if it was in tow haul. I was expecting it to only lock the gear in S mode. I lugged that engine like a SOB up the first hill til I realized it wouldn’t come out of gear lock unless I took it out of tow/haul or switched back to S and manually downshifted. I hope they fixed that on the new revisions!
    Black@Blue19 likes this.
  20. Jan 30, 2023 at 6:07 AM
    #5360
    mZiggy
    mZiggy Honey badger
    Marc
    I/YotaWerx helped Mat/VF with testing the new gearlock + direct shift for 2018+ Tundra to confirm function and it works great. Test truck was my 2020.
    The feature is already released actually for 2018+, but I did notice that some of the tables were missing after the patch is applied so I reported that to Mat and it sounds like that'll be fixed in the big VF 1.7 update that's about to drop.
    It uses S-mode only to engage it, no need to set it to T/H
  21. Jan 30, 2023 at 6:56 AM
    #5361
    Silver17
    Eastern PA
    I’m still thinking that is false. I tried looking it up, and the last time magnuson was reacquired was in 2010 by a private equity firm who appears to still own it. I think that is another one of those poorly written clickbait articles written by a wannabe automotive journalist. I see a lot of articles that look like they come from a reliable source, yet their only resource for info is from the comments section of a Facebook page from people they likely didn’t ask permission. Could be wrong though. :notsure:
  22. Jan 30, 2023 at 7:06 AM
    #5362
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It seemed to work on some TCUs but not others. There were recommended settings for tuning/dyno that may not have been great for daily driving. The 14+ ECU/TCUs were different as well, I think they had more RAM and even more different tables.
  23. Jan 30, 2023 at 7:08 AM
    #5363
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's what I was interested in for my 2011. Still don't know if its possible...
    mZiggy[QUOTED] likes this.
  24. Jan 30, 2023 at 7:10 AM
    #5364
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I did the same. And came to the same conclusion
  25. Jan 30, 2023 at 7:11 AM
    #5365
    mZiggy
    mZiggy Honey badger
    Marc
    I have a theory I'd like to test on my truck to see if I can implement it (I just keep forgetting lol), but I don't really anticipate it working so I want to say it's not possible with the current tools available
    The way Mat has been indicating his road map for various EROM features coming for different vehicles, I wonder if it's possible to give the GL/DS I helped test to the 2007-17, and maybe he just has it planned for a future feature release rather than all at once.
    HulkSmurf14 and Wynnded[QUOTED] like this.
  26. Jan 30, 2023 at 8:09 AM
    #5366
    ssmokedz
    ssmokedz Toyota Master Diagnostic Technician
    Shelton CT
    2019 Super White Tundra TRD PRO
    Damn that sucks. Sorry to hear it has been such a hassle. I've been down that road of saying "i wish i just left it alone." many many times. Hopefully you will have a finished truck soon so you can enjoy!
  27. Jan 30, 2023 at 8:26 AM
    #5367
    HulkSmurf14
    2014 Tundra Limited
    I love how it works as expected and advertised for myself...zero issues and works every time!
  28. Jan 30, 2023 at 8:40 AM
    #5368
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    We've all been there, but the beauty of these trucks is once you've got it sorted, its pretty darn reliable for what it is, one stomp on the hwy merging will make all this worth it.
    I've seen that track, there's one thing we have to keep in mind, those 1/4 mile facilities in Middle East make typical North American tracks look like road side motel, I've never seen such beautiful paved surface, I would not be surprise the results on those strips can be hard to replicate else where.
  29. Jan 30, 2023 at 8:49 AM
    #5369
    M3Tundra-JK
    Scott
    2005 GX470
    I'll be running my truck at Bandimere Speedway in April at the Test n Tune nights. Only like $45 fee. Then in May there's the Truck Invasion event
    https://bandimere.com/
  30. Jan 30, 2023 at 8:56 AM
    #5370
    Silver17
    Eastern PA
    True, but I think it’s doable given the mods. I test drove a 2014 TRD SC truck before buying mine and supercharging it. Part of the reason I didn’t buy it was I discovered there is a ton of videos of it at the drag strip on YouTube. He ran several 13.1’s on a bone stock TRD blower and tune. He said his best was a 12.8. I ran a 13.6 with 500lbs of extra weight on the truck. I bet I could hit a 13.1 if I removed it.
    Its also probably hot as balls all the time in the UAE which hurts performance.
    M3Tundra-JK likes this.
