General Supercharger Thread
  1. Oct 16, 2021 at 3:00 PM
    #421
    Saltyhero13
    Saltyhero13 Throbbing Member
    Thanks.
    So the common thread seems to be these are all methods to increase the volume.
  2. Oct 17, 2021 at 8:46 AM
    #422
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Only way to lower compression is to increase combustion chamber volume. Destroke, dished pistons, larger head volume, or thicker head gasket are the only ways to do that. Typically a dished pistons is the most common if you're serious, a thicker head gasket doesnt significantly increase the volume and destroking is relatively uncommon and more for running higher RPM.
  3. Oct 17, 2021 at 11:09 AM
    #423
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Are you going to let dinesh do the dyno tune?
    I ordered the handheld tuner and just waiting for shipping.
  4. Oct 17, 2021 at 11:22 AM
    #424
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    we'll see.
    he has to get past my 20 questions!
    I'm back to the p0171 & p0174 codes. only when i idle longer than a minute.
    the difference? a frigid cold front in Houston...we got to 58 last night!
    maybe the ECU needs to learn the cool dry air ?
    it clears fine. and I run perfect in all other instances.
  5. Oct 18, 2021 at 3:46 AM
    #425
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Re: P0171 & P0174 codes
    I'm thinking I have a vacuum leak....maybe a loose connection?
    what's the easiest way to check this?
  6. Oct 18, 2021 at 4:14 AM
    #426
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I just thought about something. When I picked my truck up my mechanic had noticed that on the Harrop provided intake tube there is 2 rubber bungs. The one closest to the intake box is used for a vent tube. The one next to the MAF is not used with the replacement FPR. He noticed that the hole went all the way through and a plug was not provided. I asked a Harrop vendor about it, and he said it should be plugged so that’s what we did. Just a thought, although I’m not sure if that would matter since it’s before the MAF. upload_2021-10-18_7-13-51.jpg
  7. Oct 19, 2021 at 5:27 AM
    #427
    nobodyintexas
    nobodyintexas What?
    South of Houston
    well. at 1st inspection I could find no leaks....the Harrop hole was plugged with the right bung.
    Tonight, I'll do the ole carb cleaner while idling trick.
    it only throws the code (P0171/P0174) at idle.
    any ideas?
    omgboost likes this.
  8. Oct 20, 2021 at 12:24 PM
    #428
    Saltyhero13
    FYI from the install manual:
    Preparation
    Testing has shown the OE fuel pump (Toyota OEM 232200S011) does not deliver enough fuel for a supercharged 3UR-FE at full load. Therefore, the fuel pump will be replaced during installation. Ensure the fuel tank contains minimal fuel, and that there is a supply of suitable fuel available to add to the tank after installation is complete. E85 fuel is not compatible.
    Initial engine start
    Minimum 91-AKI (93-RON) fuel must be used. E85 fuel is not to be used.
  9. Oct 21, 2021 at 3:54 AM
    #429
    nobodyintexas
    nobodyintexas What?
    South of Houston
    forgot to add....when it popped the code a couple days ago - I was looking at my scanguage A/F ratio...it never went below 14.5 at idle...still popped the code.
    now that warm moist air has rolled into Houston, all is well. The motor likes fog. I guess it's an air density thing?
    Maybe the ECU needs to learn dry air, as it was installed in ~june & yet to see cool dry air.
    anywho....Damn the torpedos!...Stage 2 coming soon.
    Vr0ck likes this.
  10. Oct 21, 2021 at 4:59 AM
    #430
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    https://www.lextreme.com/toyota-3ur-fe-performance-parts-2007/
    Dished 8.5:1 forged pistons anyone?
    “The current price is $1100 plus $40 shipping. If you plan to run greater then 10 psi on Tundra, then you will need these pistons. We are currently carrying all 3URFE pistons with compression and overbore size of choice.”
  11. Oct 21, 2021 at 5:03 AM
    #431
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the answer to the question I was going to ask next month.....
  12. Oct 22, 2021 at 12:17 AM
    #432
    Saltyhero13
  13. Oct 22, 2021 at 4:18 AM
    #433
    nobodyintexas
    nobodyintexas What?
    South of Houston
    1UP, Saltyhero13[QUOTED] and sd172 like this.
  14. Oct 22, 2021 at 4:25 AM
    #434
    sd172
    sd172 New Member
    South Dakota
    I can’t help but wonder what happens when one would need to sell/trade in a heavily modified vehicle. Or the insurance doesn’t want to cover any mods. I had about $10k sunk into my 2018 Tahoe by the time I traded it in for the 2021 Sequoia. The Toyota dealer gave me a fair price, but nowhere near the combined expenses.
    Stage 1 is easy to return to stock when needed.
  15. Oct 22, 2021 at 7:50 AM
    #435
    Saltyhero13
    @nobodyintexas Great point! I'm interested in higher performance as well but the supply chain issues are a big concern.
    I'll post some more as I find them and read through them. Common theme tranny and internals are an issue as you get closer or surpass 600 HP. The BRX guy heat welded his 5th gear as he was pushing 1000HP; not sure if it was in one of the posts I linked or a separate thread (think he had a 1000HP thread).
    Lower compression was talked about, comments I saw is the engine ran like shit but most didn't talk through their builds and were drive by comments.
    @sd172 I've not sold a modded vehicle but its a sunk cost in most cases unless you have a rare vehicle. I think some buyers will assume the car was abused and don't want the hassle to restore the truck to OEM
    snivilous[OP] and sd172 like this.
  16. Oct 22, 2021 at 8:30 AM
    #436
    snivilous
    SW UT
    I think if you do stuff besides bolt ons yours not too worried about resale :rofl: let alone trade in value. Someone will always buy it, just a matter of finding that person. Or like you said, if you want to get every penny back then the easy option is stay stock :D
    mustang67408 likes this.
  17. Oct 22, 2021 at 9:02 AM
    #437
    Saltyhero13
    Never speak these words again!
  18. Oct 22, 2021 at 9:03 AM
    #438
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Blasphemy!
  19. Oct 22, 2021 at 9:56 AM
    #439
    Silver17
    Northeast
    I haven’t experienced any of these lean codes on mine under any circumstances, nor have I heard of others. Someone on another post elsewhere that I was following was chasing the same codes and just finally found a torn vacuum line under the supercharger at the front of the engine (they have a magnuson). It wasn’t even visible until moving the line around since it was on the bottom side. I’d be checking all of your vacuum lines under super close inspection. If that is the issue it will follow you to stage 2 and a tune, and when you’re running more timing and bigger power then it could probably cause more catastrophic results if it causes a failure.
    Saltyhero13 likes this.
  20. Oct 22, 2021 at 10:19 AM
    #440
    nobodyintexas
    nobodyintexas What?
    South of Houston
    thanks for the thoughts on the lean codes.
    Harrop concurred with your thoughts. it's got to be a small hidden leak.
    this will be my weekend project.
    y'all have an awesome weekend!
    Jbehredt, sd172, Silver17 and 2 others like this.
  21. Oct 22, 2021 at 11:02 AM
    #441
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Saltyhero13 and nobodyintexas like this.
  22. Oct 22, 2021 at 11:45 AM
    #442
    Saltyhero13
    omgboost[QUOTED] likes this.
  23. Oct 22, 2021 at 11:53 AM
    #443
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I reckon if I wanted 1200+ hp I'd have to call Steve morris engines.
  24. Oct 22, 2021 at 12:33 PM
    #444
    Saltyhero13
    Some of those engine builds look absolutely insane
    https://youtu.be/vfvCuRMGDwY
  25. Oct 22, 2021 at 12:52 PM
    #445
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    SnowyTundra likes this.
  26. Oct 22, 2021 at 1:08 PM
    #446
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Exactly...this right here...
    I am thoroughly enjoying this ride. not, the least bit concerned about trade in value. I'll get what i negotiate.
    I'll get at least 8 years out of it...i traded in an '06 Sequoia for it! that ride was bullet proof.
  27. Oct 22, 2021 at 3:25 PM
    #447
    sd172
    sd172 New Member
    South Dakota
    It is all about the perceived value. Did I have fun modifying my Tahoe? Absolutely. Did I do some minor mods to the Sequoia? Yes.
    Do I want to keep the powertrain stock? We shall see.
  28. Oct 22, 2021 at 5:27 PM
    #448
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Is the 19-20 on the magnuson website a new thing? I haven’t looked in a while. I see the power numbers are different that an 18 or prior. Also a note about a small starter issue on 20s. Looks to me like they’ve got a tune worked out.
    AZTundra likes this.
  29. Oct 22, 2021 at 5:33 PM
    #449
    AZTundra
    Paul
    Phoenix, AZ
    That is new...wonder why the hp and torque dropped a bit.
  30. Oct 22, 2021 at 5:50 PM
    #450
    Saltyhero13
    And this:
    **Attention model year 2020 Toyota Tundra starters will remain energized for 3-5 seconds as a known effect of the calibration. Note the starter will NOT remain engaged once the engine is running and therefore will not have a detrimental effect on the starter or ring gear.
    AZTundra[QUOTED] likes this.
