General Supercharger Thread
  1. Oct 25, 2022 at 12:38 PM
    #3841
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I remain intrigued by the CVT solution tho.
    Silver17 likes this.
  2. Oct 25, 2022 at 12:47 PM
    #3842
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If it's any excuse, the stuff I work on is in a complete vacuum so any time I've looked at pressure it's always positive :rofl:
    Wynnded[QUOTED] likes this.
  3. Oct 25, 2022 at 1:01 PM
    #3843
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Basically that’s my issue. I could use a simpler “restrictor plate” with a varying size hole in it for testing purposes for the time being. A Venturi restrictor tube would obviously flow a lot nicer with less turbulence for long term.
    The pressure before and after the Venturi would be different. That’s essentially the point of the Venturi restrictor, it causes a restriction resulting in a pressure drop across it.
    You’re not wrong. Now I have to stop chatting it up in this thread, I have to clean my whole house with the vacuum…errr… I mean pressure differential cleaner.
  4. Oct 25, 2022 at 1:09 PM
    #3844
    snivilous
    SW UT
    Silver17[QUOTED] likes this.
  5. Oct 25, 2022 at 1:27 PM
    #3845
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe we should just call it suction and be done with it, I wonder if it'll catch on.
  6. Oct 25, 2022 at 1:31 PM
    #3846
    Silver17
    Northeast
    That sounds cool. What kind of stuff?
  7. Oct 25, 2022 at 1:32 PM
    #3847
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  8. Oct 25, 2022 at 3:04 PM
    #3848
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  9. Oct 25, 2022 at 3:09 PM
    #3849
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I miss getting packages lol I'm having withdrawals lol
    M3Tundra-JK[QUOTED] likes this.
  10. Oct 25, 2022 at 3:31 PM
    #3850
    snivilous
    SW UT
    Spacecraft, so usually I specify pressure as like 10^-6 torr, which is like 1/1000th micron and that's a pressure we specify for components since they want to know what level of vacuum we're operating in. Might contribute to the difference in semantics :D
  11. Oct 25, 2022 at 3:51 PM
    #3851
    Silver17
    Northeast
    That’s cool! Haven’t you learned anything from this discussion? Theres no such thing as a vacuum, that’s .00000193PSIA dude! :rofl:
    actually I did that wrong! It’s .000000002PSIA lol
  12. Oct 25, 2022 at 3:55 PM
    #3852
    snivilous
    SW UT
    Like I said, that's beyond my field of expertise :p I just make sure the space bridges don't collapse :D
  13. Oct 26, 2022 at 8:08 AM
    #3853
    M3Tundra-JK
    Scott
    2005 GX470
    Looking for a part
    Watched a vid and it said that if you don't have the tow package on the Tundra, then the Oil Cooler Tube Manifold isn't needed from the fit kit. Does anyone have this part left over they want to sell? Or know the part number for it? Got the Thermostat Bypass Manifold already
  14. Oct 26, 2022 at 8:11 AM
    #3854
    snivilous
    SW UT
    I did some welding on my stock tubes and then just ran two rubber lines from the top to the bottom. Mine didn't come with those long ass oil lines either.
    Wynnded and M3Tundra-JK[QUOTED] like this.
  15. Oct 26, 2022 at 11:23 AM
    #3855
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think I used heater hose...lol.
    snivilous[QUOTED][OP] likes this.
  16. Oct 26, 2022 at 11:23 AM
    #3856
    Silver17
    Northeast
    I got a reply from smoothboost today. I have to send them some pictures of how the bypass bolts up to the Harrop blower. He claimed they may already have something for it.
  17. Oct 26, 2022 at 11:40 AM
    #3857
    snivilous
    SW UT
    I assume it's still vacuum operated and their setup just acts like an adjustable hard stop?
  18. Oct 26, 2022 at 11:42 AM
    #3858
    M3Tundra-JK
    Scott
    2005 GX470
    I have to double check the thermostat bypass manifold they sent because I'm pretty sure it was a rubber hose, but looking at older fit kits online they're both originally metal.
    I'm probably just gonna assume my truck will be out of order for a solid week cause I'm bound to be missing something when I go to put everything together
  19. Oct 26, 2022 at 11:44 AM
    #3859
    snivilous
    SW UT
    Go through the manual and make sure you have the parts pertaining to each step, thats what I did.
  20. Oct 26, 2022 at 11:58 AM
    #3860
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The lines that run coolant down to heat exchanger next to the oil filter from the factor are metal, as are the ones in the fit kit. You'll need to remove the front driver wheel to access the the A/C compressor bolt(s) to pull it away from the block to remove the stock lines, and if you had the fit kit lines, install them then. As I didn't have the fit kit lines, I just ran heater hoses from the heat exchanger back up to the front/top of the engine. Remember to try to make note of which hose connects where to retain designed directional flow of the coolant. I zip tied the hoses to be sure that they wouldn't contact the belt checking them just about every time I open the hood and replace the ties when my paranoia gets the best of me as we all know they become brittle with time in that environment. I should probably upgrade to something more durable, but here we are, years later.
  21. Oct 26, 2022 at 3:45 PM
    #3861
    Silver17
    Northeast
    I’m honestly not sure how it works. I think it’s totally electric and probably ties into the throttle body to determine when to close the bypass valve, and is very much a full modulating analog signal. It’s intention is more to smooth out the application of boost I believe.
  22. Oct 27, 2022 at 7:34 AM
    #3862
    M3Tundra-JK
    Scott
    2005 GX470
  23. Oct 27, 2022 at 7:35 AM
    #3863
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Nope...I don't have one on my "regular" TRD Airbox lid...
  24. Oct 27, 2022 at 7:37 AM
    #3864
    M3Tundra-JK
    Scott
    2005 GX470
    I know it's not necessary, just an oddity I didn't expect to see in the instructions. Never heard of anyone running one before
    HulkSmurf14 likes this.
  25. Oct 27, 2022 at 7:37 AM
    #3865
    HulkSmurf14
    2014 Tundra Limited
    Just another thing to make sure you feel better when spending all that money on the airbox! Hahaha
  26. Oct 27, 2022 at 7:58 AM
    #3866
    Warreng
    Warreng New Member
  27. Oct 27, 2022 at 8:00 AM
    #3867
    M3Tundra-JK
    Scott
    2005 GX470
    Is it actually useful in determining when the filter is dirty enough to be changed or cleaned?
  28. Oct 27, 2022 at 8:10 AM
    #3868
    Warreng
    Warreng New Member
    with the K&N it never moved a millimeter even after it was quite dirty.
    i put a WiX filter in a few months ago and I would assume it will move as it it gets dirty?
    Dont think I would spend $$ on one.
  29. Oct 27, 2022 at 8:23 AM
    #3869
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My airbox has the Filter Minder and they're standard on our medium duty commercial vehicles where I work. They seem pretty superfluous. I've never seen one that indicated more than a few mm of restriction on the indicator and can't imagine an air filter so dirty that it would indicate even half near maximum restriction on the Minder, it would need to be phenomenally restrictive and you'd probably recognize an incredible reduction in performance from an engine. For a consumer vehicle, they're just a visual farkle (eye candy). They probably have a useful application in a very dirty, dusty environment, like having shovels of dirt or a hibernating bear cub packed into your airbox.
  30. Oct 27, 2022 at 7:41 PM
    #3870
    Saltyhero13
    Saltyhero13 Throbbing Member
    reywcms likes this.
