General Supercharger Thread
  1. Oct 12, 2022 at 1:45 PM
    #3601
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Didn't quite follow your question, but maybe this is the answer: E85 is just 85% ethanol, and subsequently E100 or E10 is 100% and 10% ethanol respectively. The amount of ethanol mixed isn't really an altitude thing, just dependent on the fuel. My understanding is since ethanol inherently has a higher octane number than gasoline, there are no additives to increase the effective octane, thus it's not advertised as an octane number. So 91 octane E10 which is the most common, has an octane of 91 and 10% ethanol. E85 doesn't list an octane, because it's effective octane is like 107 and (presumably) there are no/fewer additives to the 15% gasoline in E85 since the ethanol more than makes up for it.
    This is also why you see some high performance vehicles running E85, E100, methanol, etc. is alcohol has (some) advantages over gasoline like octane rating. Going back to your question though, as far as I'm aware there are not different blends of ethanol based on altitude. However since gasoline requires additives to bring the octane rating to a useful level, there is lower octane gasolines at higher elevations to save money for fuel companies since the higher elevation neuters the performance of the engines. So sea level needs 93 octane, but at 5500ft you have 2.7psi less of manifold pressure so are less likely to predetonate, so only need 91 octane at elevation for the same timing to be used.
    Hopefully that didn't insult your intelligence and maybe answered what you're asking. I'm not a chemist so take it with a grain of salt.
  2. Oct 12, 2022 at 1:51 PM
    #3602
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    That answered my clumsy worded question, thanks!
    snivilous[QUOTED][OP] likes this.
  3. Oct 12, 2022 at 2:06 PM
    #3603
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Did you try to clean your MAF sensor and see if that helps? So far as I could tell, it didn’t happen to me again after cleaning mine. Just curious, and maybe it would save you a diagnostic bill if it is something that stupid.
    Saltyhero13 likes this.
  4. Oct 12, 2022 at 4:34 PM
    #3604
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Nice!!!!!!:) Super Duper:)
  5. Oct 12, 2022 at 5:16 PM
    #3605
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    This could be a stupid thought/question. But if we max out the MAF with an 80mm pulley and record peak HP. If we swapped a 75mm in there would we still reach the same peak HP but with higher HP throughout the power band?
  6. Oct 12, 2022 at 5:50 PM
    #3606
    boringdriver
    boringdriver New Member
    2015 LX 570
    yeah, I tried that.
    Saltyhero13 and Silver17[QUOTED] like this.
  7. Oct 12, 2022 at 5:51 PM
    #3607
    M3Tundra-JK
    Scott
    2005 GX470
    Just placed order for a bunch misc fit kit parts $1200 from bochtoyota, they had the cheapest prices on those parts. Cheapest Fit Kit to buy whole atm is $2700. Also bought the TRD water coolant crossover manifold off sconline separately since it was cheaper there.
    • Brake Vacuum Hose
    • Thermostat By-pass Manifold Kit
    • Low Temperature Radiator (LTR) Wiring Kit
    • Belt Idler Pulley Bracket Kit
    • Belt Idler
    • Inrclr Pump Mntg Bracket
    • Intrcolr Mntg Hw Bag
    • Hose Kit
  8. Oct 12, 2022 at 6:24 PM
    #3608
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  9. Oct 12, 2022 at 6:31 PM
    #3609
    Silver17
    Eastern PA
    My guess is it would make more power throughout, and also at peak assuming the fueling is there to safely support it. The fueling is probably more of a guess on the tuners part in that situation though if it’s maxing the MAF that much sooner in the rev range. It’s probably hard to tune the fuel to match the airflow if there’s no way to accurately measure the airflow.
  10. Oct 12, 2022 at 7:36 PM
    #3610
    snivilous
    SW UT
    I think so, yes. Then the normal issues once you get to the point of maxing the MAF and start leaning out.
  11. Oct 13, 2022 at 5:06 AM
    #3611
    Silver17
    Eastern PA
    I know I’m maxing out the MAF even on the street, but the first time I ever actually got the code for it (P0103) was the 1/4 mile runs last week. Maxing it out for over 3 consecutive seconds I believe trips it. I disregarded it since I already knew what was causing it.
  12. Oct 13, 2022 at 5:27 AM
    #3612
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ditto
    I have my SGIII set to beep when I hit 500 whatevers on the MAF. I guess grams per second? ~512 is the CEL limit. (5 volts)
    anyway, I got the beep once, doing a WOT onto the hwy. I was >5000rpms. which is rare territory for me.
    I reckon all you 4.5" Intake fellas are beyond that thru MAF tuning.
    Silver17[QUOTED] likes this.
  13. Oct 13, 2022 at 6:03 AM
    #3613
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I thought you were running the maggy box? Last time my CEL came on, I cleaned my MAF sensor and so far no CEL. I’m installing the maggy box next week and have an appointment with my Tuner. We will see what happens
  14. Oct 13, 2022 at 6:47 AM
    #3614
    Silver17
    Eastern PA
    Not yet. That maggy box is in my plans for the future. I’m trying not to spend much on the truck right now. Got a baby on the way. I’m not expecting any benefits from switching the intake. It’s just something I figure I should probably do just cause I like to have things done right. Other than that one time I got the P0103 code I’ve had no issues with maxing the MAF out, it runs great and I don’t have any lean issues. I was under the impression DAP has tuned a bunch this way with the stock intake.
    vq35721[QUOTED] likes this.
  15. Oct 13, 2022 at 6:50 AM
    #3615
    M3Tundra-JK
    Scott
    2005 GX470
    Any new word on the AFE s/c intake for the Tundra? I was looking at their stuff last night and noticed they have a Supercharged Specific intake for 4Runner/FJ.
    vq35721 and Silver17 like this.
  16. Oct 13, 2022 at 6:58 AM
    #3616
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    They finished scanning etc on my contacts truck now we wait. No new update as of late, but I think it'll be a bit before it's available.
  17. Oct 13, 2022 at 7:09 AM
    #3617
    Silver17
    Eastern PA
    I still may just use the stock box with one of those 4.5” MAF tubes and 2 silicone adapters. Easy and cheap, and no reason it won’t work just as well.
    reywcms and M3Tundra-JK like this.
  18. Oct 13, 2022 at 7:49 AM
    #3618
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I sure hope the maggy box will solve my issue lol . If not, I might have to go this route too. Btw, congrats! Sleepless nights , here they come lol
  19. Oct 13, 2022 at 7:57 AM
    #3619
    Silver17
    Eastern PA
    Thanks! That’s what they tell me lol. What issue are you having exactly, which CEL did you get? Is it P0101 or P0103?
  20. Oct 13, 2022 at 8:00 AM
    #3620
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'm noticing all these issues. It's because ya'll dont have gold foil in the engine bay lol
  21. Oct 13, 2022 at 9:14 AM
    #3621
    snivilous
    SW UT
    Posting here so I don't forget and maybe it helps someone else:
    Belts
    The "stock" Magnuson belt is 112.6" long and is the Dayco 5081125 for $43 on Summit: https://www.summitracing.com/parts/dac-5081125
    The smaller belt for the Magnuson is 112.4" long. There's two options:
    Continental 4081124 for $39 on Amazon: https://www.amazon.com/Continental-4081124-8-rib-Multi-V-Serpentine/dp/B000EI4N6U
    Gates K081124HD for $49 on Amazon (this belt is also sold on DAP Tuning website for $62): https://www.amazon.com/Gates-K081124HD-V-Belt/dp/B001R5ZB6U
    There are no belts that I can find that bridge the gap between 112.4" and ~110". Going from a 2.3" pulley to a 2.0" pulley is around a 0.5" less arc length, so ideally a ~112" belt would be preferred (potentially) but I can't find anything close to that.
    ViktorG in a thread says a reliable way to stop belt slip is with the billet Harrop tensioner, but seems to dead end after that and possibly has been discontinued.
    Couplers
    My coupler is starting to make noise. I BELIEVE the coupler is from August 2019 when I installed a ZZP Performance BLACK replacement coupler. However, I had my supercharger fully rebuilt in February 2021 by Superchargers Online however the invoice and emails did not state replacement of the coupler at that time. So potentially the ZZP Black coupler lasted ~3 years and ~65k miles or the SCOL coupler lasted a year and a half and ~35k miles.
    The Superchargers online coupler kit (includes o-rings) for $150, made from PEEK: https://superchargersonline.com/product/toyota-trd-magnuson-tunder-coupler-replacement-kit-updated/
    ZZP Black Replacement Coupler for $10, OEM replacement, appears to be delrin: https://zzperformance.com/products/replacement-supercharger-coupler?_pos=1&_sid=bd3e6a0af&_ss=r
    ZZP Green Replacement Coupler for $20, "oil impregnated polymer upgrade": https://zzperformance.com/products/zzp-supercharger-coupler?_pos=2&_sid=bd3e6a0af&_ss=r
    The SCOL coupler seems insanely priced to me, they're saying that because it's PEEK and has three o-rings that is worth $140 extra over a delrin equivalent.
    HulkSmurf14, Wynnded, reywcms and 4 others like this.
  22. Oct 13, 2022 at 9:25 AM
    #3622
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    P0101
  23. Oct 13, 2022 at 9:30 AM
    #3623
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Might as well do the gold foil. It will match my wheels and suspension set up haha
  24. Oct 13, 2022 at 9:52 AM
    #3624
    Silver17
    Eastern PA
    See that’s what is interesting, the P0101 is technically not for MAF voltage ceiling. That’s the P0103 code. P0101 is more of a ghost CEL that seems to plague a lot of supercharged tundras. If I recall, even the TRD superchargers had a service bulletin a long time ago to try and address it from Toyota. A possible issue with the MAF wiring harness on the Harrop may be making the P0101 pop up more though, seeing as @boringdriver stopped getting that code once get disconnect the IAT breakout loom. For now it’s seems pretty inconsequential, just reset and go.
  25. Oct 13, 2022 at 10:05 AM
    #3625
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    I thought that issue on the maggy was because of the Airbox? :-( When I had her tuned, tuner told me that I was maxing the MAF voltage, sure enough a couple of days later, P0101 popped up. I was running the stage 1 for about a year with no CEL til I got her tuned. Damn, so basically I might be having 2 diff issues now? Lol
  26. Oct 13, 2022 at 11:04 AM
    #3626
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I had a feeling the belt would be an issue in my research I couldn't find one either. What's the Harrop tensioner look like? Again, referencing old cobra/lightning days we did larger idlers and upper idler tensioners. So lets say stock is 80mm going to a 90mm or 100mm. Full billet idlers etc.
  27. Oct 13, 2022 at 11:09 AM
    #3627
    snivilous
    SW UT
    The Harrop one just looked like beefed up components, but I can't find much info on it. Increasing the tensioner or idler diameter is an interesting and easy idea I hadn't thought of.
    reywcms[QUOTED] likes this.
  28. Oct 13, 2022 at 11:13 AM
    #3628
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    For reference http://www.billetflow.com/IdlerBracket.htm
  29. Oct 13, 2022 at 11:15 AM
    #3629
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Larger idlers would help us get a larger belt easier in theory lol
  30. Oct 13, 2022 at 1:23 PM
    #3630
    M3Tundra-JK
    Scott
    2005 GX470
    Awesome notes! I had and removed from my parts list order yesterday the Toyota 8 rib belt. However it is less than $30. OEM s/c belt part number is PTR30-34070 https://parts.frontiertoyota.com/oem-parts/toyota-trd-supercharger-belt-8-rib-5-7-v8-ptr3034070
