General Supercharger Thread
  1. Oct 11, 2022 at 1:57 PM
    #3571
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  2. Oct 11, 2022 at 11:49 PM
    #3572
    boringdriver
    boringdriver New Member
    2015 LX 570
    I need to drop it off to Prospeed to identify the issue. No codes, just that nasty cutoff every now and then. It’s odd, sometimes it’s hard to replicate the issue. Other times, it’s so easy. Having no codes for this long tells me using the oem throttle cable and avoiding the breakout MAF cable has worked in terms of no death pedal/limp mode or the P0101 code, respectively
    Silver17[QUOTED] likes this.
  3. Oct 12, 2022 at 3:52 AM
    #3573
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    IMHO In supercharged 5.7 Toyota applications there are no advantages to get long tube headers and a full 3 inch race system. At the end of the day it will cost you boost/power and you will need to do additional mods just to get your boost back to what it was with OEM or just a cat back system. It’s definitely worth having a conversation with Keith @dirtydeeds he is truly the foremost expert on exhaust systems for these trucks and has tried every single variation of exhausts and modifications that you can do and he will be the first to tell you that you can’t really screw up an exhaust system with a supercharger unless you put long tube headers on it then that’s a whole different story. ViktorG has long tubes but is running stock exhaust/ muffler to get that much needed backpressure back so there is no loss of boost.
  4. Oct 12, 2022 at 4:38 AM
    #3574
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this is my contention as well*.
    Exhaust matters little in a S/C'd situation.
    Look at the tiny little intake/MAF hole(3.5") for your power gains.
    *Albeit, my contention is completely uneducated & amateurish.
    HulkSmurf14 likes this.
  5. Oct 12, 2022 at 6:46 AM
    #3575
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I watched these two videos and still couldn't really say that I have an opinion. They didn't address our specific application scenario directly, but I would think that there'd be some aspect of what's being said that's applicable. With that said, when I upgraded to Doug Thorley headers on my S/C'd 5VZ-FE, I was able to advance the timing significantly and eliminate a ton of High Gear Low RPM pinging and I'm sure some power particularly in the bottom end.
  6. Oct 12, 2022 at 6:54 AM
    #3576
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I think they help the motor breathe better. It is all about air in and air out. I had the LTH and 3 inch exhaust before the SC and it did make a big difference naturally aspirated. The Stage II Harrop makes 7-8 psi on my truck now. Put down 512rwhp on a Mustang Dyno about 3 weeks ago. How does that compare to the folks with similar setups and no LTH?
  7. Oct 12, 2022 at 6:58 AM
    #3577
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Headers would for sure help. When you see less boost what you're seeing is less restriction. Nothing a smaller pulley can't do to add even more power on top.
  8. Oct 12, 2022 at 7:09 AM
    #3578
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    My 2012 with the TRD s/c made more power on the stock manifolds, 522rwp and 504rwp with long tube system. Unless you are maxed out with your truck, built motor, 20psi, I wouldn't do headers. I'm tuning my truck again with a 2.3 pulley and 750cc injectors next month and I'm using the stock manifold on a magnuson kit. I will post the numbers.
  9. Oct 12, 2022 at 7:20 AM
    #3579
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    This makes me very happy to see 500+ whp on the Maggy! That's my goal
    HulkSmurf14, reywcms and Saltyhero13 like this.
  10. Oct 12, 2022 at 7:24 AM
    #3580
    Fastlane47
    Maryland
    2018 Platinum
    On my 2012 it seemed easy, much easier to tune. We shall she with the 2018, my goal is 1k at the crank, taking it step by step.
  11. Oct 12, 2022 at 7:25 AM
    #3581
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm 477hp/518tq with stock exhaust manifold - TRD cat-back - 80mm pulley - 650's.
  12. Oct 12, 2022 at 7:33 AM
    #3582
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Now I want 500whp... lol God I hate you all.
  13. Oct 12, 2022 at 7:45 AM
    #3583
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Be interesting to try and get 500whp through 37s. I went for a drive yesterday and a Rivian was in front of me through the roundabout. He got on it at the exit of the round about so of course I did also. I immediately blew the tires off. The exit of the roundabout has a slight dip/g out. Sounded wicked with the wall next to me windows open blower screaming tires screeching. lol. I'll see you soon rivian (even though I'll lose) lol
  14. Oct 12, 2022 at 8:00 AM
    #3584
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
  15. Oct 12, 2022 at 8:31 AM
    #3585
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I had a Rivian leave me in the dust getting onto hwy 30 yesterday evening, was talking to the owner at the Rocky Point trailhead. We left and he was behind me when we both turned right onto the highway, flew around me like I was standing still. Need my wife to go back to medical school and start making doctor money so I can have one.
  16. Oct 12, 2022 at 8:34 AM
    #3586
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Apparently the one I saw is my buddies neighbor. He said he tows his Jeep Wrangler with it. Told him to let him know I'll be around to help when he gets stranded during towing.
  17. Oct 12, 2022 at 8:36 AM
    #3587
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Pretty sure that at some point I'll migrate to full electric, and this is looking like the route I would go based on what's currently out there and my current vehicle usage.
    M3Tundra-JK and Tbrandt[QUOTED] like this.
  18. Oct 12, 2022 at 8:45 AM
    #3588
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Exactly, I've had some conversations with the wife to get her a plaid or a rivian or whatever, but nothing electric can replace the tundra unless I want to run out of juice by the time I get to the next town towing an empty trailer.
  19. Oct 12, 2022 at 8:47 AM
    #3589
    Tbrandt
    Tristan
    Kansas City
    Same. My neighbor and I talk about electric cars quite a bit, he has a 2 year old Model Y Tesla and he compared it to an early iPhone - the technology is moving so fast that it's already outdated. It will be interesting in 10 years to see where things are at.
    Wynnded[QUOTED] likes this.
  20. Oct 12, 2022 at 8:48 AM
    #3590
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Exactly. I get the appeal if you're using it locally or whatever. But to think it can be used remotely close to a truck or offroad/overlander is a F'n joke.
    snivilous[QUOTED][OP] likes this.
  21. Oct 12, 2022 at 8:49 AM
    #3591
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The car tech yes. Battery tech not so much lol
  22. Oct 12, 2022 at 8:52 AM
    #3592
    Saltyhero13
    Saltyhero13 Throbbing Member
    One like isn't enough. I think he was too conservative with the turbo. I expect some Flinstone sh!t next time.
    Black@Blue19 and reywcms like this.
  23. Oct 12, 2022 at 8:59 AM
    #3593
    Bluecobra
    2014 Tundra
    Yep, I am on 35s and a lifted double cab long bed. Definitely not fast, but faster than it used to be. Gotta have a locking diff....
  24. Oct 12, 2022 at 9:41 AM
    #3594
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Mine is getting 509 RWHP on 37's
  25. Oct 12, 2022 at 9:52 AM
    #3595
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Stock Toyota exhaust manifolds are the exact same as short tube headers and while LTH with 3" exhaust will get you about 25-30 HP on naturally aspirated engine it doesn't do much for a supercharged application. This is not an LS and believe me the laws of getting HP out of other type of engines really do not apply to our 5.7's. If your looking for max power with LESS headaches don't do LTH with a full 3" system. It's been proven over and over and over and over again, you gain NOTHING and you will be just chasing power to get back to where you were with OEM manifolds. The origin and development of Pro Speeds fuel system for our trucks was to FIX the AFR's and get back the loss of power on Tundras with LTH.
    Wynnded and Saltyhero13 like this.
  26. Oct 12, 2022 at 11:55 AM
    #3596
    Saltyhero13
    Sounds like stock is well tuned for scavenging.
  27. Oct 12, 2022 at 12:14 PM
    #3597
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Picked up my truck from getting Magnusson supercharger installed!
    Being careful with it for now as the “93 octane” fuel purchased turned out to be E85. Tuner noted this while looking over truck when done with install and I verified with my car scanner as well.
    really irritating that the gas was not as advertised…
  28. Oct 12, 2022 at 12:37 PM
    #3598
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That's weird. Let us know how shes runs
  29. Oct 12, 2022 at 12:40 PM
    #3599
    M3Tundra-JK
    Scott
    2005 GX470
    Highest available in Denver, due to altitude, is 91. But E85 is still available. Is there no need for different levels of E* like normal fuel at different altitudes?
  30. Oct 12, 2022 at 1:11 PM
    #3600
    Saltyhero13
    That's jacked up. I hope it gets sorted!
