General Supercharger Thread
  1. Aug 31, 2022 at 11:19 AM
    #3001
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @reywcms my next question is how did you get that video to upload to the forum? I have one I could share but I thought it had to be done via a YouTube link or similar and I’m not putting it on YouTube.
  2. Aug 31, 2022 at 11:22 AM
    #3002
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Out of curiosity, how much does a full 38 gallon tank weigh? I might have to do my run on E
  3. Aug 31, 2022 at 11:23 AM
    #3003
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I loaded to Vimeo
    Silver17[QUOTED] likes this.
  4. Aug 31, 2022 at 11:23 AM
    #3004
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
    Get a draggy. Very accurate.
  5. Aug 31, 2022 at 11:26 AM
    #3005
    greentrbo95gst
    Huntington Beach
    How is the reliability of Harrop in comparison to Magnussen? I am not trying to set any records, but pulling a lot more weight so extra 150 horse would be helpful.
  6. Aug 31, 2022 at 11:27 AM
    #3006
    Silver17
    Eastern PA
    About 230lbs. But! I would advise against doing full throttle runs anywhere below 1/3 of a tank or so. While not super likely, it possible it can starve the pump when the fuel sloshes, make you go lean, and make your engine go boom aside from the poor performance.
  7. Aug 31, 2022 at 11:28 AM
    #3007
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Scootin!!!!!!:)
    reywcms[QUOTED] likes this.
  8. Aug 31, 2022 at 11:29 AM
    #3008
    greentrbo95gst
    Huntington Beach
    Here is what draggy looks like. Test and tune runs in my m5.
  9. Aug 31, 2022 at 11:29 AM
    #3009
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    About 250lbs. Be careful, some had issues with the fuel sloshing and starving the pump. Asking for trouble. I suggest everyone posting times with 1/2 tank or greater, we don't want anyone's engine going :boom:
    Edit: Ninjaed by @Silver17
  10. Aug 31, 2022 at 11:42 AM
    #3010
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The Magnusson is far more proven, but I wouldn't worry about either for reliability. I've never heard of the blower failing unless you suck something in. There is maintenance to do but it's usually around the 100k mark. I guess one reliability issue arguably is a plastic coupler that prevents shock loads on the Magnuson and they're known to wear out. Not a catastrophic failure but the blower will get loud as it develops backlash between the nose drive and the rotors.
    Either way, both will supply more horsepower than the stock bottom end can handle. The harrop is theoretically more efficient and has more power potential and runs cooler. The Magnuson potentially has better response because it's spinning faster and is a smaller unit.
  11. Aug 31, 2022 at 12:41 PM
    #3011
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I use 6 pounds per gallon of gasoline.
    M3Tundra-JK[QUOTED] likes this.
  12. Aug 31, 2022 at 1:01 PM
    #3012
    Saltyhero13
    Saltyhero13 Throbbing Member
    +1 Harrop has a long history but it is unknown what reliability impact it will have on the Tundra.
    Silver17 likes this.
  13. Aug 31, 2022 at 1:12 PM
    #3013
    Saltyhero13
    Anyone have experience with "no weld" line fittings/bungs? Thanks
  14. Aug 31, 2022 at 1:15 PM
    #3014
    Silver17
    Eastern PA
    That being said, it should if anything be easier on the engine in the thought process of my pea brain so long as you keep the boost in check by using a reasonable pulley size like 80mm at sea level, 75mm at elevation. The only reason I say that is because lower IATs, and an IAT sensor reading the actual temperature of the air entering the cylinders is a slightly better recipe for longevity IMO. I also spent more money on my new Harrop than many of these thrifty used Magnuson fellas, so I’ll at least keep telling myself that.
  15. Aug 31, 2022 at 1:32 PM
    #3015
    M3Tundra-JK
    Scott
    2005 GX470
    I had the s/c on the Taco for 90k miles and no issues before I traded it for the Tundra. Well, the only thing we did find out over on the tacomaworld forum was that the heater hose clamp at the drivers side firewall was rubbing and pitting the aluminum housing of the Magnusun. I don't think anyone had an actual hole, but it was obvious when running your hand over the housing back there.
  16. Aug 31, 2022 at 1:33 PM
    #3016
    AZTundra
    Paul
    Phoenix, AZ
    Well I had to go into the office today for a meeting, so I figured after having the Dragy for 3 weeks now it was time to try it out. I'm not going to post my 1 timeslip that I saved because it's embarrassing (sorry team Mag, I'll redeem myself later). I need to find a quiet place to get a few runs in and find the best way to launch. First attempt was in 2wd with nannies off and I just sat there for a good amount of time with the tires spinning before I even started to get traction and move. I cancelled that run before ever hitting 60 due to the bad launch. Second attempt I had to quit as well. I tried a third launch in 2wd with the nannies turned on and when they kicked in shortly after flooring it power was held back for what seemed like almost 1.5 secs before it started to go and that run came in at 7.72s. I need to head out where it's quieter and easier to make some pulls which is what I had to do for my remote tuning pulls. Is the consensus that we should be launching in 4wd? I would imagine so...nannies on or off? Hope to get some better runs in maybe over the weekend.
  17. Aug 31, 2022 at 1:34 PM
    #3017
    M3Tundra-JK
    Scott
    2005 GX470
    Ohh....I'll have to run my E46 M3 on it also!
    And then for laughs, the 2010 JK on 37's and 4.10's lol.
  18. Aug 31, 2022 at 1:39 PM
    #3018
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    4hi nannies off.
  19. Aug 31, 2022 at 1:46 PM
    #3019
    snivilous
    SW UT
    You guys with your obvious lack of drag racing at stop lights :rofl: 2wd isn't even an option lmao
    ViktorG, Jcmf52, Silver17 and 3 others like this.
  20. Aug 31, 2022 at 2:54 PM
    #3020
    Silver17
    Eastern PA
    Thanks for the Vimeo tip @reywcms. Here is one I had recorded back in March on a closed course, obviously. This was Pre Dragy era, and I still had the larger and heavier 34s on at the time. Not sure if I had the cap on for this one or not. I want to say it was just before I got it, but did have a 3/4 tank of gas.
    https://vimeo.com/745174900
  21. Aug 31, 2022 at 3:14 PM
    #3021
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks good! I like that cluster for the additional gauges.
  22. Aug 31, 2022 at 3:17 PM
    #3022
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Bajarex talk to Josef tell him Rey/Henry sent you.
  23. Aug 31, 2022 at 3:37 PM
    #3023
    M3Tundra-JK
    Scott
    2005 GX470
    Justin from OTT explaining tings
    https://www.tacomaworld.com/threads...-overland-tailor.759590/page-27#post-27760611
    "Correct. You answered my question I think! Lets see if I understand you now :rofl:. So there is a constant base line, and the tune would be the programming you add on top of the base line? Lamens terms of course. Not trying to take anything away from the design.
    Does ignition timings etc have provisions for when under heavy load (tow) or is it same same whilst towing?
    I ask only because my butt dyno and right foot tell me that toyota seems to understand that at least from the factory because my 2016 MT doesn't lug or chug in lower RPM and when towing 3500++. It's actually nice lol. I swear it knows!
    Done alot of reading on here over the years on the MT and some will say it's the Atkinson Cycle BS that is causing the initial hesitation or lugging during MT shifts. Unless you are hammering on it."
    Sort of correct. There is a constant baseline, but the tuning we do is not "on top of" the baseline. We rewrite the baseline to our specific values which are largely derived from OEM values. Just massaged where we felt necessary. So think of it as an "enhanced" OEM mapping. The factory mapping strategy working in combination with the adaptive knock strategy gives the truck a range of ignition timing it can run for any given RPM/Load. The system is very dynamic in that it's always adjusting to find the optimal setting within the allowable range. Things like towing heavy loads, changes in fuel quality/ethanol content, heat saturation, among many other variables can affect where in that range the truck will run.
    In your specific question about towing, there's not a towing specific timing map per say, but towing will likely put the truck into areas of the ignition map it may not see during normal operation/day-to-day use. These areas are specifically mapped according to the conditions the engine sees during that RPM/Load and with input from the knock control system, the truck will be able to calculate what the optimum advance should be. So in a sense it can run different ignition advance values while towing compared to normal driving, but it's not because the ECU knows it's towing a load, it's working within the defined parameters of existing mapping based off the sensor inputs it's receiving from the engine.
    The example of your MT towing the 3500+ load at lower RPM is a good example. In this instance you're going to see much higher engine load in the manual than you would in an auto in this scenario. The load on the engine puts the engine in a state where it can produce more torque than it could at lower load. As you mentioned it's very much due to the Atkinson Cycle operation during low RPM/Load conditions. So you're spot on there.
  24. Aug 31, 2022 at 4:00 PM
    #3024
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    You probably lost a second with that full LT suspension lol.
    reywcms[QUOTED] and Saltyhero13 like this.
  25. Aug 31, 2022 at 4:15 PM
    #3025
    Silver17
    Eastern PA
    Thanks it’s the Cravenspeed mount. I would have preferred them on the pillar but not many people make them due to the side curtain airbags. Ortiz customs does but it’s at least double the price.
  26. Aug 31, 2022 at 5:06 PM
    #3026
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Maggies is as OEM as it gets, it should be able to hit reliable 600whp with appropriate fuel, and cooling, where Harrops is larger and runs at lower temp at similar CFM.
    E46 M3 @ 1/4 is an ego bruiser , be prepare for 15s pass on first few tries and tears coming down your cheeks.
    This is how I feel.
    That is actually a good call, I'm putting bags on next week, wonder if running slight inflated helps.
  27. Aug 31, 2022 at 6:40 PM
    #3027
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL and the aero of the large fenders etc
  28. Aug 31, 2022 at 8:07 PM
    #3028
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Yep! Lol . I used to have 2 37 spare tires lol. Tuner came by today to flash my ECU so I can drive her when we Dyno Tune her. Wow! Smaller pulley, bigger injectors and the long tube headers sure made a noticeable difference from my previous stage 1. She’s gonna sound hella good too when riding them whoops lol
  29. Aug 31, 2022 at 9:15 PM
    #3029
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hahaha! When’s the Dyno sesh?
    vq35721[QUOTED] likes this.
  30. Aug 31, 2022 at 9:42 PM
    #3030
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Cabe Toyota in Long Beach. They have installed a ton of superchargers on Tundras, and they installed mine. Ask for Kenny
