[GEN3] 2016 Tundra LED conversion for Rear End - Library
Discussion in 'Lighting' started by BlueBottle, Mar 5, 2017.
  1. Mar 5, 2017 at 6:41 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    So i got a little addicted converting as much as I could to LED bulbs on my truck. It took some trial and error for some of the bulbs, and for the others, I knew what works well. I wanted to put together this little library for what I run (LED) in the rear of my 2016 Tundra. So this essentially could be used for 14-up(3rd Gen).
    I'm pretty happy with the outcome with all these LED's. All of them are brighter(Day or Night) than the stock halogens they replaced. Since they are LED's they also have the instant ON/OFF that we get with LED lighting.
    • High Mount 3rd Brake Lamp [921] : VLED Red HPColor - These have been discontinued.
    This is the replacement:
    • Rear Tail/Brake [3157CK] : VLED Red Triton V3 - These have been replaced by the Triton V6s:
      • Since this is NOT being used as signal lamps, load resistor is NOT needed.
    Camera - Sony a6000
    Lens - 50mm 1.8
    Settings - SS125/F1.8/ISO100
    Taken with some daylight left to show how bright these lights really are
    https://www.youtube.com/watch?v=MAf21T-Tq-g
  2. Mar 5, 2017 at 7:10 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Reserved for future
  3. Oct 15, 2017 at 12:11 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Updated VLED parts since the ones I used has been discontinued.
  4. Oct 15, 2017 at 12:51 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good info! Thanks!
    BlueBottle[OP] likes this.
  5. Nov 17, 2017 at 5:26 PM
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
  6. Jul 7, 2018 at 1:12 PM
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    S&B CAI Raptor lights OME 612 Cooper STT PRO 295/60R20 5% Tint Husky Liners Rigid D2 Fogs on OEM Switch
    Nice!
  7. Jul 25, 2018 at 10:20 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
  8. Jul 25, 2018 at 10:54 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Great info! Thanks
  9. Jul 25, 2018 at 1:51 PM
  10. Dec 3, 2018 at 5:48 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    @BlueBottle how are those SiriusLED for the rear signal holding up? Any hyperflash issues? Thanks for posting that list!
  11. Dec 3, 2018 at 5:57 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    They are still working! I ended up getting leds up front so I had to put a resistor for that. But it lasted fine without a resistor when I had the stock bulbs up front.
  12. Dec 3, 2018 at 6:20 PM
    moviepro314
    moviepro314 New Member
    Iowa
    2017 Tundra Platinum
    Line-x Premium Spay-on bed liner, Truxedo Lo Pro Roll-up Tonneau Cover, Dual Swing Cases from Undercover, Pop & Lock Power Tailgate Lock, BottlePro 2
    Recently did a similar upgrade an LOVE them.
    VLED 921-6-R for rear turn & 3rd brake light. 3157CK-6-R for brake lights.
    Swapped the interior for 6k LEDS and love them too.
    I had no hyper flash issues. Even returned the VLR-6 resistors.
  13. Dec 3, 2018 at 6:23 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Thanks for the reply!
    Im a noob, just beginning in the LED swaps. So as long as the fronts are still stock when I change out the rear blinkers to LED-no resistor is needed. But if I also change out the fronts to LED-then a resistor is needed? Will the resistor then go in the front or back or both?
  14. Dec 3, 2018 at 6:32 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It doesn’t matter where it goes. Mine is in the front though. If you have leds both front and back you need 6ohm per side.
    moviepro314 and Vr0ck[QUOTED] like this.
  15. Jan 18, 2019 at 1:39 PM
    DigitalFusion
    DigitalFusion New Member
    MN
    '15 Platinum Crewmax
    This is a great thread. I found it by searching for solution to my tail lights being too heavily smoked. However, I'm slightly confused. Everything I found said that a standard brake light is 400 lumens. The VLED V6_KIT_R is listed as 380 lumens.
    Edit: After some digging, I see that the V3 claimed "upto 600 lumens of output" whereas the V6 shows 380. It seems as if the V6's are not as bright as the V3's, and are about the same as a normal bulb?
    Edit #2 For future searchers: I contacted VLED regarding this. Here is their response:
  16. Jan 18, 2019 at 2:45 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have had both the v3 and v6. I’m happy with both. They are both at least twice as bright as the originals but they fill out the housings well.
    DigitalFusion[QUOTED] likes this.
  17. Jan 18, 2019 at 3:08 PM
    DigitalFusion
    MN
    I just ordered everything to do the conversion, except the cargo lamps as I dont care about those.
    Just FYI, but the cargo lamps link takes me to a set of H4 headlights, and the reverse light link takes you to a "not currently available" listing. I ended up ordering what I assume is just the updated part? https://www.amazon.com/gp/product/B00MC6RQAM/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
  18. Jan 18, 2019 at 3:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks, i crossed them out. Funny you mentioned those lamps, one of them actually just took a shit last week. Replaced it with a VLED. im not buying JDM Astars anymore.
  19. Jan 18, 2019 at 3:35 PM
    DigitalFusion
    MN
    well damn. I guess if/when they die on me I'll go with VLED as well. Their customer service seems pretty damn good, and they seem to have extremely fast order processing (I had a shipping notification and tracking number within 30 mins of my order).
