GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 15, 2023 at 6:58 AM
    #2731
    ENCDuker
    ENCDuker New Member
    Picked my '23 TRD Sport up on Tuesday. First image is how it arrived stock. Second picture was yesterday with a 1.75" RC leveling kit, 35x11.5R20 Falken Wildpeak R/Ts, on the 20" OEM wheels. No rubbing at all. Love the way it sits and rides. Next step is tint the front driver and passenger windows and maybe running boards if my wife doesn't get mad getting in and out of it now.
    How I picked her up on Tuesday.
    After the leveling kit and tires.
    Cdunner, MikeL, Durtywrench and 2 others like this.
  2. Apr 15, 2023 at 7:19 AM
    #2732
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You don’t need hub rings right away and the lug nuts will centre the wheel you’ll be fine till you get some.
    nodak67[QUOTED] likes this.
  3. Apr 15, 2023 at 9:17 AM
    #2733
    Mr Smif
    Mr Smif New Member
    keith
    Louisiana
    2022 Tundra SR5
    Thanks. Lookin good!
  4. Apr 15, 2023 at 1:35 PM
    #2734
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
    Can someone explain what these hub rings are??? Thank you
  5. Apr 15, 2023 at 1:42 PM
    #2735
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    It’s just a ring that up sizes your centre bore to fit the new wheel better if they are too big. They are not needed 100% of the time, here is a pic of the ones that came with my method wheels that don’t fit. I got 3D printed ones from the shop that supplied my wheels to me that I have on.
    SPDY_TRD likes this.
  6. Apr 15, 2023 at 2:40 PM
    #2736
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Isn't the centre bore of 78.3 for some Chevy products?
  7. Apr 15, 2023 at 2:54 PM
    #2737
    nodak67
    nodak67 New Member
    JR
    thanks for the reply.
    Yaboy[QUOTED] likes this.
  8. Apr 15, 2023 at 11:11 PM
    #2738
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Check out the GramLights - a bit less than half the price. Anecdotally, they're still in the mid-low 20s, weight-wise.
    iiawah808[QUOTED] likes this.
  9. Apr 15, 2023 at 11:12 PM
    #2739
    Bourbonator
    North ID
    '23 LE CM 6.5
    And that is really disappointing. I expected much lighter from BBS.
    Durtywrench[QUOTED] likes this.
  10. Apr 15, 2023 at 11:14 PM
    #2740
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Yeah me too . They look great though . I bought some rotary forged black rhino 18s that come in at 26 pounds
  11. Apr 16, 2023 at 7:42 AM
    #2741
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Or sub $900 shipped for blackhorn bh01’s at 21 lbs- get asked daily if they are volks
  12. Apr 16, 2023 at 8:08 AM
    #2742
    Durtywrench
    Lou
    23 Tundra platinum
    None
    They don’t make an 18” do they ? They look good
  13. Apr 16, 2023 at 1:52 PM
    #2743
    Jinkx
    Jinkx New Member
    Keith
    Thank you for explaining hub rings
    Yaboy likes this.
  14. Apr 16, 2023 at 4:20 PM
    #2744
    Bourbonator
    North ID
    '23 LE CM 6.5
    The offset is a non-starter for me.
  15. Apr 16, 2023 at 5:56 PM
    #2745
    DexterL
    DexterL New Member
    12??? Volks are all 0 or negative I thought? 12-18 is perfect for these trucks
    Yaboy likes this.
  16. Apr 16, 2023 at 7:26 PM
    #2746
    Bourbonator
    North ID
    '23 LE CM 6.5
    GramLights come in a +36.
  17. Apr 16, 2023 at 7:41 PM
    #2747
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    No added lift in the back correct? This was my plan as well on my sport.
  18. Apr 16, 2023 at 8:10 PM
    #2748
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Thats a great way to start! Level it out and wait a bit to see if you want to do more or just run with the level.
  19. Apr 17, 2023 at 4:11 AM
    #2749
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Yaboy likes this.
  20. Apr 17, 2023 at 4:38 AM
    #2750
    Jinkx
    Jinkx New Member
    Keith
    + 12 little Polk like 1/2 inch depending on tire used.
    + 18 keeps you flush with fender
    -12 or -18 will def have you poking out over in inch…Zero will have you poking over an inch. More like 2 inches.
  21. Apr 17, 2023 at 5:18 AM
    #2751
    nodak67
    nodak67 New Member
    JR
  22. Apr 17, 2023 at 6:39 AM
    #2752
    DexterL
    DexterL New Member
  23. Apr 17, 2023 at 6:48 AM
    #2753
    nodak67
    nodak67 New Member
    JR
    here are the spec from the fuel website on the wheels i have (condensed from the website)
    Fuel 1 Piece Flame 6 D823 (20x9, 106.10 Bore, +20 Offset, 6x139.7 Bolt Pattern, 5.790 BSM, 2500 lbs Rating, 41lbs Weight, Lug Conical, Milled Candy Red),
    Duratrac 275/60R20 P-Rated
    edit: i am guessing the BSM (back spacing) is the deciding factor on wheels
    Yaboy likes this.
  24. Apr 17, 2023 at 6:56 AM
    #2754
    nodak67
    nodak67 New Member
    JR
    probably in aftermarket wheels we should be using backspacing instead of offset maybe?
    Yaboy likes this.
  25. Apr 17, 2023 at 7:07 AM
    #2755
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Width and offset change the backing space, that measurement is what you need to know when deciding poke. Always use for calculator.
  26. Apr 17, 2023 at 7:09 AM
    #2756
    nodak67
    nodak67 New Member
    JR
  27. Apr 17, 2023 at 7:11 AM
    #2757
    nodak67
    nodak67 New Member
    JR
    i am guessing since the oem width is like 8 or 8.5 we are not getting close to the correct bsm and offset to match the oem specs, hence the poke on the fuels.
  28. Apr 17, 2023 at 7:19 AM
    #2758
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have 18x9” +18 methods with 295/70/18. I got 1.25” spacers to add on my OEM OR 18x7.5” +60 with 275/70/18 winter tires and they will have the same poke just the diameter will be a smaller. I’m subtracting 1.25” from the OEM backing space pushing the wheel outwards.
  29. Apr 17, 2023 at 8:31 AM
    #2759
    ENCDuker
    ENCDuker New Member
    @ ColumbiaGorge that is correct, just the 1.75" in the front
    ColumbiaGorge likes this.
  30. Apr 17, 2023 at 8:36 AM
    #2760
    jimmyz
    jimmyz New Member
    Interior of BC
    2023 Limited Wind Chill Hybrid Crewmax
    Just got my summer setup on now that ski season is over:
    Trd lift kit
    Method 314 18x9 +18
    35x12.5x18 Wildpeak at3w
    no rub with front mudflaps off
