GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 16, 2023 at 10:03 AM
    #2521
    OneFishDotNet
    OneFishDotNet New Member
    Side View
    Front
    a_double, DimaA, Maharisc and 2 others like this.
  2. Mar 16, 2023 at 5:51 PM
    #2522
    Fxclm5
    Fxclm5 New Member
    is it me or does it seem like a way bigger population of tundra owners lift/wide stance frog leg style/tires
    vs other owner groups just swap tires
    ive owned alotta trucks and never wanted to lift them because somebody I know is always working on their rigs, this forum makes me want to lift my ride though lol
  3. Mar 17, 2023 at 7:36 AM
    #2523
    mrjoe90
    mrjoe90 New Member
    Joe
    ‘23 SR5 TSS Army Green
    Any lift or level done?
    I am hoping that since they are “skinny”, they will tuck and operate with no lift/level
  4. Mar 17, 2023 at 8:45 AM
    #2524
    TheManderson
    TheManderson Former Tundra Owner
    Mark
    2022 Tundra Hybrid Limited 4x4 TRD Off Road (SOLD), 2024 Ford F350 Lariat Ultimate Tremor 6.7L HO Diesel
    37x12.5 BFG KO2s on 17x8.5 +28 Icon Vector 6s
    (3" TRD Lift)
    dagsom, Scantman70, =JSG= and 5 others like this.
  5. Mar 17, 2023 at 9:26 AM
    #2525
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    How's the i-force MAX handling the 37s?
  6. Mar 17, 2023 at 11:17 AM
    #2526
    TheManderson
    Mark
    It's still great. Certainly a bit slower off the line, but not much, and same juice at highway speeds as before.
    I'd consider going to 3.73s, once gears are available for these, though, just to help with towing and that off the line performance
  7. Mar 17, 2023 at 1:36 PM
    #2527
    Puldo Bruce
    Puldo Bruce New Member
    Icon stage 2 kit
    18x9 +25 Icon Rebounds
    Toyo Open Country AT3 285/75
    Was holding out for some +35s to minimize poke, but I couldn’t find any. I’m happy with the way these turned out though. Not much poking out but the sidewall.
    83845C2A-B10F-4CE3-A228-B194DAAF1D80.jpg 189232DA-FD55-4AB9-9398-088EA2DCB2C4.jpg
  8. Mar 17, 2023 at 1:39 PM
    #2528
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Looks great! I was looking at a Platinum long bed recently- potentially trade in my 23 Hybrid Limited short bed.
    Puldo Bruce[QUOTED] likes this.
  9. Mar 17, 2023 at 2:14 PM
    #2529
    Puldo Bruce
    Thanks. Next up is spending too much money to de-chrome it . I love the look of the long bed. No regrets there.
    Yaboy likes this.
  10. Mar 17, 2023 at 3:40 PM
    #2530
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Really? How much rubbing, how much trimming?
  11. Mar 17, 2023 at 7:01 PM
    #2531
    TheManderson
    Mark
    I pulled the mud flaps, pinned back the fender liner, and did the body mount chop (preemptively).
    I haven’t taken it off road yet, but the only rubbing I’ve noticed, so far, seems to be on the sway bar at full lock.
    Keep in mind, though, that BFG 37s are a bit undersized - I measured them at just a fraction over 35” in diameter, as mounted. Unfortunately, it is also just enough over 35” that the spare won’t fit in the factory location. I’m contemplating seeing if I can cut a 1/4” or so off of the back of the hitch safely (I do tow a 4000lb camper trailer).
    I’ve also considered removing the front sway bar for clearance and articulation, as well as allowing me to fit aftermarket skid plates (none seem to work with sway bar drops - particularly as large as the drop with the TRD kit) but also concerned about how that would affect handling - particularly while towing.
    FWIW I also will be trimming the front, as I have a CBI Baja Front Bumper on order.
    ARCOVT23[QUOTED] likes this.
  12. Mar 17, 2023 at 7:02 PM
    #2532
    TheManderson
    Mark
    FYI there is minimal poke - here are pics:
    EF07DC7A-0FDC-4E4A-857C-9B483AEA8CF4.jpg F5FCF676-381B-42C9-895E-F301DCB03BFE.jpg
    4genRunner likes this.
  13. Mar 17, 2023 at 7:49 PM
    #2533
    TheManderson
    Mark
    Just put it in Sport mode for the first time since putting the 37s on. Still boogies!
    22platitundy[QUOTED] likes this.
  14. Mar 18, 2023 at 4:03 AM
    #2534
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    I have the TrD lift and the trd skid plate,
    If you still have the original swaybar end links you can run the skid plate. I got all my original parts back from Toyota after they installed the lift.
    Also I ran without swaybar for two days, to swirly for me and the roads I drive.
    TheManderson[QUOTED] likes this.
  15. Mar 18, 2023 at 11:39 AM
    #2535
    TheManderson
    Mark
    It will limit your articulation, though, if you run it in the stock location, and, at least I'm thinking, probably cause more stress on the sway bar links, so you may end up with failure there, sooner or later.
  16. Mar 18, 2023 at 11:50 AM
    #2536
    TheManderson
    Mark
    You have a great looking truck!
    There are ways to, at least, minimize the cost... I've done everything but the mustache (waiting, at least, until I get the new front bumper, since the bottom pieces will be chopped off). I was able to get all of the parts for about $1000 shopping around on the online parts stores for my local toyota dealers (hint: just go to "parts.(dealer website).com" and search the part number you're looking for, which I just found here on the forum) - check a number of them, as online pricing varied widely, from full MSRP to 30%ish off. I did use Sparks Parts for the color-matched door handles. And, FWIW, so far, seems like the cheapest place I've seen for the mustache is paintedoemparts.com (anyone else have a better suggestion?).
    Of course, still way too much to spend for something that should've come from the factory that way in the first place!
  17. Mar 18, 2023 at 7:32 PM
    #2537
    CW_1981
    CW_1981 New Member
    Some new shoes!
  18. Mar 18, 2023 at 8:10 PM
    #2538
    TheManderson
    Mark
    looks great!
  19. Mar 18, 2023 at 8:40 PM
    #2539
    hopalong604
    hopalong604 New Member
    Jeremy
    Specs on lift and wheel set up? Looks great!
  20. Mar 18, 2023 at 10:17 PM
    #2540
    CW_1981
    CW_1981 New Member
    thanks man!
    Wescott lift with air ride
    18” Black Rhino rapid 0 offset
    35” Bfg AT
    hopalong604 and Durtywrench like this.
  21. Mar 19, 2023 at 9:50 AM
    #2541
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    I’ve been shopping for these wheels . Only two in the nation in 18” lol . Looks perfect. How’s the mileage now ? Could we get pictures from straight on to see the poke of the tires?
  22. Mar 19, 2023 at 10:41 AM
    #2542
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Definitely a hard wheel to get a hold of, I was lucky enough last year to find the "last 4 in the region" in bronze according to the guy at discount. I got the 9 inch wide in +12 offset
    Durtywrench[QUOTED] likes this.
  23. Mar 21, 2023 at 1:01 AM
    #2543
    Stevoid
    Stevoid New Member
    2023 White Tundra TRD Pro
    are the Method 305 double black closer to grey in center and gloss black for outer ring?
  24. Mar 21, 2023 at 4:36 AM
    #2544
    Quick_23TundraPlat
    Quick_23TundraPlat New Member
    2023 Tundra Platinum MGM
    Westcott Lift AVS/Rear Air, 35/12.5/18 Toyo Open Country AT3, Method 305 NV 18x9 (+18 Offset), Extang Solidfold 2.0 Tonneau
    they are matte black so they will always feel ‘lighter’ than the deep gloss black on the outer ring and on the Platinum fenders. They are really good looking wheels, especially for the MGM Plat (opinion :)
  25. Mar 21, 2023 at 8:22 AM
    #2545
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Just now took my 1794 TRD to dealer to check wheel alignment. Although minor, I finally determined that yes, the steering wheel has to be just a tad to the left in order to drive straight on most road surfaces. The left lane on the interstate being flat or ever so slightly left sloping is the only place that the truck will drive straight with the steering wheel straight. If I left go of the steering wheel it would track true to what ever it was set to, so no "pull" in the classic sense. I understand that right lane or crowned roads will pull to the right and thus need to steer left a bit to compensate. But it's been more so than on other vehicles.
    I was concerned that they would charge to check and correct the alignment. But it turns out that Toyota has a 12 month warranty on alignment, so no charge. Good deal and relieves my concern that I would have to argue over a charge. I see others have found that factory alignment is not good so will be interesting to see how this turns out.
  26. Mar 21, 2023 at 8:40 AM
    #2546
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
    Need some help finding wheels.
    I have a stock limited on 265/60R20s. I would like to go down to an 18inch rim and increase tire sidewall for a plusher ride but keep the overall size dimension the same to not have to mess with speedo or anything. So I'll be going for 275/65R18 Michelin LTX A/Ts.
    That being said, I really like to keep my cars looking factory, so I'd like to find either an aftermarket rim or maybe a tacoma/4runner stock rim (haven't seen all options yet) in 18inch that will let me keep my factory toyota center cap? I've seen some 18inch aftermarket rims I like, but what do I do about that cover/hub cap? Should I get a sticker, what are my options? Just to add, I am not a fan of the stock tundra 18inch rim.
    nworker and mikvic like this.
  27. Mar 21, 2023 at 8:44 AM
    #2547
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    For the part about having the steering wheel pull. I used to work at a local mech shop when I was younger and we did alignments. The old man that did alignments forever, when I worked with him he taught me that the steering wheel has to pull right a touch and never drive straight forever so if the driver falls asleep or has a heart attack while driving, the vehicle pulls off the road and into the ditch not on coming traffic. That’s just what I was taught so I’m not sure if that’s a law or just good practise.
  28. Mar 21, 2023 at 9:32 AM
    #2548
    Paul Moll
    Paul
    Idaho
    Wow, that is interesting.
    All I can say about it is that on two other vehicles that I've driven extensively in the area I live I don't find this steering wheel bias as much or at all. To be fair, the Tundra has more aggressive tires that the other vehicles, so yes, those could track differently on different road surfaces. But I would think that would show up as a pull to one side rather than a steering wheel off center bias. Will be interesting to see what is found on the alignment rack as they call it.
    Yaboy[QUOTED] likes this.
  29. Mar 21, 2023 at 10:06 AM
    #2549
    hopalong604
    Jeremy
    I have a platinum also. Curious to have your opinion on the westscott lift and how it rides?
  30. Mar 21, 2023 at 11:35 AM
    #2550
    nodak67
    nodak67 New Member
    JR
    usually toyota will do adjustments within the first 12 months for free (unwritten rule). just depends on the dealer. some balk some will do it without issue.
