GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Feb 24, 2023 at 5:34 AM
    #2431
    nodak67
    nodak67 New Member
    JR
    now there is a person you dont see very often, an SR owner and happy its an upgrade compared to before (most just get the SR for a work truck and dont give a second thought). congo rats :)
    many happy miles to you and the tundra, welcome aboard.
    Henry1jg and NAngelo[QUOTED] like this.
  2. Feb 24, 2023 at 6:26 AM
    #2432
    rdogg1
    rdogg1 New Member
    Jay
    2023 limited
    Rc 3.5 lift,35s,Rc nerfs
    35x12.5x20
  3. Feb 24, 2023 at 12:29 PM
    #2433
    willofontario
    willofontario New Member
    LT285/60R20 - BF Goodrich All-Terrain KO2
    No lift
    Colour-matched wheel arches
    mayan, =JSG=, ryanwgregg and 6 others like this.
  4. Feb 25, 2023 at 8:18 AM
    #2434
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Looks good. Did you have your stock parts painted or new parts then paint?
    TuxTundra and tmillon671 like this.
  5. Feb 27, 2023 at 11:43 AM
    #2435
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    I’m looking at the methods mr316 and the new mr318s has anyone run hub centric rings with method wheels?
  6. Feb 27, 2023 at 12:49 PM
    #2436
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You will want to run the hub rings, I tried that once with one of my other cars and it was unbearable. The vibration started at about 40 mph and got worse the faster you went. Eventually shaking all your fillings out!
  7. Feb 27, 2023 at 1:01 PM
    #2437
    Tundrafarm
    I can only find hub centric rings 106 to 95.1 method wheels are 106.25 wanting to know if that’s okay.
  8. Feb 27, 2023 at 1:06 PM
    #2438
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think there was a post in this thread some time ago about someone finding a company on e-bay that made every size imaginable. You could also get some made if you know if a fab shop that could make some. I did that for some wheels in the past. Try searching the forum for hub rings and see if that turns up.
  9. Feb 27, 2023 at 1:07 PM
    #2439
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Haven’t had an issue with my
    Blackhorn bh01’s without rings, but bought some to have put on whenever I get a rotation next
  10. Feb 27, 2023 at 1:48 PM
    #2440
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    My method 316 came with rings but they wouldn’t fit with them on. You don’t need them. Ring included was not labeled with a size. You will need ET lug nuts though
    Wheel Accessories Parts Set of 24 Black 14x1.5 Lug Nut Small Diameter 0.31" Shank Length Narrow Extended Thread (ET) Spline Tuner Lug Nuts for Aftermarket Wheels Lug Nut (Black, M14x1.50) https://www.amazon.com/dp/B08L75GQS3
    LunaTuna likes this.
  11. Feb 27, 2023 at 3:37 PM
    #2441
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Yes. Holler at me if you need help.
  12. Feb 27, 2023 at 4:44 PM
    #2442
    Aces and 8s
    Aces and 8s I Turn Wrenches
    2023 Tundra CM Ltd
    I noticed a bit more harshness in the ride with the wildpeaks, but nothing crazy. It's starting to mellow out now too after a few hundred miles.
  13. Feb 27, 2023 at 7:00 PM
    #2443
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    For reference stock 18” styled steel wheels and oem Yokohama Geolander tires weigh 78.2 pounds and stock TRD 20” wheels with oem Bridgestone Wildpeaks weigh 75.6 pounds.
  14. Mar 2, 2023 at 10:24 PM
    #2444
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Need some advice. I really like the Blackhorn BH01s. Cannot stand that silver on TRD OR 18'
    On my Tacoma I went a size up from stock Firestone 265/65/17 to Good Year Wrangler 265/70/17 and same offset wheel. It's nothing crazy and I am fine with that. So coming back to Tundra, what else would I need to go with 285/75/17 Discoverer AT3. I don't really think about lift but would do RC 1.75 leveling kit if need it. But a thing to consider here is I use my truck for work and on a daily basis I carry around 300 pounds plus another 100 would be Retrax I am considering. Does that mean I would rather need a 3/1 lift instead of just a level kit?
  15. Mar 3, 2023 at 4:22 AM
    #2445
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    You wont need to do anything for 285/75/17 tires to work. You could change out the rear springs to accommodate the weight in the back and not just add a spacer, it’s the same work to add a spacer or change the spring. Offset that isn’t too much would be +25 and up. If you are in Calgary talk to Krave automotive they are the guys to go to. https://kraveautomotive.ca/
    AGTAB and in_the_mud[QUOTED] like this.
  16. Mar 3, 2023 at 5:04 AM
    #2446
    FrozenTundra204
    FrozenTundra204 New Member
    MJ
    2023 Toyota Tundra 4x4 Platinum Blueprint
    TRD dual exhaust, 285/60r20 BFGoodrich AT K02 tires
    285/60r20 BFGoodrich K02. No lift, level, or spacers.
    ARCOVT23, Tom976, enabl3D and 9 others like this.
  17. Mar 3, 2023 at 5:56 AM
    #2447
    Norman N. G.
    Norman N. G. New Member
    2023 Tundra Limited w/TRD Off Road Package
    She looks GREAT!!! Did you have the Dealership put the BF's on?
  18. Mar 3, 2023 at 6:20 AM
    #2448
    FrozenTundra204
    MJ
    Thank you! Yes, the dealership put the tires on. They actually had the best price I could find, and were willing to price match if I could find better. The dealer also recommended the tire installer's business for a lift (he has his own business that specializes in modifying Toyota trucks), so working with him to have Bilstein 5100 ride height adjustable shock absorbers installed to do a very slight lift in the front. They are just not available yet in Canada. Additionally, the parts department at the dealership has been very helpful helping me find other components for the truck. Very happy with this dealership so far.
    Welderdude80 and Boerseun like this.
  19. Mar 3, 2023 at 7:40 AM
    #2449
    Norman N. G.
    Manitoba?
    So shocks instead of a leveling kit will suffice?
  20. Mar 3, 2023 at 9:40 AM
    #2450
    FrozenTundra204
    MJ
    Yes, in Manitoba.
    I spoke with ckautofab about the using the ride height adjustable shocks, and they indicated that is the only component required for a lift of about an inch.
    Boerseun likes this.
  21. Mar 3, 2023 at 9:46 AM
    #2451
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    2022 Tundra CMLB Lunar Rock
    I am getting ready to upgrade my tires and wheels on my truck. I have been flip flopping between staying with the 18's or going to the 17's. I know a lot of guys have gone to the 17's. Has anyone had any issues running the 17's on their trucks? Thanks in advance.
  22. Mar 3, 2023 at 9:59 AM
    #2452
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    17s are close but fit and the wheel weights need to placed to clear the calliper.
  23. Mar 3, 2023 at 10:05 AM
    #2453
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Ignorant question incoming: are the Bilstein 5100 adjustable shock absorbers for the front only? Do you have a link you can share for these?
  24. Mar 3, 2023 at 10:11 AM
    #2454
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Bilstein 5100 have an adjustable collar you can move up and down to level the truck, I had them on my Tacoma they are nice stock replacement.
    FrozenTundra204 likes this.
  25. Mar 3, 2023 at 10:28 AM
    #2455
    FrozenTundra204
    MJ
    dragokvm, surfmc and Boerseun like this.
  26. Mar 4, 2023 at 11:52 AM
    #2456
    Descend
    Descend New Member
    North West
    '23 Tundra TRD Pro MGM
    I want to upgrade my 285/65/18 OEM Wild Peaks to A/T3W's. I wouldn't mind going a bit bigger but don't need huge as I don't want to mess with the fuel efficiency too much. Anyone have a recommendation? Stock TRD Pro.
  27. Mar 5, 2023 at 9:13 PM
    #2457
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    What’s your set up specs ?
  28. Mar 7, 2023 at 9:11 AM
    #2458
    dfwtundraplat
    dfwtundraplat New Member
    Did anyone regear their transmissions to accommodate the bigger/heavier tires? Is this even possible?
  29. Mar 7, 2023 at 9:57 AM
    #2459
    cruiserhead
    cruiserhead New Member
    For the hybrid owners, I've read someone complain that the hybrid doesn't kick in properly, at the right speeds, with the bigger tires. Is this an issue to be concerned with? (I'm trying to find where I read that...)
  30. Mar 7, 2023 at 9:58 AM
    #2460
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    I think any larger tire is going to impact MPGs more than normal b/c of how lightweight the Falken OEM AT3W is at 38lbs, and even replacing with same size will be 20lbs more with E rated.
    Descend[QUOTED] likes this.
