GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Feb 5, 2023 at 12:08 PM
    #2311
    EyeRideBykes
    EyeRideBykes New Member
    ‘23 Tundra 1794 OR
    Westcott 3/1” on HRE Flowform FT1 wheels and BFG KO2 35x12.5x17
    HRE FLOWFORM FT1 17x9 +0
    =JSG=, AGTAB, AND and 2 others like this.
  2. Feb 5, 2023 at 12:37 PM
    #2312
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Those are my favorite wheels! I was looking at the black ones in 20 inch but the offset creates a bit more poke than I was hoping for.
    Looks great!
  3. Feb 5, 2023 at 1:06 PM
    #2313
    EyeRideBykes
    ‘23 Tundra 1794 OR
    @PBNB Thanks. There is definitely some poke but I got 2” fender flares that should fix that.
  4. Feb 5, 2023 at 6:46 PM
    #2314
    ArticTundra
    ArticTundra New Member
    Cold
    Hey all. I've read damn near all these posts but having trouble getting the answer to my question. Help!
    I'd like to level the truck and put 35's on. Well, as close to 35's as I can. I'm not wild about a 12.5" wide tire, so I might end up with something similar to a 285/75/18. Trimming is not a problem for me. I would like the least amount of poke possible while still keeping all my travel/flex. Reason being is I live on dirt roads and want to avoid spraying the side as much as I can.
    b0yax likes this.
  5. Feb 5, 2023 at 10:04 PM
    #2315
    b0yax
    b0yax New Member
    Does toyo open at3 wont rub or anything i need to adjust on stock oem trd pro wheel? I want stock on everything. How does the ride and noise? Is it good on snow and rain? Im gonna be 80-90% on road and sometimes long distance. Hows mpg too? First time owning a truck.
  6. Feb 5, 2023 at 10:16 PM
    #2316
    b0yax
    b0yax New Member
    hows the performance on rain and snow? Mpg and ride?
  7. Feb 6, 2023 at 7:15 AM
    #2317
    Tom
    Tom New Member
    my new wheels are .5 wider and I’m at 35 offset. This will net about 1.25” poke which I can tell you is enough poke to cause spraying mud and flying rocks. Your best bet is to keep stock wheels or find aftermarket with 60 offset(don’t think any available). Or get the poke and add 2” flare and wide mud flaps.
    Unitdosed likes this.
  8. Feb 6, 2023 at 7:58 AM
    #2318
    ArticTundra
    Cold
    Thanks for that photo. Gives me a good idea where I’ll be putting clear bra!!
    Tom[QUOTED] likes this.
  9. Feb 7, 2023 at 5:27 PM
    #2319
    Skinny1371
    Skinny1371 New Member
    2022 TRD 4x4
    Method Rims and Falken Wild Peaks.
  10. Feb 7, 2023 at 6:41 PM
    #2320
    Hanny-Tundra
    Hanny-Tundra New Member
    Ride is great in my opinion - just did a 800km trip and it was smooth, close to stock for the most part. Perhaps a little more direct and responsive in the handling department that I attribute to the 12 ply tires and to a lesser degree the struts.
    I recommend this complete strut set-up over the spacers especially for the price!
  11. Feb 8, 2023 at 3:10 PM
    #2321
    Blackchief29
    Blackchief29 New Member
    Nitto Ridge Grapplers 35/12.5/18
    Attached are pics tires of before and after from side view and front labels “B” & “A” to show tread width difference.
    Siopao, Tibetan Nomad, g35man and 8 others like this.
  12. Feb 9, 2023 at 8:47 AM
    #2322
    jake21384
    jake21384 New Member
    2023 Tundra Platinum
    First post. I like many of you…probably read all 78 pages of the wheels and tires thread. I did more hours of research than I’d like to admit. I went with Nitto Recon Grapplers. 275/60/20 stock rims. They ride pretty rough compared to my old Terra Grapplers but they do look awesome.
    Jorts, Dhust27, Henry1jg and 5 others like this.
  13. Feb 9, 2023 at 10:21 AM
    #2323
    TuxTundra
    TuxTundra New Member
    2023 1794 Tundra 4x4
    Window Tint all the way around
    Which step bars do you have?
  14. Feb 9, 2023 at 1:01 PM
    #2324
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Factory TRD. I believe the part #PT767-34220
    TuxTundra[QUOTED] likes this.
  15. Feb 9, 2023 at 1:07 PM
    #2325
    Keopi
    Keopi New Member
    Hey guys, finally decided to register but have been stalking for awhile.
    Here's my truck, 2022 1794.
    Just got the wheels and tires earlier. Icon vector 6 17x8.5 +25offset wrapped in wrangler a/t 35x12.5, stock height.
    Rubs a bit on the carpet on full turn, just need to push it in.
    Super happy cuz it doesn't look like grandpa's truck now lmao
    Minor complaint on the icon tho. the center caps don't fit on the front wheels.
    PS: if anyone near rapid city sd interested in my stock wheels/tires no tpms, I'll let em go super cheap, i'm getting rid of them cuz i don't wanna leave it in the place i'm renting. I'm just here cuz of wife's work
  16. Feb 9, 2023 at 1:13 PM
    #2326
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Not grandpa's truck at all! Looks like some mud flaps are needed to keep that mesquite looking top notch!
  17. Feb 9, 2023 at 1:16 PM
    #2327
    Keopi
    Keopi New Member
    heres what it looks like stock set up.
    I'm from deep south texas. It's super hard to keep your vehicle clean here up north lmao.
    mayan and Justinfro like this.
  18. Feb 9, 2023 at 3:26 PM
    #2328
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    Great looking rig. I kept my stock TRD OR rims but wanted TRD center caps. After ordering them, I found the front didn’t fit because of the dust cover on the axle. I’m assuming you might be running into a similar problem with your new rims and center caps. I took off my dust caps and “pounded” them in a little bit, just to flatten out the bulge enough for the center caps to fit. Might be something for you to look into, depending on how and why they aren’t fitting.
    Keopi[QUOTED] and Unitdosed like this.
  19. Feb 9, 2023 at 4:37 PM
    #2329
    Keopi
    Keopi New Member
    yeh, the bulge is preventing the center caps to snap in. I'll see what i can do, thanks for the info!
  20. Feb 9, 2023 at 4:53 PM
    #2330
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    I'm so glad you came into my life tonight.
    I was about to purchase the TRD center caps for my stock TRD OR rims!
  21. Feb 9, 2023 at 7:02 PM
    #2331
    Troyboy84
    BC Canada
    the back caps went on perfectly, the fronts now fit as well, a few smacks with a hammer on the dust cap, just enough to make them click in.
    =JSG=, LunaTuna, Yaboy and 1 other person like this.
  22. Feb 9, 2023 at 7:03 PM
    #2332
    Troyboy84
    BC Canada
    The middle picture was before I flattened the dust caps.
  23. Feb 9, 2023 at 7:20 PM
    #2333
    Breathing Borla
    Northern Illinois
    As near as I can tell those exact caps fit the platinum wheels with no mods at all, must be a little different
  24. Feb 9, 2023 at 7:23 PM
    #2334
    Unitdosed
    None, yet
    Thanks for posting!
  25. Feb 10, 2023 at 7:02 AM
    #2335
    LunaTuna
    LunaTuna New Member
    Morning all,
    amazing information on here, so thanks for that.
    I want to put 285/70/18 Tires on, debating if I want to add them to the stock rims or get Methods MR305 NV. I actually don't mind the stock rims IF they can fit the 285,
    So, can that size fit on the stock rims I have ?
    Yaboy and Sean492 like this.
  26. Feb 10, 2023 at 7:38 AM
    #2336
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    I’ve seen several with 295’s on the stock Off road wheels. 285’s will be fine
  27. Feb 10, 2023 at 8:19 AM
    #2337
    LunaTuna
    LunaTuna New Member
    Nice ! , assuming that I don't really have to change anything to suspension, CPU Gearing etc. with that, it's not even an inch taller... thoughts ?
  28. Feb 10, 2023 at 8:23 AM
    #2338
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    I point friends at this site to help them visually to see the difference.
    24NiteShade and in_the_mud like this.
  29. Feb 10, 2023 at 8:31 AM
    #2339
    LunaTuna
    LunaTuna New Member
    thank you.
    I think the stock Rims are 7.5" I could be wrong.
  30. Feb 10, 2023 at 8:59 AM
    #2340
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    From the HV manual pg 547 (non HV pg 551)
    dragokvm and Sean492 like this.
