GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jan 19, 2023 at 7:46 PM
    #2161
    SD.Tundra.858
    SD.Tundra.858 Family man...Toyota fan! Best spices in town!
    Travis
    San Diego, CA
    2023 Black Limited 4x4 w/ Platinum package
    Debating for now. Drives so nice as is. I have a 2007 FJ for all my off road adventures. But I have to admit, looks like it needs a little bigger tire so a lift would be in order!
  2. Jan 19, 2023 at 8:01 PM
    #2162
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    Is it safe to assume that if the 285/75R18 fit OEM setup (+60 offset) they would fit with an aftermarket wheel running +12 to +20 range offset?
    AND[QUOTED] and Yaboy like this.
  3. Jan 19, 2023 at 8:26 PM
    #2163
    TexasTondra
    TexasTondra New Member
  4. Jan 19, 2023 at 8:56 PM
    #2164
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    That’s great info ! Thank you for getting it
  5. Jan 20, 2023 at 8:58 AM
    #2165
    Krusher22plat
    Krusher22plat New Member
    22plat
    Inquiring minds want to know..what is Limited but Platinum package model? It has normal grille (which i actually like as had to paint Plat grille). Are you just saying it has AVS an running boards? As such pkg doesnt seem to exist as I might have looked hard at that one. Thanks.
    DexterL likes this.
  6. Jan 20, 2023 at 9:11 AM
    #2166
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    11 months later. They finally show up.
  7. Jan 20, 2023 at 10:25 AM
    #2167
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I can put a vote in for Continental AT's for highway and towing. Excellent in wet and even on gravel. Not so good in mud/snow more than a couple of inches. Handled and wore extremely well on a different vehicle (Honda Ridgeline)
  8. Jan 20, 2023 at 10:41 AM
    #2168
    SD.Tundra.858
    Travis
    San Diego, CA
    Right? I'm so confused on it too. But basically it has the following:
    14" display,
    Premium LED headlights (platinum lighting)
    Moonroof
    Resr window rolls down (not sure if all do this)
    Premium JBL sound
    Softex leather
    Heated/AC seats
    Qi wireless charging
    Auto bright lights
    And a couple other things.
    Truck liner.
    No running boards. Yes, AVS.
    Hope that helps! I just know the dealer told me it is a limited with platinum package. Not the fine line, details kind of guy. So I don't dive into all the package differences. Too many, too confusing.
    Krusher22plat[QUOTED] likes this.
  9. Jan 20, 2023 at 12:20 PM
    #2169
    AverageAZN
    AverageAZN New Member
    Austin
    2004 Toyota Sequoia
    OME/Dobinson long travel lift, 34s
    What a good brand for ET lugnuts? esYHExpXpawXqCE-gpNuZXg9AYsZCjOirLDsPi2J_52a6b2403bd8e756ab344ac2393eba0980fe61a3.jpg
  10. Jan 20, 2023 at 1:45 PM
    #2170
    weign
    weign New Member
    Wayne
    22' TRD Sport
    1.75 Level 275/60-20 Tires Cap
    Cooper AT3 4s 275/60-20.
  11. Jan 20, 2023 at 2:34 PM
    #2171
    GojiraPRO
    GojiraPRO New Member
    2022 White Tundra TRD PRO
    Stock
    To the hybrid engine owners..have you noticed quite a speed drop off since changing over to the heavier 35" tires?
  12. Jan 20, 2023 at 2:37 PM
    #2172
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    I don't have 35s, but I do have 295/60/20s which are close to 34s. They are obviously heavier than the stock tires but the hybrid has plenty of power to handle them. Truck is still quite quick.
  13. Jan 20, 2023 at 3:07 PM
    #2173
    GojiraPRO
    Stock
    Yeah im sure this was brought up before. Sorry!
    Yeah I know it will be a bit slower, but how noticeable is all I was wondering. I dont use the truck to speed and dont punch it very much. But its nice having that extra quickness when passing as I highway drive alot on the prairies.
  14. Jan 20, 2023 at 3:12 PM
    #2174
    AverageAZN
    Austin
    2004 Toyota Sequoia
    You can definitely feel the weight of the 35's... Not quite as sporty as it used to be on stock tires but still plenty of power, you just need to use the gas pedal more. Still getting used to it, I also went pretty heavy with method 706's and 35" Ko2's i think its about 96 pounds each wheel, stock is something like 65 i think
  15. Jan 20, 2023 at 3:20 PM
    #2175
    GojiraPRO
    Stock
    Yeah that will make a difference for sure. Are you on the Hybrid engine too?
    I figured since there is enough torque that I wouldnt notice a HUGE drop off but figured id ask to see what the hybrid guys think that are running 35" tires. I know each brand is a bit different.
  16. Jan 20, 2023 at 3:22 PM
    #2176
    AverageAZN
    Austin
    2004 Toyota Sequoia
    yeah mines a hybrid. You mostly notice it on starts from stop. Just doesnt feel effortless anymore
  17. Jan 20, 2023 at 3:23 PM
    #2177
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Any difference in speed reading on Speedometer when going up a size or two in tires ?
  18. Jan 20, 2023 at 3:27 PM
    #2178
    GojiraPRO
    Stock
    Ill keep that in mind thanks guys. Honestly been weighing the pros and cons for me for 35s on my stock TRD Pro.
    I know it wont rub much if at all, the main concern is the speedometer, not sure how long itll take for the companies to put something out to recalibrate, im in Canada so im running in KMs too, surprinsgly it doesnt bug most the guys that have changed over to 35s? I know its pretty easy to adjust, and I do have a radar that is GPS based so it tells me my speed as well, but something about the speed being off on a brand new truck bugs my OCD is all. Anyone else feel the same way? If this wasnt an issue I would have changed over by now.
  19. Jan 20, 2023 at 3:31 PM
    #2179
    GojiraPRO
    Stock
    Using the speed calibrator calculator for tire sizes, when I change over it'll be roughly 7km (4.4MPH) difference when going 60MPH.
  20. Jan 20, 2023 at 3:31 PM
    #2180
    GG.Offroad
    GG.Offroad New Member
    Austin
    Westminster, CO
    2023 Tundra Limited Hybrid Lunar Rock
    www.ggoffroad.com
    HyperTech told me ther'ye working on a speedo calibration for the Tundra:
  21. Jan 20, 2023 at 3:32 PM
    #2181
    GojiraPRO
    Stock
    Do you know changing/re calibrating voids any type of warranty? Sorry guys im totally new to getting a bigger tire for my truck!!
  22. Jan 20, 2023 at 5:43 PM
    #2182
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Ultimately it’s at the discretion of the dealership.
  23. Jan 20, 2023 at 7:48 PM
    #2183
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    The 295/70/18 will also fit with the stock wheels and suspension on the TRD OR with mudflaps and without pinning back the liner (no rub)
    kdd and AverageAZN like this.
  24. Jan 20, 2023 at 7:52 PM
    #2184
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    classic dealership… there is no such thing. Do you have a platinum warranty, because that’s a thing! You have a loaded limited (premium package) minus the TRD package, but the platinum only comes in the platinum trim.
  25. Jan 20, 2023 at 8:21 PM
    #2185
    Peak23
    Peak23 New Member
    Kyle
    2023 tundra crew max SR5
    thanks, nope no rubbing at all actually. I thought they definitely would …
  26. Jan 20, 2023 at 10:07 PM
    #2186
    SD.Tundra.858
    Travis
    San Diego, CA
    Thanks for this. I have been trying to figure that out!
  27. Jan 20, 2023 at 10:28 PM
    #2187
    worksjo
    worksjo New Member
    I don’t know if this is any deal really but I just ordered a set of Falken Wildpeak A/T3W in 295/70R18 from Discount Tire and they were $329 a piece.
  28. Jan 21, 2023 at 7:34 AM
    #2188
    osu1978
    osu1978 New Member
    If changing/re-calibrating causes something to break then its possible they could deny a warranty claim but again it has to be the cause of the issue. For example you brick your ECU during this calibration process they will most likely deny a warranty claim for a new ECU. If your rear shock leaks they can't deny your claim as this would have nothing to do with recalibrating your speedometer.
  29. Jan 21, 2023 at 8:07 AM
    #2189
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Wow, noice.
    Post the specs!
  30. Jan 21, 2023 at 8:42 AM
    #2190
    bigjuice
    WA State
    2024 Terra TRD Pro
    Love it…these are the Grahamlights right?
    +18 or 20 offset…fully forged and like what…24lbs.
    Can’t wait I see how they look on the truck?
    You getting center caps?
