GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Dec 21, 2022 at 12:04 PM
    #1891
    HornetOne3
    HornetOne3 New Member
    Columbus ,Ohio
    2016 Barcelona red Crewmax SR5
    That's one sharp looking truck .
    paradizecityz[QUOTED] likes this.
  2. Dec 21, 2022 at 12:58 PM
    #1892
    Baldilocks
    Baldilocks New Member
    None
  3. Dec 21, 2022 at 3:42 PM
    #1893
    Supertech1
    Supertech1 New Member
    I’ve been struggling with this tire decision so I finally decided to try the LT275/70-18 Cooper Rugged Trek. Had these on my SR5, but 20” P load 275/60/20. Was trying to find a balance between ride quality, noise, weight, and look. I liked the look of slight poke I had with +20 aftermarket wheels on SR5, but did not like the mud in the bed, on the hood, mirrors, on the cab…everywhere. Live and learn.
    I decided to try the LT Rugged Treks knowing Discount Tire would swap them if I changed my mind. If DT would’ve had the Toyo AT3 285/70/18 available, that would’ve been my first choice. Now if these don’t work out, I’ll probably move to the 295/70 or 35x12.5 D load Toyo AT3.
    I’ve only driven 20 miles on these, but so far I’m impressed with the improved handling, ride comfort, noise level and the look of the tire/truck. I feel like the acceleration is same, or very close, and might even be smoother with the additional tire weight. Based on the dash MPG read out, I’d say MPG will be down about 1 MPG or so.
    On the truck, the tires are about .5-.75 inch taller than the stock Falkens. This is with 37 lbs pressure. I’ll play with the poundage, target low to mid 40’s. This would increase the height, but firm up the ride.
    Honestly… I’m good with the height, but do wish they were an inch wider.
    Helo, ytank1, Yaboy and 2 others like this.
  4. Dec 21, 2022 at 4:37 PM
    #1894
    Breathing Borla
    Northern Illinois
    looks good, what is the weight of those at 18"?
    just curious
  5. Dec 21, 2022 at 4:43 PM
    #1895
    Supertech1
    The spec sheet says 59, but I’ve seen 57-58 lbs posted elsewhere. I’ll have a total weight, with the BBS Pro wheels, in a day or two.
  6. Dec 21, 2022 at 5:57 PM
    #1896
    EvoTundra
    EvoTundra New Member
    Do you have a link to the decal?
  7. Dec 21, 2022 at 5:58 PM
    #1897
    GhostF8CEkill3r
    GhostF8CEkill3r Darth Tundra
    JSUN
    Conroe, Texas
    2023 Black Tundra Platinum Hybrid
    3" Front, 1" Rear - (Leveled) on 35" x 12.50"R20 Toyo ATIII w/1" wheel spacers.
  8. Dec 21, 2022 at 5:59 PM
    #1898
    Breathing Borla
    Northern Illinois
    Those load e sure get heavy fast, looks good though
  9. Dec 21, 2022 at 6:13 PM
    #1899
    Supertech1
    Agreed, wish there were more SL options in larger size.
  10. Dec 22, 2022 at 5:03 AM
    #1900
    Jongie123
    Jongie123 New Member
    Johnny
    2022 Midnight Black Metallic Tundra 4x4
    Do you happen to have a part number for those new 18 x 9 wheels ?
  11. Dec 22, 2022 at 6:21 AM
    #1901
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Vin didn’t provide a part number.
    Here’s the info I have.
  12. Dec 22, 2022 at 6:35 AM
    #1902
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Yeah, y'all are correct. I thought my truck came with the HT G056s on it, but they're the X-CV crossover tires at 37.5 lbs. My mistake. I hate it when that happens!
  13. Dec 22, 2022 at 10:48 AM
    #1903
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    I’d like to replace my stock 20x8 wheels with 20x9.5 but everything I see is around 12mm offset which by my calculations puts the outer wheel lip out about 2.5”. I don’t mind the lip going out 1” which is about even with fender but I’d rather not have it poke out past the fender.
    Anyone find or using 20x9.5 wheels with around 52mm offset?
  14. Dec 22, 2022 at 11:10 AM
    #1904
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You will have to look closely for anything greater than about +15 offset. I went with a 20x8.5 with a +15. I am expecting a little poke but not too much. The stock wheels are set in a bit so there is about 45 to 50 mm to play with. Then if they stick out too far, get some TRD Pro fender flares to add another ~20 to 25mm of coverage. Another way would be to use the OE wheels and add a spacer. I think anything in 20x9.5 will have an offset close to "0". I also found that there are wheels with a higher offset number have a centre bore that fits Chevy but not Tundra.
    Your best bet would be to pop by your local tire shop and have them go through the wheel catalogues to see what is available.
  15. Dec 22, 2022 at 3:20 PM
    #1905
    Callmedaddy
    Callmedaddy New Member
    23 blue limited 4x4
    Hey guys just bought a 23 limited 4x4 and wanting to keep the factory 20s but do bigger all terrains and a level kit what size would y’all recommend. I tow allot and don’t want anything that’s gonna absolutely kill gas either. Had a 2nd gen tundra on 35 and got like 10mpg so don’t want to do that again
  16. Dec 22, 2022 at 3:29 PM
    #1906
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    295/60/20. But you might as well just go 35s at that point, especially if you're going to level it. Could go smaller than 295/60/20 but may look small with a level.
  17. Dec 22, 2022 at 3:41 PM
    #1907
    Breathing Borla
    Northern Illinois
    33" P rated is about as big as you can go without losing MPG and going up to Load E
    Im going with the 275/60/20 Cooper AT3 4S
  18. Dec 22, 2022 at 3:52 PM
    #1908
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    285/65/20 looks great. I added the RC level kit.
    Callmedaddy[QUOTED] likes this.
  19. Dec 22, 2022 at 5:07 PM
    #1909
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    I agree with 295/60R20. I was just looking at a sales manager’s 1794 today. He had 295s on it with the Wescott lift and it looked great IMO. He now has 35s and the poke is slinging crap up the side. Both tires were on the stock TRD 20s. He couldn’t say how much either affected is mpg. I did a similar thing with tires and murdering my mileage on a 2nd gen. Enjoy your Tundra!
  20. Dec 22, 2022 at 5:36 PM
    #1910
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    SCS F5 18x9 +12mm
    Matte Dark Bronze
  21. Dec 22, 2022 at 5:58 PM
    #1911
    Callmedaddy
    23 blue limited 4x4
    I love your truck and so does the wife when I was looking through the forum she said she wanted mine to look like yours. How’s it ride with that rc level kit? I was thinking of going with the wescotts design kit but that is 3” vs 1.75”
  22. Dec 22, 2022 at 8:05 PM
    #1912
    22 Lifted Limited
    22 Lifted Limited New Member
    2022 Tundra Hybrid Limited
    Method 316 18x9 18mm offset with 285/75r18 Toyo AT3 on Westcott 3/1
    dragokvm, Boerseun, rst and 6 others like this.
  23. Dec 22, 2022 at 10:00 PM
    #1913
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Damn…those look good.
  24. Dec 23, 2022 at 7:38 AM
    #1914
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    look for the lightest tire you can find…. Also the lightest wheels. My 17 in wheels weight 15.5 lbs less than stock, my 35in tires weight 15.5 lbs more than stock, so total per corner is only 11.5lbs more- helps with gas mileage a ton
    Breathing Borla likes this.
  25. Dec 23, 2022 at 8:04 AM
    #1915
    Tom976
    Tom976 New Member
    Tom
    The kits that raise the vehicle... These kits the ones that replace the springs to raise the truck or the ones that put metal collars on the shock to give it a little extra height?
  26. Dec 23, 2022 at 8:13 AM
    #1916
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    There are kits ranging from spacers to full coil over systems. The cost will vary based. There are a few good threads to look at that go into detail. Just search the forum to find out the details.
    In my case, I want to get a TRD 3" Lift Kit and I am waiting for the prices to come more into my range. I am going to be installing a levelling kit to raise the front up and accommodate the larger tires.
    Tom976 likes this.
  27. Dec 23, 2022 at 9:00 AM
    #1917
    uberoval
    uberoval New Member
    I'll play...
    Westcott 3/1, VR forged wheels 18" x 9" -12mm, Toyo AT3's 35" x 12.50"
    OEM wheel/tire weight : 74 lbs
    This setup : 93 lbs, was hoping for something in the mid 80's but oh well.
    Scooter73 and DarthTRDPro like this.
  28. Dec 23, 2022 at 9:45 AM
    #1918
    My Trk- Limited
    My Trk- Limited New Member
    Thought I would share.
    Put on 35/11.5 R20 Wildpeaks .Original Rims, 20221222_142752.jpg 20221222_142806.jpg No rub ,no lift, mudgaurds still on.
    No poke. Looks good.
    jhtram, 22platitundy, Tom976 and 6 others like this.
  29. Dec 23, 2022 at 9:51 AM
    #1919
    Norman N. G.
    Norman N. G. New Member
    2023 Tundra Limited w/TRD Off Road Package
    That certainly does look AWESOME!!!
  30. Dec 23, 2022 at 9:52 AM
    #1920
    My Trk- Limited
    These are load range D. As I didn't want to go to a E. About $425 ea at Simple Tire.
