GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Nov 26, 2022 at 5:54 PM
    #1681
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Great looking truck! I’m looking to add the PRO fender flares. Were they difficult to install?
  2. Nov 28, 2022 at 7:14 AM
    #1682
    aj350925
    aj350925 New Member
    I need to get some E rated tires to tow my 10k # trailer safer. I towed a few times with my 22 plat and the stock tires which I slightly over inflated to 55psi.
    I am looking at Micheline Agilis CrossClimate. Has anyone used these before? Thoughts, or reviews?
    Of the available 20" tire sizes while on stock 20" wheels, any reason to get one over the other?
    • LT265/60R20121/118R
    • LT275/65R20126/123R
    • LT285/60R20125/122R
  3. Nov 28, 2022 at 4:33 PM
    #1683
    Fr0zenTundra
    Fr0zenTundra New Member
    Wi
    '22 platinum hybrid
    posted this in the mega lift thread as well but figured i would try and get an answer here too
    this has been discussed several times generally...
    for those of you who have pinned back the felt in the front wheel well, how specifically did you do so?
    it looks to be a 12mm hole in the body but it isn't threaded. i could tap it and add threads but haven'theard of anyone needing to do so. i haven't found a plastic rivet that will work either.
    295/65/20 toyo at3's going on this week and trying to get the pinning out of the way beforehand. thanks in advance for the help.
  4. Nov 29, 2022 at 11:12 AM
    #1684
    palmercooter
    palmercooter New Member
    Man I want TE37's so bad I just wish they offered more offsets. When you get them installed post some pictures!
    erdub54[QUOTED] likes this.
  5. Nov 29, 2022 at 11:23 AM
    #1685
    palmercooter
    Post some pictures when you get your wheels on. I'm trying to decide if I'm ok with the offset and poke of the Gram Lights or Volks.
  6. Nov 29, 2022 at 7:23 PM
    #1686
    23LUNATRD
    23LUNATRD New Member
    23 Tundra SR5 TRD Off-road LunaRock
    Nitto Recon Grapplers 295/70/18 installed on my 23 SR5 TRD Off-road on the stock rims, suspension
    IMG_20221128_190202_942.jpg 20221129_152534.jpg 20221129_152546.jpg 20221129_152544.jpg
    CORam, dragokvm, TUNDRA375 and 8 others like this.
  7. Nov 29, 2022 at 7:37 PM
    #1687
    GunnyTundy
    GunnyTundy New Member
    North Dallas, Texas
    2022 Lunar Rock Tundra
    Any rubbing?
  8. Nov 29, 2022 at 7:38 PM
    #1688
    23LUNATRD
    No rubbing experienced yet
  9. Nov 29, 2022 at 8:32 PM
    #1689
    erdub54
    erdub54 New Member
    2023 Tundra TRD Pro Solar Octane
    IG: Mallrig.Pro
    Will do! Just waiting for the right price on 35s
  10. Nov 29, 2022 at 8:42 PM
    #1690
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    That looks awesome. How’s the ride difference with those tires compared to the stock Michelins?
  11. Nov 30, 2022 at 9:51 AM
    #1691
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Looks so good. You've somehow made the 18" TRD Off Road wheels look good!
  12. Nov 30, 2022 at 10:39 AM
    #1692
    addwolanin
    addwolanin New Member
    I think this is the best place for this question: I have 22 sr5 and just ordered method 316s in 18X9 +18. I also have a 1.5x1” spacer level from corn fed suspensions. I am going back and forth between 285/75r18 and 295/70r18. The plan is to go with wildpeaks in E. I really don’t want any rubbing, I’ve gone through this entire thread and can’t make my mind up. Any thoughts from the professionals?
  13. Nov 30, 2022 at 10:47 AM
    #1693
    22platitundy
    They're very similar.
  14. Nov 30, 2022 at 10:51 AM
    #1694
    addwolanin
    Yeah I guess it’s a question of slightly more height or slightly more width, idk which is more likely to cause rubbing though
  15. Nov 30, 2022 at 11:21 AM
    #1695
    22platitundy
    I think they both should be fine. I'd have the tire shop test fit the one you prefer and ask them to put the other one on if it rubs.
    addwolanin likes this.
  16. Nov 30, 2022 at 11:49 AM
    #1696
    uberoval
    uberoval New Member
    Found a set of 18x9 TE37 M-Spec local to me with a 0 offset available as anything + is going to take 4-8 MONTHS to arrive. What would be the best tire (no larger than 35") that Toyo or Nitto
    offers that would be the least amount of "poke"??
    I really suck at picking out wheels/tires sometimes and this is one of those times....
    iiawah808 likes this.
  17. Nov 30, 2022 at 12:33 PM
    #1697
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Just do it. It’ll be sick!
  18. Nov 30, 2022 at 1:39 PM
    #1698
    uberoval
    uberoval New Member
    Ha! If these wheels weren't so friggin' expensive I'd already have them, trust me. Just double checking with the tundra hive.
    iiawah808[QUOTED] likes this.
  19. Nov 30, 2022 at 5:58 PM
    #1699
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I am looking at some Method 701’s 18x9 et 18. And some toyos or falkens in a 35x 12.5. I am running my out of the box suspension that comes on the TRD off road package with no lift. Does this sound like a tight fit where I am cutting lugs off the tires against the fenders?
  20. Dec 1, 2022 at 5:54 AM
    #1700
    23LUNATRD
    It's hard to describe accurately.
    The stock Michelins bad a distinct humm at speeds over 70mph. The Recon Grappelers do not. The ride is maybe a touch rougher but nothing substantial. Driving with these definitely has a different feel to it. I've only been able to drive the truck two days with them on before leaving for a business trip, but as of right now my mpg dropped by .6 mpg
  21. Dec 1, 2022 at 5:55 AM
    #1701
    23LUNATRD
    Thanks for the kind words.
  22. Dec 1, 2022 at 7:06 AM
    #1702
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    DO NOT trim your tires….. trim plastic and pin back fender liner
    TK1979 likes this.
  23. Dec 1, 2022 at 7:49 AM
    #1703
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Thanks, I was concerned about the tires being too big and would get damaged by the sharp edges. I do want to get a lift but waiting for the prices of the TRD kit to settle down. In my area, I will be looking at over 7,500 bucks for that.
  24. Dec 1, 2022 at 5:38 PM
    #1704
    nodak67
    nodak67 New Member
    JR
    well after a few weeks of discussion the wife decided on getting these. cant find any blue rims that come close to the dark blue and they all didnt look right with an off shade of blue. better to go with a constrasting red than weird blue shade.
    TK1979 and ToyoMon like this.
  25. Dec 1, 2022 at 6:31 PM
    #1705
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    Good call. Think it will look good with a little red.
    Also just realized from your post that we can see our trucks in the websites like TireRack now when looking for wheels. This will be fun :thumbsup:
  26. Dec 1, 2022 at 6:32 PM
    #1706
    Outbound
    Aaron
    Northern Alberta
    Falken Wildpeak 275/70R18. Stock suspension. No rubbing at full lock.
    FortyNorth, TK1979, Yaboy and 3 others like this.
  27. Dec 1, 2022 at 7:05 PM
    #1707
    nodak67
    nodak67 New Member
    JR
    i used tirerack for a side view and used a local tire dealer for the angled view.
    if you care to use them its tiresplusnd.com for the angled view
    ToyoMon[QUOTED] likes this.
  28. Dec 1, 2022 at 8:44 PM
    #1708
    dutch2112
    dutch2112 New Member
    2023 Limited hybrid Trd
    35” Falken Wildpeak AT3, 17x8.5 method 305 nv, trd lift kit, trd pro grill, trd exhaust
    I been waiting on my method 305s for a bit and just received an email they are back in stock with a descent price for anyone else looking. I already have the Trd lift waiting, falkens as well
  29. Dec 2, 2022 at 7:52 AM
    #1709
    uberoval
    uberoval New Member
    What size wheel are you going with? Offset?
  30. Dec 2, 2022 at 8:01 AM
    #1710
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Looks like I can't buy Methods direct. I have to go through some middleman up here in Canada. So my price doubles! I might try to pop down into Wash and get some wheels and tires if I can free up some time. Certainly would save a few thousand!
