GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 14, 2022 at 11:05 AM
    #691
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
    Thanks for the input! My only real concern with the Wildpeaks are that they are about 8 pounds heavier (per tire) than the Coopers. Considering the wheels I'm running are already a little on the heavy side at 32 pounds, I'm not sure I want 100 pounds per tire. From what I've read, that 8-9 pounds per tire can make a huge difference.
  2. Apr 14, 2022 at 11:24 AM
    #692
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    You are likely mixing LT and passenger ratings. LT's are generally 10-ply tires rather than ~3 for passenger tires.
    Wildpeak can be had in either depending on the size of the tire.
    TexasTundra90[QUOTED] likes this.
  3. Apr 14, 2022 at 11:36 AM
    #693
    Breathing Borla
    AZ
    I have the coopers and they are everything you listed there, I had BFGs before these, Cooper are hands down better overall.
    and made in usa as well.
  4. Apr 14, 2022 at 12:04 PM
    #694
    TexasTundra90
    Aaron
    i probably didn’t do a very good job of typing that out.
    the Wildpeaks weigh just under 69 pounds per tire. The Coopers are about 61 for the 295. With the combined weight of the 32 pound rims, I feel like that extra 8-9 pounds per wheel could make a big different.
    jpod[QUOTED] likes this.
  5. Apr 14, 2022 at 12:32 PM
    #695
    cruisernate
    cruisernate New Member
    2022 Tundra TRD Off Road (Army Green)
    As everyone has said, these are the SR5 TRD Off Road Rims (Canada)
  6. Apr 14, 2022 at 3:51 PM
    #696
    -Mike-
    -Mike- New Member
    2022 Tundra SR5 TRD Off-Road
    TRD Air filters. New pass side turbo : )
    Method 316’s. Falken Wild Peak 35/12.50-18. Westcott 3/1 lift.
    iLDE, MTundra87, Ryuu and 4 others like this.
  7. Apr 14, 2022 at 9:05 PM
    #697
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    Got some new shoes today finally. 35x12.5x18 Toyo Open Country AT3’s wrapped around some Method 304’s +18 offset.
    9B7111A5-4369-459B-97AF-EA561CFB5C79.jpg 7209056F-0AC3-48B3-827C-65753CEFB44A.jpg
    3AB62C83-C39F-4FBB-BF4A-7F1F334D6383.jpg FE82F240-595F-4B39-9CC5-D35430C19F12.jpg
    aogrady22, iLDE, Terndrerrr and 8 others like this.
  8. Apr 15, 2022 at 7:24 AM
    #698
    Breathing Borla
    AZ
    for some reason these trucks with the spacer lift seem like the front is high than the rear in these pics, maybe its just the angle or something
    frichco228 and Terndrerrr like this.
  9. Apr 15, 2022 at 8:26 AM
    #699
    TexasTundra90
    Aaron
    Looks great! I'm sure this has been covered & I may have even asked already but did you do a wrap on the chrome?
  10. Apr 15, 2022 at 8:32 AM
    #700
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Def the angle or your eyes. I have a 2" spacer on mine and it's level. I've measured hub to fender, ground to fender, and even put a 3' level on the bed rail cap & then on the ground ground...angles matched on both.
    In minor defense of your statement I will say this: Immediately following the spacer installation, my front measured about .5" higher before the suspension settled. I drove it around for awhile, hit a few bumps, rolled the body left & right during some tight turns in an empty neighborhood development. After about ~3 miles, I measured it again and it was level. If people are excited and taking pics immediately after install before the suspension settles...then it's possible the front is slightly higher.
  11. Apr 15, 2022 at 9:21 AM
    #701
    Sparky916
    Blake
    Yep everything is wrapped.
  12. Apr 15, 2022 at 9:23 AM
    #702
    Sparky916
    Blake
    Yeah it just looks like that in pics. I think part of it is the trim on top of the bed being black makes it seem like the rear is sitting lower. To be honest, I haven’t actually measured it though.
  13. Apr 15, 2022 at 1:40 PM
    #703
    KentuckyWindage
    KentuckyWindage New Member
    275/65r20 BFG AT KO2
    Pacer164, iLDE, Tsquare[OP] and 2 others like this.
  14. Apr 15, 2022 at 2:30 PM
    #704
    Desert22
    Desert22 New Member
    2022 Tundra Limited
    35” Nitto Ridge Grapplers and 20x9 Fuel Sledge461B0796-0930-4C8F-9E3A-30BD0411F260.jpg2D2618F7-4479-4F84-B21A-418348D8D776.jpg
  15. Apr 15, 2022 at 5:33 PM
    #705
    Sparky916
    Blake
    Peak23 likes this.
  16. Apr 15, 2022 at 6:04 PM
    #706
    dstrbdmedic167
    dstrbdmedic167 New Member
    James
    Posted this on the 22 pic thread but thought I'd post here too. There is a good bit of poke but it's not "bro level" poke imo. This setup came off my Silverado and was an easy swap. I already had them here so may as well use them, right? I may change the rims out down the road but for now it works and does look quite good overall.
    295/60/20 Ridge Graps
    20x9 Fuel Siege +1 offset
    Wescott Designs 3/1 Level
  17. Apr 16, 2022 at 9:47 AM
    #707
    Dick Proenneke
    Dick Proenneke New Member
    Dick
    2022 Toyota Tundra Limited
    Tonneau, 3M, Tires
    Those are the nicest aftermarket wheels I have seen so far on the 2022. The styling goes well with the new Tundra design.
    Maharisc and dstrbdmedic167 like this.
  18. Apr 16, 2022 at 9:50 AM
    #708
    dstrbdmedic167
    James
    Thanks!
  19. Apr 16, 2022 at 8:03 PM
    #709
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Would those wheels fit on the stock rims on a Platinum? Also, how do you like that Wescott lift so far?
  20. Apr 16, 2022 at 8:49 PM
    #710
    theripper
    theripper New Member
    Oregon
    2022 MGM Tundra Platinum
    I went with the Wildpeaks, they ride so nice and are really quiet for e rated tire. I’m really happy with them. The weight increase wasn’t really noticeable, the truck still pulls like a monster and handles very nicely.
  21. Apr 17, 2022 at 7:54 AM
    #711
    dstrbdmedic167
    James
    Yea, they should work on stock wheels with any issues. I can tell the overall ride is a little bit stiffer but nothing to write home about.
  22. Apr 18, 2022 at 7:04 AM
    #712
    Breathing Borla
    AZ
    thats a lot of poke, do they have. +35?
  23. Apr 18, 2022 at 7:12 AM
    #713
    dstrbdmedic167
    James
    Assuming you’re talking about my truck, they make a +20 or +1. If I can sell these rims alone I may pick up the same setup with the +20. For now we ride with a little poke.
  24. Apr 18, 2022 at 7:33 AM
    #714
    Breathing Borla
    AZ
    yes, I was talking about yours, looks nice, just way to much poke for northern IL winters here.
    I wish more companies would make +35 ish so its flush
    I like those wheels though, look sharp, they have a full black version too I see
  25. Apr 18, 2022 at 8:00 AM
    #715
    dstrbdmedic167
    James
    Yea, that’s a bit much for someone up north. Luckily I don’t have that issue here in NC much.
    If this set wasn’t a takeoff from my ‘20 trail boss I would have gone with the +20 to bring it in a little.
    Having said that, if Toyota didn’t set the factory to +60 we (I) wouldn’t have this problem lol.
  26. Apr 18, 2022 at 9:26 AM
    #716
    TexasTundra90
    Aaron
    Curious for all of those that upgrade wheels/tires on the TRD Off-Roads.
    - Did you sell the OEM tires/wheels?
    - If so, how much did you end up getting for them?
    Getting my truck tomorrow & doing new wheels/tires on Sunday. Trying to figure out if I should take my tire shop up on their offer to sell them there or if I can get away with selling them on my own.
    Medic343 likes this.
  27. Apr 18, 2022 at 9:30 AM
    #717
    TexasTundra90
    Aaron
    Won't lie, I'm not usually a fan of bigger wheels but damn does that look good. Well done & quite the changeup from what a lot of folks in here have done.
  28. Apr 18, 2022 at 9:33 AM
    #718
    dstrbdmedic167
    James
    That honestly means a lot. I always try to do things a bit different than everyone else. That’s why I didn’t just go with a set of methods and 35’s like a lot of people. Not saying it doesn’t look good but everyone seems to be doing it.
  29. Apr 18, 2022 at 9:40 AM
    #719
    dstrbdmedic167
    James
    I’m holding onto mine for now. Will likely sell down the road.
    From what I’ve seen in the FB groups, I’d say $1300-$2000 depending on trim level (which rim) and if you have sensors or not. If the tire ship is giving you a good deal or thinks they can then go for it. You can always get replacements stocks down the road if you need too.
  30. Apr 18, 2022 at 9:46 AM
    #720
    TexasTundra90
    Aaron
    I think you did really well. Looks really good!
