GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 4, 2022 at 11:37 AM
    #631
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    What is bizarre is I checked with a tire shop here and they were telling me that the KO2's in 285/70R18's are the same weight as the Duratrac's 295/65R18's. I realize I will take a knock or two on the mpg, but that is crazy to me that a larger tire is lighter than a smaller tire that are both E rated...and have 3/32's more tread. What am I missing? Density of the rubber BFG's use over Goodyear?
  2. Apr 5, 2022 at 10:05 PM
    #632
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    Any rubbing whatsoever on your setup?
  3. Apr 6, 2022 at 3:32 PM
    #633
    Weimer369
    Weimer369 New Member
    Rob
    2022 Tundra Limited TRD Offroad Army Green
    Been through both 3rd gen tire threads and haven't seen anyone running a +12 offset ?
    Looking to add a set of Black Rhino Bantams with the 295/70/18 BFG KO2. Ive seen a lot of guys with 35x12.5 and a +18 offset with a little poke but was wondering if i ran these 11.6" tires with the +12 offset if it would still poke a little...
    Justinfro and Medic343 like this.
  4. Apr 6, 2022 at 3:37 PM
    #634
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    As you get closer to 0 the poke gets greater...but a +6 differential is so minor that it will look VERY similar to +18s, maybe a 1/4" more poke
    Weimer369[QUOTED] likes this.
  5. Apr 6, 2022 at 4:02 PM
    #635
    Henry2019
    Henry2019 N/A
    Houston, Texas
    Easiest way for me to determine the poke is to do MM to inches conversion then i pull out my stick ruler and go on from there :thumbsup:
  6. Apr 6, 2022 at 4:33 PM
    #636
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Black Rhino Rapids in +12 here…295/70/18’s
    You will get poke alright…just a little more than the +18’s
    ramnj, TexasTundra90, 9OH1 and 3 others like this.
  7. Apr 6, 2022 at 5:03 PM
    #637
    Weimer369
    Rob
    That's not too much poke...looks really good !
    Are you running any level or lift with them ?
  8. Apr 7, 2022 at 12:20 AM
    #638
    bigjuice
    WA State
    2024 Terra TRD Pro
    Yup…Westcott 3/1 lift
  9. Apr 7, 2022 at 11:30 AM
    #639
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
    this is a +7
    ramnj and Ryuu like this.
  10. Apr 7, 2022 at 1:17 PM
    #640
    Weimer369
    Rob
    I love the look of that stance...
  11. Apr 7, 2022 at 1:19 PM
    #641
    Weimer369
    Rob
    Hard to tell from pics...if you had to guess how much poke do you think that is with the +12 ? 1" ?
  12. Apr 7, 2022 at 1:41 PM
    #642
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  13. Apr 7, 2022 at 2:02 PM
    #643
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I really dig the black mustache vs wrapping it to match the body color. Assuming the Toyota body parts are in this same black finish, this is the way I'm gonna go (eventually).
  14. Apr 7, 2022 at 2:25 PM
    #644
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
  15. Apr 8, 2022 at 8:13 AM
    #645
    Tundralimited
    Tundralimited New Member
    Hello Tundra community members!
    ramnj, O2_Stat, Eagleye and 2 others like this.
  16. Apr 8, 2022 at 8:21 AM
    #646
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Wow, w/the LIFT and tires it really makes the truck look like a truck now..Beautiful!
    bigjuice[QUOTED] likes this.
  17. Apr 8, 2022 at 8:31 AM
    #647
    Owensnole
    Owensnole New Member
    Shane
    2022 Tundra SR5 - CrewMax
  18. Apr 8, 2022 at 9:51 AM
    #648
    fluke702
    fluke702 New Member
    Looks good, what are those HRE rims? Looks expensive!!
  19. Apr 8, 2022 at 10:59 AM
    #649
    Tundralimited
    HRE flow form FT1 if anyone is interested, 20x9, 0 offset. Contacted HRE and they had no specs on the car but everything from the previous Tacoma specs fit.
  20. Apr 8, 2022 at 8:01 PM
    #650
    Evan1794
    Evan1794 New Member
    2022 1794 TRD Blueprint
    35X12.5X20 Mickey Thompson Baja Boss A/T on stock trd wheels with wescott 3/1 lift.
    ramnj, Lebo, aogrady22 and 10 others like this.
  21. Apr 8, 2022 at 8:28 PM
    #651
    TexasTundra90
    TexasTundra90 New Member
    Aaron
    2022 Crew Max Army Green Tundra TRD Off-Road
    2022 Crew Max Army Green Tundra TRD Off-Road Mods so far: 295/70/18 Falken Wildpeaks ‘18 Battle Born wheels ‘1.75 Rough Country Leveling kit
    Nice! What are the specs for the battle born rims?
  22. Apr 8, 2022 at 8:58 PM
    #652
    TexasTundra90
    Aaron
    Does anyone run the Hankook Dynapro AT2's?
  23. Apr 8, 2022 at 9:23 PM
    #653
    bigjuice
    WA State
    2024 Terra TRD Pro
    That Blueprint color really tricks the eyes depending on the lighting and angles.
    With the 12.5 wide tire are you free and clear from any rubbing?
    Upper Control arm rubbing with true 35’s I thought/heard could be an issue with the stock 20’s if you didn’t run a spacer/shim hence the question.
  24. Apr 8, 2022 at 9:26 PM
    #654
    bigjuice
    WA State
    2024 Terra TRD Pro
    Just about yes…depending on how the suspension is loaded however (like the incline and slanted driveway I have) it can appear more on one side and less on the other.
    …but flat surface it’s about 1”
  25. Apr 8, 2022 at 9:28 PM
    #655
    Evan1794
    Evan1794 New Member
    There is no rubbing. I was prepared to use the 1/4" spacers but didn't need them. Didn't even need to pin the fender liners back. I'm guessing it must be the tire I used.
  26. Apr 8, 2022 at 9:30 PM
    #656
    bigjuice
    WA State
    2024 Terra TRD Pro
    Oh ok…very nice :thumbsup:
  27. Apr 9, 2022 at 1:56 AM
    #657
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    18x9 +18
    TexasTundra90[QUOTED] likes this.
  28. Apr 9, 2022 at 5:39 AM
    #658
    Tundra plat 22
    Tundra plat 22 New Member
    2022 tundra platinum blue print blue
    1.75 lever , 35x 12.5 x17 mitts ridgegrapper Rims motiv mill 17x9 offset black
    Beautiful truck
  29. Apr 9, 2022 at 6:33 AM
    #659
    Tundra plat 22
    A334C0DC-8D50-4020-9AB8-FC73E207B458.jpg1.75 rough country n airbag readjusted up 1 inch
    ramnj, aogrady22, iLDE and 2 others like this.
  30. Apr 9, 2022 at 7:27 AM
    #660
    TexasTundra90
    Aaron
    How has everyone’s experience with the Rough Country 1.75 been?
    Have a local shop running a deal right now where they are doing a free rough country level kit (& install) with the purchase of a wheel/tire combo.
