GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jul 6, 2025 at 5:29 AM
    #5581
    dark_knight_sig
    dark_knight_sig New Member
    2023 Toyota Tundra SR5
    Where did you order the 18 inch RRWs? Can't find them in stock anywhere
  2. Jul 7, 2025 at 5:09 AM
    #5582
    beer30
    beer30 New Member
    From RRW, it took several months for them to come in.
    I do believe 88 Rotors keeps a stock of them though.
  3. Jul 7, 2025 at 5:20 AM
    #5583
    dark_knight_sig
    Got it, appreciate the info. Not sure if you answered this elsewhere, is that the trd lift?
  4. Jul 7, 2025 at 5:21 AM
    #5584
    beer30
    beer30 New Member
    It's the Factory 3" lift, although I put Dobinson's springs on the rear. I wasn't a fan of the spacer lift that they did on the rear, it felt super soft.
  5. Jul 7, 2025 at 5:22 AM
    #5585
    dark_knight_sig
    Ah nice, it looks great
    beer30[QUOTED] likes this.
  6. Jul 7, 2025 at 8:14 PM
    #5586
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Did you have any rubbing on the liners or anything like that? I have the same except no Westcott but I put Bilstein 6122 (1.7" lift) in front and Bilstein 6100 + Eibach pro coils in rear (1"). I get some rub when turning and it's definitely annoying. Wondering if there's an easy fix?
  7. Jul 13, 2025 at 7:57 AM
    #5587
    BLU3C0BRA
    BLU3C0BRA New Member
    2024 Ice Cap SR5 TRD Sport 4x4
    Icon stage 6 3 inch lift 20 inch fuels 35 ridge grapplers Gorhino running boards
    Icon 2.5 Stage 6 (3.5 in lift)
    Fuel 20x9 +20
    Nitto Ridge Grapplers 35x12.5
    Pin back front fender liner
    MAC25Tundra, SDtrueblue and Paul499 like this.
  8. Jul 21, 2025 at 12:50 PM
    #5588
    MikeVpdx503
    MikeVpdx503 New Member
    Confirmed fitment of LT285/65R20 on stock wheels and suspension on pavement at least.
    This is at full lock reversing out of my driveway.
    I can get my girlie size hands in and all around without touching fender liner, UCA or LCA but it looks like it might rub UCA if fully stuffed with articulation while off road. This is where a .5-1” front suspension lift could be a factor but I dislike spacer lift and avoid. Not interested in a full suspension lift. I would opt for a very mild body mount lift before suspension but I’m happy as is to fit 34.5” tires stock.
    tlakeTundra, MAC25Tundra and Paul499 like this.
  9. Jul 21, 2025 at 1:51 PM
    #5589
    PATundra13
    PATundra13 New Member
    Pittsburgh, PA
    2024 Tundra 1794 I-Force Max, Smoked Mesquite
    RC running boards and RC hard tonneau cover, TRD air filters, Mace MFG knobs, Beat Sonic amp, TVD decals, front windows tinted.
    285/65/R20 geolander g018 at4. No lift or level stock 1794 wheels. This is the size that should have come stock.
    tlakeTundra and BlackNBlu like this.
  10. Jul 24, 2025 at 9:49 AM
    #5590
    hothb
    hothb I’d rather be biking
    Montana
    ‘25 Limited TRD Off-Road 6.5” bed
    So many sick setups here, nice work everyone.
    Just picked up a 25 Limited Crewmax 6.5 foot bed.
    Quick question here as I dont see it covered (maybe its irrelevant) - does the TRD off-road package have the same clearance as the non-TRD?
    Safe to assume 285/65R20 is the max with stock suspension for both?
  11. Jul 26, 2025 at 1:51 PM
    #5591
    Daedalus
    Daedalus New Member
    I’ve seen a few things here or there on this topic.
    Pressures. 285/75 18 e rated tires (10ply)
    what pressure are you all running on 35s.
  12. Jul 26, 2025 at 2:03 PM
    #5592
    bailey bulldog
    bailey bulldog New Member
    Trying 42, may go to 44 on my duratrac RTs.
  13. Jul 26, 2025 at 2:06 PM
    #5593
    Daedalus
    Daedalus New Member
    I’m at 42f 38r.
    was wondering if I. Needed to drop lower. Seeing a variety of answers.
  14. Jul 26, 2025 at 2:10 PM
    #5594
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I set mine to 38 all around
  15. Jul 26, 2025 at 2:20 PM
    #5595
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    unless you’re heavily loaded that seems super high…
    Best way is to have the truck weighed per axle and look at the load/inflation chart for your tire
  16. Jul 30, 2025 at 2:58 PM
    #5596
    D_Money
    D_Money New Member
    23 Pro MGM
    Still need to swap mine out, so no pics yet…other things have come up and had some trips get in the way so will be doing soon. Did you end up going with Toyo AT3’s? E rated? Do they have a true 37” and what width are yours? Am between Wildpeak AT4W’s and the Toyo AT3’s. Thanks!
  17. Jul 30, 2025 at 3:12 PM
    #5597
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I ran 295/60R20's Toyos AT3's E rated at 40 psi. Be prepared for the mileage hit! I saw mine go way down with the bigger E rated tires.
    I have 295/70R18 Wildpeaks AT4W's on the new truck and I like them but the are pumped up to 80 psi currently (65 psi on the front). I am going to play around with the pressure when I have a moment to try to smooth put the ride a bit.
    Another thing to consider is getting some Centramatics behind these big AT tires. They will last longer and not start the cupping and howling noise associated with these tires.
  18. Jul 31, 2025 at 7:06 PM
    #5598
    Tundra Owner2
    Tundra Owner2 Tundra Owner2
    Tires, TRD aluminum Skid Plate, 14 inch screen protector, and X15 Tonneau cover.
    MY22, 31K+. Just broke down and got new tires. 295/70/18 Cooper Stronghold ATs. OEM wheels with+60 offset. No lift, no rub, no poke. The tire shop insisted they wouldn't fit. while on the lift, I had the tech mount the driver's side and I showed him the turning radius and spacing. He put the remaining three on, put it on the ground and again I showed him full turn with lock, plenty of spacing. My only concern was the the spacing between tire and UCA...absolutely no issues, lots of room. They other techs started clapping and said it looked like a truck now. They were impressed. Next mod will be a lift of some sort.2957018 pic1.jpg 2957018 pic2.jpg 2957018 pic3.jpg
    kirkb, BlackNBlu and hothb like this.
  19. Jul 31, 2025 at 7:44 PM
    #5599
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Looks good. I have same setup with falkens and added a 1” cornfed front lift.
  20. Aug 2, 2025 at 11:56 AM
    #5600
    HS25Tundra
    HS25Tundra New Member
    2025 Lunar Rock Tundra Limited Hybrid 4x4
    Did you have any issues with rubbing? And did you need a lift for that setup? I’m looking to get the same setup so was curious and do you happen to know how much they weigh?
  21. Aug 2, 2025 at 12:05 PM
    #5601
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Currently at 40F/R on same size and E-rated/10 ply. (Cooper Stronghold A/T)
    Still playing with pressures. Might drop to 38-ish.
    Daedalus[QUOTED] likes this.
  22. Aug 2, 2025 at 12:07 PM
    #5602
    Daedalus
    Daedalus New Member
    I ended up dropping down to 39f 37r and it seems to have done okay.
    I was seeing funny center rib wear from over pressure on the tires
    now they are wearing much more evenly (dry concrete is a great indicator).
    BlackNBlu likes this.
  23. Aug 2, 2025 at 5:51 PM
    #5603
    Tundra Owner2
    I have my set at 38 all the way around. I haven't notice any uneven wear yet. Total asphalt asset this month.
    MAC25Tundra and Daedalus[QUOTED] like this.
  24. Aug 3, 2025 at 7:08 AM
    #5604
    18" TRD Off Road Wheels
    Completely off topic, but i love the squished Taco avatar. Where'd you find it?
  25. Aug 3, 2025 at 9:19 AM
    #5605
    Tundra Owner2
    I googled "cartoon tundra" and added a smiley face and saved as JPEG.
    GODZILLA[QUOTED] likes this.
  26. Aug 4, 2025 at 5:02 PM
    #5606
    Trdmikey8
    Trdmikey8 New Member
    How does the 275 ride? Im thinking of getting 285 but discount tire says it won't fit and will rub with my leveling kit. But he said 275 will fit perfect
  27. Aug 4, 2025 at 5:03 PM
    #5607
    Trdmikey8
    Looks very good. I have the same offset but discount tire says I can't fit anything bigger than 275. But the offroad shops say I can..
  28. Aug 5, 2025 at 6:44 PM
    #5608
    bailey bulldog
    I have 285/75r18 Duratrac RTs, which are 35.06" tall and they fit, no issues.
  29. Aug 6, 2025 at 8:54 AM
    #5609
    Daedalus
    Daedalus New Member
    Cornfed 1.5 level.
    285/75 18s.
    tlakeTundra and Paul499 like this.
  30. Aug 7, 2025 at 10:44 AM
    #5610
    hothb
    Montana
    Trying to do a gut-check on offset...
    275/70r18 +25mm offset...stock suspension...should fit eh?
    Paul499 likes this.
