GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. May 16, 2025 at 9:35 PM
    #5521
    MTR1989
    MTR1989 New Member
    25 Tundra
  2. May 16, 2025 at 9:37 PM
    #5522
    MTR1989
    MTR1989 New Member
    25 Tundra
    Oh geez.. duh! My bad. Thanks
  3. May 19, 2025 at 10:54 PM
    #5523
    Manutd818
    Manutd818 New Member
    2024 Tundra Limited Trd off-road
    I’m looking at the wildpeak at4s. Can’t decide on the size. I have the OR 20” wheels. I can go with 285/65/20 which is 34.8 tire or 35/11.5/20 which is a 35” tire. Keep in mind 285/65 runs bigger than ko3 or the toyos in 35/11.5. Not sure if they will rub. Stock suspension no lift or level. Not interested at the moment.
  4. May 20, 2025 at 6:49 AM
    #5524
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
  5. May 20, 2025 at 11:21 AM
    #5525
    izzulap
    izzulap New Member
    James
    24 limited CM/5.5
    3 inch Trd lift
    Trying to figure this out, I am in the market for new tires, I currently have 265/60r20 tires on the factory black 20x8 +60 wheels. Can I fit 33x12.50r20s without rubbing on the UCA? Would I need to run a 1-2 inch spacer to prevent hitting? I have the 3 inch trd lift
  6. May 21, 2025 at 11:53 AM
    #5526
    csmobley
    csmobley New Member
    New Bern, NC
    2025 Toyota Tundra TRD Pro
    @izzulap from everything I have read on this thread, which is a lot, you should be able to run 35's with zero issues, with the factory 3" TRD lift installed. So I would imagine 33's would for sure be a no issue install. Just my opinion.
    SoCal_Erik likes this.
  7. May 21, 2025 at 3:07 PM
    #5527
    izzulap
    izzulap New Member
    James
    24 limited CM/5.5
    3 inch Trd lift
    Thank you, my main concern was about the width and clearing the UCA i've read multiple places that 12.5 width wont fit or wont fit on the 8 inch wheel. But I have also read that there are no issues. I just need to keep researching before I pull the trigger on anything I guess.
  8. May 21, 2025 at 3:13 PM
    #5528
    csmobley
    csmobley New Member
    New Bern, NC
    @izzulap totally agree and get it! Good luck with your research!
  9. May 28, 2025 at 9:59 AM
    #5529
    Gerch
    Gerch New Member
    Sorry for the late reply.
    The Nitto Terra Grappler G3 is a great tire! They do well in the rain and are very quiet on the road. They look good. No complaints. I got the SL to keep the weight down. I only notice about a 1 mpg drop on the trucks computer. Very happy with my decision.
    mach1man001 likes this.
  10. May 29, 2025 at 11:10 AM
    #5530
    izzulap
    izzulap New Member
    James
    24 limited CM/5.5
    3 inch Trd lift
    Ended up with used tires off facebook for $175 $72 to mount and balance them. 295/65r20 BFG km3. Little rub on rear fender liner, I might take some sheers and trim them. Or I’ll get some 1-1.5 spacers
    MAC25Tundra likes this.
  11. May 30, 2025 at 8:14 PM
    #5531
    Lahhi
    Lahhi New Member
    Evan
    2025 tundra sr5
    Lift, tires, tint, leather, rock rails
    New member here. Came back to Tundra after having a 2012 years ago. I have a 2025 SR5. Did a 2" level, trd wheels with 275/65 r20. Fits great! Also added rock slides for side steps, tinted the windows and katzskin leather throughout. 20250530_193649.jpg
  12. May 31, 2025 at 5:48 AM
    #5532
    Daedalus
    Daedalus New Member
    285/75 18 is a perfect fit.
    34.8x11ish.
  13. May 31, 2025 at 5:50 AM
    #5533
    Daedalus
    Daedalus New Member
    Example
  14. Jun 3, 2025 at 8:05 AM
    #5534
    aston018
    aston018 New Member
    Drew
    24 Tundra LTD TRD OR
    Bilstein 5100, wheels & tires,
    This is exactly what I'm looking to do. No rubbing on UCAs or sway bar?
  15. Jun 3, 2025 at 9:29 AM
    #5535
    Toklas
    Toklas New Member
    2023 limited TRD OR CM short bed blueprint
    so these are 285/75r18 with stock TRDOR no lift and OEM wheel at +60 offset? it looks like you removed the front mud flaps? did you do anything else?
  16. Jun 3, 2025 at 9:46 AM
    #5536
    Daedalus
    Daedalus New Member
    Just the mudflats and the box in the wheel well.
    Zero rubbing or issues.
  17. Jun 3, 2025 at 9:55 AM
    #5537
    Toklas
    Toklas New Member
    i'm looking at 295/70r18 which is just a bit smaller 343" but a bit wider and maybe +25 offset. my guess is it will be close to the same as yours. hoping its just the mudflaps and the liner/box remove..
  18. Jun 3, 2025 at 10:14 AM
    #5538
    Daedalus
    Daedalus New Member
    Honestly, the height wasn't my concern, it was the width. The truck has about an inch between the UCA and the tire sidewall. With it not being a true 35" tire, it still clears the FSB.
  19. Jun 5, 2025 at 8:56 AM
    #5539
    dark_knight_sig
    dark_knight_sig New Member
    2023 Toyota Tundra SR5
    Looks great! I've been trying to research to see if there is a max load capacity for these wheels but can't find anything. I know they can fit the tundra, but can they handle the load of the tundra? Have you had any issues with them?
  20. Jun 5, 2025 at 3:56 PM
    #5540
    HomieDontPlayDat
    HomieDontPlayDat New Member
    Vinny
    Southwest
    2025 Tundra TRD
    I upgraded from 265/60R20 to 285/65R20 Falcon WP on stock TRD wheels and they fit fine, No rubbing on full tilt. I do have some 1.75” rough country leveling kit to raise the front but have not installed them yet.
    BlackNBlu, Daedalus[QUOTED] and kirkb like this.
  21. Jun 6, 2025 at 9:32 AM
    #5541
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
  22. Jun 6, 2025 at 10:31 AM
    #5542
    HomieDontPlayDat
    Vinny
    Southwest
    2025 Tundra TRD
    When I get home I’m will measure and take pics for distance
    GoHuskers[QUOTED] likes this.
  23. Jun 7, 2025 at 6:16 AM
    #5543
    Manutd818
    I have the WP at4 also same size. I would say it’s about an inch. Your hand can get in there pretty comfortably.
  24. Jun 7, 2025 at 6:46 AM
    #5544
    Daedalus
    Daedalus New Member
    285/75 18s
    plenty of clearance.
    GoHuskers and HomieDontPlayDat like this.
  25. Jun 10, 2025 at 7:11 AM
    #5545
    24TundraTRD
    24TundraTRD New Member
    '24 CrewMax Limited TRD
    New tires. Cooper Discoverer AT3 XLT 275/65/20. No lift / level.
  26. Jun 10, 2025 at 11:10 AM
    #5546
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    That looks about perfect. I have a 25 limited off-road. If that size fits stock I might go that route for hunting and fishing. Any more pics of that set up sir? Thanks
  27. Jun 10, 2025 at 11:12 AM
    #5547
    bowhuntercoop
    Also looks awesome. I feel like if I go 275/65/20 go with the sl to save weight. Bigger then that stuck with load range E. Gunna wear these stocks down and decide a size I guess!
  28. Jun 10, 2025 at 11:43 AM
    #5548
    24TundraTRD
    That was my plan, but after towing with the stock Falkens I went ahead and pulled the trigger. They weren't awful, but clearly weren't made for towing. $1000 is cheap insurance.
  29. Jun 10, 2025 at 5:37 PM
    #5549
    Thebio2
    Thebio2 New Member
    18x9 Method MR305 NV +18 wheels
    KO3 LT275/70R18
    I maybe daft, but the center caps didn’t fit with the hub centric rings. What and I doing wrong?
    Truck is so much better looking now even without them.
  30. Jun 10, 2025 at 9:56 PM
    #5550
    HomieDontPlayDat
    Vinny
    Southwest
    2025 Tundra TRD
    I thought I needed a lift but drove it 300 miles today to Cali and no rubbing issues around tight spaces and a few U-turns. I do have a rough country 1.75” leveling lift that I will install next week.
    Rigger and bowhuntercoop[QUOTED] like this.
