GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 11, 2025 at 3:10 PM
    #5461
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    DX4 Capers, 18X9 +12
    Cooper Discoverer Stronghold AT, 285/75/18
    [edit] The white letters were an experiment with tire paint marker and have since been power-washed off. [/edit]
    Pretty minimal poke; just the tire bulge beyond the fender edge.
    Going to get some EGR flares color-matched for an extra inch of coverage, and likely some Rek-Gen flaps.
    Weights and measures; comparison to stock 20's:
    Stock 20's and 265/60 Mildpeaks = 74 pounds/corner
    18's and 285/75 Coopers = 85 pounds/corner
    Net gain of 11 pounds per corner.
  2. Apr 15, 2025 at 1:45 PM
    #5462
    1stTundraNotLast
    1stTundraNotLast New Member
    Ben
    2024 Lunar Rock 1794
    Factory Lift, Tonneau cover.
    How big of a lift are you running? Did you have to do a horn chop to fit the 37's in there?
    Also- does anyone have a NOMAD WHEELS discount code? The ones I want are only 15% off. Sad tundra face.
  3. Apr 17, 2025 at 11:19 AM
    #5463
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Sick! Do you rub swaybar with this setup?
    Pizzanaut[QUOTED] likes this.
  4. Apr 17, 2025 at 1:37 PM
    #5464
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Switched out OEM tires in January to a set of winters…on the OEM 20’s that now come standard.
    Then put on a set of KO3’s A/T’s on the weekend…back to my aftermarket 18’s.
  5. Apr 17, 2025 at 2:31 PM
    #5465
    Cowboyzfan
    Cowboyzfan New Member
    South Texas
    2023 Army Green SR5 Crewmax 4x4 TRD Sport - Straight Stock
    Xpel XR Window Tint Premium 3D Dashboard letters Tundra Tailgate Inserts Gear Shift Panel Trim Cover - Matt Black
    Nice! Did the tire shop give you any grief about selecting this size. Discount Tire website gives a warning about 275/65/R20 "The product must meet all vehicle manufacturers’ safety standards and specifications. Discount Tire will only install a product authorized for a specific vehicle." blah blah blah...
  6. Apr 18, 2025 at 7:28 AM
    #5466
    Pizzanaut
    Pizzanaut New Member
    No rub full lock both directions! Really happy with the end result
    ARCOVT23[QUOTED] likes this.
  7. Apr 18, 2025 at 1:36 PM
    #5467
    bailey bulldog
    bailey bulldog New Member
    How are you liking the tires? Good in the rain? Noisy?
  8. Apr 18, 2025 at 2:30 PM
    #5468
    roti
    roti New Member
    Not at all. They actually told me the max I could go was a 285 without rub. This was back in 2022 when the Tundras first came out and we didn’t have a whole lot of setups to compare against either. They were pretty well informed surprisingly
    Cowboyzfan[QUOTED] likes this.
  9. Apr 18, 2025 at 2:34 PM
    #5469
    Noelandry
    Noelandry New Member
    Adrian
    2025 Limited
    Thanks to the forum for helping me get the set up I was hoping for. To help with some of the suffocating research I conducted, I will put everything in one spot. I have a 2025 Magnetic Metallic Grey Limited Tundra. My key items I wanted to accomplish were:
    -OEM wheels
    -No more than a 1" leveling kit
    -No heavy increase in weight
    -Offset less than 60mm
    -18" wheel
    -Limited..LIMITED amount of poke
    Stock tires on the limited trim are a 265/60r20 Bridgestone Dueller and weigh in at 47.112 lbs. Stock 20" wheels weighs 40 lbs. 87 lbs total.
    I found some 2025 4Runner OEM take-offs. The 2024 and up Tacoma and 2025 4runners all have the same hub bore, bolt pattern and threads as a Tundra. The wheel is Toyota part number PTR56-35242-F1 @ 18x8 with a 40mm offset. Wheel weighs 32 lbs.
    I went with 295/70r18 Toyo Open Country R/T Trails that weigh in at 65 lbs. That puts an additional 10 lbs at each wheel. Not the best, not the worst. I had Discount Tire match the Buy 3, Get 1 Free from Mopar dealers. They didn't even bat an eye at my request and pushed it right through. Saved myself easily $500!
    As it stands, the truck does not have a leveling kit. As noted repetitively the 295/70r18 will fit factory suspension. The 40mm offset provides a bit more room up by the upper control arm.
    Buying the wheels from a dealer isn't that much, most of them are priced at $250 each. I found all 4 of mine for $400. As more time goes by and more 2025 4runners hit the market there will be plenty of additional opportunities moving forward to capture these additional options.
    Couldn't be happier with the end result!!!
    hothb, GODZILLA, 96706Tundra and 3 others like this.
  10. Apr 18, 2025 at 3:19 PM
    #5470
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Love the way 37" tires look on my Tundra. Just have to figure out the rubbing on the sway bar at full turn. I've read of putting the TRD Pro sway bar as it has a different bend and will fix the problem. Anybody else tried it?
    Done searches for a fix but I'm not good on the internet search stuff. Any help is appreciated.
  11. Apr 18, 2025 at 3:54 PM
    #5471
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    These are factory issued on 6th Gen 4Runners? They’re made in Mexico. I thought it was an accessory Tacoma wheel.
  12. Apr 18, 2025 at 5:48 PM
    #5472
    D_Money
    D_Money New Member
    23 Pro MGM
    Nice, you did do the 37's...looks awesome! Did you get the Wescott 3/1 & TRD shocks put in as well? Looking to do 17's & 37x12.5 soon on my Pro...I can update about sway bar rub once that is done. Probably within 1-2 weeks.
    Your wheels still the same 18's from before it looks like? Also, what is your offset?
  13. Apr 18, 2025 at 9:44 PM
    #5473
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Yes, and very happy with the results. The most important is getting the shop to do the Westcott recommended alignment. I also stayed with the 18” wheels. I was concerned with the wheels not fitting correctly if I went with 17”. Offset is 18+ and wheels are 18x9.
    Truck rides better than when it was stock with the exception of the rub on the sway bar at full turn.
    Hope to see your pics soon.
  14. Apr 18, 2025 at 10:01 PM
    #5474
    D_Money
    D_Money New Member
    23 Pro MGM
    For sure, I will update with pics, before & after. Currently wheel/tire combo is stock Pro. I will be adding a leveling kit as well, which will have a little more in the front, to raise total height probably another inch or so. Will see what the shop all has to do to make it fit but should be minimal. I’m looking to do either +0 or -10 offset…I figure the Pro fender flares/covers stick out a little more and that may also aid in clearance perhaps. Maybe power steps too while they’re at it lol.
    ramnj[QUOTED] likes this.
  15. Apr 19, 2025 at 4:13 AM
    #5475
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
  16. Apr 24, 2025 at 7:08 AM
    #5476
    RedBull
    RedBull New Member
    Boise
    2023 Platinum Hybrid 4x4 Supersonic Red
    Fuel Rebel 18x9, Nitto Recon Grappler 295/70/18, Westcott 2/1 level
    Just finished an 800-mile road trip and was very pleased with the noise/comfort level. Saw light rain over the passes and these Recon Grapplers did okay, but they do break traction easily on snow/ice. Had a freak hailstorm a couple of weeks ago and the truck was fishtailing like crazy. I have a dedicated set of Michelin X-Ice on the OEM 20" wheels for the winters so I knew going in that this set was primarily for dry good weather conditions and so far I'm happy with how they have performed.
  17. Apr 24, 2025 at 7:39 AM
    #5477
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    What is everyone doing when it comes to tire pressure sensors? Tranferring to new wheels or buying new ones?
    I want to get some stock TRD OR wheels for my ‘24 platinum and wonder if the truck would automatically pick up the sensors from TRD OR wheels from another truck.
  18. Apr 24, 2025 at 7:52 AM
    #5478
    greenranger
    greenranger New Member
    JT
    2022 TRD OR
    This looks sick. Good work!
  19. Apr 24, 2025 at 11:54 AM
    #5479
    Pizzanaut
    I got new sensors with the new rims, in the gage cluster dashboard screen there’s a process to re-recognize the new sensors in settings. Had to drive a few miles over a day or two (short work trips) but eventually it recognized the new ones.
    Yugo[QUOTED] likes this.
  20. Apr 24, 2025 at 3:30 PM
    #5480
    ScottyBowman
    ScottyBowman New Member
    Scott
    New Brunswick, Canada
    2025 Toyota Tundra Limited
    Falken Wildpeak AT4 295/60/20 Rough Country 1.75 levelling kit Go Rhino RB20 Slim Running Boards Extang Trifecta Tri-Fold Tonneau Cover
    Did you ever replace them with the Coopers? If so, how do you find the ride?
  21. Apr 24, 2025 at 6:23 PM
    #5481
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    Thank you for the feedback. If you don’t mind please share part number for the sensors. I had trouble programming new sensors when I had my 2018 so now I am a little paranoid.
  22. Apr 25, 2025 at 7:23 PM
    #5482
    24TundraTRD
    24TundraTRD New Member
    '24 CrewMax Limited TRD
    That's the tire and size I'm looking at. How have you liked them?
  23. Apr 26, 2025 at 12:03 PM
    #5483
    Pizzanaut
    should be UVS7051 Sensors
  24. Apr 27, 2025 at 4:27 PM
    #5484
    HeyMcFly
    HeyMcFly New Member
    2022 Tundra Platinum
    Did you ever install the Westcott kit? If so, how does it look with the tires? Debating if I want to keep the stock rims and just get the AT3
  25. Apr 28, 2025 at 8:20 AM
    #5485
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
    Sorry - just saw this.
    I did not replace the UCA's or do a diff drop. I went to between 1.75-2.00".
  26. Apr 28, 2025 at 3:22 PM
    #5486
    csmobley
    csmobley New Member
    New Bern, NC
    2025 Toyota Tundra TRD Pro
    Hey bud, nice looking truck. Picking mine up next month, wondering if you went with the +25 offset on these or the +0 offset?
  27. Apr 29, 2025 at 11:36 AM
    #5487
    ORANGETRDPROGIRL
    ORANGETRDPROGIRL New Member
    South Florida
    Solar Orange Tundra TRDPRO
    12.5 will more than likely be too wide for the stock rims and would more than likely rub as well without some kind of lift.
  28. May 2, 2025 at 9:16 AM
    #5488
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Pm replied to. These are the 0 offset. Definitely some poke but not terrible
  29. May 2, 2025 at 5:35 PM
    #5489
    LuneyTunes
    LuneyTunes New Member
    2025 Tundra Lunar Rock SR5
    Just got some new goodies for my Tundra. Stoked with how it turned out!
    Method 703 +35 17”
    KO2 35/12.5/17
    Bilstein 5100 struts and shocks (4th clip setting)
    Trdmikey8, COTundra23, jachal and 4 others like this.
  30. May 4, 2025 at 3:30 AM
    #5490
    18" TRD Off Road Wheels
    This is some great info! Quick question: Did your original TPMS sensors swap over, or did you have to get new ones?
    Corndog123 likes this.
