GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Feb 19, 2025 at 5:53 PM
    #5371
    Reef2018
    Reef2018 New Member
    Colton
    24 TRD Offroad 4x4 Limited
    thanks so much. do you have any pictures from a little further away? What are the tire dimensions
  2. Feb 19, 2025 at 5:59 PM
    #5372
    Jer
    Jer New Member
    Jeremy
    2024 supersonic red TRD sport
    Do these help?
    Redward 25 and Reef2018[QUOTED] like this.
  3. Feb 19, 2025 at 7:22 PM
    #5373
    SlowRollin
    SlowRollin New Member
    Utah
    White 24’ Limited OR
    Just got mine finished up.
    RRW RR5-H 17” 285/75 Toyo AT3s
    2snailsandabattery likes this.
  4. Feb 20, 2025 at 5:50 AM
    #5374
    2snailsandabattery
    2snailsandabattery New Member
    2023 limited
    Icon stage 1
    Are these the +25 ?Looks great
  5. Feb 20, 2025 at 6:12 AM
    #5375
    SlowRollin
    Utah
    Thanks! They’re +18. On stock suspension.
  6. Feb 20, 2025 at 6:18 AM
    #5376
    Reef2018
    Reef2018 New Member
    Colton
    Are the width on these 11.3? The K02 35’s are 12.5 so I’m thinking at the same offset, I’d be poking out about an inch more.
  7. Feb 20, 2025 at 6:55 AM
    #5377
    SlowRollin
    Utah
    Yes, they’re 11.3. I would think you’d have closer to 1/2” more poke due to some of the extra width being on the inside as well. Either way, I don’t think it would be a ton more and would look really good.
    Reef2018[QUOTED] likes this.
  8. Feb 20, 2025 at 7:04 AM
    #5378
    2snailsandabattery
    2023 limited
    Icon stage 1
    +18 8 inch wide? You are kind of making me regret my 8.5 +25 order. This looks perfect
  9. Feb 20, 2025 at 10:08 AM
    #5379
    Smokedmescal24
    Smokedmescal24 New Member
    TRD lift with 275/65R20 Nitto Recon Grapplers on oem wheels. These were the only tires I found in SL for that tire size. I think this size/spec just came out this year. Wanted something bigger but light. Slight sway bar rub on driver side.
    Tony.ga, ramnj, ytank1 and 4 others like this.
  10. Feb 20, 2025 at 10:55 AM
    #5380
    SlowRollin
    Utah
    Yeah, it’s the +18 17x8s. What tires are you planning on running?
  11. Feb 20, 2025 at 11:11 AM
    #5381
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    18x9+20 Gram Light 57DR-X on 295/70/18 Wildpeak AT3Ws
    HAMITY, dadrocz, Volator and 8 others like this.
  12. Feb 20, 2025 at 1:15 PM
    #5382
    2snailsandabattery
    2023 limited
    Icon stage 1
    315/70 r17 ko3s
  13. Feb 21, 2025 at 6:22 AM
    #5383
    Bigasia00
    Bigasia00 New Member
    Lunar Rock 2024 Tundra SR5
    Kept it nice and simple. Basic tire upgrade - Nitto Ridge Grapplers: 275/60/r20's (stock everything else). Ride is still very smooth, not a lot of extra noise, and looks way better than the OEM tires. Couple of before and afters:
  14. Feb 21, 2025 at 1:54 PM
    #5384
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    35x12.5 KO2 on 18x9 +19
    OE 3" lift
  15. Feb 23, 2025 at 2:18 PM
    #5385
    euroshowoff
    euroshowoff New Member
    Ronnie
    2024 Limited
    18x8 Tacoma pro wheels +20 on 35x11.5 fallen at4s
    G500, iknowbro, Siblue and 2 others like this.
  16. Feb 23, 2025 at 2:20 PM
    #5386
    bailey bulldog
    bailey bulldog New Member
    Looks great! Where did you get the wheels?
  17. Feb 23, 2025 at 2:31 PM
    #5387
    euroshowoff
    Ronnie
    2024 Limited
    My local dealer had the best price, and free shipping. Think it was like $217 a wheel. Had to order the center caps separately.
  18. Feb 23, 2025 at 2:48 PM
    #5388
    mikeaesq
    mikeaesq New Member
    2025 1794 TRD Off Road
    Which dealer?
  19. Feb 23, 2025 at 2:51 PM
    #5389
    bailey bulldog
    How much do they weigh?
  20. Feb 23, 2025 at 4:06 PM
    #5390
    euroshowoff
    Ronnie
    2024 Limited
    Sheehy Fredericksburg Va
  21. Feb 24, 2025 at 5:30 PM
    #5391
    Csstundra
    Csstundra New Member
    Craig
    2022 Platinum
    How do the 295s ride? I have 285s which I believe is a car rated tire. The 295s are a truck rated tire I believe. Would like to go up the 295s
  22. Mar 1, 2025 at 6:26 PM
    #5392
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    yup - got them in 295/70/18 and am very impressed... quiet, good handling and great in the snow....
  23. Mar 2, 2025 at 12:38 PM
    #5393
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    Well boys, this is a long time coming. Finally sprung for new shoes after having the truck for a year, 12k miles.
    20x9 Weld Ledge 6 +20 (34 lbs)
    P285/60R20 Toyo Open Country AT3 116T (48 lbs)
    Rough Country N3 2” front leveling struts
    Total cost for everything ordered and installed + alignment was $3980. After a year of research I determined this was a reasonable price. Installer handled everything. Went to 941 Wheels and Tires in Bradenton, FL. They were great, very easy to deal with, check them out if you're in the area.
    Stock platinum setup
    Tire 38 lbs, wheel 37.9 lbs = 75.9 lbs
    New setup
    Tire 48 lbs, wheel 34 lbs = 82 lbs
    Was looking for the biggest P-rated tire and a lightweight wheel to keep the ride nice, road noise minimal, and gas mileage decent.
    Wanted to stick with 20s because this pavement princess will never tow, haul, or see dirt. Plus I like the look of these Weld wheels and they don’t weigh a ton like the Fuels or Methods everyone seems to have. My installer hasn’t seen a lot of Weld wheels but did comment that they seemed light and strong and they were the straightest driving wheels he’s installed. He prob says that to everyone so I’ll take it with a grain of salt.
    Also was looking for a goldilocks lift. I wanted the leveled look but didn't want a cheap puck spacer on my smooth riding platinum. Also didn't want to drop thousands more on a suspension lift kit. So I found what I believe to be the perfect compromise with the RC N3 leveling struts which gave the truck a 2" lift in the front and made it perfectly level without firming up the ride.
    Speaking of looks, it looks like a different truck! I’ve seen a lot of comments from others about how “pictures don’t do it justice” and I totally get it now. It just looks so beefy and badass in person with the lift and AT tires.
  24. Mar 2, 2025 at 12:38 PM
    #5394
    Paul499
    Paul
    Sarasota, FL
    ^^After driving the truck stock for a whole year as my daily, here are my initial observations after the upgrade…
    Ride feels pretty much like stock. It feels more planted to the road but not heavier or harsher. I was worried about stiffness but it’s nice and smooth, really similar to stock. I took it on the highway and went up to about 95 mph to see if road noise or vibration would be a problem but had no issues. The RC N3 struts and Toyo tires have made a great first impression.
    For you hybrid owners, I was worried about the electric motor never engaging after adding a slightly heavier setup but it’s still kicking in at all the same places. I’ve become a master of maximizing the hybrid and it hasn’t really changed after the upgrade. Would prob be different with E rated tires.
    The biggest difference is slowing down - with the stock setup I coasted a lot in suburban driving. It would coast and maintain momentum forever. Now I def feel the truck slowing down more when I coast. Also I have to apply the brakes just a little bit more to stop.
    After literally only 2 days of driving my gas mileage is exactly the same at 18.3 mpg. I do expect it to go down a little. I’ll keep an eye on it.
    So far I’ve been running at 42 PSI and it feels smooth - that’s what my installer recommended. I’ll probably play around with it a little bit but stay in that 40-45 PSI range.
    I'll end with a quick anecdote. Went to Costco to fill her up and there's a pretty gnarly speed bump to get over to the gas pumps. With the truck stock I had to slow down quite a bit but yesterday I blasted right over that thing without touching the brake. That's as close to off-roading this pavement princess will ever see!
    ramnj, GoHuskers and MSPlatty like this.
  25. Mar 2, 2025 at 1:27 PM
    #5395
    SnowToy
    SnowToy New Member
    That looks good with the 20's.... and the AT3's are a great choice .... Love them on my wife's DD...they're the only tire of that size (35x13.5) we've ever had take under 2 oz . of weight to balance...
    Paul499 likes this.
  26. Mar 2, 2025 at 1:50 PM
    #5396
    Daedalus
    Daedalus New Member
    285/75 18” stock TRD off road wheels.
    No lift. Zero scrub or rubbing.
    this thread was incredibly informative when looking for tires.
    TheDo114 and BryMan83 like this.
  27. Mar 2, 2025 at 3:31 PM
    #5397
    typk33
    typk33 New Member
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
    2024 TRD 3 inch lift. 35X12.50X20 Venom Swampthang ATs. 20X9 Vortek Ti20250302_105653.jpg 20250302_175458.jpg 20250302_102625.jpg tans +18
  28. Mar 4, 2025 at 10:40 AM
    #5398
    Noobo Baggins
    Glenn
    I'd say you nailed it. Looks excellent.
    That's about as good as it gets with just a 2" leveling kit.
    Paul499[QUOTED] likes this.
  29. Mar 4, 2025 at 1:16 PM
    #5399
    RickyPNW
    RickyPNW New Member
    '23 TRD 1794, FWC Raven
    Anyone running 17x8 wheels? When I search, I only get hits for 17x8.5, which seems to be pretty common.
    I have a set of 17x8.5 with -10 offset, and I'm starting to second-guess having such a negative offset. I don't mind poke, but et-10 seems like it will be excessive. I have a set of 17x8 et20 around, but it's a narrower wheel, not by much relatively.
  30. Mar 4, 2025 at 5:57 PM
    #5400
    96706Tundra
    96706Tundra New Member
    HI
    2024 Tundra SR5 TRD OR
    18x8.5 +20mm Trailhunter wheels
    Falken WildpeakAT4w 285/70r18
    RC level
    ytank1, kirkb, Paul499 and 2 others like this.
