GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Nov 4, 2024 at 1:08 PM
    #5221
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    These all look great. I'm getting a 2" front, 1" rear suspension lift installed next week. I have pro flairs. What wheels do you suggest to make sure I'm not getting much of a poke when I eventually add 35" tires?
  2. Nov 4, 2024 at 1:38 PM
    #5222
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    Stick out our 17x8.5 +20mm spec if you're after a conservative poke. We just released this new spec a couple of weeks ago for the Tacoma, but it will work well on the 3rd gen Tundra as well.
  3. Nov 5, 2024 at 1:29 PM
    #5223
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    LT295/60R20 K03s, TRD lift, 1" spacers. Will need to pin back liners, just a slight rub at certain angles and full lock.
  4. Nov 5, 2024 at 1:54 PM
    #5224
    slcsez2000
    slcsez2000 New Member
    added rough country sport flares to my + 12mm offset and pretty much takes all the poke
    plus look Sweeeeet
  5. Nov 5, 2024 at 1:55 PM
    #5225
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Nice rig. Those are sweet tires. How do they ride? Can you comment on their wet traction yet? Are they noisy?
  6. Nov 5, 2024 at 3:08 PM
    #5226
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    I was pleasantly surprised with these after install. I had 295/55 Toyos before that were standard ply, but going up to 60 series I had to go 10 ply. They are just as smooth and quiet as the Toyos, if not more so. Biggest difference is weight, which you can feel in acceleration and braking, but for the look it's well worth it IMO.
    As far as wet traction and snow eventually, haven't had the opportunity to test yet, but I have great confidence they'll be just fine.
    drewpweinerMD[QUOTED] likes this.
  7. Nov 8, 2024 at 9:27 AM
    #5227
    B22024
    B22024 New Member
    2024 Tundra TRD
    Do they sell red caliper covers for the 2024 Tundra TRD?
  8. Nov 9, 2024 at 12:14 PM
    #5228
    4x Taco Owner
    4x Taco Owner New Member
    North Idaho
    2025 limited offroad
    I just picked up a 2025 Limited off road with the 3" factory lift. Im thinking i want to get 285/60/20s put on the factory rims. Anybody have that set up and if so any rubbing? I dont want to have to do any trimming 20241109_110737.jpg
    BlackNBlu and ramnj like this.
  9. Nov 9, 2024 at 5:00 PM
    #5229
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    285/60/20 will fit on a stock height truck.
  10. Nov 9, 2024 at 5:11 PM
    #5230
    4x Taco Owner
    North Idaho
    Thanks
  11. Nov 9, 2024 at 5:16 PM
    #5231
    Northern Toyota
    Tires and bilstein
    I’d go bigger though. I went 295/70/18 on a 1” levelling kit, they also fit stock height.
  12. Nov 9, 2024 at 5:26 PM
    #5232
    4x Taco Owner
    North Idaho
    And you dont have any rubbing?
  13. Nov 9, 2024 at 8:10 PM
    #5233
    Incupunk
    Incupunk New Member
    Joshua
    2023 Army Green 1794
    TRD Pro Grill, TRD Pro Fender Flares, Bakflip M4 Tonneau, Custom 1794 Radio Volume Knob, 360 Degree Ceramic Tint
    I'm going to go 35x12.50r20 on my stock 1794 wheels in a week or two and I'll let you know. I'm putting on the Wescott Lift which is 3" front 1" rear. I think if I kept it stock I'd have to cut down to 35x11.5 tire which I've "heard" won't rub the UCAs.
  14. Nov 10, 2024 at 1:32 AM
    #5234
    Northern Toyota
    Tires and bilstein
    No rubbing
  15. Nov 15, 2024 at 5:58 PM
    #5235
    MtTundra24
    MtTundra24 New Member
    Nathan
    2024 black tundra trd
    Been lurking on here for a few months now, finally pulled the trigger.
    @SCSPerformance ray 10 17x8.5 +20
    BFG KO3 285/70r17
  16. Nov 15, 2024 at 6:11 PM
    #5236
    Narco
    Narco New Member
    23 Hybrid Limited Off-road
    I spy a sweet looking LC, but also nice tundra. Big fan of SCS wheels - had them on two different 4Runners and they're were great.
  17. Nov 18, 2024 at 8:03 PM
    #5237
    ABlackBird
    ABlackBird New Member
    2024 Tundra Limited TRD
    Any issues with the tire hitting the wheel well when bottoming out with the level kit? Ive seen that size will fit without rubbing but wonder if there are any issue while off roading
  18. Nov 18, 2024 at 9:20 PM
    #5238
    Rykr
    Rykr New Member
    2023 SR5 TRD Sport 4x4 MGM
    rough country does. Like $200
    B22024[QUOTED] likes this.
  19. Nov 20, 2024 at 3:06 AM
    #5239
    Northern Toyota
    Tires and bilstein
    I’m not a rock crawler but haven’t had any rubbing in over a year in my driving. The rear tires are close to the plastic wheel liners but never rubbed. A razor blade could fix that easily if it did
    ABlackBird[QUOTED] likes this.
  20. Nov 20, 2024 at 2:38 PM
    #5240
    710
    710 New Member
    CDA Idaho
    2024 Tundra Platinum with AVS
    275/65r20 Toyo AT3 stock Platinum with AVS. Fit great. No rubbing.
    I Have the Westcott kit I can install but now I wonder if it will look like the tires are too small.
  21. Nov 22, 2024 at 10:35 AM
    #5241
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Just had 285/60r20 BFG KO3 tires installed on my stock 2025 limited with zero fitment issues. No rub on control arms or through full range of steering.
    MtnCrewmax, Oakman, BlackNBlu and 2 others like this.
  22. Nov 22, 2024 at 11:03 AM
    #5242
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    IMG_4885.jpgTrd lift, stock wheels no spacers, 295/70r18 toyo at3.
  23. Nov 23, 2024 at 5:24 AM
    #5243
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Need some help, I dont know the stock wheel (23 limited 20x8) offset but looking at some method 316’s 20x9 with a +18 offset it 0 offset, I prefer the stock look and not looking for a lot of poke. What am I looking at here, I’ve seen a lot of different numbers and cant make sense of it. This truck might drive down a bunch of dirt roads but it’s purely a daily driver and dirt bike hauler. Running Pathfinder (discount tire) AT 275/65/20’s. Picture of truck as is now.
    Thanks
  24. Nov 23, 2024 at 7:41 AM
    #5244
    710
    710 New Member
    CDA Idaho
    I believe your wheels stock offset is +60mm. I really like the look people are getting in the +25 to +18 range.
    Not too much poke but looks aggressive.
    obgod3[QUOTED] likes this.
  25. Nov 23, 2024 at 12:19 PM
    #5245
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    How are you liking these? Stiffer ride due to E load/weight, MPG hit, and any more pics?
    I'm debating the Toyo's between 295/70R18 or 35x12.5R18. 35's are 3 lbs heavier but are D load instead of E.
  26. Nov 23, 2024 at 2:27 PM
    #5246
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    I like them, I have a set of ATIII 37’s on icon wheels for the summer.
    I have a 295/70r18 spare that fits perfectly.
    certainly a bit louder and stiffer than stock tires but I have zero regrets.
    Hoody[QUOTED] likes this.
  27. Nov 24, 2024 at 6:24 PM
    #5247
    shorenetworks
    shorenetworks New Member
    East coast California DBA New Jersey
    2023 Tundra self destruct edition
    Bought and going on the truck this week!!
    Land Cruiser 1st edition on a TRD army green
    Oakman and drewpweinerMD like this.
  28. Nov 25, 2024 at 2:17 AM
    #5248
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    18x8?
  29. Nov 25, 2024 at 3:03 AM
    #5249
    ToroR9
    ToroR9 New Member
    2024 Limited Black
    Hi guys! After days of research in this forum, I decided to go with RC M1 Struts, and the Nittos Recon Grapplers 315/60/20 on the OEM wheels. The ride feels like stock, but I have a little bit of rubbing in full turn. I'm considering putting wheel spacers, but with minimal poke. Any suggestions?
    DoubleCab likes this.
  30. Nov 25, 2024 at 3:09 AM
    #5250
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Looks great! Where are you rubbing?
